- am i making this to complicated
- HELP!!!! No Tailight after install of aftermarket front signals
- thundermax will not link Ideas?
- Question about PCIII power source when off the bike
- Need help with SERT map?
- Thundermax
- FuelPak ?
- O2 sensor removal harmfull?
- Anyone in Chicago willing to help me tune my bike?
- erratic idle
- Brake light makes Radio cut out!
- Soot, Pre-detonation, ???
- Turn signal problem - reward!
- turn signal issues?
- help speedometer keep reseting itself
- Old School Sound from Fuel Injection
- possible TSSM problem/open short
- Speedometer and Tachometer are not working
- Bike wont connect with SERT
- crane hi-4 kit opinions
- Taillight and turn signal trouble - UPDATE
- Help.. Led lights..badlands module
- PCIII installed- Fuel Pac gone
- Clean the O2 sensors?
- PC3 in 07 Softtails
- Fuel injectors on 08's and the connectors
- Sert Maps
- HELP!!!!!!! No Spark At The Rear Cylinder
- major short problems
- Help picking TMAX map
- Ironhead sporty starter spin
- Yet another sert question
- Hot weather detonation
- Battery and charging system help needed
- sert
- Won't start
- 2001 Ultra Shutting Down
- Programming Speedo Mileage
- Stage 1 - Thanks
- fuel management
- Intermittant Engine Light
- Rush 1.75 slip ons & SE a/c questions
- PCIII Map
- Dyno Tuneing...is it worth the money?
- Regulator problem?
- Non HD SERT
- Stock Injectors?
- Need help w/Biketronic radio wiring
- Dynojet- excellent product backing !
- VH FuelPak Question
- Damn horn won't work!
- Fuel pump not working HELP PLEASE
- power commander and the rocker
- SERT or PC3?
- mini tach wiring
- Stage I ???'s
- Cruise control problems on my 07 road king
- PClll/computer/bike
- Advice / Information on '08 FLHX Tuning
- stealer won't give copy of sert map
- DYNO tuning with iridium plugs?
- TMAX install issue
- SERT install ??
- 02 Sensor unplugged effect AFR settings?
- wiring radio to hand controls
- Need SERT help/map for 07 Dyna
- Wits end..
- unplugged O2 sensors?
- settings power comander
- pc3usb not seen by laptop
- do i ajustable ignition
- Dobeck Performance Fuel Optimizer
- 02 sensor life with SERT
- Does anyone know about Rapid Bike EFI tuner
- Siren Installation
- tuners????
- led taillights
- No brake light....'95 Ultra (FLHTCUI)
- Will self install sert void warranty
- Looking for a SERT map to use with S/E mufflers....
- Check Engine Ligh, What Happened?
- SE Triple Platinum Performance Spark Plugs
- 05 Ultra Turn Signals
- Codes???
- cruising speeds /rpm/pc111
- 2000 UC shutting down
- Teclusion/Dobeck/RevTech 1250ST DFO
- headlight brightness
- Bike firing on one cylinder!!
- Mystery Harley Fuel Injectors
- EGC speakers
- Check engine light
- tach hook up
- 05 FLHX replacement gauges ideas?
- 2007 RK SERT map help please
- True Duals
- Softail Security System Question
- K&N + PCIII Install the best $$$ I have spent ...
- Super Race Tuner problems (32109-08)
- need a map
- Need Help With some Wiring!!!
- K&N RK-3909 Kit Install Problems and Solution- '02 FLHRi
- Ignition Performance Gains?
- To Confirm Understanding of SERT/SE AC/Pipes Process
- New Tmax - AFR Help!...FIXED!!
- pc111 idle
- Engine Idle speed problem
- Wideband O2 Sensor replacement
- fuel injection 1998 roadking
- MM to Delphi Conversion?
- TMax - first time issuse
- changing pipes and a/c on 2007 fatboy
- no fuel pump on 2007 fxd
- Need assistance with ignition switch
- Help with bolt on gone wrong...
- PCIII cylinder trim
- What do numbers mean, on PCIII?
- PC111 and HD service ?
- internal wiring of fat bars
- question concerning remapping for stage 1
- SERT Aficionados...Will it remain proportional?
- Ultra Radio Woes!!
- Water out the exhaust?
