PDA
View Full Version : Ignition/Tuner/ECM/Fuel Injection
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 [34] 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90
  1. Need New Battery, what do you recommend?
  2. oxygen sensor wires
  3. Starter Solenoid
  4. Cobra Fi 2000 Power Pro Auto Tuner
  5. Hesitates-Idle races
  6. 2005 Street Glide No Nothing...
  7. Heritage starts running bad after 30 miles
  8. Police to basic handlebar switch conversion
  9. tts help
  10. 1993 Sportster Hazard Lights Electrical problem. Help!!!
  11. Radio Blowing Fuses
  12. turn signals dim with lights on
  13. 2007 starter grind
  14. 2007 dyna front cylinder misfire
  15. Spit and sputtering 08 Streetglide
  16. Trip reset button help
  17. DIY Flash programming stock EFI
  18. Starter issue 94 Evo
  19. cold start problem DTT TC-88
  20. Help magnetti marelli
  21. warning lights
  22. Swap-Any thoughts ???
  23. Exhaust Pipe Temp too High
  24. ABS warning light
  25. LED Mirror Top Flew Off-Ideas??
  26. Need advice on charging issue>>>>>
  27. Please help! 2004 Electra Glide speedo drops out under full throttle
  28. Intermittent jerking and misfire
  29. 2001 Magnetti Fuel Gauge Advice?
  30. Softail won't start
  31. Lost my Lights...
  32. Oil Gauge/oil pressure problem
  33. 96 Road King EFI
  34. LED Fuel Mirror Top Flew Off-Ideas??
  35. 87 softail w/ 98 evo engine.
  36. Turn signal brake light issue
  37. 6 volt battery ?
  38. check engine code 42 what does it mean
  39. Bike wont start with New ignition module
  40. Short Shot install? What tools needed?
  41. Tmax without factory alarm ?? Questions... (possible or not ?)
  42. Air intake
  43. 98 Road King with no spark
  44. Accell Self Learner Module - how long does it take to learn?
  45. which one ecm or tuner
  46. Ultra engine dead miss
  47. Fuel issue
  48. No Idea where to look now
  49. Need Help Fuel Injection
  50. 07 flhtc
  51. 2005 FLHTI Loses Power Between 75-80mph
  52. Thundermax AFR settings
  53. Power Commander Map
  54. Starter problem on 07 Road King
  55. PV Log Tuner Error Message
  56. Speedo Wire Harness 96 Dyna
  57. Power Vision Data Logging?
  58. Calibration Identity
  59. I Made A Mistake: Time To Suck It Up
  60. "P" warning light
  61. Super tuner 32109-08C Country Specific?
  62. Stock map 2009 road king
  63. For sale: POWER COMMANDER V
  64. Fuelmoto does it again!
  65. 98 Fatboy electrical popping noise?
  66. Fuel pump regulator wiring question
  67. Need help electrical issue?
  68. 06 Street Glide Idle Reset???
  69. 05 FXDLI battery drain
  70. Power commander maps and converters
  71. Power Commander 5 question
  72. Dies at 75-80 mph
  73. First time at Smart Tuning, looking for advice
  74. Engine not starting
  75. PPCIII question
  76. Screamin Eagle sparkplug gap
  77. No power? 1997 FLHTCUI
  78. Wiring diagram for 92 FXRS fuel gauge/sending unit
  79. need help with charging problem
  80. Diamond E3 Spark Plugs Qusetion
  81. Charging Problem
  82. HD 31504-91a starter relay, is there an automotive application for this?
  83. No power at the Key
  84. Need Help Trying to static time 70 FLH
  85. Help with Dyno Dip
  86. Running lights/driving lights not working
  87. '03 EFI Fat Boy Shut Down
  88. Charging Problems 96 FLHPI
  89. cracked piston....possible ignition problem?
  90. Electrical Problem when Starting
  91. Need help SE ignition control module
  92. rear cyclinder missing and popping
  93. dazed and confused
  94. Screamin' Error ... SEPST Abort ... help?
  95. Not getting spark.
  96. 883 to 1200
  97. EFI SE Super Tuner - Need map setting help
  98. Security alarm blows regular horn
  99. True Duals and S.E. Tuner
  100. Help!!! 06 ultra wont start
  101. speedometer light stays on
  102. 09 Street Glide goes into limp mode, throws usual codes
  103. Correct Speedometer 96 Dyna
  104. No electrical power to 2002 Springer FXSTS
  105. Screaming Eagle Super Tuner updates !@#@#!
  106. flucuating Voltage
  107. odometer dont work.
