PDA
View Full Version : Ignition/Tuner/ECM/Fuel Injection
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90
  1. Start issue on occasion
  2. >>>Announcing two new forums for this area.<<<
  3. 2009 Night Train Big Shot Tuner
  4. Please help an old man with zero tech skills
  5. 2002 ultra popping
  6. How to smooth out idle.
  7. Termination of auto tune session
  8. ThunderMax and seafoam?
  9. Powervision - Engine vs. Head Temp
  10. A new thread about pinging
  11. Raise idle using the tts mastertune
  12. Power Vision incompatible with new low rider S?
  13. PV Question
  14. I broke something
  15. Fast Idle Solenoid has mind of it's own
  16. Need a fuel pak map (95")
  17. Two brothers comp s to vance and hines big radius 2-2 , re dyno??
  18. ThunderMax Known issue bulletin
  19. PV MAP Tables
  20. Tuning with TTS and a MacBook Pro - nope - Microsoft Surface
  21. superchip tuner
  22. Quick Map Question
  23. ThunderMax V&H settings and others?
  24. igniton switch conversion?
  25. 2008 streetglide Power Commander V possible issue
  26. powersion tune question
  27. Retune: Use Map in ECM or use a Canned
  28. 96" with 58mm Throttle Body Tunning
  29. 2012 FLHTK Utra Limited Speed Sensor Wire Colors
  30. Best high out put starter
  31. 2007 Dyna Street Bob Fuel Injection Priming Noise
  32. Who can Tune ThunderMax in NJ
  33. Do i need a new coil for single fire
  34. '12 Street bob Power Commander 5
  35. '06 Street glide cruise control
  36. Two minute idle log
  37. Pinging?
  38. Ca emissions removal 2015 streetbob
  39. FP3 app android to windows
  40. Power vision to tts mastertune
  41. No access to dyno...which tuning module?
  42. hot after FP3 install
  43. Muffler change (only) - richer or leaner?
  44. Dyno tune using V&H fuel pack
  45. Stage one kit
  46. Target Tune map
  47. 2015 RG - Ignition Switch Knob Detent/Ignition Lugs Misaligned, Security System Armed
  48. No power to fuel pump fuse after ecm/tsm change
  49. SEPST Part # 32109-08A
  50. Cobra FI2000 Power Pro
  51. new exhaust
  52. Wanted ThunderMax dyno tune kc area
  53. WT?, No Spark, It was running
  54. I'm so confused...
  55. Change tuners or not?
  56. Fuel moto power vision
  57. Head Temp VS Engine Temp
  58. PV... AT... I'm confused!!!
  59. Need help. Custom length spark plug wires.
  60. 89flhtc never had one do this before
  61. Error code P1511
  62. SE Spark Plug Wires And Ion Sensors
  63. Anyone tell me what this part is Pn 001218-01
  64. PV Autotune
  65. ECM TSSM replaceed and no spark??
  66. Powervision PV-1 vs. Vance and Hines FP3
  67. Repeated Coil Failures
  68. 09 Ultra
  69. TTS mastertune need download for 124ci build
  70. Fuel Moto maps, how close are they?
  71. Old ride for an old Geezer
  72. Dynatek Fusion EFI
  73. PC 5 Failure
  74. map for TTS SE255cam
  75. Fuel pac 3 displayed on infotainment screen
  76. Extension cables PV2 and O2 sensors
  77. Little help: Bad Dyno Experience
  78. Question Re: Autotune 02 Sensors
  79. PV map
  80. Did my bike suck up some sand?
  81. I'm need of stock map
  82. A little Help Please, I can't seem to get her running right.
  83. Lack of Powervision capability
  84. Dyna 2000i 1984 Shovelhead
  85. FP3 w/ Jackpot Classic Slipons. What Tune?
  86. 2014 FXDB check engine light
  87. check engine lite fix?
  88. Changed spark plugs - misfiring
  89. 1996 fxdl no spark
  90. DLC on 2000 Heritage
  91. MAP for PCV - 103" with 57h, Python Venom Radius, SE A/C
  92. Target Tune
  93. Line of code in ecm maps
  94. Looking for info on tuning
  95. Good Tuner in Charlotte NC area
  96. Cam Bearing oil/air breathing
  97. Tuner left attached, or not?
  98. Ignition Curves for an Evo....
  99. Depository of Tunes
  100. fp3 Speedometer Calibration
  101. Fuel injector connector help needed
  102. Power Vision with TT
  103. fuel pump
  104. Power Vision help with understanding.
  105. 05 Heritage w/thunder max hard starting
  106. 2001 Ultra Classic Idle Problems
  107. Softail SERT map needed.
  108. Electrical problem. Keep blowing fuel pump fuse
  109. Dynojet CAN Link Cable
  110. FP3 with Rinehart Slimline duals and 4" slip ons
  111. powervision question
  112. 124 LC Map request -TTS Mastertune
  113. PCIII vs PCV
  114. power vision, closed loop
  115. Can I ride with fuel line e disconnected?
  116. Power commander 5 placement.
  117. Timing adjustments and Timing patterns
  118. PowerVision Problem
  119. 2006 twin camm 88 efi question
  120. Ecm question
  121. Recommend a good tuner for powervision in central Florida
  122. HELP...stator wires
  123. Help me understand.
  124. PCV Map Request - 117"
  125. New to Power Vision questions
  126. Help 97 EFI fuel line replacement
  127. Engine lights...
  128. DK 587 with screaming eagle slip ons. Tuner?
  129. Super glide died
  130. New to the tuner/programmer world. Help me out.
  131. trouble starting 07 street glide
  132. late model 103 high out put factory air cleaner???
