PDA
View Full Version : Ignition/Tuner/ECM/Fuel Injection
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 [86] 87 88 89 90
  1. Hey there, hope ya can help
  2. voltmeter question
  3. E-85
  4. Tail light hook up, please help.
  5. Duno Results for FLHXI Rineharts 2 into 1
  6. hand control switches
  7. Anybody use Skagit Powersports in Wa. for dyno tuning?
  8. Cal #55 SERT map installed in 06 RK Custom Running pretty bad RESOLVED
  9. crank case sensor
  10. Auxiliary brake/run/turn signal conversion kit
  11. injectors/sert tunung
  12. hdmaps.com
  13. Intermittent miss
  14. Code U1097
  15. chip burning
  16. SERT,where to buy?
  17. SERT ?
  18. SERT OR TUNDERMAX
  19. tach
  20. batteries
  21. How hot is normal for an EG
  22. please tell me...
  23. Help me out: Intermittent Power Loss While Cruising!!!
  24. Brake light switch questions...
  25. Road King Police tach
  26. to dyno or not to dyno???
  27. ECM Problem?
  28. whats in it?
  29. ignition and accessory breakers
  30. PCIII USB Incompatable W/Windows ME?
  31. V&H Fuel Pak
  32. shes screams like a raped ape
  33. Cranks, Will not Start
  34. Ignition Switch
  35. Spark Plug Wires
  36. Heat managment questions?
  37. Bike won't start
  38. 1991 electraglide
  39. points
  40. Electronic ignition pickup fried?
  41. PC III/K&N Kit?
  42. Bike Died on Highway...Help...
  43. Need PCIII temp fix........help
  44. harness help
  45. Bike just shuts off
  46. Stage 1 and TFI ?
  47. SERT?
  48. Sert PC III
  49. Arlen Ness Big Shot Fuel Injection Tuner
  50. "Pre-Install" PC III USB Download?
  51. SE Ignition & Alarm Issues
  52. how to test a crank position sensor
  53. Does anyone know of a good book on EFI
  54. Need SERT Map for 2006 Low Rider with D&D Fat Cat
  55. HD application not fitting?
  56. running lamp problem
  57. Slip Ons
  58. Headlight Modulator
  59. 92 fxrs-conv turn signal problem
  60. 98 wide glide speedo
  61. spuratic idle
  62. ECM ?
  63. Experts in RI.....
  64. Experts in RI.....
  65. Experts in RI.....
  66. PCIIIusb Map
  67. Question re SERT/ ECM Programming
  68. Re-programming ECM for weather changes
  69. 06 Sporty Ignition module-speedo conflict??
  70. 06 SG SERT MAP
  71. ECM question...Bob? (revised)
  72. Dyno release form ?
  73. Sportster Ignitions
  74. Power Command map
  75. Help! Looking for a copy of SERT cd
  76. Race Fueler/DFO/Fuel Pack
  77. 1991 electraglide electrical problem
  78. Top tuner(s) in the Phoenix area ???
  79. LOOKING FOR ROAD KING LIGHT BAR
  80. cruise/tach. hookup
  81. Arlin Ness Headlight Outage
  82. Do I Need To Map
  83. TURN SIGNAL 2006 STREET BOB .
  84. need custom electrical help form a wiring guru
  85. outdated PCIII maps
  86. EFI sert Question for all of you that have been there
  87. Are TFI/DFO's now dinosaurs?
  88. High mounted LED Tail/Brake light
  89. Dyna Passing Lamp Installation
  90. ECM question for the mechanic gurues
  91. Engine Idle high at start up
  92. engine sputters...ignition or carb?
  93. points to electronic
  94. PCIII or sert
  95. bullet turn signal disassembly?
  96. Thundermax ecm
  97. portable CD input
  98. PC III HELP WITH MAP!!!
  99. How to determine ECM stage
  100. Answer from PC. on 25 * injectors
  101. Turn Signal Cancel Issues
  102. Ignition switch question
  103. what kind of spark plugs!
  104. Overheating - too lean?
  105. SERT & octane
  106. Runs fine then all of a sudden dies
  107. Race Tuner question...........
  108. runs hot...
  109. Wiring ignition module
  110. PROBLEM:Doing away with front turn signals
  111. screaming eagle adjustable igniton
  112. ECM
  113. SERT QUESTION
  114. Help! Speedometer quit, no lights, no starter
  115. race tuner
  116. EFI Idle Adjustment
  117. Fuel Injectors
  118. Dyno Tune Question
  119. When did HD make the switch from 8 degree injectors too 25 degree?
  120. anyone using the 06 efi ecm "race" download
  121. dyno time
  122. a few basic efi and PCIII ?'s
  123. What size battery do I need? HELP!
  124. 02 Sensors question?
