- Best plug fopr modded engine
- Terrible Decel Pop with Power Vision. Help!
- Bike died, left with intermittent buzz
- Kuddos to FuelMoto
- CA tuners
- Any hope in CA?
- Fm mapped dynojet pv and target tune
- Running 87 Octane Pure gas... problems?
- Looking at a 2006 FLHTCI with "bad induction module"
- 07 up smart security system
- FP3 idle
- Pv data
- intake port diameter
- Need a tuner that hold tune
- ERROR 41 on Dyna FXDX 2000
- your results with FP3 auto tune
- FuelPack3 connecting to Vance and Hines on weekends
- Drop In Fuel Pump
- Fuel Filter Canister Leak
- ultima usb program cable
- hard to start
- Bike runs rough, backfires, dies
- Stock air fuel ratio
- Fuel Moto Micro EFI Tuner Install Notes - 2012 Softail
- Where do I find maps for power commander 3
- Red security light staying on
- Do i need a programmer?
- V&H FP3 and Rush 3" slipon tuning
- SEPST compatibility?
- Harley orange performance tuner
- Random start problem
- Need PC-V map 08 Touring, SE 103" kit, SE 255 cams, SE Air Breather
- Tuners in SE PA
- throttle body
- Do models that come with SE aircleaners have different base maps?
- would high engine heat cause fuel pump issues?
- Se street tuner pro ve adjustment
- 07 ultra turn ignition on nothing
- back to stock after stage one upgrade, tuner and high flow air cleaner?
- EFI temperature range
- EFI vs Carb ignition
- Closed Loop Bias Table question
- Ignition switch wiring. Help!!
- Rear cylinder has no fire
- 2002 Fat Boy with EFI
- i have many error codes with the EFI. I am wondering on the best way to troubleshoot it.
- 99 883 Custom no spark
- 89 XL runs ok for less than a minute at a time
- 06 Electraglide blowing fuse
- Ignition left on for hours
- Starter button
- Question Re: air fuel mixture on Dyno chart
- Fuel pump - brand new
- Igniter/ignition module
- Really low Harley Stage 2 numbers.
- 2001 Magnetti Marelli fuel return line
- 1972 Harley Legerro 65cc basement find
- Rickey Carter
- Issues
- After TTS cal for 103 with 48h cams
- FP3 help! My 2014 RK won't start now.
- Chrome Back Plate with OEM Air Filter Cover
- Most cfm for 107 build
- Spark plug reading
- Stalling and popping
- New Key Fob
- Bike stalls out help.
- Bike dying
- ECM connector problem
- Efi identification
- Sportster no spark
- installing new tssm
- will a low battery affect my power commander?
- More power while the bike is still "cold" / "cold idle"? Or in my head?
- fuel pump and ECM
- Fuel Pump and ECM
- 2004 superglide help
- Intermittent Missfire 2004 Road King
- Codes on a 2011 FLSTC?
- Data log/intake Leak
- Question about recently purchased FXDBP
- Evo BT Timing
- Loss of Comms BCM codes
- Idle help
- Low beam blows fuses but not all the time
- Codes
- Looking for a Tune for Fuel Moto 107"
- Target Tune Install Question
- Will sepro street tuner work
- "Reflash aborted" SE Pro Street tuner
- Ignition switch
- Cruise control on a 1996 Electra glide ultra classic
- no spark after regulator over charged
- SEPST software update failure.
- Alternator Intermittent
- 98 Road King EFI no spark issues
- Fuel injection
- 2012 FXDWG 110ci: Swapping in larger injectors and throttle body
- U1300 low data
- PV1 box - broken?
- Deceleration kPa Value
- V&h fp3 help
- Tuner Question
- FI irrational idle
- Cobra fi2000R PowrPro Tuner
- Early model Vance & Hines Fuelpak
- Stage 1 tuning
- Haunted bike, no spark, no power. One thing after another
- Random shutoff. Codes: P1511, P2105, P2102
- Fork lock problem,2012 ultra classic
- Not getting fuel
- O-Ring Size
- Bike randomly shutting off while driving, help!
- Random shutting off while driving and won't turn over
- Problem With Ignition Switch???
- 79 Shovelhead ignition issues
- Another "no Spark" thread
- Scream'n Eagle Ignition mod.
- Remaining miles 'r lo'
- Crossover Fuel Line Size
- FLT2004 ignition to FXSTB 2004
- 2003 Fat Boy will Crank but not Start
- EVO - Moving to Single Fire
- High alt and pinging
- Decel Pop, just one, but its loud, Lean or rich??
