PDA
View Full Version : Ignition/Tuner/ECM/Fuel Injection
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 [50] 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90
  1. smart tuning & left directional not working
  2. 08 bobber taillights
  3. Bulb Replace
  4. TTS Tables
  5. Identify make / model of starter?
  6. Resetting the VCI for use on more than one bike
  7. speedo issues 2007 sportster
  8. starter/solenoid
  9. A Couple of Ultra Wiring Questions
  10. digital speedo
  11. Electronic Ignition PROBLEM?????
  12. Oxygen sensor bad for second time
  13. Need HD Electrical Wrench
  14. Fuel Injection to Carb
  15. HP Garage Door Opener Transmitter Install - slightly off topic
  16. Regulator location?
  17. HELP~~ rear turn signal/brake/running lights
  18. Open or Closed?
  19. Dynojet Power Commander V
  20. P0505 - High Idle on 2007 FLHTC - Resolution
  21. Automatic compression releases Need HELP
  22. Tech Help needed
  23. How does dynojet get their maps
  24. Is idle rpm adjustable?
  25. Turn Signal Issue
  26. 07 dyna dyno jet PCV exist?
  27. 2001 efi
  28. HD garage door opener kit
  29. Terry Components TV-3 = BUYER BEWARE
  30. Lights Go Off/On
  31. How the heck do I get the Smart Tune to work!!!!
  32. spark plug help
  33. Pc 3 usb ?
  34. timing a motor using vacuum gauge
  35. 50mm SE Throttle Body
  36. Turn Signal Question
  37. speedo failure 02 heritage softail
  38. Rough idle
  39. New wires and switches - 95 fatboy - a couple questions
  40. 08 dyna cvo seprt map
  41. 2010 Ultra - Can I wait on the Dyno?
  42. 04 Ultra Blowing Acc Fuse?????
  43. Check Engine Light
  44. Can't get Fatboy to unlock?
  45. 07 Sporty back cyl won't light off...?
  46. Battery died while on the Interstate.
  47. 2003 electral glide Turn signal issues.
  48. wiring harness help pls?
  49. 88 sportster electrical problems
  50. Street Glide dies while running......
  51. Fuel cross over change
  52. ridemaxx plus
  53. Help simplifying wire harness
  54. Bike dies at idle? PCIII
  55. V-Rod Muscle Turn Signal Mirrors
  56. TTS Master Tune question
  57. codes
  58. not charging
  59. Ordered my TTS Mastertune
  60. Running an inverter?
  61. T-max map , using a LOT of gas !!!
  62. Need help...
  63. EFI cold start fast idle concerns
  64. 2006 flht cuse
  65. headlight good-indicator light bad
  66. Should I update new speedo to actual bike mileage? HOW?
  67. Brake lights work, tailights work, just not after using brakes
  68. electrical issue
  69. blowing fuse in 12 volt chargers
  70. DTC's PPU 82883 for a 2002 FLSTF
  71. Help!!
  72. 1999 FLHTCUI Mapping/Tuning
  73. battery question?
  74. charging problems
  75. 04 SE Deuce Rear Turn Blinkers Always ON
  76. Please Help me..
  77. Help Installing Badlands Load EQ III
  78. Idle Speed
  79. missing
  80. wiring question
  81. TTS Tune for Andrews 26H
  82. Question on 2010 Ultra
  83. cams lower VE
  84. Evo single fire
  85. 1997 HD Touring Wiring
  86. led load equalizer
  87. charging system problem HELP!
  88. Turn signal problems
  89. 03 road king will not start
  90. TTS Master Tune For 2005 Softails
  91. Front Turn Signal
  92. TTS Tuning Experience
  93. Fault code P0505
  94. wanna get rid of my speedometer
  95. Thundermax set up steps
  96. Need help w/ RK Accessory Plug
  97. TTS Timing
  98. Thundermax , NEED Help !
  99. No tach operation!!!!!
  100. SMART Tune question
  101. Going without VOES. What do do with ignition module VOES wire?
  102. What is this??? hint - it has two wires purple and brown
  103. 2000 flhtcui diognostic code 16
  104. Starting Issue - 01 Fatboy
  105. tts map
  106. Need help badd??????????????????????????????????/
  107. Need PC-III Map for 2008 Road Glide
  108. NW Ohio/SE Michigan Dyno Facility
  109. 2010 xied
  110. 93 FXR starting problem
  111. TTS mastertune in Canada
  112. PCIII or PCV
  113. Kudos to Doc!!!!
  114. Help with Electrical Problems Circuit Breaker, Regulator or Stator?
  115. Intermittent Headlight
  116. Diagnostic on speedo says "no response" from ECM....help
  117. No spark
  118. TTS base map for HQ 107 package?
  119. Brake light stays on
  120. sert to tts upgrade
  121. 96 FatBoy Electrical - lights dim / flicker every 8-10 secs
  122. 06 flhxi efi p0261 p0263
  123. OK I Need some expertise /advice on EFI
  124. Accel SLM (Self Learning Module) anybody have any experience, advice or comments?
  125. ? When is a Vtwin not a Vtwin?
