- TMax high rev on startup - fixed
- 2008 XL 883 Sportster PCIII Map
- Power commander install on a used machine
- Installed my PCIII tonight
- Hunting/Surging problems 2008 Heritage Classic
- Tachometer
- Vance & Hines Fuel Pack
- Battery Dying Affect Security System & Fuelpak?
- Pinging - Need a new timing map
- Average lifespan of a starter?
- Harley Download Question
- just quits?
- Thundermax poll
- breaker issues?
- p1510...p2138
- brake light
- EFI TO CARB
- Replace 8 Degree Injectors or Not?
- T-Max Basic Settings and Tuning
- Engine stalling at different time.
- kickstart with dyna2000 (dynatek)?
- Decel Popping with map change with SERT.
- Getting "BUS ER" when installin road zeppelin
- Virgina Race Tuner and Dyno
- front speakers not working
- big city thunder baffles
- ign map for carbed dyna
- Lighting question
- Electrical issues
- harley cone shaped air cleaners
- ECU/ECM Mapping and Tuning
- Tmax Experts
- O7 FATBOY PARTS
- Power Commander Question
- wiring a horn
- Selling my Tmax on Ebay
- Harley Amplifier Problems
- Question -New stator needed?
- Handlebar switches
- Voltage regulator gone bad 06 Sg
- burned up PC 3
- Passing lamp problem.
- Purge Tube Fitting?
- question about a replacement speedo
- Adding PCIII to SERT ECM
- Need stock specs for 06 touring bike
- Peak HP vs. Rev Limiter vs. Red Line
- Right turn signal problems
- 07 engine light question
- 1996 1200 xl intermitant turn signals
- How to disable auto signal light cut off.
- Power Commander III and EFI question
- STARTER PROBLEM
- Starter problem
- Need some guidance from experienced riders
- race tuner or ecm
- Power Commander
- Nightrider O2 IED's - Field Test
- Metal core vs. Spiro core plug wires
- Braided wire cover?
- HLY Dakota speedo has extra wire, help!
- Installed HD TSSM now fires once wont start
- Dyna TC88-1 question
- Clutch switch ???
- blinkers & horn
- tuners
- fuel pack???
- PC III Compatability
- Driver Info
- O2 sensor blanks
- Correct VOES for Evo
- TMAX Firmware upgrade?
- unbalance a tc88b?
- yet another sert question
- ECM Stage 1 question...
- Code p1351
- map for 2008 street glide. pow com III
- Battery discharged in 3 days
- VIN not found
- Where to install a PCIII on Street Bob?
- new jersey sert tuners
- Question for you Thundermax Experts
- Power Commander
- pc111 or thundermax
- pcIII adjustment for quiet baffle
- Desktop Dyno
- Is anybody happy with the Stage I download?
- SERT Self Tuning question
- High Idle
- SERT V4.77 FREE DOWNLOAD
- Map #78 V4.77 "L" vs V4.6.2 "J"
- SERT/PC
- Coil Question
- Can't get tmax decel values to load in module.
- Entirely melted negative terminal
- SERT file help please
- Changing baffles & SERT
- HD stage 1 dowload
- PC III blues
- Arlen Ness Big Shot tuner
- PC111 USB Sudden Drop In MPG
- Help...Need Molex connector
- H-D Batteries questions
- Totally confused
- Totally confused
- Which Ignition Tuner is best
- help install streached tank
- DFO VS POWER COMANDER VS FUEL PACK
- Power Commander III USB questions.
- Map for Dresser Duals? Help!!!
- Oil Pres & Air Temp plugs
- SERT's being shipped WITHOUT the cd!
- Fuelpak for softail
- 08 SERT help please
- Cobra FI2000R
- EGSTD with 120 ci missing badly
- 02 ULTRA INTERMITTENTLY DIES
- Retuning my hog. Need opinions on maps.
- FATBOB RACETUNER
- PLEASE HELP-garage door wiring on 2006 flhx
- Anyone know where to get a deal on a Thundermax?
- Do I need to dyno?
- SE Street legal slip ons - Need to remap?
