PDA
View Full Version : Ignition/Tuner/ECM/Fuel Injection
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 [83] 84 85 86 87 88 89 90
  1. help me please
  2. Low Fuel Light
  3. Dobeck Performance TFI experience?
  4. SERT Program
  5. How does a Power Commander Work?
  6. got P0154 but I have PCIII w/ O2 elims.
  7. How do I tune bike with module?
  8. Sudden problem with pinging/knocking.
  9. How do you bypass a bank angle sensor on a twin cam
  10. Twin tec TCFI2 install
  11. remapping vs sert for unkown brand mufflers
  12. SERT comparison
  13. Battery and Check engine light '05 RKC
  14. PCIII location
  15. Accessory fuse keeps blowing
  16. couple of electrical problems
  17. 74 XLH 1000 not starting, or firing
  18. Here we go again...Fuelpak, pcIII, SERT?
  19. 07 just died???
  20. weird starting prob
  21. Speedometer/Odometer No Worky-Almost There
  22. Battery Tender recomendations?
  23. F.I. tech question
  24. What is the SERT Version for 07's?
  25. Help!! Cant locate 3 pin connector for siren install on an 06 sporty.
  26. Need Help
  27. SERT Map for '06 Street Glide
  28. Heat Managment question
  29. Champion RN12YC to Bosch Platinum+4 Cross Reference??
  30. DFO/TFI Location on Ultra
  31. re-mapping for the short-term
  32. how to bypass passin lamp
  33. ThunderMax
  34. Engine light, PCIII equipped
  35. SERT DYNO File
  36. PCIII
  37. front stop switch keeps burning out
  38. pulled my hair out!!!
  39. WIRING FUEL GAUGE
  40. Relay sizes ?(breakers)
  41. O2 Eliminators
  42. Custom Map
  43. Alternator output for a bagger????
  44. baffles
  45. SERT or Dealer Download?
  46. Installing passing lamp ?
  47. PCIII or FUELPAK?
  48. Dyno results
  49. Expert Tuning advice please
  50. How to figure out if theres an electrical problem?
  51. Screamin' Eagle Stage I Kit or K&N RK-3909 Kit?
  52. Help tuning with the crane hi 4
  53. hard starting
  54. Rear Cylinder Misfiring/Not Firing??
  55. mileage drop from 39MPG to 34MPG
  56. DFO Settings Advice?
  57. 06 fatboy stalls/ coughs help
  58. Sert tuner in Mo.
  59. Question regarding remap for SE A/C on '05 TC88
  60. here is a good website, have a look?
  61. Confused!!
  62. Sportster 98 electrical problem
  63. How to fix a muffled Horn?????
  64. popping on throttle letoff
  65. timing marks for 61 pan
  66. SERT tuner in Texas
  67. Dyna Ignition Module on EVO
  68. SERT Tuning/Loading question
  69. Good Dyno guy w/SERT exp. in St. Louis area?
  70. NEED SERT MAP!!!!!
  71. Here's a little SERT/ECM info for ya
  72. Injector problem?
  73. SERT models
  74. No Blinkie Blinkie
  75. PC III USB- Understanding the Numbers
  76. H-D pager II, no RCS signal being received
  77. PCIII
  78. PCIII and replace just the air cleaner
  79. do the factory screaming eagles come with a sert
  80. Cobra Fi2000R
  81. New PCIII Installed - Help?
  82. 2007 fuelpak?
  83. Magneti Marelli ECM Tuning ??
  84. spark plug wire resistance?
  85. HD SERT Question
  86. About misfire, bad ignition module.
  87. Vance & Hines MAP
  88. Aussie SERT's put on hold
  89. Fuel pressure test
  90. SERT questions
  91. Removing turn signals
  92. 99 Roadking Classic FI issue
  93. 2003 Night Train idle problem when coming to a stop
  94. Sert Details Question
  95. Started, backfired, wont fire.eas?
  96. Turn Signal malfunction
  97. SERT Data Mode
  98. EFI tuning for new bike
  99. 32107-01E On a 2007 Glide Question
  100. Start and die problem
  101. Highway lite problem
  102. SERT - V&H Ovals - map help
  103. Washed Bike, Now Have Starter Issue
  104. Quick EFI Question
  105. EFI Idle problems
  106. Great Tuner Overview Article
  107. 07 SERT owners question please.
  108. Headlamp Aiming
  109. Ignition Timing/Plug Heat Range
  110. Closed Loop Bias Opinions
  111. 93 Sportster
  112. tried a different PCIII map....
  113. I need some help please!
  114. PCIII
  115. 06 FLHRI idle ?
