PDA
View Full Version : Ignition/Tuner/ECM/Fuel Injection
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 [45] 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90
  1. EFI Tuner Question
  2. battery charging connections
  3. 2006 Road Glide- No display
  4. TSM or TSSM?
  5. Tach Problem
  6. rev limit question on evo
  7. Stock Speedo Mileage Reinstatement
  8. 2008 SG starter problem
  9. forcing passing lamps on with high beams
  10. 2005 Sportster won't start after minor crash
  11. Bike won't start I need help
  12. Battery/Starter Problems
  13. SE race tuner
  14. What Have I got here?
  15. Power Commander II 0r III ??
  16. Starter pull
  17. Help deciphering DTC codes 2002 FLSTCI
  18. Dakota Digital Speedo/Tacho
  19. Installing apes,where do i cut electrical wires?
  20. 02 Dyna WG Ignition problem
  21. Lights dimming intermittently-regulator issue?
  22. Intermittent charging circuit issue
  23. How do I check my codes - 2002 FLSTCI
  24. spark question
  25. P.C. pc111
  26. Starter issues?
  27. Fuel Injection Question?
  28. 2003 FXDWG Auxiliary lights
  29. Cal Code (SEPST-SEST)? 2009 FLHT/SE 103" flat tops/54H cams/.030 hg
  30. no spark - 2011 SG
  31. 02 FLSTCI idles fine but sputters when you increase throttle
  32. SESPT connection issue
  33. mechanical to electronic speedometer conversion
  34. stage 1 without HD download
  35. Hot idle issue
  36. Late Model Ignition Question..
  37. No Brake Light at Lever
  38. Stage 1 Download
  39. White, Yellow, Black which goes where headlight?
  40. quiet baffles and tune
  41. why do i have carbon build-up
  42. SE Spun Aluminum Guages
  43. closed loop system?
  44. Bypassing the factory security system
  45. 2010 Street Glide running rich
  46. engine code P1358
  47. Need a tuner
  48. Multilock terminal removal
  49. TTS - Dyna in Overheat mode
  50. ignition for ultima 127
  51. Bad ground maybe
  52. Pingel Electric Shifter
  53. Ignition problem?
  54. idle speed a little high on freash rebuild
  55. Tail Light fuse
  56. Update...TTS VTune
  57. Turn Signal Problem
  58. Explosion at start up with Dynatech
  59. HELP 01 Flstf wont start electrical
  60. Need advice
  61. Does the 2010 HD Stage One download really only increase the redline?
  62. Tts
  63. sporty starting problems
  64. Painted inner fairing now electric issue....
  65. Sensor Plate
  66. Texas tuner ??
  67. Check Engine Light
  68. 2011 softtail help
  69. signal turns on when i press the brake
  70. 1990 softail ignition swith relocation
  71. Auto Tune Trims Question
  72. tach install
  73. First Harley owned and need some help please!
  74. Generic charger with Harley battery tender connector
  75. Looking for a good tuner...
  76. Fuel Moto Power Commander grease use..
  77. "ignition module" Help Needed!
  78. Battery out for Winter
  79. efi tuner
  80. Continuity Testing Question
  81. Starting help...!
  82. Tuner Question S.E.R.T. and Super Tuner
  83. PC III compatability
  84. Newbie needs help
  85. 2006 RKC ECM Removal
  86. Tach question
  87. Mastertune TTS Programming
  88. 2000 Road King ECM question
  89. Oil on spark plug threads?
  90. 2008 Street Glide ALARM problems
  91. Need some knowledgeable advice
  92. pro tuner software??
  93. advice needed. TTS or SERT
  94. fried SERT?
  95. 1999 roadking check engine light
  96. License Plate/Light Kit
  97. more than one power commander
  98. Hooker Headers/ SE AC PCIII Map??
  99. O2 sensors. Yes or no??
  100. Starter Question, Thanks
  101. What does code really mean?
  102. Tuner ID
  103. Available tuners??
  104. Air/Fuel ratio with Power Commander and XiEDs
  105. use O2 eliminators or leave them on
  106. Tour-Pak Brake Light Conversion Troubles
  107. Super Tuner base map calibrations
  108. Sert
  109. FuelPak
  110. 09 Ultra Andrews 48h cams tuned
  111. New exhaust
  112. Doc's Performance Tuning
  113. battery not charging
  114. Noise!!
  115. tapping into "instrument" fuse
  116. Indicators LED
  117. Do the Cables from SERT...
  118. When front brakes are applied NO brake light
  119. Replace Ignition Switch
  120. 2011 Crossbones EFI system (Is there one?)
