PDA
View Full Version : Ignition/Tuner/ECM/Fuel Injection
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 [66] 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90
  1. Jackshaft and starter gear loose
  2. KHROME WERKS 300505 BARS.
  3. lost FOB
  4. Thundermax issues???
  5. Engine stalling at Stop Light when accelerating
  6. pcIII, KRied, o2
  7. SE Stage I Cartridge
  8. Terry VS Zippers
  9. Brake light stays lit. Help
  10. kick-only starting
  11. ECM Hardware and Communications Protcol ?
  12. Successfully hacked my Harley from my Mac
  13. 1991 FLHTC turn signal gremlin!
  14. 01 road king will not idle
  15. SERT Map needed for 98" GMR w/Tw-37
  16. Dyno'd yesterday...
  17. 8 degree injectors....
  18. speedo plug connector needed
  19. 06 FLHXI ECM compatibility
  20. Sert vs Vance & Hines Fuel Pak
  21. SERT...best map for HQ 103"?
  22. SERT update download?
  23. Electrical Gremlins...
  24. SERT map for Stage 11 Fat Bob
  25. need pc3usb map help
  26. PCIII resetting throttle postion. Help !
  27. ECM calibration
  28. Speedo Swap Causes Engine not to Start.....
  29. Right Turn signal does not work
  30. Need SERT cables
  31. PCIII Map for stock 04 RKP and firmware update probs
  32. Gas Milage Question
  33. 2004 road king custom controls
  34. SERT programming error message (PROBLEM SOLVED!)
  35. Pipe Bluing too much????
  36. turn signal
  37. Symbol in Schematic
  38. SG ACC Switch Light Wont Come On
  39. TMax question
  40. Help With Security System Smart Siren II and Pager
  41. speedo trouble
  42. How do you set the pin with a fob?
  43. Fuelmoto and PCIII
  44. SERT questions
  45. Speedometer troubles 883 Sportster
  46. Help with map with sert
  47. Problem solved DTC 41 99 FLH MM EFI
  48. Andrews 54 cam!
  49. Loss of spark
  50. security lamp stays on
  51. Help tweaking my SERT map
  52. Engine Light Troubles
  53. Sputtering problems (Coil or Module)
  54. tail light not working
  55. 07 Softail - Are FI Tuner &/or Dnld necessary w/ AC & Slip-ons?
  56. SERT Map loading
  57. V-ROD instrument cluster
  58. 06 Streetbob speedo troubleshooting question
  59. Thundermax - First Thing You Would Change
  60. Fuel mixture and sound
  61. PCIII Map Needed
  62. I NOW HAVE THE OIL COOLER FLOW MYSTERY SOLVED
  63. Looking for Injectors...Please Help.
  64. sert map for se heavy breather
  65. "run" wire questions
  66. Brake lights won't work
  67. re-wire for apes.
  68. looking for good tuner in middle tn
  69. wack throttle open/ping
  70. Thundermax decel throttle question
  71. rocker type switches
  72. High Voltage Spikes
  73. fuel gauge
  74. PC III Startup question
  75. Starter Or Battery Problem
  76. Progressively harder to start 08 RG. Update
  77. 03 Dyna trouble
  78. 2000 Road King Fuel Injection question
  79. DTC P0562
  80. Stumbles (slightly) When Just Started
  81. Tuner delima - SERT or PC3?
  82. O2 Eliminator FYI
  83. Do I need a new charging system in 86 FLHT?
  84. SERT software ver 4.7.7
  85. Trickle charger ampage setting
  86. Melted Positive Battery Post
  87. sert pro's (i commend all of you)
  88. PCIII map help
  89. idle speed 07 softail std
  90. Need tuning help!!!
  91. Problem loading map with se tuner
  92. what is 32117-01j
  93. Fat Cat / SERT Pinging / Gurgling
  94. Anyone with experience w/HD garage door openers?
  95. installing LED turn signals
  96. TMax: Still Got Pops on Decel
  97. Does a SERT void warranty
  98. Lights always on
  99. Help With SERT
  100. 2001 FXD Regulator Problem
  101. Race Tuner or Super Tuner?
  102. Bike WON'T start!!!
  103. SPEEDO NOT WORKING
  104. Does PCIII Store A History of Maps Used?
  105. '08 1200N switched accessory power??
  106. 8 or 25 degree injectors which has less
  107. PCIII behind rear mudguard
  108. Fuel Light with OEM Gauge
  109. SPO Map
  110. PC III USB Map?
  111. signall ights
  112. Need help!
  113. Daytona Sensors Twin Scan II
  114. Where's the best dyno tech in Houston, TX
  115. Pro Tuner Training DVD
  116. Engin light and battery light came on
  117. Check Engine Light
  118. Fueller's
  119. Wire size to big?
  120. FXDF Running Rich, Need PC3 Help. Map Details Inside.
  121. "Parking Lights" problem
  122. Engine mgt light - 07 Ultra
  123. 7 pin plug
  124. Regulator update
  125. Plug and Play Fuel Enrichment
  126. Fuel Mileage after Dyno
  127. solenoid/starter
  128. question about harley moto..
