- Replacement rear signals-where to instal?
- No spark
- tssm code keeps reapearing
- Single throttle cable??
- Disarm Smart Security System
- No spark, plugs dry
- Kuryakyn run turn controller
- Fuel Pres Guage:
- Help with tach choice please
- Question on Slip on Change
- V&H Fuelpak setting
- I think it needs to be re-maped
- Anybody got this->PCIII USB LCD Display
- Dyno Results (bad) w/SERF on 07 Sportster
- Installing PCIII usb w/o Laptop
- Dazed and confused about SERT for '05 Ultra...
- "Race" Download Question
- HELP! Everything's dead (FXST), but power at starter
- Sert Question
- How much noise do Stage I breathers make?
- PC III Map for 06 FLHTCUI
- Updated CD for race tuner....where to buy?
- 07 Sert tuning
- Power Commander map
- Is there a need to change map
- harley RACE download on a 06 bob
- need PC 111 usb map for Stage1 Big Bore 95"
- Anyone heard of Cycle Solutions?
- Tachometer Connection?
- Thunderheader w/o intake?
- Tuning Reference
- Dropped the idle
- Spark Plug Interference
- harley race tuner
- another ThunderMax ECM install
- battery tender for 2 month old bike?
- electrical gremlin on 89 TourGlide......
- Bike not liking new map
- LED's and Load Equalizers, I am so...
- 95 UC speakers stopped working
- Torque smoothing download question...
- PCIII question
- What Map To Use for my Low Rider
- PC III Map For M/M Bike?
- Tail Light Wiring
- Can you hear me now?
- Still confused with EFI
- HD Run Brake Controller?
- Sert vs Stage one dealer download
- Were to blinkers connect to on 07 bob
- SERT Manual Online
- Installed the Thundermax ECM today!
- PCIII USB RPM and Throttle Position Question
- How to disassemble rear blinkers
- Headlight wiring???
- accessory wiring
- Jump start motorcycle from car???
- Error Codes
- What does cert and map refer too?
- USB to Serial Connector for SERT
- Terrys Terminal performence module
- Load Equilizer
- Problem: Turn Signals do not blink
- Total-Fuel DFO anyone use this or have info ?
- Throttle body fell off 03 Road King Classic
- How do I upgrade SERT?
- getting gas-getting spark-won't crank
- PCIII or DFO?
- Slip Ons
- PCIII...question
- 07 with Wide Band O2
- Bullet blinkers question
- Turn Signal Connector
- Tried to get my 8 degree injectors replaced
- pc111 buttons using
- engine restart after stall
- Isolator brought of Ebay
- Has anyone Indexed their Spark plugs?
- Please Explain The Security System To Me
- SERT Ownership?
- LED lights
- Advice on a Map for 2006 Deluxe
- 05 fatboy problem after installing bars
- IGNITION SWITCH ON, NO POWER TO START IT
- Help with PCIII
- 07 fxdl/ tach/ bus signal HELP
- One SERT, Two Bikes?
- SERT / PC III Fuel Mileage & Performance
- electrical problem or cold weather?
- Newbie - Exhaust Question...Help..!
- Rear Turn signal Lights Question
- SERT Question??
- vance & hines without baffles
- Need some racing fueler help! Please
- Grounding?
- SERT Map for '05 Ultra with D&D Fatcats???
- Fuel Mileage 07 Ultra
- What am I getting?
- PCIII Ignition Timing Adjustments
- power commander or sert and baffles?
- can't get SERT software to connect...COMport issue?
- ignition wiring?
- Remove Battery without setting OFF alarm
- SERT Help 04 Ultra Classic
- Just bought the TFI for my 06 Dyna...anyone else use it?
- Anyone Know D&S Performance in Dallas?
- Audio System Upgrade
- SERT - Where is section 9.0???
- 8 degree injectors
- upgraded turn signal lights
- electra-pod lite under Oil tanks?
- HD Race fueler vs Race Tuner
- Direct Link Tuner by Technno Research
- Is SERT Plug-n-PLay?
- Map for 2006 Dyna w/ V&H Straightshot Slip-on HS
- Electrical Problem
- no power to radio
- New Style Turn Signal Relocation Kit
- Calling all EFI tuners........help a Brutha out
- Springer auxillary light bar installation help
- US Download for HDI ECM
- EFI tuner vs. HD download
- Stage-1 download only available through dealer?