  125. electric speedometers
  126. Crane HI-4/Dyna 2000/Daytona Twin Tec/ which is best
  127. HELP...no tail light, running lights or rear brake light
  128. Front Fender Light - Road King - And what does the "other" switch do?
  129. Screamin eagle adjustable
  130. Installation of internally wired bars?
  131. SERT Required??
  132. race tuner ecu blocked need help
  133. Need Help with SERT!
  134. Changing Plug Wires
  135. running problem 05 883 sportster
  136. 2001 Road King poor fuel ecoomy
  137. EFI Mapping for Slip ons
  138. 2way remote start security?
  139. PClll / Engine light
  140. Cam opinions
  141. another fuel injector problem
  142. Upgrading exhaust again and I need some help...
  143. V&H+Stage I+SERT
  144. SE II's sound like sh**
  145. SE race fueler
  146. Why say NO! to the HD Download?
  147. Want to upgrade igniton which is best ?
  148. Need help with basic SERT Download
  149. Dyna 2000i interface wiring question
  150. main circuit
  151. Need help please
  152. Question about 8 degree injectors?
  153. serious problem
  154. Possible Injector Problems
  155. Is my PClll bad
  156. stage 2 down load
  157. Fuel Guage Replacement
  158. "skip" in spark?
  159. Starting problems, starter dead
  160. Injector Problems.
  161. tuners which one
  162. engine light
  163. PCIII map sharing
  164. Handle Bar replacement Dyna Wide Glide
  165. Knock Sensor
  166. spark from negative terminal on battery
  167. PC III USB Losing MAP
  168. did i piss away 300 bucks on a pc3
  169. 06 STREET BOB ADVICE
  170. EFI Idle Speed
  171. Reading My Plugs
  172. PCIII Fuel Map Question
  173. removing wires from the "gray" connectors
  174. Check Engine Light / ECM Code U1097
  175. FLHTCUI Stator
  176. 1800-2400 rpm surging
  177. Terry Components: factory specs?
  178. security system sensitivity
  179. Looking for a Race Tuner expert!
  180. power commander III USB
  181. Security Lamp
  182. HD security system
  183. injectors question
  184. Need Help
  185. Looking for a MAP
  186. Fuel Injection Conversion?
  187. Voltage Regulator fault?
  188. Twin SCAN 88 - - ???
  189. Dumping Fuel?????
  190. Clearing the personal security code
  191. speedo whacked out!
  192. I need some Dyno Ed Help Please
  193. need help with right map for pc3
  194. Enricher for EFI
  195. Starter Button for 82' FXR Shovel
  196. Cruise Control/Bank Angle Sensor
  197. Ignition timing curve for 06 883
  198. Fog lamps to match HID headlamp
  199. Fog lamps to match HID headlamp
  200. O4 Tacho
  201. need help from hd wrench
  202. Fuel Tuner
  203. 32107-01D vs 32107-01E SERT
  204. Running Light too bright??
  205. single fire vs. dual fire
  206. tail light bolb
  207. 03 Road King EFI Sputter
  208. 1996 softail springer
  209. Cruise Control
  210. Dripping Fuel Lines
  211. Cruise control
  212. wiring up fuel gauge
  213. Carb to Injection?
  214. Low idle stall
  215. Remove CA emissions?
  216. Factory HD Alarm with proximity addon?
  217. Dyno Tune Cost?
  218. HD download
  219. Idle RPM
  220. no fire shovelhead
  221. A Little Advice, Please
  222. Charging system question....
  223. fuel gage wiring diagram
  224. popping on deceleration
  225. PC III question
  226. SE Race tuner Help
  227. MOVED: problems putting bike in neutral!!!
  228. did they do it????
  229. Need Wiring Diagram 64 Sportster
  230. Basic SERT question from a beginner
  231. Voltage output out of starter solenoid?
  232. Terry Components Terminal Velocity II
  233. Electrical problem has me stumped
  234. '06 Night Train
  235. Should I be worried? Spark Plug Pic
  236. ecm trouble
  237. Anyone ever used an Accel Fuel Injection Kit
  238. 06 RKC stalls out when on road.
  239. TSSM Fault code
  240. Stalling of engine
  241. Dyno tune or not
  242. Sputtering at 70MPH
  243. headlight issues
  244. 2003 Ultra not starting
  245. 2003 Ultra Not Starting/ Is Now Running!!!!
  246. 06 changes over 05 on the touring bikes
  247. side mount license/ tail light wiring problem
  248. 2003 Ultra
  249. Charging System Help
  250. Finished Dyno-Tune
