PDA
View Full Version : Ignition/Tuner/ECM/Fuel Injection
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 [27] 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90
  1. Problem Starting
  2. Intermittent no start - electrical HELP PLEASE
  3. Quick question.
  4. ignition
  5. installing new equipment
  6. SEPST VCI Recording questions
  7. 538Amps on startup, can that be right?
  8. Power Vision Tuning Order?
  9. Fuel Gauge Wiring Difference Between 01 Carb vs EFI
  10. TTS - Reload stock flash?
  11. 103 - Good timing table needed
  12. Apache Choppers Dyno Tuning
  13. FP3vance and hines fuel system
  14. Stage 1 tuning a Supertrapp 2:1
  15. why couldnt tuner tweak the first tune?
  16. Why couldnt tuner tweek of the tune in my bike?
  17. DTC P0262 Front Injector High
  18. Procharger and Power Vision
  19. Run/turn/brake help!!!
  20. TTS - Change Base Map
  21. kuryakyn Mach 2 A/C Gasket
  22. reset adaptive fuel
  23. Air fuel ratio thoughts
  24. Run, turn , brake with LEDS
  25. Engine Flare At Start-Up (TTS MasterTune)?
  26. Roadking efi
  27. Vance/Hines FP3 help!!!
  28. mapping w/pc3 usb
  29. Incorrectly wired Sirius radio,wires smoked,now won't 'clutch in' start
  30. Spark advance
  31. super tuner map help
  32. PCV or SESPT for 2013 Street Bob
  33. How to tell?
  34. speedometer calibration power vision
  35. 1988 sportster 883 dreaded click starter not working please help!
  36. Lighting Problem...need help.
  37. Bike start running bad after 1 1/4 mile
  38. Sert Missing!
  39. Auto Tune: changing exhaust?
  40. My Review of the FP3 (the new Fuelpak)
  41. Connecting Heated Grips to Fuse Cavity 2013 FLHX
  42. Chrome tool box lock
  43. 2 issues on a rebuild of a 2000 883
  44. PCIII USB Map Help
  45. License plate light out
  46. Vance and Hines Fuelpack California Model Question
  47. simple fuel tuner recommendation ?
  48. (TTS) HD06 still shows "ECM Good" after loading calibration?
  49. 1989 FLH, No Spark
  50. Almost rode 2 miles...
  51. rear brake light switch
  52. Powercommander problem
  53. Decel pop...what is too much?
  54. magneti morelli to carb ignition swap
  55. 4 degree advance
  56. (TTS) Is there a way to view your Stock Map?
  57. TCFI IID Software and Firmware Needed
  58. Out With Fuel Injection
  59. Carburetor opinions, please
  60. Fuel Induction Removal-few pics
  61. need map 4 2000flh s&s509
  62. 2000 Road King Crank sensor?
  63. 05 Super Glide lights out
  64. running rough hesitant.
  65. Please Help! Bike dont start
  66. Power Vision on a CVO Ultra
  67. fades off idle
  68. Unknow wire
  69. New Strange Sound
  70. Intermittent stalling, high idle 08 Road King Police
  71. dyno tune temp
  72. Dyna Ignition Switch Issue
  73. Street Performance Tuner vs. Pro Super Tuner
  74. Coughing through air filter
  75. P1353, P1356 Codes
  76. Crank no Start condition
  77. 2009 Road King issue
  78. EFI Throttle body what is its maximum capacity
  79. Engint temp sensor
  80. missing, coughing, spitting
  81. 14 Iron 883 with Power Vision Lost Gear Indicator
  82. Starting File Help
  83. SESTP and ???
  84. Testing out a FuelPak
  85. New Regulator, paint sealed, where to ground?
  86. fuel managment
  87. Runs hard then cuts out at 5k RPM
  88. dyno time
  89. TGS Throttle grip sensor problem
  90. noob and power vision on a 2013 street bob need help fast nerves are shot
  91. noob and power vision on a 2013 street bob
  92. No Power to my Iron 883. Fully Charged Battery
  93. Why do I need a larger Throttle Body?
  94. lose the O2 sensors???
  95. O2 Sensor Voltage - What Does It Mean?
  96. Battery light comes on
  97. Pics of baffles after recent dyno tune
  98. Do I need it or not
  99. Powervision Mounted In Bag?
  100. idle issue
  101. Bike may already be tuned what to do?
  102. Rotor cup on 1200S?
  103. 2001 FXDL randomly dies
  104. Fuel tank liner
  105. power vision 2 on the way!
  106. Recent Dyno tune ?
  107. '06 Dyna FXDCI starting problem - everything went dead
  108. What base map to start with?
  109. Can Power Commander V INCREASE mileage
  110. 106 thundermax rough idel
  111. P0373
  112. Knocking noise coming from engine
  113. TTS O2 Sensor Voltage Calculator?
  114. Cruise control for 1986 Electra
  115. New Bung Placement
  116. no fuse box power from battery
  117. 2014 Touring Garage door opener
  118. Screamin Eagle Race Tuner or PCIII
  119. Tuner needed?
  120. 2007 flhx what's next
  121. V&H FP3 Tuner???
  122. Looking for PCIII map
  123. Squish & ping
  124. battery tender
  125. Dyno Testing
  126. First Harley starter problem.
  127. Advice On Connecting Starter Switch 2004 Deuce
  128. which cam
  129. Acel supercoil
  130. Pro Race plug wires & spark knock
  131. Cam position Sensor Replacement 2000 Dyna
  132. 2009 Night train won't start !!
