- Heat Demons on Apes?
- Ignition coil testing question
- 1994 Fatboy.....NEED HELP
- 06 SG with check engine lamp-3 seconds
- Is this an electrical problem?
- total electric power outage
- TTS vs SEPST - Software user-friendlyness
- weird brake light behavior
- 2003 Ultra blowing Maxi fuse
- New battery question
- 08 Street Glide Backfiring and will not run
- Do I need a fuelpak?
- Blending the VE Mastertune tables
- Key light stays red on "08 Street Glide
- Help
- 2010 street glide tri bar light problem
- Help! 07 Fatboy won't start
- 1993 883 is DEAD !!!
- What will i gain
- re-installing fuel tank sending unit
- Custom Build Harley(drag engine) Coil problems.
- Trouble w/ Auxillary Lamp Kit Install
- Electrical spark through linkage.
- 02' FXDL wont stay running
- Hiccups in a Fat Boy, 05, 88
- PCIII usb, tech questions / set up?
- Help with reoccurring codes
- HSFM Disarming issues with 07 Fatboy
- wiring for new bars-HELP!!!
- HD Code Reader
- A few questions on the PV Tuner
- which super tuner map
- Sert data record ?
- Need a map for 510g cams
- Sputtering
- HD stage 1 flash with o2 eliminator kit
- 2002 sportster
- No O2 sensors?
- tuner question
- Unplugged Ignition Module...Why?
- 98 Road King Speedometer Issue
- Ultra Idel Problems!!!!
- No right blinker& front stop light
- Stalling
- Voltage Regulator Hardware
- Turn signal alarm module
- FLHT Cruise Contol kit on 03 FLHRI
- Alternator not charging battery or providing power to engine
- Dyna s or dyna 2000i ?
- Starter shorting out
- Battery theory question
- Dyna TSM
- To PCV or Not to PCV? Need Advice
- Speedo mode changing and gas light comes on early.
- acc fuse popping
- Fuel Filter Cross Reference?
- 2008 ultra EMC
- Dynatek TC88-3 first impressions
- SE-tuner vs anything else?...
- revolution performance engine uner
- 03 Ultra Idel Problems!!!!
- Cough through the intake problem...
- 48 + Fuelpak Speedo and IDLE problem.
- 2002 Dyna Charging
- 2008 FLHPI Police Road King
- Runs about 2 miles and no power/voltage..nada
- VIN number blank when trying to marry SERT pro
- PCIII Map suggestions?
- 07 fatboy misfiring
- RKC wiring question
- Ultra Classic 2010
- 4000 rpm start up and spirratic high idle
- Magneti Marelli fuel pressure regulator vacuum hose
- Custom Tune
- Stator vs. Voltage Regulator
- proper air fuel mixture
- timing for woods 555 cam
- how to install electronis speedo?
- race tuning stock motor
- 03 Ultra - Headlight/Passing Lamps Fuse Blows When Turning Ignition On
- no signal lights or brake lights!!!
- Chinese LED tail lights...no instructions
- Help..EVO cuts out momentarily
- 1997 Roadking Speedo Quit
- 2001 Roadking ECM replace?
- wiring for heartland 180 run/turn/stop
- Garmin blowing accessory fuse
- voltmeter shows a drop
- Dead on the Road
- Does ECM recalibration have an effect on Fuelpak?
- turn signal problems
- 1990 fxr not running right
- Who Owns A 1985 Electra Glide Classic Out There
- backfire on decel one cylinder. yes exh:gaskets ok
- speedo stopped working?
- voltage reg hookup?
- Turn Signals mind of their own
- backfire out exhaust at idle please help
- Ignition Timing
- 88 Softail Electrical HELP
- slow leak
- Starter dosn't engage properly Help!
- Tach wiring = HELP!!
- Engine temperatre sensor fault
- oil, fuel, air, volt gauges and headlight not coming on
- Is Power Commander really hard on ECM's ?
- Fuel gauge elimination after Speed/Tach combo install
- I miss my CARB. Please help.
- Best Tuner service in Austin, TX area?
- GPS Power question
- running lights
- Guage light is flickering
- 2007 Softail blown turn signal fuse
- 96 FLHRI.97 ecm running rich with red injectors
- connect tach to 2010 HD Road King w/ aftermarket speedo
- Turn signal electrical feedback -pulse (faint) opposite turn signal - front only
- Adding to HD Fuse box
- Problem with fuel gauge and low fuel light
- ultima starter
- Idle Control actuator
- Engine miss on 04 fatboy
- Warning: RideMaxx put me on side of the road
- New bike misses at time
- thundermax ?s
- 07 SG 103 SE Build-starting issues
- Dyno Tuner
- Ping not shown in logs??
