- Aghhh! Cruise control help please!
- S.E.R.T. won't find my bike....please help.
- Nightster Turn Signal Failure - Help?
- 2006 ultra classic dropping a cylinder check engine light
- 2007 Nighttrain dead!
- Fire ants!
- 1999 Road King Classic not starting
- Hard cold start, fuel pressure light flashes
- ***Cruise Control works sometimes***
- Another TSSM question
- Self Adjusting timming
- Now what???
- 01 Deuce fuel ?
- Hd roadking 2010
- Tmax help
- how to remove circuit breakers?
- factory security ?
- Still happy with your RevPerf EMS tuner?
- 97 Ultra Electrical Issues
- Turn Signal Woe
- TBW change. Now runs bad
- Cobra: Fi2000 PowerPro
- Need HELP with Road King charging system !!!!!
- jrayme2005
- ****Stranded Right Now!! HELP*****
- engine codes
- Smoked a new Batt
- Bike wont start?...Help
- fuel range function
- OK to use heat shrink?
- PC Map Needed
- electric gremlins ?
- 2006 electra glide wiring diagram
- Reading The Mulitimeter & Can I Do This
- 2006 FXDLi Speedometer Cuts Out
- Dyno Jet Power Commander III question
- EFI Guru's, Help Needed Please??
- Speed sensor
- Cutting control wires
- Question about changing tuner
- Alarm question
- Kuryaken Pandora with alloy art fender strut signals
- Bad starter clutch....?
- 07 nightster flooded
- Brake lights stay on Nightster
- 99 Road Glide Magnetti Morrelli
- Hot or Cold plugs
- true duel
- Erratic Won't Run
- TMAT failure
- New Speedo, Now Low Fuel Light Stays On
- spedo, directionals brake lights not working . . .help
- 2004 FLHRI Road King sputtering/dieing
- Need a better understanding
- Ignition Coil - Wrecked? or Just Needs Cleaning?
- tach signal
- Can't get handle bar switch back together
- Speedo alternatives
- EFI tuner numbers - throttle position
- S&s vfi
- thoughts on this
- Stage 1 kit install...on an 09?
- Ultra won't start, daytona coming up fast, desperate!- Dayton
- reposition spark plug cables
- copy of win pep?
- Fuel injector cross reference
- 2012 Dyna No TTS Available Yet?
- Screaming Eagle Race Tuner vs. USB III Power Commander
- auto tuner setup driving process
- Identifying Wires/Connections
- ***Bulb for 2009 S/G License Plate***
- Zero electrical response - help in diagnosing needed
- Indicators only sometimes work
- Which SOLENOLD Would You Buy Guys
- Turn signal ?????
- Power commander
- Headlamp will not come on.
- Charging system problems
- Peculiar "Wouldn't Start"
- Value in rewiring?
- Bike went into "limp" mode
- codes 23 and 41
- Cobra Fi2000 AT
- 2011 FLHP front turn signals
- How To Find Current File in ECM?
- What is TB size on 2010 Fat Bob?
- Too Much "Wear & Tear" On The Starter?
- S&S Big bore kit 106" and ECU Map?
- turn signal rapid flashing
- Security system wont allow bike to start
- Anybody have this happen to you??
- PC V and check engine light
- Is tuner a MUST?
- Shorting Help!!
- Revolution Performance EMS
- 08 Street Glide Check eng lite and battery light come on intermittenly
- Tuner Help Please??
- 2009 screamin eagle fatbob
- Lambda Sensor Specs ??
- 6th gear indicator light flashing
- Change in O2 (Lambda) sensor location / size ?
- 09 Ultra Classic starts as soon as key is turned on
- starter grinding
- engine light and alarm went off...
- fuel line not pressurizing
- 45 wont idle,sparks jumping all over points
- Engine light/codes? 2000 Police Bike
- 09 Road King both battery terminals painted red!
- Troubles codes
- Help needed on 6th gear indicator and cruise control
- 2001 RKC intermittent running
- 85 softail wiring
- TMAX failure
- Back again 99 superglide
- triker
- 07 RKC stranded
- brake light issue
- Still missin' after fuel line replacement
- Motor build isues ????
- Throttle body noise
- is it my coil?
- is it my coil?
- Fuel Moto/ PC3 accelerator pump?
- Revtech vs. Commander? Pros and Cons
- Missing/sneezing
- Spark plug wire or coil replacements?
