- Raising rev limiter on pc111
- SERT ???'s
- Turn signal switch
- starter jackshaft
- SERT map needed
- Headlamp/Bright Indicator Question
- FuelPak on '01 FatBoy w/BigShots
- turn signals dont stay on
- Wires in handle bar....Help
- S.E. Pro EFI Race Tuner
- Part # for J disc?
- Kuryakyn LED taillights question
- cruise control for SG
- PCIII, wont respond to faceplate buttons
- Quick Poll - 903 Recall Yes or No for Stock 07
- HYPER LITES?
- Harley download
- Ignition race tuner for carburated models
- H or J Map?
- LED Install-I want run and brake lights
- New Straight answer on Slip-ons
- differnce between the two?? help
- Speedometer cable question
- removing security system. fob hfsm alarm
- Daytona Twin Tuner EF Controller
- Backfire on Decel ??
- No rear turn signal/horn not working
- MMB Tachometer for my 2006 Night Train
- 2007 Heritage Softail FI Hesitation
- '07 fuel controller-to simple for me
- Anyone know where this goes to?
- so cal dyno tuners
- Need Spark Plug Help, PLEASE!!
- SERT (tuning unit) part number question
- NW Florida Tuners ?
- Tuning HELP needed ASAP - PLEASE
- Fatty shut down...blowing ignition fuses UPDATE :fixed it
- SF Bay Area SERT Tuner?
- Wanted: PC-III map for 98" stage IV build.
- Smart Siren II Install Question
- '98 E-glide No Spark/Start
- 2006 Heritage
- tourque smoothing 903 flash.....WORKS!!
- Fatboy Electrics
- plug check
- CB Install on HK Radio
- ECM access denied HELP!
- Engine quits
- Newbe help on 05 1200 custom
- what starter for a 96CI?
- Road Tech Radio Pinouts
- Best tuner and why?
- Professional SERT tuning scheduled, ? questions to ask?
- 2000 EFI popping on decel/shifting
- Another decel popping question...
- 1990 flhs starter
- Need SERT Map, 06 Dyna
- DTT O2 Sensor Issue
- electrical gremlin
- ELECTRICAL HELP NEEDED
- PC3 "stock map" realization?
- Can a starter relay drain your battery
- SERT have I got it right ?????
- accessory power (cigarette lighter)
- Where to buy SERT
- high beam indicater
- H-K v8.19 "Fixes"
- Ignition coil check out
- Rush 2.25/SEAC/SERT-anyone had it dyno'd?
- PCIII heres wat i got
- power commander
- Best reputable tuner in Tacoma area?
- Quick question about idle
- Stock tail light replacement-2006 Night Train
- 8 degree inj VS 25
- Fuse size?
- SERT P/C or FUELPAK for St/Glide stage II 95 Engine
- intermittent starting problem.... PLEASE HELP
- GPS power source
- 07 SERT canned Map vs Custom
- 2007 103 builds:Gas mileage for touring
- is the SERT a dealer tune or do you do it yourself?
- ch?'04 FXST rear brake light switch
- Happy SERT customer
- Fatboy battery drain.....
- SERT MAP
- SERT Data Logging?
- negitive cable
- PCIII fuel mileage
- Backfire on Deceleration; PCIII Settings?
- *Fixed*Problem w/Security and Engine Lights
- wego install
- 48mm H.P. Inc. Throttle Body...
- sert advice
- running lean
- help with kick start gears?
- ThunderMax
- blowing Accessories fuse on 06 SG need Wire diagram
- 2001 Road King EFI starting problem
- fuelpak, longshots, quite baffles?
- nd after Engine Starts But then Dies
- Do i need to retune
- need a sert tuner in san diego
- techie challenge
- could some one educate me?
- Odometer reads error
- ECM change
- Tuners in West Ohio or Indiana
- Switching from SERT to PCIII?
- Starting problem *XLCR*
- drained battery?
- Digital speedometer
- engine vibration
- Tuning Link Software Center???
- SERT Tuners
- home made pipes on 06, will it work??
- ecm retune for aftermarket slip ons?
- fuel pak??, ** INSTALL UPDATE*** 04/03
- Starting Problem
- HD Race Tuner No VIN Found Issue
- V & H fuel pak and hypercharger settings
- PC III USB - No maps for '06 95"
- Need a PC map 4 Fat Cats
- Dissapointing Dyno #'s
- PC dyno question
- A Good SERT Map for V&H Bigshot Longs & SEAC
- TC 96 Heat, Does Stage One Help?
