- pcIII electrical chirp
- T-Max knock sensors?
- Thundermax Upgraded Firm/Software?
- Looking for post that had a throttle gauge in it
- No electrics on Softail std 2002 (carb)
- Getting dyno tuned by the dealer
- Fuel Management & Stock Bike
- How do you run a dyno test?
- radio on street glide
- Exhausts and Stage 1 SE (Deuce 2004)
- Doc 1 is back in town
- SERT Knock Sensors??????
- starting
- Sporty misfire
- Got my SERT, and Stg I intake. Installing Saturday. Questions
- HD Garage opener Install- Void Warranty?
- Screaming hot positive terminal???
- Battery keeps dying...?
- Stage 1 results....Is this acceptable?
- missing ecm node
- Check engine light stays on too long?
- 2001 Road Glide heaadlight adjustment
- Adjusting CLB and AFR tables
- FOB Won't Marry To TSSM
- EFI and a dead battery
- Boogey Light question
- Torque vs. Horsepower via Stage I,II,SERT
- Security System
- Headlight Keeps Blowing
- Can this cause a decel pop?
- brake light stays on (help)
- MAP Sensor
- Turn signal issue
- colder spark plug
- PCIII sputter
- sert on a stock h-d
- fuel pak
- SERT / Air Temperature Enrichment
- Misfire at part throttle EFI (intermittant)
- which cylinder
- How is a SERT downloaded to the ECM
- Thundermax Question
- 07 Touring, Big Sucker, Rinehart True Duals and Sert
- Turn signal cancel module question - LED conversion
- Starter Problems?
- Speedometer Issue
- 1995 fxstc brake light (fuse)
- a concern about Fuelpack after install
- Screamin Eagle Deuce air/fuel question
- PCIII Question re Throttle set
- SERT Data mode recording
- 2004 Road King intermittant missing HELP!!
- T-Max
- Which SERT Calib File should I Use
- Power commander driver for win98 ?
- Battery cable loop/deployed soldier
- differrance in 07 and 08 throttle body
- minor popping on decel gone-Thundermax
- Engine Light Reset
- People who have installed SERT
- 03 Dyna Turnsignal Problem
- ARGGG ... automatic turn signal blues
- SERT related question
- Fatcat exhaust installed & dyno SERT question
- Need running lights
- Kuryakyn run/turn/brake keeps blowing headlight fuse
- Need help Bike still killing on me.
- Techlusion best price?
- Data Link question...'07 Touring/T-Max
- Turn signal relay location
- Check engine lamp diagnostics
- Looking for someone with PCIII on stock 07 Ultra
- Headlight fuse keeps blowin...
- battery problems
- Thundermax-will autotune dial it in by itself?
- Dyno question
- Still have occasional starting problem
- Anyone had Jamie dyno their bike?
- SERT Installation question
- Installing billet headlight shell
- Dfo/ Tfi chirping at idle ???
- thundermax, and cams
- '07 Road King ingnition question
- Stage 1 cartridge download?
- Intermitent Speedo Issue ?
- PCIII 07 Deuce MAP Question Please Help !!!
- '96 FLHR and '96 FLSTN Charging Systems
- DTT install question
- Issues with PCIII ???
- Thundermax Issue
- Keep losing the cold idle setting
- How do I check the coil on my 03 bagger?
- SERT map?
- Race fueler question?
- Confused as a baby in a @#@@% bar
- Adjustable Map Ignition
- Lost power - massive popping
- SERT Beginner guidance requested.
- SERT - TFI GEN III.i just .
- SERT Just arrived
- Kuryakyn LED lights??????
- PCIII & Big Sucker Installed...is it just me?
- SERT tuner gurus need you help
- Changing AFR? What's happening to me?
- Stock Bike
- Engine shutting off when hot
- No Problem
- 03 Bagger dies while rideing.
- nostalgic mini tach installation
- Arlen Ness Big Shot
- Running Lights burn out
- 0%throttle tweaking-Sert?
- Whistling Fuel Tank Problem FIXED!!
- right turn signal
- Screamin Eagle Race Fueler
- Starter dead! Fuse??? rely???
- Power Commander or HD Race Tuner
- What Dyno Numbers Can I Expect ??
- Is Dyno Tune Necessary w SERT?
