View Full Version : Sportster Models
- Pulled the tricker on 72
- Wanting to put Tbars on my 2010 Iron 883? help? tip?
- Leaning towards ape hangers.. installation questions
- Good Lord these older Sportys must be easy to steal! Replace lock switch?
- FWD controls - Harley brand or GTFO?
- Tank Lift/ Wire Tuck/ Coil and Ignition Relocate--Done
- 09 Sportster 1200 Spark Issue
- What should i do?
- Nightster travel bag
- Power inverter?
- Height
- LED headlight on My Nightster
- OEM #26554-77B for my sportster, what & were?
- Speedo problems
- Looking for a Nightster
- Fuel Line Question
- Another Bolt Size Question Need Help.
- My 48 so far..
- Oil drain hose.
- older sportster question
- 2012 Iron V&H exhaust problem
- Straight Handlebars for Iron 883 Pictures
- Finally got a bike!
- New to the Forum...
- Front tire not centered under fender
- headlight issue on 94 Sporty
- What type of AC is this? - Can insert be added?
- Fender bibs: functional or purely cosmetic?
- those that have put hardtail struts on ur sporties
- Headlamp Visor Kit Item #68129-98DH or 68129-97 Can it fit on 48?
- Gas Tank Question, Please Help
- Widest back tire without mods?
- NEED HELP... 21" Wheel on fornt. What size rotor?
- Handlebars
- overflow into primary?
- Plug Wire Help
- Spring Solo Seat for Iron883
- Rusted/weathered screws
- Added LED Strip to rear fender
- Where can I buy the Z-Bars I might try???
- Just A Few Minutes Today
- Some NEW shot's of the mistress...
- Mustang Vintage solo or vintage wide solo
- Sporster Owners with the HD LED Fuel Gauge
- Did Some Painting
- New Seat
- What kit for hardtailing an 09 nightster????
- 883 Carb wont tune!!
- Looking for a circle 48 decal
- 48 brake upgrade options
- S&S shorty on a 2006 sportster
- OK, I can't find the answer!
- RETRO design concepts for your Sportster !
- late straightshots for 2003 sporty?
- Risers help
- "smart" security system
- HD Turn Signal Mirrors
- 8" Z Bars and Cables replacement on 48 questions
- 2007 Nightster
- RSD gauge relocator...
- id on a sportster
- Forcewinder intake
- frozen face
- Progress shots on my chopper
- Yet another tire width question?
- School a noob in sportster options
- Short shots and arlen ness super sucker... can i use these?
- Does swingarm bag work with passenger pegs?
- Stage 1 before engine break-in?
- Air cleaner and exhaust
- Painting bike, WHAT COLOR?
- rear tires
- Got The Dogs
- Finally Finished the Paint Job!!
- Plug Wires - What Size
- Quick Detach windshield mount options?
- Sportster Fabrication
- 48 2012
- 2012 883
- Emulsion tube
- Sporty Oil Leak
- XR fork questions
- Cam trouble
- XL1200V seventy-two air cleane on 48
- Saddle question
- Looking for cheap stash tube.
- Got my new pipes on!!!
- V&H Twin Slash 3" Black with SE Heat Shields for head pipes...
- 14" Road 6 Customs apes..(PICS)!!!!!!!!
- 16" Apes with Burly 12" Cable Kit
- Fork tube Blinker relocation
- saddlebags
- Who needs a shrink when you have a motorcycle!
- Winter Modifications (with pics)
- Raw or Matte Black, please help me decide?!
- 2001 1200 XLC Fuse Keeps Blowing
- Forty-Eight pillion Seat & Licks NovaDot Helmet.
- Drag specialties retro bob a/c and crankshaft breather instructions?
- Key hard to remove.
- My Clean 1200C with new seat and bag
- 92 xlh tank upgrade
- Stock Shock Adjustment
- Rhinehart vs V&H
- Wheel spacing questions
- Rebuild
- larger gas tank
- Fuel cap won't remove
- Rear-end
- Can't decide apes or low z bars?
- XR LH Front Brake Caliper swap on 48
- Please post a pic of your '04+ Sporty with a Mustang seat & driver backrest
- Wheel swap question????
- Passenger pad pillion with suction cups?
- 1993 Sportster 883 won't start...
- Question about HD stage 1 air cleaner/recalibration
- My Nightster (Almost) Finished
- Dakota Digital on 2011 Iron XL883n
- Heavy breather question....help
- altitude jetting ?