  108. Fly by wire Throttle help
  109. Looking for advice
  110. Code P0562
  111. Code help on an 02 ultra
  112. HESITATION & Power Lost
  113. can't get codes out of 2001 Ultra
  114. 04 fuel tank onto 07 Heritage - wiring problem
  115. Techlusion and DAkota Digital
  116. Odometer doesn't work after ThunderMax install
  117. Ther is a Plug under my Bike and I have no Idea what it is for...
  118. Fuse intermittenly blows
  119. Dead battery
  120. Re-wrapping Wiring Harness
  121. no spark
  122. Electical shorts - what wires go to ground
  123. Lamda or Stoich?
  124. Stator?
  125. Need advise
  126. PC3 if already SERT tuned
  127. 64 Pan Battery Connection
  128. What is the easiest way to take off my exhaust?
  129. Need help with my 2008 Dyna
  130. V INERR Error Code on Start-up
  131. High Low switch issue?
  132. HELP! voltage regulator?
  133. 06 Street Glide Idles 2500 to 2800
  134. Bike just quits
  135. Bassani Road Rage map
  136. PowerCommander Tune
  137. Another VSS Issue
  138. V&H Fuelpak or Dyno tuned?
  139. Front Brake leaves brake light on
  140. normal/hyper-speed turn signals
  141. Battery Cables
  142. Rear turn signal wire gauge FXDB??
  143. Power Vision - Oil Temperature
  144. 08 Street Bob washed up
  145. warning lights
  146. Will NOT STOP HESITATING
  147. Re-wired handlebars now brake light stuck on and no blinkers??
  148. Won't crank
  149. rear turn signal issues FXDB
  150. 07 Dyna shuts down
  151. TTS and cruise calibration...help!!
  152. FLHP Won't Start
  153. Electronic cruise control
  154. ECM for new-build
  155. Performance ignition?
  156. 2010 1200 spotster electrical nightmare
  157. 02 flstfi misses, cough out intake and stalls
  158. E-15 Gas
  159. Spark plugs not firing
  160. Heated Grips Keep Blowing Accessory Fuse
  161. Kellermann LED 1000 DF
  162. Best tuner within 250 miles of St. Paul Minnesota??
  163. missing under load
  164. 2000 Road King Issues
  165. question on PCV and dyno tune
  166. Power tap
  167. 2000 FLHTCUI Motor Hesitating
  168. Thundermax ECM shutdown
  169. i think my dyna is pinging
  170. 90 Electra Glide Electrical issues
  171. '92 Sporty, starter wont crank. Plenty of juice..
  172. Like a good challenge - RCK won't start
  173. 08 FXCW won't disarm but will arm!!!!!!!
  174. Hd led wiring ?
  175. 2011 Heritage throttle stuck...
  176. Curious behaviour 09 FLHTC
  177. '06 HD Deluxe won't start
  178. P0113 Code
  179. PC-V+ Auto tune.. No engine temp indication
  180. 05 sportster won't start
  181. new power vision - no map from Fuel moto?
  182. No brake light
  183. Head Lamp Life
  184. Shovelhead - problem static timing new Crane Hi-4N
  185. Colorado Tuner for 2012 with Pinging issues
  186. question on ECU possible reflash
  187. Replacing the TSM on a 94 fxstc
  188. Fuel Pressure Issue
  189. 2012 SG LED headlight.
  190. Check engine light on and slight loss of power
  191. security system assistance
  192. Voltage drop, battery and check engine light on
  193. PowerVision LogTuner Basic Help - recording values
  194. DTC codes 2010 FLHR???
  195. Starting
  196. Testing ignition module and pickup/sensor
  197. 2009 dyna superglide backfire-stall
  198. Ignition
  199. No power to coil. Please help!!!!!
  200. Too much Voltage
  201. Tail light not working!
  202. Taillights/Running lights problem
  203. Brake Light Out
  204. My bike shocks me.
  205. possible fuel injection problems
  206. Bad stator=engine heat?
  207. Sepst Training DVD
  208. 1 sec Run after Smart Security System install in 2012 Softail
  209. Idle adjustment-can't find thread/post
  210. K & N versus factory
  211. Security problem...I think
  212. Pc3 mounting
  213. bad electric surges, NEED HELP
  214. My '07 RG won't start
  215. 2012 Blackline will not crank.
  216. Not starting ?
  217. popping issues
  218. leaving O2 sensors out for test ok?
  219. Boom audio Issues on my Road King Classic
  220. Ignition coil test?
  221. 1990 fltcu engine noise. evo
  222. Breakout Box
  223. rear turn signal wire
  224. V regulator or not?
  225. Wide glide no ignition
  226. Elect.Problem-starter
  227. Bike Cuts Off In Mid Ride
  228. power vision maps
  229. 2006 dyna efi. Help me diagnose
  230. i wanna change my efi to carb. i have a 99 flhtpi
  231. 1998 sporty turn signal module.
  232. need help with wet coil..........
  233. Turn signals don't work...
  234. Battery Life?
  235. tts master tune
  236. 1977 HD Low Rider turn signal issues
  237. General Battery charger question
  238. Stator Replacement...Anything else??
  239. Fi2000 PowrPro
  240. P0122 TPS1 Low error code
  241. backfires shutting off
  242. "Range" strangess
  243. TTS Mastertune
  244. Dynotune or autotune?
  245. Help Ride maxx
  246. 103" hard start
  247. Melted Poss and Neg Battery terminals
  248. need a education on 103 tuning
  249. Do I NEED a tuner??
  250. Throttle stuck?
