PDA
View Full Version : Ignition/Tuner/ECM/Fuel Injection
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 [53] 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90
  1. Wiring diagram for 91 flhtcu
  2. Power Commander or SE Race Tuner
  3. 95 wide glide starter dead
  4. help** tbw ape bar question
  5. Do EFI engines have O2 sensors?
  6. Is HD Stage 1 download, generic?
  7. Fuel Pak Settings with RSD Velocity Stack ?
  8. Start switch won't work
  9. Hidden Ignition switch
  10. Have SERT, thinking PC-V now
  11. PCIII Closed Throttle Values
  12. 00 fxst cuts out
  13. FuelPak & Samson True Duals synch issues
  14. Tuning help please 2010 FLHR
  15. PCIII map for SE204 cams
  16. Stage 1 Air Cleaner Kit
  17. 6 volt battery needed
  18. Maintenance 101 Question - use for impact wrench?
  19. electrical issue
  20. Exhaust Still Popping After A Dyno
  21. loose light bulbs
  22. SEST cranking fuel
  23. Magnelli Injection hard start
  24. Another...Mystery Engine Shut Down
  25. What brand Stator do you guys recommend for`94 Fatboy?
  26. Now Whats Wrong?
  27. Mystery Engine Shut Down
  28. power commander with autotune?
  29. Swapping headlights on an 09 Fat Bob
  30. Is the TTS server down?
  31. Running Lights
  32. TTS mastertune question
  33. Turn signal issues
  34. Turn signals flash when ignition is turned on
  35. Cough & Backfire
  36. Waterproofing Electrical Wiring
  37. popping and skipping
  38. map help
  39. power comander V
  40. quick question about XIEDs
  41. Request: Edited Thundermax Map - 07 dyna - rineheart 2 into 1
  42. Voltage Regulator gone bad??
  43. 08' Ultra with electrical problems
  44. 1988 softtail loosing front spark
  45. almost taken out
  46. tach for 08 heritage
  47. No start, No turnover, No nuthin
  48. No Turn Signals
  49. 1991 electronic flasher problem
  50. Looking for Fuel Injectors Wiring Diagram for 2003 Roadking
  51. speedo,tach.turn signals,brake lights don't work
  52. Question about tach signal from ECU
  53. Electronic throttle cuts out
  54. Simple wiring diagram
  55. power commander 5
  56. TTS tuner file needed
  57. Help
  58. 89 sportster 1200 blinker/running light issue
  59. Rear-End Variance on Softail Models
  60. Sportster Electrical Starting Issue
  61. ignition switch replacement
  62. code retrieval procedure
  63. Installed apes now now low beam
  64. PC-V Map = Hooker troublemakers, Se stage I
  65. Searching photos of 2010 O2 sensor plugs
  66. Ignition coil/module twin cam FI
  67. Headlamp/Passing Lamps go out intermittently
  68. Bulb cross reference
  69. 2000 FLHRI cannot start, no engine light????
  70. Need some Help
  71. My plugs after the Fuel Pak
  72. how to tell if 07 Roadking has factory alarm
  73. 08 rocker fuelpak settings
  74. SE 103 ci Kit & SEST - can I get by without Dyno tuning?
  75. Removing Gas Tank 2009 ultra
  76. installing factory heated grips 2009 ultra
  77. Electrical Problem
  78. Windows Vista 64 bit & Tuner Software Problem
  79. Slow starting after installing the PCV
  80. Latus H-D for Dyno tuning - your feedback?
  81. Switching superglide ignition and speedometer
  82. Pc #812-511...
  83. Can't find the breaker!
  84. SERT, SEST, TTS, PC-III, PC-V, etc. what's the scoop
  85. Anyone with an Autotune system...
  86. Motor Dies when cruising
  87. rotor on charge system shears bolts
  88. 1999 and 2004 speedometer difference? Pls help.
  89. thundermax software and vista
  90. idle issue?!?
  91. PCV software/map question
  92. hestitate in bike
  93. Hey all took my front turn singals off, now check engine light on... HELP
  94. SF Bay Area ThunderMax tuner?
  95. How to hook up to accessory plug on '07 Dyna?
  96. Unplugged 02 Sensor
  97. Electrical Mystery
  98. Parking (running) light keeps blowing out
  99. Fuel Pak question
  100. PC V map/questions
  101. Bike bogs on Up shift/Rapid Acceleration...?
  102. SEST Tuning
  103. home tuning???
  104. Stage 1 or Heavy Breather?
  105. Taillight woes!
  106. NEED HELP GUYS. 09 Road Glide- Ignition switch was turned too far....
  107. Voltage regulators
  108. ECM Tuners
  109. HELP Wireing diagram for a 2009 fatboy
  110. Biketronics stereo
  111. cams
  112. SERT question
  113. error message showin
  114. Speed sensor for 6 speed evo trany
  115. ocassional cylinder quits firing
  116. I want to install LED blinkers without a load equlizer... Will a electronic flasher??
  117. Thundermax- installing modified map
  118. '08 Ultra, lost FOB/key, on the road, stuck!!!
  119. Electrical problem
  120. Bad Ignition Switch?
  121. Engine light??
  122. 2010 touring O2 sensor bypass
  123. 1996 harley dyna ignition problem
  124. EFI Fuel Pump Question....
  125. Ignition trouble while on the road.
  126. fuel gauge
  127. The problem with the rear turn signals
  128. 2009 street glide run hot ??