- power commander or harley race tuner
- Hazard Flashers
- LOOKING FOR A SERT TUNER IN NEW ENGLAND
- front fender light installation-07' Deluxe
- T-Max for '08 Touring
- engine code
- Help with dyno 96 & Fatcats
- Turn signal disassembly
- Turn Signal, Brake and Horn quit working HELP
- new SERT for sale
- PCIII+Peacemakers: WHAT MAP I can install???
- SERT AFR question?
- Newbie Question
- CHECK ENGINE LITE
- V&H Fuelpak vs Power Commander III ??
- SERT Software Update
- Thundermax calibration of O2 sensors
- LC1 WBO2 Kit from Nightrider
- Fuse box help on an '06
- Turn signal keeps coming on
- LED sidemount taillight
- Electric help needed
- Yet another O2 sensor eliminator question.
- EFI Fuel Management Decision?????
- Enough juice for heated gear?
- DO YOU NEED A MAP FOR POWER COMMANDER 3 08 BAGGER I HAVE A FEW.
- speed odmeter
- Engine light / RPM goes up
- Headlight flasher w/button
- red top injectors
- Anyone hear of the RideMaxx?
- New ECM download??Same as SERT
- Screamin' Eagle Pro EFI Super Tuner
- The Ten Million Dollar question....
- Brake light, Turn Signal and Horn out
- Questions regarding Stage I, '07
- Silver Gauges
- Sert tables question
- Brake light on flhx
- PCIII options from Fuelmoto
- RevTech Spark Plug Wires?
- FXST 2000 DTCs
- SERT (2008) Version N Calibrations Online???
- Nightrider O2 IED
- Wiring Schematic please
- SERT Tuning
- 4.5 T-Max Firmware
- Accessing a Power Source
- Motorcycle Trailer Lights
- Which would cause more heat advance the timing or retared the timing?
- ThunderMax question
- Coil or not to Coil, that is the question!
- help! bike's a no go
- cruise control ?
- Need a Map for Powercommanderlllusb for an 05 FLHRSi.
- Replacing the AIR Filter
- Help reading my dyno run
- No power after starter install
- Does my bike have a power commander or a V & H fuel pack?
- TMAX VS DTT
- Cyl Head Temp gauge
- Power Commander II vs. Power Commander III
- 02 Sensor/ SERT HELP!!
- need your help
- Hogtunes vs. J & M speakers
- New HD self tune race tuner
- Tuning For BCT Baffles
- Thundermax on sale on ebay for $650
- Help Program Stage 1 SERT basic steps
- Smart siren problem
- Fuel light staying on
- ECM/SERT Question
- HELP!!! Fuse panel
- 211 cam
- dtc codes
- High Idle and Some Surging
- Will this rotor work?
- Wiring - Turn Signals to Running Lights ?
- To many Options
- ECM - Stage 1 and Tuning question Yet Again.
- Grating starter
- PCIII/power cutting out
- V&H BBS no fuel optimizer
- Battery problem?
- Question about spark plugs
- Touring re: Battery Discharge Voltage Levels
- Stage 1 without the bike?
- police eg stereo
- 08 FL security system question
- battery check light
- Rumble road speaker upgrade?
- Stage 1 Download help
- Speedo needle jumps when ignition on
- Electrical question - fuel gauge/low fuel light (06FXDI)
- ThunderMax question - Low performance
- NEUTRAL LIGHT MALFUNCTION
- Defective connector for Deuce LED tailight?
- 05 FXDCI cranks but won't start
- DFO/TFI or Fuelpak
- I'm sorry but 2 quick PC3 questions
- POWER COMMANDER CHOICES?
- Compu-fire charging kits and products?
- Please help identifying a connector
- sorry I don't know but...PC3 buttons?
- PCIII HELP.....
- Tmax First Run
- Code P1004
- breakout box
- ADJUSTING MagMarelli Air Bleed Screws?
- Has anyone updated to the latest PCIII USB firmware
- PC III vs HD Race Tuner
- SERT map sharing?
- Cams and Tuner
- Need help w/ TMAX tps timing adjustments
- transfer security system
- HQ 113" build
- 08 Touring PC III installed
- injector max pulse width?
- Size of 08 Throttle body on Softtail
- 1999 Sportster-where are my fuses
- just a small problem
- Questions: Base Map for 07 FXDC & 4.5 Upgrade
- Wire removal from connectors
- Super Glide Electrical...
- T Max Base Map Advise
- Best Stage 1 Intake