- Do I need SERT, PCIII with no mods
- Turn off Gas Light - '04 Dyna
- Re-Tune
- Which base map?
- Which SERT
- PCIII USB ON 2006 FXSTS
- Does anyone have a SERT file for 2007 Street Glide?
- Stage 1 install ??
- Trouble Code
- $195 - 1-2hrs for a Good Dyno?????
- New Street Legal Power Commander EX
- Internal bar wiring on '06 Dyna - how to ?
- would like to get more out of my 07 night train
- Throttle Position????
- Power commander mapping
- V & H Fulepak on 07 Fatboy?
- Electric speedo wiring
- PCIII/AN BIG SUCKER installed....result
- GROUNDING POINTS OF 1989 1200 SPORTY
- Saddlebag LED/Spoilers wired as turn signals, too
- Electrical problem on '00 Nightrain
- harley intercom pinout on plug
- 07 Map Sampson True Duals
- Which Air Cleaner ?
- Tachometer
- Looking for a good tuner
- Are PCIII's compatable across HD models??
- Can anyone help me with engine check light
- Sparks from seat
- SERT HELP NEEDED
- 07 ECM
- Red Engine Light On/Off Without Loss of Performance
- Starter Clicks Sometimes
- Hard Starting Issue
- Security HELP!!!!
- Because i am new i cant post in the alarm section?? i cant program
- Screamin' Eagle Pro EFI Race Tuner #32107-01F ?
- bike won't start
- my tach is stuk
- Did I get the right SERT?
- Ign switch load eliminator
- Ultima Thunderfire 1.4 kw starter
- Low beam and spots not working, help plz
- Power Conmmander III USB/EX
- Dropped bike Won't start. Help!!!
- Brake light troubleshooting
- Changing CID
- Bad Hesitation At Part Throttle (EFI)
- PCIII revxtend
- Cruise inop 2001 Ultra classic
- Radio Volume
- whats a SE's Race Fueler
- PCIII Went TU?
- Ing. Switch
- Tail light wiring connection help
- VOES question
- No power
- Best price on SERT?
- S.E.R.T.
- Sturgis sert map
- Fuel Pak
- dyna backfire after cam change
- Cruise control on WG
- Loading Maps in PCIII
- ECM problem solved!
- sert packaged with missing hardware??
- Tail Light Fuse blowing
- Anyone running a V&H Fuelpak??
- Need a simple tune, what's best?
- putting stock pipe's back on
- Upgrade fuel injection
- changing the idle speed on a 06 fatboy EFI
- Need SERT Part # for 2006 FLHTCUI
- Aftermarket turnsignal ?
- Help!! Water in my ignition?
- Bike running hotter after service
- road king electrical problems
- Tuner needed in Colorado Springs area
- SERT Cable Length
- Power Commander / SERT / dealer questions
- Daytona Twin-Tec on 07 Trike. Anybody?
- 85 Sportster XL 1000 wiring Diagram
- need fuel map
- How to tell if the tuner worked?
- Lack of PCIII User Manual Info
- Did I buy a used SERT
- Sabin Perfomance?
- Auxiliary Running Light / Brake Light / Turn Signal Conversion Kit modification
- PCIII accell pump
- New PCIII Question
- Intermittend dead motor problem
- Won't start
- Fuelpak question
- Shovelhead voltage regulator @ 30 Amps?
- 99 Ultra keeps burning relays.
- Turn signals as brake lights?
- Bike will not start
- electrical noise
- Factory FLH Headlight Terminal Block
- Bike probs in Daytona..Do I need a new tune?
- PC III Throttle Position Question
- HELP Suddenly it won't START!!!
- Arlen Ness Big Shot Tuner
- 7500 mile and a Nudder Regulator ?
- Charging problems
- Starts and idles fine, dies when I gas it???
- PC111 Map Needed 06 ultra RH TD Big Sucker
- Power Commander Cables
- Installed SERT Today - WOW!
- Speedo help?
- blew headlight fuse and now neutral light won't shine...
- Idle ?
- Just replaced PCIII W/SERT
- pcIII USB
- Kuryakyn Panacea Tailight Problem
- Dealer tune or Fuel Pak
- A/F Ratio Gauge
- Fuel Injection swap
- need a good Connecticut tuner for sert
- Sert CD version "J" question
- PCIII - finding correct map
- clogged fuel injector
- Rev Xtender?
