View Full Version : Sportster Models
- My New 2015 Iron 883, and helps with Tracker concept ?
- schematic for transmission spacing tool
- Turn Signals/Blinkers issue
- Ghost Rider!
- Rear turn signal to brake light bulb question
- 1200 Roadster
- riding lights too high to put windshield on
- Sportster oil dipstick
- miles per fill up
- Screamin' Eagle slip-ons don't slip on easy
- FP3 - Iddle setup
- 2016 Dyna tank on 2015 Sportster
- rebuilding her sportster and
- Pls post Pics of 3.8 gln tank on a 48
- Lock tight
- Preping for a paint shop
- fat guy on a little bike (48)
- FortyEight speedo 2014
- Brought Home 2016 Forty-Eight
- XL seventy two 1200V
- Best mounted saddle bad for Sportster
- Ignition switch?
- 2009 Nighster upgrade
- Setting up the idle.
- Clutch and other problems.
- Where can I get a larger tank for my Sporty!
- Price of part 69200080 .Harness with Led Indicator
- W158 TTIs into V&H short shots, am I missing something obvious here?
- Chrome plating
- She is home now
- black Iron with wrapped exhaust pic request
- Do Sportsters sound different?
- 05 sporty 1200 custom
- 2009 Sportster Custom: highest bars?
- 1980 sportster 1000
- speedometer/clock question
- XR 1200 nisson calipers 4 piston
- Ticking getting louder
- Outlaw High performance oil filter
- Lights on the sppedo panel are out
- Anyone have an alarm?
- Solo seat options
- 2-up conversion complete
- Installation Steps for 10" Z Bars on a Nightster
- Transmission fluid change on a 2013 1200 72
- i need some handlebar sizing advice
- 2 error codes , Iron 2014 .
- 92 Sportster Timing
- wiring loom
- Do DK Custom foot extensions
- i really hate to do this.... LEDS
- Any Known Issues with 2007 883XL Low?
- "Custom" Seat or Custom Maker?
- Seat?
- Sportster Sickness
- 2015 1200C Here is the bike.
- Clutch cable outside fork?
- Tidy Alternate Turn Signal Reloc.
- Battery tender/optimiser
- Forty Eight Fender Chop
- out of ideas
- Setup when riding hard?
- biltwell riser install advice, won't thread
- 2003 Sportster gearbox removal
- Harley 48, 2015 or 2016?
- A Little Too Loud
- 48 speedo relocation help.
- Need a Speedometer for a 1995 XL 1200
- 2 up 2007 oem 1 piece passenger seat
- 2016 HD Iron vs Bonneville SE
- 48 Tank Cover - Interesting Designs
- "Limp" Front Brake Lever
- wider tire
- fuel milage after tuning with a power vision
- Battery Cover Paint Chipping
- Riserless apes
- Sprayed my quarter fairing! Pictures.
- '05 883 so far
- The wife's new Iron 883
- Anyone running Biltwell Keysones?
- Rear turn signals on a bobber
- Sportster Coil Question
- Tranny question
- Key leash
- Fork oil suggestions
- Bike won't upshift
- Need help with a diagnosis.
- Ugh, what is behind that right side lower engine cover?
- Is it the battery already?
- suspension clearance
- bag options for the sportster.
- 2009 sportster engine swap question
- Hot Street XL 10.30 ET swing arm ride
- 10.33 et xl hammer 1250
- Gas Tank Swap
- sporster 48 front end
- Sporty front wheel differences
- Jimmy's Forty-Eight
- Biltwell Chumps installation advice
- New Le Pera on the '48
- crappy ride
- Tank lift, coil and ignition reposition
- Anyone installed fairings on their Sporty? - Please post pic
- Necessary Electronics
- My "stage one" 2015 48
- Powder coating rocker covers
- Sportster quarter fairing
- Exhaust from 2009 Iron 883 fit
- Lost washer???
- Does this bolt hold oil?
- Velocity Stack on 48
- 2016 Iron 883 Sportster Test Ride and Review
- Tips on riding with ape hangers?
- Bit by the Harley bug!
- Will a left side petcock work?
- Putting a 2005 rubber mounted engine on a kraft tech solid mount frame?
- Rear wheel removal or not as the case may be?
- Need help replacing oil vent line 1200XLC
- Where I started and where I am at now
- Chopped fender brake light wiring
- Bike Won't Start
- 2004 Sportster 1200 Roadster primary leak
- Speedometer Help
- TSM issues on 06 sportster
- Trying to lower my sporty
- Do you ever get used to the noise??