- Sportster not starting
- Cold idle Fluctuates
- Fuel Leaking Quick Disconnect Leaking
- Sputtering/stalling
- STatic time evo dyna s
- HRS carburetor issues detonation
- Breather blow by
- 2009 Roadglide Dyno HP
- Won't idle
- Can you please read this spark plug?
- O-Ring size...fuel check valve.
- Powervision questions
- I need help with a S&S 107 with S&S Hi-4n ignition
- Colder plugs help with ping?
- 01 road King cranks but no spark need help with code
- IAC and TPS
- 2013 street glide
- Looking to identify regulator
- Rach and misfire
- Installing fuel canopy
- No Sound When Key is Turn On
- Fouled Plugs..barely runs..02 Road King
- 32114-01a
- No Power to the Instrument panel
- Boosterplug
- >>>>>>If you have a Tuner or Tuning Question post in the Dyno Room<<<<<<
- Ignition pickup melting
- 2010 ultra motor swap??
- 07 FLHTC misfire
- Fuel-filter replacement
- having some issues with my 13 streetbob
- 07 Harley Davidson street glide crank but no start, Help!
- Stage 1 upgrades and tuning
- 1995 Magnetti-marelli FI issue
- Newer to forum and bikes & looking for some help
- Tool to remove ignition switch?
- 99 roadking issues tuning help
- Mods 1st, then ECU reflash or Tune 2nd?
- SE spark plugs TP12 S
- v inerr
- FP3 Map Lookup - Exhaust
- 03 RKC EFI issue, Need Help!
- How can an FP3 revise/amend/fine-tune a canned Map when its been detached?
- Dyno Tune Worth the Money
- Check Engine Light-DTC P0118-Questions
- Leaking fuel from tank fuel valve
- B2176 Security antenna output open
- Exhaust gas temperatures
- Screamin eagle 31710-99 ignition kit problem
- 94 wide glide no spark
- FXDL 2017 PV P1505 Code
- Replacing a PC11 with ??????
- installing a Thunderheader?
- 2003 xl1200c no spark at coil
- 2001 ultra classic fuel problem
- Fuel Problem?
- 2000 ultra classic
- Neutral light stays on all the time.
- Not starting
- new key fob for 2006 FXDI35 Super Glide
- 01 Fatboy won't idle, electrical shuts off
- Not Starting but cranks. NO spark?
- NGK Iridium Plugs in stock TC88" 06' FXDLI results
- detonation issue
- Slow RPM run up and no power
- Harley heritage softail 2015 error code
- Bike hitting Rev Limit at 3-4K..
- 2014 fxsb - HIGH RPM and then no start - HELP !!!
- Tune request 08 Fat Bob 48h cams
- EVO Ignition Module repeat failure?
- 10Rg to 07 target tune
- 2008 Harley Fatboy
- First harley throwing codes
- codes 24 and 25
- 2007 Superglide Coughing on Start Up
- fuel moto header fp3 setting
- Gas? 87 or 93 octane?
- Power Vision - Making the 6 Pin Connector a 4 Pin
- About to get dyno in Atlanta area?
- New Member....1st Harley
- cobra vs power commander V
- Check engine p0107 after bar upgrade
- Hot Starts - Thank-you
- 2003 fatboy no spark
- Computer requirements
- One Dead Cylinder, No Spark
- Dynatek 2000 on EVO Softail
- Air Cleaner/Breather/Coils for MF F-Bomb + 43 LBS Injectors
- Intermittent Pop after Stop.
- 17 cvo 114
- New HD Tune Strategy question
- PV- AT Pro, timing run, MAP:L msg ?
- ran out of gas
- ran out of gas
- 2001 rk - hard to start, cel stays on, tach inop
- My 2003 fatboy
- 03 Ultra classic Mapping
- IAT question
- New Tune - Pinging/knock?
- Performance Above 4k... Autotuning?
- Ultima
- Finally got my bike dyno'ed, and it wasn't what I expected
- 07 softail deluxe "psspt" s=no rSP
- 2009 883 Not Starting
- Rev limiter
- igorj
- PV Tune for FM 107/B Heads/777 cams
- Low Fuel light not coming on - running out of gas -
- V&H FP3 for 2008 Road King where is best price??
- Return check valve
- E lp code
- Starter is not working on new bike
- Volt gage reads 10
- Bike will not start
- 2002 Softail EFI
- Fuel injectors
- 2002 Softail EFI
- 2004 Dyna EFI P1353, P1356
- Need TMAP sensor plug - female side -12 Street Glide
- My speedometer won't work!
- 1988 evo Sporty chopper wiring/spark issues
- Any good Mesa AZ mechanics?
- melted positive wire no power. how do i turn the alarm of to fix the wire and change out the battery?
- Power Arc Ignition
- 2013 dyna superglide help