- Passing light question
- Question about going back to stock muffler with EFI
- ULTRA-CLASSIC CUTS OUT WHEN RIDING
- Hot running '07's
- 07 TPS sensor adjustment procedure
- I'm done with AGM batteries....
- In need of a closer SERT map!! Or time saving advice!
- 07 overheat on rear cly. only
- S E race fueller help
- TMAX-AUTO TUNE & MPG
- running light
- Location of Power Commander on a 1999 Electra Glide Classic
- How do I Test a Dyna DS6-2 Ignition?
- Engine Ping - What is It?
- Engine Detonation - permanent damage? Help
- Thundermax observation
- turn signal problem
- PCIII and Ness big sucker
- Ignition switch
- narrow band 02 sensor (NB02) mod.
- Engine Guru's...Stage 1/pipes and power band ????
- same 96 fxdwg, left turn signal only issues
- cert tuning
- Stage 1
- SERT Question
- Dyno Tuner - Dayton Ohio
- Fuelpack FP-0450 - 06 Ultra
- sportster won't start, no lights, etc.
- starter won't disengage
- SERT Map Suggestion Needed - 06 Bob
- Sert or PC3
- speedo issues 96 FXDWG
- What now?
- SERT Question?
- ignition
- horn and rear turn signals dont work
- SERT Cal needed
- HELP NEED SERT 07 DYNA
- HELP.cruise control problem
- FI Cleaning
- power commander
- Can an o2 sensor
- NEED TUNER IN CONNECTICUT
- cal map #
- sert problem
- Fuel Pak
- 07 RoadKing Fuel gauge
- test ignition mod?
- s/e ignition ?
- JBS Skull headlight problem
- No power anywhere
- Dyno Run!!!!!!!!!!!!!!!
- A little help, please
- Tweeking V&H fuel pak
- Major Problem
- No spark
- good tuner in so cal ?
- thunder max
- USB to Serial Adapter question...again.
- reduce idle speed on 2007 models with scanalyzer?
- '05 Fatboy--ECM problems?
- coil repair?
- Just had my bike dyno'd...What do you think?
- 02 roadking
- recommended cams for......
- 02 Ultra Hiccuping and Coughing
- What's the best option?
- PC Map Rosetta Stone
- Need map for PCIII for my mods....
- S&S Engine
- Alpha-n systems
- Fuelpak and Rinehart S/O's - Info
- sert cal map
- water damaged ultra classic HELP!!!!
- TMax ?
- Having problems with the Sert & VISTA??? SOLUTION!
- TUNER IN ILLINOIS
- FXD35 Fuelpak and Bub jug huggers?
- FI-1440ST on 2007 streetglide
- PC III Adventures...
- High Beam Indicater
- Looking for install instructions for 91558-01A Garage Door Opener
- Add on Fuelers
- My baby is home now...she has no juice.
- dyno run on a stage one download form harley how lean is lean
- Thundermax -No Guide or Software
- TMAX-6th speed indicator not working-followup
- EFI to carb
- big boar battery
- Oil in Stator Plug Connector??
- Smog Sensor?
- turnsignal/running lights conversion
- O2 Sensor causing excessive back pressure?
- Another PC3 question
- V&H Fuelpak install
- PCIII New firmware observation
- newbie needing help. How to change starter on 1996 Road King??
- 07 stage 1 download
- Putting O2 sensors on an 06 Street Glide??
- PCIII on stock 07???????
- another decel pop question
- IGNITION MODULE PROBLEMS
- HAY YALL
- more popping
- S&S IST Ignition With Mikuni Carb
- dyno tune changed bike
- error code 16 98 road king
- spark plugs 96" tc
- Alarm sensitivity
- maps for my set up# 80 or 81
- tach needle jumping
- Are these plugs going to give me troube?
- SE pro efi fueler?
- sert install trouble
- Security System not recognizing FOBs
- idle
- Litttle Help Please
- SERT MAP #78 OR #79
- Help wiring GPS
- Gas Tank FXSTD
- map# Any suggestions?
- Thundermax model question
- FOB HELP
- closed loop biased # for sert
- High RPM @ start
- Two selectable maps on a PCIII
- PC III Serial Cable:
- V & H fuel pak
- closed loop ?
- PC III Map-EGC W\...