  121. SE Pro Super Tuner
  122. Manual to auto advance timer
  123. Bike runs rough pings knocks hard to start when hot
  124. Un plug o2 sensor
  125. S&S Pro Tune/S&S VFI HELP!
  126. PC-V with LCD
  127. Light circuit burning out fuses ... WTF
  128. SESPT tuning suggestions
  129. ifixit manifesto- funny and true
  130. Fuel injector question
  131. Dynojet Power Vision, the Future of Tuning is here!
  132. Can I install SE slip ons without remapping and/or changing air filter?
  133. Cam Position Sensor specs
  134. ECM Relocation
  135. Troubleshooting for 2008 FLHX cruise control
  136. 2000 Roadking misfire in fuel injection
  137. Engine backfire and loss of power
  138. Loud pop on cold startup...
  139. anyone have experience with the daytona twin tec tuner??
  140. Intermittent Electrical surges
  141. Doc"s performance tuning does it right
  142. street glide radio problem
  143. no power to ignition
  144. replacing off/run start buttons
  145. ThunderMax MM EFI conversion kits
  146. Fuel Preasure
  147. How do I- open amp connectors
  148. Frustrated to the depth of my soul! Blinkers, Brake Light, and Horn!
  149. Charging System Diagnostics
  150. Brake lite
  151. Electra glo lighted hand grip end cap?
  152. wireless throttle
  153. Fuel leak
  154. Help wiring tail light
  155. Horsepower gain on 103ci after it is tuned
  156. Love the 32109-08A Screamin Eagle Pro Super Tuner
  157. VTHunder Harley Electronic Ignition Control VT12000A
  158. Stuffing a PCV & AT in a Dyna FXDF!?
  159. ICM - Replace / Reprogram
  160. street glide radio problem
  161. street glide radio problem
  162. Need TTS Base Map
  163. Idle Issues
  164. pro tuner
  165. SERT map files??
  166. stage 1 question
  167. Out of order turn signal
  168. TTS Warning - yellow cells?
  169. Thinking about XIEDS- objections?
  170. TTS Help!
  171. Help with screamin eagle 50mm throttle body retrofit to 04 deuce
  172. Tach and Speedo flickering
  173. Run turn stop module question
  174. 1997 1340 wide glide indicator too fast and will not stay on
  175. Ignition switch
  176. San Antonio, Tx. tuners?
  177. Magnetti marelli HPI
  178. Can someone explain to me . .
  179. '04 ultra engine dies when warms up
  180. Road king shuts down
  181. Alpha vs Beta
  182. HELP- RPM Spike/Rev up 08 FLHX. tbw on right turn
  183. Wanted Factory 2010 103" map (TTS)
  184. Help!!!!! Electrical issue
  185. StarBrite Startron
  186. Different Plug Colors
  187. Fuel Gauge
  188. Security module swap out
  189. Speedo/tach combo question
  190. Anybody tried this management system?
  191. 99 FXDX front turn signal wiring???
  192. 2010 Dyna - Samson/Big Sucker/TTS Questions
  193. New 95" build--Trouble codes Po107 & po373
  194. Battery running down
  195. Beware When Buying SE Tuner
  196. power commander v not connecting to pc
  197. Stock ECM Replacement 04 ultra
  198. testing the horn
  199. ’09 FLHTP PCV map
  200. 2003 fatboy security manual unlock
  201. Has anybody had any luck buying a base map for SERT?
  202. PC111 usb accel function question
  203. Help with Thundermax tuner
  204. Stay Away From Electrosport Products
  205. turn signal feedback
  206. Help me out... remove dual fire for compression release
  207. Security help for '05 Deuce
  208. 2003 Heritage Softail Classic idle issue
  209. 2000 UC no tach
  210. EFI adjustments?
  211. Arlen Ness CHEAP SHOT
  212. Need Help
  213. How Much $$$ for a good dyno tune
  214. Super Tuner and Stock Maps
  215. ThunderMax with AutoTune (TMAT) Users - data call
  216. turn the key nothing
  217. Settings for Daytona Twintec TC88 Ignition
  218. What type of Charger to use for storeage?
  219. What is a battery eliminator?
  220. PCV in 2009 vs. 2010
  221. fuses
  222. wiring help for Light duty momentary switch
  223. Fix U1016
  224. Ultima ignition problem
  225. Constant Check Engine Light>> any ideas..
  226. Speedo questions for the PRO's
  227. Bike S*** the bed
  228. Voltage/Battery/Starting issue
  229. How to get ECM Power to Match a Carb
  230. Touring Model Fuse Blck
  231. Radio Memory wire color in fairing?
  232. ECM info
  233. Would a '95 need a load equalizer with LED's?
  234. Starter pops and doesn't start
  235. Intake Air Temp sensor....where?
  236. Diesel in an EFI Heritage
  237. Diesel in an EFI Heritage
  238. Newby to Carbs vs. EFI
  239. TTS Tune for 2010/2011 Touring with Jackpot headpipes and JackPot Mufflers?
  240. PCV- do they hate it?
  241. Eliminating Oxygen sensore on 07 bagger
  242. stupid question: which gauge 20 or 16
  243. ECM Flash Error
  244. Need help! 99 Road King EFI
  245. Power Loss at Altitude
  246. O1 fxdwg personal code help
  247. Intermittant Not Starting when Hot
  248. 98 road king wont start
  249. right amber running light not working...
  250. No electrical power