- SEST Advice needed
- 07 RK Tip Light Install
- power commander left on all the time
- 2003 e glide classic wont start
- Led turn signals,resistor?
- Stator replacement
- 04 flhrsi
- no spark issues,help with my 99 super glide
- Charge problem with 2000 Electraglide
- Ignition switch bad???
- Thundermax question
- Complicated mess - Slight miss - runs rich - cv carb 1200
- I fried something
- Tuner ~ Camp Pendleton
- Code 41 and 42 cam and crank sensors
- New Battery already dead
- turns signals flash as hazards
- need help!!!!
- Stage 1 and Dyno Tune
- Melted battery terminal
- tuning question in Maryland (powervision, download, SERT)?
- Won't start at all plz help!
- Decel Pop, Low Idle and Spitting, Misses @ 2500 RPM,,,
- When's the last time someone's seen one of these?
- fuel pump help
- Remove Electrical Terminal Pins?
- Please help me find a SERT map!!!
- heritage
- Fxd tach on fxdb
- 08 STreetglide ECM codes
- Lean condition on fron cylinder.
- My 1996 Ultra will not idle down.
- 2011 Fat Bob TTS Map
- Odometer "stuck" on Km wont switch back to miles.
- fuelpak settings
- No brake lights-blinkers work only 4 way
- '07 FLHT PCIII question
- 1995 Ultra Classic idle problem
- running lean?
- SERT Pro info urgently needed. Please comment !!
- Puzzled
- Bike not starting with new battery... At times...
- Tuner conversion questions...
- pc III and stock injector limits
- Thundermax questions
- Mikuni Parts ?
- My 2" Tachometer is giving bouncy erratic reading at start up and above 2000K
- Stater engages and clicks back out.
- 2001 SE road glide
- Rear brake light switch operation
- lights affecting ignition
- Trouble codes
- 2007 fxstsse w zippers autotune**HELP**
- The Bully Fule Tuner
- Studder problem after hitting a pothole
- Acronyms/ EFI terminology
- Fuel gauge problem
- Power Vision Tuner Screen Shots - Suggestions?
- Capacity of Dyna Alternator
- Brake light always on
- ALTITUDE A/F changes?
- Throttle body Noise **HELP**
- Still coughing and dying (help needed)
- Scanalyzar ???????????
- how to program new keyfob?
- setting static timing on my S&S 124
- Supertrap PC III MAp
- Wiring for Tourpack on 02 E glide Standard
- Popping on decel
- Check Engine light not coming on at ignition
- battery tender pigtail
- 2011 EG Limted - no heated grip power
- PC III Map
- 2001 Road King won't start - no speedo, odometer, brake light, turn signals, or horn.
- Frustrated with Power commander V
- 06 Sportster 1200 ignition problems
- New 2012 Blue Pearl RGC
- Dyno tuner in Concord NC
- Need PV map 2010-11 103, 255 cams, pro pipe chrome
- Had to clear (reset) thundermax again!
- Silly easy sporty electrical question
- Static timing 94 evo w older SE ignition
- bike won't start
- electrical 2001 flhtcui
- TTS Cables?
- Help! No power......
- Decel pop - AFR settings?
- Dyna 2011: 4 pin connector?
- Installing an air horn?
- map help PC V, 96", rinehart 3.5",SE heavy breather
- electrical gremlin..blinker!
- Best Spark Plugs
- Turn signal disassembly
- Fuel Management: What Should I do???
- need ECM help
- Loose Ground somewhers!!!!
- Change Download after Changing to 2 into 1? (2004 Dyna)
- Fuel Management System / 99 RKC
- Lost My Lights - headlamp, running lights and tail light
- $16 Mount for Dynojet Powervision Tuner
- Time to start over AGAIN......
- TTS Mastertune tuner in Ohio?
- Idle question
- 92 Decker with Cruise issues
- spedo/blinker/running problem
- map for 54H cams on 07 - using PCIII
- dealer stage 1 download question
- battery terminal side mount adapter?
- Issue with Zippers Thundermax tuner
- Does anybody have a SERT map for my build?
- HELP!!! Lights dimming, circut breaker clicking?
- tc88 advice needed for custom build
- DTC list?
- 08 streetglide fly by wire plug diagram?? HELP!
- help
- do i have a ecm download?
- 2004 flhtcui charging problem
- which auto tuner?
- Thundermax problem with gauges
- removing catalytic converter
- PC III failure- tuners in general
- Running in O2 sensor.
- Turn Signal Help
- Harley Dealer tune. Can someone check this ?