- Sportster front wheel questions
- My 2015 48 stage one review
- Does this look normal??
- waving to 3 wheelers?
- Black or Chrome Apes on a Nightster?
- Bassani Radial Sweepers Review
- Roadsters
- Easy cheat (trick) to installing a solo seat
- 1200 Iron vs 48?
- 04- up Ignition timing
- Extending Forks - Anything To Watch Out For?
- Thread size in replacement clucth perch?
- Winter Project
- Engine Removal 98 883
- Final pics of my 1989 Sportster build
- A tweak to the inverted-mirror mod!
- My 2015 iron 883
- Pipe Identification
- Why do Sportys vibrate?
- 2016 48 with 49mm forks, anyone have one yet?
- Upstate NY - Beautiful Riding Weather
- Recommended Tuner? - 2008 Nightster
- 2007 Sportster 883 vs 1200cc...how can you tell?
- small sissy bar bag for 48 (Forty Eight)
- Exhaust Questions/Help
- Sportster Mid Shift Kit - question.
- O2 Sensor Extensions, Got The LAF Pipes Back ON
- Whitewalls on the nighty
- Belt Drive Question
- 2007 Sportster 883 for $4700???
- No rear brake pressure
- Removing rear turn signals?
- Forty Eight Fender/Strut Chop
- Hypercharger question
- Swapped debry cover now clutch is abit loose
- 1250 vs 1250 drag race
- Can I pick your brains please
- What Primary oil for 09 Sportster
- finally, a smooth biltwell sporty 8 seat
- New menmber from Manor Texas
- Need opinions on shock length
- Cruise control (throttle lock) options
- New seat and sissy bar on my 72!!
- Nightster tins fit 48
- 97 sportster won't crank
- Please read my spark plugs. Pictures.
- HELP! Need nut size for roadside replacement.
- power vision tuner
- The different styles of riders: which one are you?
- Adjusting Race Tech Emulators so they work?
- Winter Battery Care
- Are these exhaust gaskets ok?
- Sportsters Are Girls' Bikes
- New (to me) Nightster
- White walls on my 1200 Custom... Would You?
- Low fuel light always on
- Brushed chrome
- Will this 16x5 rim fit my 07 1200C?
- First things to do when getting a new sportster
- 2007 trigger levers?
- Frozen Breather Screw (bolt)
- Gasket oversight!
- Should I replace exhaust gaskets? And which type?
- Help / Opinions
- Fairing or Windshield
- SuperLow advice
- Possible O2 Sensor Issue?
- 85 ironhead issues
- 2006 sportster weak spark
- Oil splotches??
- Sportster 883 advice please!!
- Iron 883 vs 1200 Custom
- Ironhead electrical question
- Shifter to Nowhere
- Oil Level Confusion
- Drive Belt Pully Cover Clearance Question
- Top clamp / speedo gurus
- DKCustom's 2" forward control extensions
- wind gusts to 25mph
- 1400 Conversion
- Fork Skins
- Battery bolt tightness issues.solutions?
- Indicator lights
- Anyone with Ebay sissy bar???
- Questions about exhaust
- Messy wiring With handle bar swap
- Rebuilding Front Forks on XL1200C
- Guaranteed to make someone laugh...
- Installed my short shots today
- 2001 883 Sportster Losing Power
- Remove passenger pegs? Ideas??
- Speedo relocation help...
- License Plate
- Dr Jekyll and Mr Hyde : My 2004 Sportster 883 Custom
- Anybody wanna weld me up an aluminum tank? $$$$$
- Getting rid of riser
- Will 48 forward controls fit 2000 883
- Broken noise reduction kit/quiet baffle, will it cause probs?
- How to choose the right Sportster?
- To wrap or not to wrap
- Passenger peg relo
- Need to quiet down my new Bassani slip-ons
- Biltwell High Drags
- Are ICMs mated to bike?
- Pitted rim - advice please.
- Handle bar risers
- Saddlebag Support Bracket Bolts
- New Sportster In The Garage!
- Rear Axle Adjuster
- Fuel Tank
- Where do you guys mount your cameras on your Sporty?
- 81 XLS Roadster
- Xl 1200c 2001
- Cut and grind the speedo housing / top clamp?
- Superlow 1200T?
- Stock Iron Headlights!
- Bike's Not Running Right - Cobra Fi2000 PowrPro
- Factory alarms
- Sold my Sporty
- 2006 883 overheating recall??
- Lightening the clutch pull?
- My New Iron!
- Video, is this normal idle? for a warm bike?
- Couple of minor issues with new bike...