  133. Dyna wont start
  134. Thundermax and V&H Throttlepak
  135. 2004 Deuce Won't Start After Removing Fuel Tank
  136. Power Commander - General Help Question
  137. When do I start AutoTune?
  138. Powervision tune needed
  139. Pc3
  140. Charging System
  141. NEED HELP with electrical prob. 2013 RK
  142. Rear Turn Signals and Dash Indicators Issue
  143. ECM Flash Tuner by Twin TEc????
  144. Does a tune 'drift' or slowly degrade?
  145. Lost speedo then digital odo, bang bang stop.
  146. horn question
  147. Lost speedo then digital odo, bang bang stop.
  148. 2000 Dyna SuperGlide Control Switch Harness
  149. 01 carb FXDL short to battery
  150. Looking for a tuner to tune my bike
  151. 2010 Street Glide - Extra Connectors
  152. Security System Recovery on Salvage Bike.
  153. Kudos to DynoJet PowerCommander tech
  154. PV and 2004 Road King
  155. Smart Security 4100021B
  156. starter relay or ignition keyswitch relay
  157. FI Questions
  158. 2010 FXDWG rear running light problem
  159. Tuner question
  160. tuner help
  161. Can Bus Shift Light
  162. electric fuel pump
  163. air fuel problem ?
  164. Tuner
  165. Power vision help
  166. 2010 heritage speeometer
  167. Power Vision - how did you run wiring?
  168. Will replacing your voltage regulator extend the life of your stator?
  169. Tuner Question?
  170. idle air control motor
  171. Fuel Injected Model Sensor Signals
  172. Disonnecting front turn signals
  173. Lo charging problem saga
  174. Code Help
  175. Quite confused here
  176. 2003 deuce exhaust exchange
  177. Tuning Basics Book?
  178. Digital Led Odometer/tripmeter repair
  179. Thundermax or powervison with autotune?
  180. Power Vision
  181. CANBUD HD Lan Help
  182. 05 road king classic dyno tuning
  183. Power Vision ? For Non 02 sensor bikes
  184. Garage Door Opener using Horn Button
  185. Power Commander III USB question
  186. Efi loading up??
  187. Squeak in fuel tank?
  188. Need help with rear turn signal
  189. Right to Repair agreement
  190. Changing Front Sprocket to 30T from 32T
  191. 03 FXDL Starts, warms up then dies and wont start again.
  192. New to me bike have a couple elec/tune ???
  193. The most basic tuner question, where do I start?
  194. PCV help needed please...
  195. Power Vision, Emailing a tune?
  196. Curiosity must be satisfied
  197. blown ignition fuse
  198. Starting issues Road King
  199. 07 street glide slow to turn over hot and spitting back through air cleaner
  200. Battery
  201. new guy with electrical problems
  202. Tach stuck on 2500 RPM
  203. Engine shutting down
  204. How to remove 2 pins
  205. throttle blade control
  206. Can I just get a power Vison ECM tune with out all the toys ?
  207. ignition problems?
  208. 2006 Dyna Charging System
  209. Install Phase 7 - 2 Wires What are They
  210. HD (Heavy Duty) starter
  211. Wierd Sttarting problem this morning
  212. Backing Plate Differences
  213. Handlebar Changeout Electrical Tool
  214. engine check lamp glowing
  215. tts cam tune data help
  216. Help, gas and oil pouring from ignition
  217. pro super tuner problems
  218. 72 year old Battery
  219. 6 pin to 3 pin ignition
  220. Horn Won't Work
  221. thinking of installing an AFR
  222. How can I check my Starter
  223. Best "Low Buck" tuner ???
  224. Electrical issues on a 99 Wide Glide
  225. Best S&S 106 Thundermax Map
  226. fuel moto power vision installation help
  227. No start 2000 Softail
  228. Wattage draw '09 & later Big Twin
  229. 2000 Dyna Speedo blanks out & Engine Light on
  230. bare bones
  231. PCIII USB Map needed
  232. AFR with Stock Sensors & Tuner
  233. help with tuneing file
  234. SEPST Question (viewing settings)
  235. Starting a 2010 fatboy in the cold...
  236. 2011 flhtk vs 2014 flhtk
  237. TPS Sensor code
  238. Squeak when I turn off the Bike
  239. Bikes and Batteries of today
  240. Dummy Fuel Gauges
  241. O2 Sensors For A Springer
  242. Tail lights not working
  243. Sportster 2005 - FOB - turns
  244. Buying first bike - Tuner Question
  245. Lever Action Solenoid
  246. Security Light/Shifter Gear Indicator
  247. Speedometer on stock '11 FatBoy Softail. How much off is it at 70mph?
  248. Stalling Problem
  249. lost fob ebay tssm
  250. WOLO Bad Boy Blown Fuse