  133. 80 FXE starting issue
  134. 01 EG engine light on
  135. Rear O2 Sensor Issue
  136. wer vision questions
  137. low fuel pressure causing limiting RPM???
  138. PC3usb map help...04FXDI
  139. Taking advantage of me?
  140. Monitoring actual AFR with a Power Vision.
  141. Power Vision Map for 107 Build
  142. My RK is trippin
  143. Power Commander USB Cable
  144. Trouble starting after some changes
  145. Power vison from FuelMoto
  146. No Power to Coils and Cam Sensor. (help please)
  147. Need advice / guidance on calibrating TPS sensor on replacement TB - 2013 Breakout
  148. Air Cleaner shopping
  149. FP3 for 07-10
  150. help with tune after cam install
  151. Screaming eagle 50mm throttle body retrofit on pre 06 efi twin cam help
  152. 94 softail custom. What ignition module to get
  153. Softail slim 2014 - VIN mismatch on ECM
  154. Power vision?
  155. 2008 FLSTN Fuel line removal from fuel rail
  156. self diagnostic test
  157. tach off scale with Ultima ignition
  158. Rev limiting at 3k now with the Power Commander V
  159. need help with screw size
  160. New ICM. No Spark! Won't enter learn procedure
  161. Bike Wont Start - Need Help!!
  162. diag. code
  163. air cleaner ??? flhx 09
  164. Power Commander 3 help
  165. changing to PV from FP3
  166. How to remove fuel line?
  167. Power vision install.
  168. Setting timing... to voes or not to voes
  169. Back firing loss of acceleration
  170. To Dyno Tune or Not To?
  171. The best/most diverse tuner
  172. 2015 dyna 103' dyno sheet
  173. 2010 Tuner?
  174. coil ohm output
  175. PV 2 map for fueling 574's
  176. Stangas - Western Australia
  177. Fuelmoto Tuner Question
  178. Fuelpak 3 and Thunderheader with K&N
  179. Idle Control Harley RPM MINIMIZER#13 SILVER EDITION
  180. Cobra 2000
  181. Gas mileage down and black coming out of exhaust
  182. Bike Cutting out around 70mph
  183. Engine swap, new tuner required?
  184. PCV MAP for S&S 124 640 Cam??
  185. Gas leak from check valve or fuel line - 2002 FLHTCUI
  186. Another PCV map question
  187. Codes
  188. What would cause an ICM to melt?
  189. No power to fuel pump fuse
  190. Dyno tuner in Kansas City area?
  191. no spark cold
  192. PCV: choosing the correct map
  193. ignition cap won't lock
  194. Power Vision/ Race Tuner Question
  195. 2002 Fatboy True Dual Map help
  196. Performance ignition/coil for an '02 dyna?
  197. Hesitation issue
  198. Superchips Vigilante
  199. Motor cuts out
  200. Loosing throttle response while driving
  201. Two bikes, two different tuners-can I consolidate?
  202. Ignition Coil leaking goop!
  203. Air filter - Engine Check Problem
  204. Question on sizing throttle body correctly
  205. super tuner pro
  206. Tune ?
  207. ECM & TSM married or divorced
  208. PCV tuning question for older HD Touring model
  209. 04 Ultra Clasic wont keep running
  210. Update client
  211. Most recent Super tuner Pro 2016 update ? Np pdf file of calibrations ?
  212. How to know whacha' got?
  213. Will an Arlen Ness Big Sucker work with my set up?
  214. Intermittent P0122 Code.
  215. Wiring a NO switch onto a Harley
  216. Se58mm throttle body swap
  217. New Ignition
  218. Copying TTS Tables
  219. FAT BOB 09 - relays problem
  220. accel tuner
  221. routing of WBO2 sensor on a touring bike (Limited)
  222. intermittent engine light
  223. 2011 Throttle body on a 2010
  224. intermittent engine light
  225. Thundermax tuner - "race ready" module or "street approved" ??? Cali rider here
  226. XR1200 EFI Tuning
  227. 03 sporty electrical help
  228. new owner with fuel module and o2 sensor question
  229. Tuning Cause Hotter Cat?
  230. Marry new ECM Question
  231. Dyno guy around sacramento or northern cal
  232. Nothing for the SE585?
  233. 124 build with S&S 58mm TB??
  234. Map for 574 reaper hELP
  235. Can't Find PV Log Files To Open In Excel
  236. PV, think I did a bad thing. Am I screwed?
  237. V&H FP3 New Product Teaser
  238. Vance & Hines FP3 Sticky
  239. Could it be Ethanol?
  240. '01 Ultra EFI Race Fueler problems/other tuning options
  241. Dropped my powervision. Screen doesn't work!
  242. Harley sporster iron conversion 1200 mapping
  243. Power Vision Tune License Question
  244. FP3 or PV?
  245. Introduction and request for info
  246. Anyone familiar with the DTT ignitions?
  247. Screaming eagle super tuner pro
  248. Do I need a tune or anything?
  249. scan data
  250. FP3 install-Now bike won't start.