- Injector Substitute:
- sert tuning
- bike wont fire...help
- Wiring on radio jack
- Radio Shack siren installed '05 Ultra - was: ECM screw mounts broken
- Looking for PCIII Maps
- M&M ECM
- HELP! Battery keeps dying.
- Is stock ECM 'tuneable" ?
- map for Hooker Fourbiddens?
- Help with ECM signals
- Problem Loading
- CRANK SENSOR QUESTION
- Charging question
- Delphi Switching Oxygen Sensors
- scanner
- headlight problems
- Newbie about power comander
- Poor MPG with TMax
- Electrical Issues
- Can I Use My Friend's Old SE EFI Race Tuner?
- hesitated on take off
- A Quick PCIII/Stage 1 Download Questions for the Experts here...
- For beerguytx
- Name for plug style on siren?
- Speedo problem
- Needing advice
- How do you install headphone jack to stereo
- New Ultra, No Joy
- How do I check DTC codes on '01 TC 95"
- 2008 touring bike base tune '2000TL001-b0.MT6' cuts timing to aggressively off idle
- Electrical Snafu 08 FLHRSE4
- Running lights conversion.
- Cobra 2000 or V&H Fuelpak
- Bad mpg why all of a sudden?
- 08 ultra complete security sytem install
- Need PCIII Tuning Help -- Sorry
- connector for siren + unidentified connectors loose
- Dynojet recommended 807-120 for my True Dual
- Horn problem on VRod
- Rough Riding at low RPMs
- NOOB questions on fuel injection
- Another TMax Question...
- sert calibration
- Power Commander Installation Nightster
- Supertrapp SE Fuelpak Settings
- SERT-can u save your stock map first?
- Closed Loop Performance
- O2 + stoich meter would it work..???
- 1982 starting issues
- oh so popular 'pop' @ idle or under load?
- ignition switch replacement
- PCIII Adjustments
- cobra fi 2000r 02 popping on decel
- EFI Questions
- GETTING SPARK WHEN IGNITION SWITCH IS TURNED ON
- Can't open custom SERT Map
- ThunderMax pinging Twin Cam 96
- SERT tuner search in Middle Tennessee
- battery
- Do I need a Dyno?
- Latus HD map
- Remote pager system
- HD Plugs
- Question for Steve Cole
- Tuner Question
- Tmax Thundermax Initialization
- I need more power!?!?
- Engine Temp w/SERT
- Surging between 1800-2500 RPM
- Throttle Wire
- Help with a SERT Map
- Speedo Problems, Voltage seems low? Any ideas
- Plugging O2 bung with PClll
- Stage 1 download & Nightrider 02 IED
- PCIII question
- Interesting Electrical Problem
- Remove PCIII
- Wide band 02 sensor
- Dyno Tuner in Tucson/Phoenix Area
- Does the Fuel Pak and Arlen Ness Big shot eliminate the 02 sensor signal?
- sert question
- '01 MAP Sensor
- DOES ANYONE HAVE A PCIII ON AN 08 TOURING MODEL THAT WORKS?
- PCIII manual adjust??
- EBay tuner scams
- PCIII RADIO FREQUENCY (RF) INTERFERENCE
- can't rev
- Injector differences...Please help
- SERT- BELKIN ?
- Injector "timing" (Not igntion!!!)
- PC III Doesn't work on 08 FLHX
- Stage One
- Pro one turn signal light bar
- 08 Street Glide map
- Module Wiring
- SERT map?
- Reading spark plugs
- '74 FLH Won't start
- headlight bulb replacement
- 2000 1200C Sporty turn Sig.
- Road King died
- PCIII map
- testing the charging system got me???
- blown fuses& engine light comes on
- spyke ignition
- idle problem
- Tuning for mileage ???
- Dyno time---when?
- possible pre-ignition
- PCIII Install on 08 Street Glide
- New t-max software update
- Stage 1 and Warranty 07 Deluxe
- 05 HERITAGE SECURITY PROBLEMS
- sert map for 80" evo
- Cloudy Lights
- Mount for Inno2 XM Radio
- SERT Difficulties
- MegaLogViewer now does TCFI and SERT graphing
- factory alarm
- Wires for Single Fire Ignition
- Fuel Pak and erratic idle on '08 EGC
- MOVED: test
- installing an security module
- SERT CD ISSUE
- I get no spark