  116. electrical problem
  117. mufflers
  118. 06 dyna running hot
  119. Just installed a SERT on my '07 Heritage...
  120. odessey batteries
  121. Am I about to be screwed by the MoCo?
  122. air-fuel mixture
  123. Cobra® FI2000R Tripot Plug In Fuel Processor, 1995-2006
  124. HELP!!! Ignition Woes
  125. Electrical problem
  126. '04 883 Custom performance question
  127. SERT Down Load Original Program ?
  128. Finally someone listened
  129. Fuel guage
  130. crank sensor. Crank position sensor. I opened the cover and this is what I have
  131. New SERT install
  132. Screamin' Eagle Pro EFI Race Fueler
  133. TSM/TSSM error code 31
  134. Here goes nothing
  135. XM and Sirius radio questions
  136. Electrical woes...
  137. Looking for Dyna 2000i interface cable
  138. Is this the dreaded 8 degree injector problem?
  139. Recommended PCIII USB Map
  140. PCIII Accelerator Pump
  141. 32107-01F SERT Questions
  142. Power Commander or SERT?
  143. Who'd of thought.....
  144. Lost in tuner land
  145. ECM stupidy question.....
  146. ??? for SH Bob
  147. Starting idling problems...
  148. another electrical gremlin
  149. Dual Points Installation
  150. Spark GAP
  151. Which Ignition Tuner for 00 Carbed Dyna?
  152. Sert Question?
  153. SERT Tuning
  154. Hooker Tuned Flow exhaust ?
  155. cam pick up sensor...where?
  156. Touring Vance and Hines Fuel Pack
  157. Exhaust Y-pipe crack/ Glowing Red hot!
  158. 06 Roadglide no spedo, tach,turn signals HELP!
  159. RJ's New Hampshire
  160. EFI ON A CUSTOM TANK
  161. couple of SERT questions
  162. downloads
  163. are there round keyed ing. for '94 fl models
  164. RPM wire????
  165. Security system question
  166. Turn signal problem
  167. FXR No spark
  168. Help, broken throttle cable!
  169. 07 Road Glide Fresh Off The Dyno!!!!!
  170. starter
  171. brake light not operating
  172. Stage one download?
  173. Oil gauge is whacko
  174. Loaded Map #228
  175. Help install Mini Tach on 97 FLSTF
  176. Intermittent firing on one cylinder
  177. What is plug "arcing" ? What causes it?
  178. would not start
  179. Starter Relay - radio problem fixed
  180. Dyno Run 510g cams, 95"
  181. Speedomter not working
  182. Hyper flash with Radiantz LED turn signals
  183. PCIII on an 06 Dyna - Any Tips?
  184. terrycomp and the 07's
  185. Dyno Tuning
  186. Ness Big Shot Question
  187. DFO issues
  188. It happened again! where to check now?
  189. Load Balancers?
  190. Help me solve this electrical problem
  191. Which Race fueler is this one, its Chrome??
  192. Power commander
  193. passing lamp's
  194. What is SERT / Map / PCM III
  195. Cold engine/warm ambient temp
  196. Kill switch won't kill the engine...
  197. idle question
  198. Fi2000, TFI and Fuelpak, Same thing???
  199. starter not engaging belt drive
  200. 06 Deuce problem
  201. 1970 Shovel draining battery
  202. Taillight/License bracket for 2006+ Bobtail Fender
  203. Code U1016
  204. Living with the Big Sucker II
  205. NEED DIAGRAM OF WIRING
  206. Sportster turn signal shuts off too early! Can it be adjusted?
  207. PC III usb Placement for a 06 softail
  208. 1995 Fatboy
  209. 93 Hertage Softail starting problems
  210. PC III questions
  211. turn signal does not blink
  212. Race Tuner
  213. Air temp sensor
  214. HD download vs PCIII usb
  215. Better Fuel Mileage?
  216. Better Fuel Mileage?
  217. Recommended SERT map 2006 Deuce ?
  218. What Map
  219. what to do when removing tachometer?
  220. S&S IST Ignition
  221. Lose all electrical power
  222. Warning Light
  223. Fuel Pak .... Yea I know ....
  224. SERT Data Mode
  225. Electrical problem
  226. SERT instruction help
  227. Shutting your bike down.
  228. Packard Connectors
  229. race download / setup
  230. 98 road king gas mileage
  231. pcIII 95" download where do I start?
  232. PC III USB Map For 1550?
  233. Headlight bulb top bottom?
  234. race download?
  235. Cruise Control
  236. What did your dyno work cost?
  237. 1995 Fatboy
  238. Hd alarm is it worth the cost?
  239. 1987 FXR Ignition Problem????
  240. International vs. Domestic Lighting?
  241. Fuel Pak on my new 06 Fatboy
  242. reading the sparkplug
  243. Easy upgrade
  244. 73 Ironhead Starter Problems
  245. Newbie Post- SE Slip-On & Mapping Question
  246. 2007 PCIII
  247. Spedometer Odometer potential problem
  248. 2nd regulator bad!!!whats up???
  249. SERT map files for 2007
  250. PISSED !