- Electrical clicking noise, starting issue, lights issue
- Electrical issue
- HELP ape install, now no brake light turn signals flash 6 times
- Intake seals don't last
- Computer requirements for Thundermax Autotune
- Testing the charging system?
- replacing stator= replace rotor ?????
- Lever and the Brake switch
- Problem with Auto Tune 02 Sensor - Help!
- ABS light always on
- testing coil pack
- Power Commander 09 Touring problems
- Streetglide 2007 won't start
- Good Dyno shops? Vancouver BC
- fuel injection problem
- Blowing fuses with the start button
- need some advice
- taillight not working on 87 sportster
- 1997 FLHTCUI w/ 24K miles
- accessory fuse blowing
- four way flashers
- Total electrical power loss
- Load Equilizer for LED Lights? Do I need one?
- Help with some "noise" ?
- PC-V issue
- Speedo/Tach inop, no power to Power Commander
- Speedo/Tach Inop Key and Battery Light on
- How do I find a faulty ground?
- 1982 fxr starter/selenoid troubles
- Harley garage door opener for multiple bikes
- SE selectable map controller
- TTS MasterTune Forums?
- thundermax results ?
- Have to Manually Touch Starter Relay Connector
- ultra won't start..no speedo,radio,accessory
- darn thing just quits
- 5 inch speedo / tech problems
- Tail Light Socket
- odometer resetting issue - any ideas
- right turn signals not working
- How common is it for the rear brake light switch to go bad?
- o2 sensor eliminators
- 2010 tach inop
- need coil help
- diagnostics codes?
- programmer help
- Rear brake light
- pulling a little more headlight wire out now no headlight
- Are you smarter than a harley dealer
- Great Spark and fuel supply-won't start ???
- 2004 Fatboy Starting Issues
- TTS Mastertune map request
- Fuel Range & Start hesitation
- hi low switch
- Cylinder misfire at idle
- 2000 Ultra ..no start
- Bike Won't Start, TSM?
- 2000 night train rear tail light
- Cuts out with heavy throttle...
- Mt. Vernon,IL Dyno Tuner
- tuner and intake advice
- need help - SE super tuner vs PCV
- Starter connection problem..
- 2006 flhtci dying while riding
- ECM Map or FuelPak???
- Idle problem
- SE Pro Tuner Hookup Questions
- Bike stops running above 60 mph
- Need help with a few trouble codes related to brake swith
- Tts
- Charging trouble
- Electrical Help Needed
- Turn signals
- Help with Brake tombstone light setup
- 2002 RKC battery drain
- Dobeck TFI for a 2011 FLHX, infos?
- Engine light
- IVC Number?
- Help! bike will not turn over
- Smart Tune Questions
- Had a TTS tune and dyno but got it back and it is still popping and backfiring...
- Any insight on my starting issue
- battery change in FOB
- new FOB pin
- Problems with my 2000 heritage
- No Tach/Speedo when using SmartTune
- Battery Question 28ah vs 30ah
- Wiring Help Needed!
- Ignition Table PCIII usb
- Smart tune- now change the AFR or VE?
- 2004 Heritage Classic FLSTCI Tuner
- Quick connection HELP
- 2007 HD Nightster
- 2004 wgi won't start
- Going Back From MT8 to MT7?
- battery current draw
- Dyna ignition switch to Softail ignition switch help needed!
- Where is the TSM on a 1998 Fatboy?
- Just curious about my ignition system
- 1996 Sportster wont start
- 1976 Shovelhead ?electrical? issue, when in gear.
- 08 heritage efi question
- Smart tune questions
- Tachometer signal wire location--'06 Road King
- Boom audio
- Tuner opinions wanted
- Electrical Wiring Question- Grounding Wires
- Blowing accessory fuse
- Decel Popping and 0 throttle position
- Thundermax issues
- Looking for opinions on the V&H Fuelpak....
- Speedo don't work
- Tightening spotlight mounting nuts
- Tuning ??
- 02 FLSTCI still sputtters at low speeds after top end rebuild
- Need help with cv carb?
- Fender tip light out
- How can I wire additional signals (independant) with a run/turn/brake module?
- which spark plugs to use ?
- ECM Part number
- 99 dyna wide glide... no spark..advice please
- More than just the speedometer not working
- Single fire Crane ignition on a dual fire Harley?