  129. 2007 Road Glide fowling plugs and lost spark on a trip now..
  130. Tuned Fuel Consumption ?'s
  131. Vance and Hines Fuel Pak Codes
  132. 04 Softail Electrical Gremlin?
  133. 07 bdeluxe running light conv. ....Brake Lights On all the time
  134. Magneti-Marelli Fuel Pressure Tweaking?
  135. 78 Low Rider cutting out at 70 mpg
  136. 2004 sportster won't start
  137. Radio Ground Issue? - Please Help!
  138. Base tune for the SERT
  139. handlebar controls with aftermarket radio on RG?
  140. Radio--Accessory problem
  141. Adding turn signals on a vintage Sportster
  142. '05 Carbed Fatboy 95" upgrade Twin Tec 88a timing settings
  143. T-max then what?
  144. 2010 touring exhaust
  145. Stock ECM
  146. ?? does anyone know how to remove the fuel pressure regulator
  147. trouble after build **long post**
  148. Lubricate Ignition Lock Cylinder With ???
  149. airfilter sneeze
  150. Bike died today....elecrtical??? 03 Softtail Standard
  151. Very weak starting
  152. HQ Auto tune connections
  153. Complete power loss
  154. 25K Service - EFI - Fuel Tank Filter Screen
  155. Won't start when hot
  156. Head Light out
  157. feels limited...
  158. PCIII Map for my 95/203 touring
  159. 2000 Deuce - Turn Signal Problems
  160. 07 Ultra Map Needed for PCIII
  161. SEST Map Question
  162. New PCIII/V & Cam Install question
  163. got a spitting problem
  164. Ignition Harness
  165. 2002 Fat Boy... Headlight Dimming
  166. 2005 Ultra Classic won't stat unless pushed.
  167. No Cruise/Turn signal canceling after Autometer 19466 Speedo/Tach combo instal
  168. Tuning Out Decel Pop
  169. High alitude and timing.
  170. Electrical Problems
  171. Anyone have the latest V-tune directions from Doc
  172. bike wont start after ride last night
  173. PCV on my Dyna, small problem
  174. SERT fitment question
  175. Good Scoop.... "New Fuel"
  176. EFI fuel problem
  177. Blue Spark Plug Wires for my 09 Road King
  178. Adjusting Decel Enleanment with the SEST
  179. Stage 1 Fuel Map Question
  180. Engine light coming on again
  181. signal fuse blows when activated
  182. 1995 Ultra with Low Voltage Problem
  183. 07 nightrain problem
  184. SEST software
  185. Super-Tuner vs. PC-V vs. Fuel Pak vs. Warranty?
  186. Wiring for factory spot switch ?
  187. Stock 96" with SE255 cam SERT map needed
  188. 03 Ultra Dies When Hot
  189. 03 Ultra Dies When Hot
  190. Decel Popping when Hot
  191. Need some Imput on Cycle Electric Regulators
  192. Cruise control issues
  193. Dash Removal for Softie
  194. My most recent experience with tuning
  195. Starter Kickback
  196. 2002 Sportster (1200) Fuse "Box"
  197. Questions about HD SuperSmart Battery Tender?
  198. won't start
  199. Starter Jackshaft - Need a advice
  200. runs after ignition off
  201. Heres a new story, MY Harley died while riding
  202. How do I connect power to GPS
  203. "rule of thumb" tuning
  204. Red Light On lEFT, But no Green Light on rIGHT Cruise Swith?
  205. error 280 with TTS master tune
  206. Possible Electrical problem ???? Need help
  207. bike has no spark
  208. FuelPak Settings ?
  209. change exhaust need re-tune?
  210. 74 sx125 Voltage Regulator
  211. charging issue
  212. 2002 Road King Classic - Ignition Problem?
  213. does anyone know anything about the American Micro-Fuel Device Fuel maxx
  214. Wiring Diagram for '37 UL
  215. Bleeding off fuel pressure?
  216. left turn flashes fast.
  217. Mytune
  218. 1990 Fatboy starter problem
  219. Fatboy just died?
  220. Ignition module test
  221. Question concerning batteries
  222. 2004 FLHRSI EFI Tuning
  223. Coils
  224. PC3- what is firmware?
  225. Thoughts about the Fuelpak????
  226. 95 roadking charging system
  227. Iron 1200 question
  228. Bad speed sensor....AGAIN!!!
  229. What Tuner or Fueler do you use???
  230. Comparing SERT to SEST w/smart tuner
  231. Loose fuel injector plugs
  232. Alarm Security Siren
  233. Stator, Rotor
  234. Map for FLSTSE2 ???
  235. 2009 sportster iron blowing fuses
  236. Question about Warmup Enrichment Table
  237. Ground wire was loose.
  238. Fat bob deccel pop
  239. 8 year old electrical problem solved
  240. Somebody please help!
  241. Carbureted Fat Boy Engine Light comes on radomly
  242. 08 XL1200C electrical problem
  243. Vance and Hines Fuel pak or Power Commander V
  244. Stator Life Expectancy Question
  245. Resetting AFV
  246. 01 Road King poor idle
  247. sluggish deluxe
  248. Current version of SEST software
  249. EITMS and SERT question...
  250. dies when clutch released
