PDA
View Full Version : Ignition/Tuner/ECM/Fuel Injection
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 [30] 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90
  1. 2010 FLHR PCV Big Sucker Big Radius Heres Map!
  2. pc5 & autotune
  3. Tmax tuner - idle setting
  4. Second Stator replaced
  5. Cobra Powerpro tuner
  6. 94 heritage softtail
  7. Fuel problem
  8. Powervision 2 Gauges
  9. Fault code meanings and bike not running right
  10. 2007 Ultra Classic tach not working
  11. SE Pro Super Tuner...how many PC's?
  12. 2013 Softail Lighting colors
  13. trouble starting (compu fire elite 1)
  14. Strange Problem With Blinkers
  15. 2001 883 sportster
  16. 2007 Road King Classic Speedometer Problem
  17. Need Wiring Help 2013 Street Glide
  18. Removing stuck Timer Plate Stand-off Screws
  19. 2007 Sportster 883 diagnostic
  20. Tach problem on my '06 FLHTPI
  21. Intermitant Charging - Stator?
  22. Trouble Code : Pn 141nU002-8
  23. Mastertune
  24. Fat Bob Fuel issue
  25. This getting old
  26. Battery draining
  27. brake lights inop/hissing in rear speakers/no cruise
  28. another Headlight issue
  29. A rythmical short ?
  30. Stage 1 question
  31. Wiring to pull a trailer with a 1990 Softail Heritage
  32. New Member...need help!!
  33. Headlight issue
  34. Rear spark plug is seized
  35. 2008 Road King Classic Charging Issues
  36. Charging system
  37. need a map
  38. cv carb issue
  39. Idle adjusting tool part number
  40. SERT question
  41. 99 ignition advance?
  42. Need Map! PCV,2010FLHR,Big Sucker,K&N HiFlow,V&H Big Radius
  43. 2002 Road King EFI issues
  44. Maybe an ECM?
  45. Harley sportster starting problem
  46. Changing pipes on '12 fxdb. ViED, Fuelpak, or ?
  47. coil wires
  48. Need PC3 dynoed Map for 07 Ultra with Bassani true duals
  49. 1200 sportster/low speed chug?
  50. Lost Metal Key...still have the FOB
  51. Help me tune with TTS
  52. Power vision auto tune frustration
  53. 05 road king blinker issues
  54. Tuner Choices
  55. engine light trouble shooting help needed
  56. Fuel pressure help please
  57. Question after reading ECM tuning threads.
  58. Revtech 100 carb tuning?
  59. Shovelhead wiring mayhem please help!
  60. Adding O2 Sensors and Power Vision
  61. speedometer and tach gauges?
  62. No start
  63. 2005 HD 1200C - No Speedometer or odometer
  64. Kuryakyn TTS mastertune or powervision
  65. engine surge
  66. ECM question
  67. local tuning questions
  68. fuel pressure tester (inexpensive)
  69. Electrical mayhem
  70. ThunderMax question on why not to use handlebar OFF/RUN switch
  71. Pulled code, can't find description of code
  72. TC Starter rebuild or buy new?
  73. left pipe blowing cold
  74. 2002 Road King Classic... Battery drain/thundermax tuner problem?
  75. brake light
  76. 1995 sportster with changing turn signal problems?..
  77. PowerVison Autotune Question
  78. harness wiring
  79. SEPST Decel Enleanment Adjustments to Eliminate Decel Pop
  80. Head Light problem !!
  81. 2010 FLHTCU Throttle stopped working
  82. Power Vision software, what am I doing wrong
  83. Speed sensor wiring ?
  84. Can't see the connection here. Electrical help?
  85. My 98 Springer Softail
  86. Could it be the system relay?
  87. Brake light blowing fuses 2007 Street Glide need help
  88. ignition coil wiring HELP
  89. EFI to carb conversion with Thunder Heart ignition....
  90. What is that EFI unit that replaces the stock one?
  91. 4 amp parasitic battery drain
  92. Aftermarket fuses and bulbs
  93. 04 Electra sputtering when hot
  94. Heritage EFI suddenly won't idle
  95. Dead battery and ow dead security
  96. Testing Single Fire Coil -- Primary/Secondary?
  97. Fuse for cruise & Brake lights
  98. DJ Auto Tune Issue
  99. unhappy
  100. hiding the wires
  101. Bike barely starts and cuts off on its own
  102. @#$$#@ Check Engine light (long)
