PDA
View Full Version : Ignition/Tuner/ECM/Fuel Injection
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 [72] 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90
  1. analog speedometer AND signal canceling failed
  2. adjusting the idle?
  3. Do I need my ECM reprogrammed?
  4. MAP vs. elevation question
  5. SERT Maps
  6. PC III usb vs PC III usb EX
  7. Fat Boy injection problems
  8. Security and Fuelpak
  9. Thundermax the best?
  10. How to "open" a bullet headlight
  11. brake light switch
  12. Looking for good Power Commander III map
  13. what happens when the IAC settings are off?
  14. need help engine light comes on 07 street bob
  15. Running Light
  16. techlusion TFI i give it a thumbs up
  17. Help, Bike died, Will not reset
  18. Wiring up an accessory port.
  19. I just won the Olympics for Stupidity
  20. 07 Speedo problem
  21. PCIII map for Stock mufflers with no baffle 07 FLHTC
  22. comparing specific maps between tuners
  23. SERT fuel-air ratio
  24. Best new battery
  25. Accel Ignition Wires
  26. ISO GRIP THROTTLE ADJUST
  27. 06 FLHTCI Brake light fuse
  28. Corbin Heated Dual Tour Install tips
  29. FLSTF charge woes
  30. PCIII map for straightshots HS--04 Dyna
  31. I do not understand this concept.
  32. 08 SERT part number
  33. Broken Horn Number 2
  34. Daytona Sensor Setup is lookin good!!!!!
  35. SERT-Microsoft Vista-USB to serial cable????
  36. Powercommander Firmware update Help
  37. aftermarket coil for 01 fxdl
  38. info needed for 08 Road King Tach install
  39. 07 FLHTC and Revtech DFO
  40. Speedometer Removal on 05 Roadglide
  41. List of available EFI controllers
  42. SERT Map for stock 07 96B
  43. Where did the dealer put it?
  44. LOOKING FOR A GOOD TUNER IN NORTH CENTRAL FLORIDA
  45. ECM Memory
  46. 07 FLHX and Zippers autotune
  47. SERT engine data mode problems
  48. Charging System Problems???
  49. cold natured FLHTCUSE
  50. Stage 1 DL
  51. FuelMoto help with PCIII Mods and Timing Adjustments
  52. I want to install turn signals myself... Any tips?
  53. 99 Ultra fried stator
  54. A SIMPLE, QUICK ONE
  55. Battery re: Winter Storage (Ultra)
  56. SERT Data Mode
  57. How to work the SERT
  58. CHROMITE II SPARK PLUG WIRES
  59. Check Engine Light '07 Softail w/ Vance&Hines
  60. Softail Headlight Problem
  61. Eletrical Problem FLHTC
  62. J&M CB on fatboy
  63. security alarm question
  64. pinging on acceleration
  65. GOOD DYNO TUNER IN PHOENIX AREA
  66. security alarm question
  67. ignition modules
  68. TMax and stripped bolts
  69. PCIII Send Map, Send Table, Whats the Difference?
  70. PCIII ignition and fuel firmware update?
  71. Need some help determaning what a specific error code could mean
  72. how to enter Diagnostic mode on a 01 flstfi fatboy with a delfi system
  73. Auxiliary power
  74. PC III or SERT with no O2 sensors? (04 Dyna)
  75. Turn signal o rings
  76. POWER COMMANDER MAP
  77. Which tuner help.
  78. Terry Terminal Velocity II Fuel Manager
  79. PCIII timing
  80. Daytona Sensor Tuning tomorrow
  81. T-Max 4.4 to 4.5 upgrade alert
  82. Best A/C for TMAX?
  83. stage II AC question
  84. fuelpak no baffles tune 2007
  85. NO KEY....Ignition Lock Removal
  86. TC88b custom spark issue
  87. Confused about tuners
  88. Cobra fi200r
  89. T-Max trouble, but company is great
  90. Question: HDI?
  91. Cobra Fi2000R ????
  92. Electrical Connector question
  93. running with unknown SERT mapping
  94. Low Fuel Light not working
  95. SE Selectable Ignition Module p/n 32704-01
  96. Help! I'm screwing with my PCIII timing!
  97. Shovel Ignition
  98. flsts tailight
  99. Jerking
  100. Engine Light on Speedo
  101. Screamin Eagle Ignition Module 32704-01
  102. Language problem
  103. Ignition timing information request
  104. 01 road king very rough idle
  105. New member + New electrical problem
  106. SERT capabilities
  107. Electrical failure
  108. changed plugs now bike is backfiring
  109. viewing SERT tuning
  110. cannot get the dtc codes on 04 flhr
  111. 08 big bore/sert?
  112. Screaming eagle pro race tuner
  113. tail lights work brake lights dont
  114. ECM life expetancy
  115. Flat battery after Tmax install
  116. Great Power Commander Warranty Service
  117. Just replace the chip in the control unit?
  118. sert error message
  119. TMAX Install Question
  120. SIGNALS/ ELECTRICAL HELP NEEDED
  121. Harley Garage Door Opener Problem
  122. Voltage reg, module or????
  123. Ambient Temp Gauge
  124. 06 sert to an 07?