  126. road king accesories switch
  127. Spark Plug Condition?
  128. Power commander issue?
  129. PCV running 2 maps
  130. Rerouting Head Breathers outside the Air Cleaner
  131. im a TTS dumazz
  132. Crane Hi-4 Ignition
  133. 09 ultra bogging down
  134. Heritage Softail has miss
  135. Cruise control accelerates on its own
  136. Engine light after cam install and PCV
  137. SEST questions on using the data record help!
  138. Running 2 maps in a PCV
  139. Replacing TSSM with TSM to get ride of Security Function
  140. Battery conections getting loose
  141. Zippers ECU with Auto tune
  142. Brake light issue
  143. No Spark Period
  144. Chugging Start
  145. electrical short random
  146. TTS map file
  147. 2007 nightrain off rear cylinder
  148. Problem with removal of ECM
  149. 99 Sportster flashers won't stay on
  150. EFI, Power commander Help!
  151. Running Rough In Heat Of Traffic
  152. Experiences using SEST Pro Smart Tune Feature
  153. turn signal / security system indicator behavior
  154. 99 electra glide fuel line
  155. Road King to Ultra Classic conversion issue
  156. Ignition Switch Housing/Ignition Issues
  157. Dead Starter
  158. HD Secutiry and ECM/Fuel Tuners
  159. Trouble code HELP!
  160. Looking for a tuner
  161. 81sportster generator light brightens with throttle
  162. Diagnostic code troubleshooting
  163. Advice Requested re: PCIII USB
  164. code P0263
  165. Headlights and Running lights not working
  166. Super tuner update v3.003.0003 ..What are the changes?
  167. Dyno tuned today!
  168. Turn sig dont work. could the alarm effect it?
  169. HELP ! I need to know
  170. Intake Solenoid Eliminator Needed
  171. Electrical Short on 05 Wide Glide w/ FI
  172. Arlen Ness Big Sucker 09 Road King
  173. Misfiring
  174. stage 1 download question
  175. Ignition
  176. Power commander fault
  177. LED tail light issues
  178. running lights stopped working-any thoughts
  179. Where to buy tts?
  180. Power Commander USB III map?
  181. M/M EFI runaway idle when cold 3000 rpm
  182. Power Commander USBIII map?
  183. ignition coil 12v supply HELP!!!
  184. need help with electrical short!
  185. thanx to producer and coldcase
  186. T-Max - best map for my Dyna?
  187. Fuel Tank on Heritage
  188. 2010 FLTRX - is a Stage 1 DOWNLOAD advisable with...
  189. Battery problem
  190. Prices for a new SE Tuner
  191. 09 FLHTCU Fast Idle
  192. Siren install and uninstall
  193. tts map for a stage 1
  194. Clutch side switch housing
  195. Does a new 06 ignition module need dealer reprogramming
  196. Running on one cyl
  197. Battery & chattering
  198. 2005 Fatboy ECM error code PO122 Please Help
  199. ACC switch - need help pls
  200. a "simple" question....?
  201. Fuel Processor Necessary?
  202. 09 streetglide dealer said ecm fried had to replace sest with power commander
  203. Question for "smart tune" users
  204. Would you Dyno a Stock Bike?
  205. Turn signal ground location??
  206. Thinking about changing from PCIII to SEST
  207. SEPST Smart Tune...
  208. Intermittent dying issue
  209. starter bolts
  210. Will Screamin Eagle Super Tuner work with Windows 7
  211. RPM's real high when first started after Thundermax Auto Tune...
  212. Fuel gauge/idiot light?
  213. Radiant Strobe Flasher Softail Springer 2008
  214. Completed my 1st "Smart Tune"
  215. I have no lights..
  216. battery & stator dead x 2 on 09
  217. Wy do threads disappear from this subject after a few days??
  218. ? on switchs for switching between maps on a PC-V
  219. Intermittent front cylinder firing.
  220. Looking for a good dyno tuner in mainly IOWA..on the river.. Wisconsin...Illinois
  221. Speaker noise with radio off
  222. SEPST Cord
  223. My lights stay on when I turn my ignition switch to accessories. or Left?
  224. How does the PCV handle the in between numbers on the various tables
  225. 01 RoadKing Electrical is DEAD
  226. Random Electrical failures
  227. Help with a ghost
  228. High idle
  229. Looking for a good dyno in my area
  230. Idle drops to 500 RPM, whats up?
  231. Best TTS canned MAP to start with for stage 1 ?
  232. TTS tune questions from a newbie
  233. Fuelmoto PCV ...... two for two
  234. Initial break-in canned map??
  235. SEPST MAP 2009 Ultra
  236. TTS on the Dyno
  237. anyone know what im talking about?
  238. Engine light coming on intermittently
  239. 88 FXR Starter Drive
  240. tuner wants to eleminate my 02 sensors
  241. Disarming the 2006 Alarm
  242. Disarming the 2006 Alarm
  243. TTS download...now no 6th gear light?? WTF??
  244. smart siern 2 FOB
  245. power commander III accelerator pump question?
  246. air fuel gauge
  247. race tuner hic up ??
  248. TMax Data cable?
  249. Nothing happens!!
  250. Pulling myhair out.