  103. Rear brake light out XL1200N
  104. Buell question
  105. intermittent starting problem
  106. Need Help.
  107. 2000 Road King Police FLHPI Horn
  108. Download or tuner?
  109. Accessory wire
  110. 76 xlch electrical problems
  111. Time to see mechanic with electrical problems?
  112. 2002 Sporty Speedo/Odo dead after new bars
  113. Yaffe tank install , now tripping ECM FUSE
  114. Very Low Idle When Clutching Toward a Stop
  115. Mysterious engine light.
  116. throttle body
  117. Mysterious engine light.
  118. all of a sudden- nothing
  119. Kat Eye Led Tail
  120. 1976 sportster electrical problemss
  121. Deadbeat Custom's Cloth Covered Spark Plug Wire Install
  122. Power commander v
  123. hate walking please help
  124. Why are Tuners Married to bike
  125. Is mapping necessary???????????
  126. 1998 roadking
  127. engine light
  128. Touring Driving Light LED Question
  129. TC88 EFI engine heat and fuel
  130. Rear brake light worked now it stays on?
  131. New Street Glide with a miss
  132. MM throttle body or Delfi which is better and why
  133. RPM's on my 88 EFI
  134. RKC accessory switch
  135. efi to carb
  136. 2000 twin cam fatboy 42/56 code
  137. 2012 Softail ECM Problems..HELP
  138. sportster not charging
  139. evo timing
  140. curious, for the wiz and wurk truck
  141. My $600 Broken ground.
  142. Daytona Twin Tec VT-i Electronic Ignition System
  143. Blinker and Tail light problem
  144. 1984 FLH Shovel
  145. MAP problem
  146. Wont start now
  147. Sportster 883 XL 2006 engine light on..
  148. FLHRC when hot sputters and power loss when attempting to drive
  149. Starter noise
  150. Cruise Control factory on police bike (TBW)
  151. And it begins...
  152. Cobra Fi2000r
  153. Tuning help
  154. Stage One
  155. Baffle, molex connector at TCA
  156. Right Turn Signal Issues
  157. Ignition Coil Wiring
  158. Power vision maps or lack of
  159. upgrades
  160. FM 107 w/ PV
  161. dyno tuner stumped!
  162. How to test cam sensor?
  163. Looking for some help on no spark!
  164. O2
  165. adjust EFI? Smelling gas in oil
  166. fuel pressure problem
  167. Dead front cylinder
  168. X14IED - no error codes
  169. Screamin’ Eagle ProSuper Tuner High Idle
  170. Battery OR Voltage Regulator
  171. 2008 FLHX cruise control intermittent
  172. Waitaminute. A dealer installed SEPST voids my warranty?
  173. Lowered street glide wiring
  174. Powervision PV2 help
  175. new build tune question
  176. Map comparison for TW777/58mm on 2009 FXDFSE
  177. O2 Sensors or ????
  178. FM 107" PV Maps
  179. Thundermax question.
  180. Is the SEPST Mac Compatible?
  181. Mystery Plug
  182. PC-V map issues
  183. Ultra Tourpak with Brake lights on RK
  184. multiple DTC's help
  185. se 32632-96 on a 91 883?
  186. SE street / SE pro....
  187. Pciii
  188. Help tuning with the SEPST and TW555 cams
  189. Red Key Icon light
  190. SEPT Question
  191. 10mm spark plug wire assembly
  192. Running lights
  193. How do I get a Tmax to 'autotune'?
  194. 07 Nighttrain cuts out after wash
  195. marelli ECU
  196. Need help with wiring
  197. triing to add r/t/b module
  198. 2013 ultra limited
  199. Trouble starting hot engine
  200. 103 Engine Mods - How Crazy Can You Get While Using 91 Octane
  201. PCV map suggestion needed...
  202. Getting High Idle
  203. PC-V/Auto_tune enlightenment from DHD
  204. Grinding noise in fuel tank-Anyone having same issue?
  205. Short or other electrical problem
  206. Click click click
  207. Map request please 06 dyna pcv
  208. Street Glide bad starter?
  209. Power to new lights/switch Touring
  210. engine cutting out under accel/load
  211. Bad voltage regulator on 1994 Fat Boy?
  212. Crank sensor issues
  213. Who & Where Do I Attach This Module
  214. What ignition upgrade?
  215. injector issue
  216. Race Tuner question
  217. Ultra intermittant problem
  218. Cobra Power Pro question
  219. Stumped......
  220. 1979 fxef want start other then kick
  221. Power Commander 5/Auto tune ?
  222. 2008 Road King Idle all over the place!
  223. 2006fuel injected Road King Police
  224. Starting issue
  225. I have no idea what's wrong.
  226. 1999 Dyna Wide Glide Code 42
  227. Hard start 1st thing in the morning
  228. Intermittent Shutdown
  229. 2008 Dyna fuel issue?
  230. Best Map for PCV on a 2012 Ultra
  231. O2 Malfunction
  232. Where is the O2 sensor connector on a Softail?
  233. 96 vs 103
  234. 03 FLHT Starting issues
  235. Charging system issue/Battery Light
  236. Help me set my flywheel mark on my S&S 124"
  237. TmaxI software
  238. TTS download for 2006 Vrod
  239. HELP! 2006 Softail FLSTI Cuts-out Electrical Gremlin
  240. Sticky Throttle
  241. ***which tuner to buy?***
  242. Brke light wont work
  243. accessory problem
  244. Spitting out Fuel
  245. My Headlamp Wires To H4 Socket Connector
  246. Why cant i see "reset adaptive fuel"
  247. 32109-08B vs. 32109-08C
  248. 2009 harley nightster with power commander v and not finding map
  249. HD Garage Door Opener
  250. Where to find the ECM ona 96' Road King?