  125. Need help from the mechanics in the group
  126. DFO unit for 08 super glide
  127. TMAX Installed....07 FLHX
  128. Unplugging o2 sensor
  129. Tmax o2 sensor replacement
  130. PCIII, Sert, or TMax.. Which one?
  131. One More SERT Question
  132. I'm new to the SERT I need help with a MAP
  133. surging on o6
  134. Headlight pulsing
  135. Summer / Winter programs
  136. Wont start
  137. 07 Alarm Sensitivity Adjustment
  138. doesnt start like it used to.
  139. Battery chargers and SERTs
  140. EFI Race Tuner Use on 2008/2005 Models
  141. reare running light went out?
  142. Fatcat and Thundermax
  143. h-d skull fuel gauge
  144. post fall problem
  145. Timing advance with PCIII
  146. PC III LEDs
  147. headlight/aux light wiring problem??
  148. Fuel injection v Carb ?$?$?$?$?$?$
  149. Fly by wire confusion...
  150. Red Key light wont go out HELP!!!!
  151. how to convert neon lights that are 110 a/c to d/c
  152. Dead speedometer/odometer, signals, brake lights
  153. High Energy Ingition systems
  154. ignition noise in sirius
  155. Looking for PCIII map suggestion
  156. bike backfires but does not start
  157. Speedometer diagnostic check? P S SP T B
  158. Stock tuning tables?
  159. 07 EFI
  160. Spark Plugs
  161. Good sert tuners in Michigan
  162. PLEASE HELP!! WIRING DIAGRAM 59' IRONHEAD sporty
  163. wide range o2 system
  164. ThunderMax in California
  165. 2000 Hertitage Springer Electrical Problem
  166. SERT Questions
  167. HD Remote Pager II (rechargable)
  168. 07' idle...
  169. DTC Fault Condition P0152
  170. DTT TCFI II on stock 88?
  171. The instant I give it throttle it dies! ('05 Springer Classic)
  172. Voltage Regulator wire running HOT!
  173. ThunderMAX in UK ?
  174. Tunning Mystery??
  175. New Firmware on PC Site ?
  176. SERT questions on adjustments
  177. 2003 xl1200 Electrical
  178. sert tuner wont connect
  179. PCIII mapping
  180. can anyone help with desk top dyno
  181. Thunderfire Starter
  182. ignition module question
  183. Newest SERT #78 for the "07 Ultra
  184. Stator Replacement- few questions
  185. Side or top post starter??????
  186. Belkin F5U109 USB to RS232 adapter
  187. Turn Signals
  188. power comander dead again
  189. 81 ironhead electric problems
  190. T-Max timing adjustments
  191. Starter motor "repaired", now no start
  192. DTT vs. T-Max user freindly ???????????
  193. HD warranty and Power Commander
  194. 2008 Fatboy FuelPak Install Photos
  195. 1980 FXWG Ignition
  196. Wiring question. Rear Turn Signals
  197. Head spinning...help stop
  198. FXSTC Starter Question
  199. 2008 ECM
  200. Sputtering, spitting, dying....please help
  201. Are all fuel management system equal?
  202. Accelerator pump option for PC III
  203. Installed PC III with Rush 2 in pipes and SE AC.
  204. PCIII and Fuelmoto
  205. HELP with starting problems
  206. Need some help
  207. Injector Colors
  208. Latest Firmware Upgrade for Tmax
  209. Stock "Run" Wire/"Ground" Wire
  210. ICT Twin Talon replacement ECM
  211. Need help with my LOWGLIDE
  212. Stage 1 Download Worth It?
  213. No Power after Switch install '07 FLHX
  214. bad starter motor, or what?
  215. PC III arriving tomorrow. Might be a lot of fun
  216. 07 Ultra classic keeps shutting off
  217. SERT 08 is out!!!
  218. Road King Passing Light Extra Wire?
  219. Help with some questions and a delema
  220. MAP load question
  221. Dead FLHX after new switch install
  222. PCIII EX MAP for 03 Fatboy Python Exhaust, Stage 1 Air Filter
  223. Electrical Gremlin? Front Running light KAPUT~
  224. dyno tune poor gas mileage
  225. SE plug wires much higher resistance ???
  226. SERT's for 2008 Bikes
  227. ict twin talon rules
  228. TMAX Bung pictures
  229. Stage 1 download..AF Mixture
  230. Hack the SERT.
  231. Out of Fuel?
  232. Anyone using 159AE004-A1 or 159AE003-A0 on Touring
  233. did you adjust timing with yer PCIII?
  234. Why popping only at 2400 – 2500 rpm’s and how do I get ride of it
  235. Stator
  236. Half way done with ThunderMax
  237. UPDATE: '08 Fatboy batter cannot keep a good charge ??
  238. LED Saddlebag Lid Spoilers
  239. Screaming Eagle & stage I question
  240. '05 Lowrider Blowing ECM and Fuel Pump Fuses
  241. '07 idle
  242. Good sert tuner in S.E. Michigan
  243. 07 Airfilter back plate wiring
  244. Need a tach. Any recomendations?
  245. HelpSERT won't read ECM
  246. Attention SERT Gods!
  247. VOES
  248. run, brake, turn signal module kit installation??
  249. Front turn signals not working
  250. Motor noise