- PCIII?
- Battery indicator
- sert question?
- Power Commander or SERT?
- Popping - But "NOT" on Decel
- add ons. do i need download or power commander?
- No Brake Lights
- Front signal conversion prob
- vance and hines fuel pack vs. pc3
- Who uses trailer Isolator plug
- Nology plug wires
- Difference in SERT 32107-01F and 01E
- Sylvania H4 or 9003?
- headlamp bulb - which one???
- '06 RKC heated gear connection location??
- Beaker Points fitted in 1989 Sporty Why
- Bulb ?'s
- DFO or Race Fueler
- Need PC III USB Map For '04 FLHTCUI
- HD Fog Light on '06 Dyna Pics
- battery troubles
- efi control
- Which SERT map profile to use.....
- DFO and Stage 1 download
- TFI/DFO Purchase
- Popping on Decel
- stage one map need
- Any electronic wizards out there?
- 03 Softail Single or Dual fire?
- zuma 550 gps
- Sportster EFI Tuning using HD Race Fueler (long)
- Error Codes- 07 Softail Std
- New HD Air horn creates static on radio
- street glide fog light install
- Need Help on TFI
- Correct spark plug for 1989 1200 sporty
- How do you evaluate a Sert data file?
- new battery, brite lites, no start
- Run-brake-signal Controller
- Melted Negative battery terminal????
- SERT DYNO NUMBERS
- Problems with sporty ignition switch
- SERT ???
- What did your SERT -01F come with
- Biketronics Smart Equalizer BT 801 questions.
- Faulty Ignition Coil / Computer Module
- New Starter Fitament - Angle Post or Top Post
- Which Sert file to choose?
- new bike battery tender blinking amber?
- 07 clock quit
- PC3 USB
- What comes with the sert?
- Spark When Connecting Battery
- sequential LED'S
- De-Pressureize Fuel Tank -01' Deuce
- Time out trailer plug help
- Dealer Download, SERT, PCIII
- 07 fatboy rush slipons K&N air filter
- Anyone got a PC-IIII map for Supertrapp 2:1 / K&N RK-3909 combo?
- 2007 SERT (01-F) Manual wanted
- STARTER PROBLEMS
- battery losing charge after sitting for a couple of weeks
- Speedo and sound in and out
- Remap after 95" SE kit ?
- Multiple HD Garage Door Transmitters
- electrics
- Dyno Tune
- 1965 xlch magneto retard
- S&S VFI-No Respect?
- 2003 883c misfire and stalling
- o7 ping on acceleration
- se ac and se slipon
- big sucker vs se
- Got my 25 degree injectors without a hassle
- miss firing
- PCIII question
- sporster turn signal problem
- Changing Speedometer 03 FLHTCUI
- PCIIIUSB & Altitude
- Fuelpack/PCIIIUSD Street Bob Experience
- sucessful Sert download....yea!!!
- PCIII no throttle % indication ?
- question about roll off switch
- Dobeck TFI Unit: 07 Street Glide
- SERT will not load....please help!
- help with 94 Fatboy
- anyone using Terry components?
- 07 with SE AC but stock pipes
- Turn signal chaos
- what should I expect from a SERt
- which SE stage 1 EFI kit?
- Noise with key off
- 83 Sporty Charging Issue
- SERT W/Boost:
- Question about LED lighting
- electrical current draw short circuit problem
- Throttle control...
- Cooooooold start
- EFI stock settings
- Sert tuning constants
- Turn signal problems
- spark plug concerns
- dobeck
- headlight mounting
- High Idle and wont come down
- sert and canned maps
- Hi beams and passing lamps
- Tour Pack turnsignal conversion
- RPM drop
- 1550's Run Rich?
- Printer Anywhere (Beta) Free Download
- Help making decision, Please.
- 3496K bulbs, anyone tried them?
- Dealer service require my SERT module?
- one cylinder burns richer
- SERT cables and software
- Tune or Not?
- Neutral Indicator Light
- Motorcycle EFI Explained (Sert/PC/ECM Download)
- pc3 or hd race tuner
- All Balls Starter
- high beam wire?
- SERT cables
- Got my Letter
- 07 intake- PCIIIUSB map
- Idle question
- 07 Harley O2 bung size