- Detachable windshield problems
- Question for the experts
- ECU Flash with 1200 kit?
- P-Pad
- Mustang/Corbin seat fitment question vs. stock
- Seat mods?
- XL883c Stage 1 Screaming Eagle Breather
- Allen Ness big shot tuner
- Turning over Engine by hand?
- Rehab Iron
- Members in SE Pennsylvania and N Wilmington, DE area
- Quick detach sissy bar
- 05 883 Sportster
- Joker Machine handlebar clamp
- Highway Pegs
- Install: Vance and Hines Short Shots
- Luggage Rack For Sporty
- 2009 iron 883
- Which exhaust for my Nightster
- Vance & Hines Comp Series 2-into-1
- Apes on your Iron
- sportster 72?s Thoughts
- K&N Filter question
- What is the stock rear shock length for an 03 883 custom?
- WTF!?! Idle Question
- Has anyone ?
- Which Bars, Friscos? Zeds? Or?
- B16 or H16 tyre?
- tank options (efi)
- cv carb float pin stuck..
- PHOTOS of my 09' Iron finally....
- 100% cure for rear cylinder overheating
- Fuel/oil issue
- Would these pipes work on the Iron?
- My 48, current state.
- Lepera Barebones on a 48
- Front suspension question, advice wanted
- Strange FYI for LED Bulb
- 883 big bore?
- Licks bars issue
- Where is the reset button?/
- Found this on CL. Very interesting.
- sporty shocks
- Dimpled and stepped bars
- Nightster seats?
- Charging a dead battery
- 8" mini apes?? Can't find pics
- My first Harley
- A little help / speedo
- Speedo relocation to forks
- Which risers should I get
- Adjustable Highway Peg Support Kit
- Sportster vibration
- Cams,Heads,Piston for Nightster Questions
- Show me your Sportster Pics!!
- Sissy bar or luggage rack for solo 48
- What can you add to lighting without overloading electrical?
- Coil relocation and wire tuck on my 48 no tank lift
- What to do????
- Any Sporster riders in the Hollywood California area?
- passenger comfort upgrade opinions
- Iron 2009 Seat challenge
- Floor chock
- Watch Bennedict Campbell's "72"
- Ahhh...
- Phase 1 of my Air Force 48 complete.......for now
- Headphones ??
- drilled bars
- Front turn signal relocation question...
- Fig. Mach. Pegs?
- Done with the mods
- Sportster Low Seat
- weird glitch in my NEW forty eight. misfiring?
- Exhaust smell
- Being Seen
- Cheapest place for short shots?
- late in the season, but....
- Hi from Garland TX
- 2012 xl1200v
- 1966 Sportster tire choices?
- Sissy bar pictures with info?
- Noob post: Sporty Seats
- Harley rear sets?
- A few mods...what do you think?
- Cobra fi2000 differences?
- Painting Help...
- Hate my riser!
- 02 Sporty 883?
- keeping seat dry
- tire question
- Took the sportster to Garden of the Gods in Colorado Springs
- Advice needed on a new battery
- Power Commander V questions
- 48 rocker covers removal tips
- Longer kickstands?
- Cafe build - Suspension question
- smoothest shocks?
- Anyone have pics of a skid lid on?
- Biltwell Frisco's, or Drag Bars
- My Arms are too damn short
- Made a decision on my rear suspension!
- New 48
- Stage 1 Upgrade and New solo Saddlebag Pics added
- drag bar and front brake reservoir problem
- NRHS Experience
- I need a cooler Air Cleaner cover.
- 2009 XLC 1200 Sporty spark/ignition problem
- cafe nightster
- 10inch struts VS 10inch shocks ::folks please steer me in the right direction::
- Dan's Wanna-be Bobber Build
- rattle can projects!!!
- battery dead twicein 2 months? HELP!
- Kuryakyn 9252
- Stage 1 worth it?
- Shift "clunk"
- Battery?
- Buying from a dealer vs craigslist
- My new ride - 91 HD Sportster xlh 1200
- 76 Starter question
- Sportster Trailer hitch
- Lowbrow Dirtster Build
- I got them!!
- Wheel bearings ????
- 99 stock forwards fit?
- New, to me, 06 883 with dead speedo
- Riveting 101
- 29.5" drag bar w/ stock risers, ss brake line length?
- Cobra PowrPro Fi2000 Cold Start Issue - FYI
- Any Ideas for My Girlfriend's Sporty? Pics and Suggestions.