  129. Mapping Issue
  130. Why won't HD-SE- plug wires work with FI
  131. Check engine light/security?
  132. Probably a stupid question ... EFI Race Tuner
  133. need help with blinkers
  134. 02 IED
  135. ANOTHER CHECK ENGINE LIGHT QUESTION
  136. starting issues
  137. K & N air filter upgrade
  138. FuelPak for sale
  139. how to determine max elec output
  140. radio buzzing
  141. security light queastion
  142. Mastertune, aka TTS DataMaster
  143. engine trouble light
  144. Need help with mystery problem!
  145. DTC trouble code P1356 '06 Streetglide
  146. Bike runs rough
  147. Dyno Tune info needed
  148. tuner question
  149. new sert part number
  150. CHECK ENGINE LIGHT QUESTION
  151. lighting and fouled plug
  152. tUNER SOFTWARE???
  153. Sert or PCIII
  154. bike died again
  155. SERT - 2008 Touring map #100 - anyone leaned it out?
  156. speedo and tach question
  157. FuelPak Mounting Pics - Night Train Softail
  158. Cruise Control Error Code 112
  159. Cycle shack slip ons only - Need retune?
  160. Tach problems on a Deuce
  161. Fuel Pump Relay
  162. 110 octane race fuel?
  163. help with digital speedo
  164. Ignition
  165. Kuryakyn Short Fender Strut Mounts
  166. pc111 tuning
  167. Complete power failure on 04 Heritage Softail Classic Injection
  168. Still Pinging- Need Some Help
  169. little help
  170. Real world vs. dyno tuning
  171. Top Speed
  172. Zipper's Website, fuel issues
  173. Are Power Commanders universal or specific ones for different bikes?
  174. Electrical and Lighting problems....HELP!!!
  175. Ultra troubles
  176. Trailer wiring ?
  177. TTS harley tuner (UPDATED W/New Info)
  178. battery help
  179. Air fuel ratio
  180. SERT MAP, does tuning location matter
  181. Dyno Questions
  182. SERT question ??????
  183. Turn Lamps Went Dark
  184. Dyno Tune Question.......
  185. Fuel Pak Settings - 07 FLHTC
  186. pcIII
  187. I just want to keep this simple...
  188. Electrical SOS
  189. Sporster random shutdown
  190. Can oil be cleaned from SE air filter?
  191. Load Equalizer
  192. glowing head pipes and fuelpak....normal?
  193. PC3 map needed
  194. fuelpak throttle position readings not working
  195. 1994 Glide No Start
  196. turn signals
  197. Molex Grimper?
  198. SE pipes and FI adjustments
  199. Lights keep going off
  200. Please delete, BB
  201. IS THERE A BETTER BATTERY THAN HARLEYS
  202. Can I get the original equipment map for my bike?
  203. Sert data mode - VTD Password
  204. different cyl temps
  205. ELECTRICAL EXPERTS!!! NO POWER TO ECM
  206. 2005 road king Blowing Fuses
  207. back firing, popping and black residue on back wheel
  208. e mail map
  209. PC III USB Map needed?
  210. Nightrider IED's getting trouble codes
  211. Dual Fire?
  212. Decision time - SERT?
  213. Badlands 3 load equilizer problem
  214. Cobra FI2000R or V&H Fuelpak for Cobra pipes?
  215. help with idle
  216. Bike won't start
  217. am i making this to complicated
  218. HELP!!!! No Tailight after install of aftermarket front signals
  219. thundermax will not link Ideas?
  220. Question about PCIII power source when off the bike
  221. Need help with SERT map?
  222. Thundermax
  223. FuelPak ?
  224. O2 sensor removal harmfull?
  225. Anyone in Chicago willing to help me tune my bike?
  226. erratic idle
  227. Brake light makes Radio cut out!
  228. Soot, Pre-detonation, ???
  229. Turn signal problem - reward!
  230. turn signal issues?
  231. help speedometer keep reseting itself
  232. Old School Sound from Fuel Injection
  233. possible TSSM problem/open short
  234. Speedometer and Tachometer are not working
  235. Bike wont connect with SERT
  236. crane hi-4 kit opinions
  237. Taillight and turn signal trouble - UPDATE
  238. Help.. Led lights..badlands module
  239. PCIII installed- Fuel Pac gone
  240. Clean the O2 sensors?
  241. PC3 in 07 Softtails
  242. Fuel injectors on 08's and the connectors
  243. Sert Maps
  244. HELP!!!!!!! No Spark At The Rear Cylinder
  245. major short problems
  246. Help picking TMAX map
  247. Ironhead sporty starter spin
  248. Yet another sert question
  249. Hot weather detonation
  250. Battery and charging system help needed
