- Tank fittings, Delphi/MM interchangeable ???
- 2001 roadking turn signal
- Factory ignition won't idle
- sert tuner question
- Looking for a tuner
- ECM update needed?
- 09 Heritage ignition fuse problem...
- I think I need a starter any tips?
- 09 nightster electrical problem
- dakotadigitaldirect
- 09 pipes on a 2012 RG??
- Going From Dual Plugs to single plug and Comp Release
- '88 sportster with a seemingly electrical issue
- best tuner for 01' road king/ magneti marelli
- What is this dial on my grip?
- Tuner question
- Sea foam nozzle sucked into air intake
- Evolution compression test
- fuel pak vs., Throttle pay
- charging system problem
- Stage 4 and up ...
- XiED with SEPT
- 08 Sportster running rough
- Problem Starting (Video)
- fuel pump wont run. Been trouble shooting
- signal lights failure
- Correct Plug and Gap for 77 Ironhead
- Confused on mapping option to use?
- Battery / starting 08 FLHX
- Starter just spins
- 2006 Street Bob Indicator / Park lights on while running
- Question: screws holding ECU stripped
- Charging problems, 1994 softail
- 08 E-glide...10 volts..intermittent charging issue
- Lights on after engine fires up
- What & Where Do These Leads GO
- Instrument wiring harness compatibility?
- HELP...no prime fuel pump and will not crank over.
- FLSTF Turn Signals
- Throttle lag. Power Vision and/or Throttlepak?
- Bootloader won't install
- Front Injector P0261 code
- Ignition circuit breaker clicking, wont start
- Blinker works and then stops working
- HQ 500/0034 cams and fuel map
- Sputtering and Popping Road King
- Dyno Tuned Now Battery Shot
- Auto Tune v SERT
- Turn Signal Stop/Run Light Module ? PN: 69462-06A
- O2 sensors inactive after installing Fi2000R
- what size is the 103ci softail OEM throttle body
- b2136 DTC code after installing Phase 7 headlight?
- need picture of 2007 Speedo connector
- stock hd ignition wiring
- Night train throwing O2 sensor trouble but bike has never had them!!!
- NO ideal!
- Map for CFR Pipes and SE Cam and SE Intake?
- O2 Sensor eliminators
- idle problem after engine work
- help me with my map.
- Glowing Images From Saddlebags
- Whine and Dead Batt
- ECM for S&S 124
- Engine Light on will not go off
- 07 street glide shut off while riding.
- Looking for sert cables or equal
- 94-95 Softail rear fender harness question
- P1511 code EFI power mgmt
- Pc3 map needed please
- Electrical Issues ????
- bike shut off while riding 2008 street glide
- Reading codes
- tachometer problems
- Flash tuner vs Piggy back tuner
- Right side turn signals and running lights not working.
- Questions about codes
- crankshaft position switch hitting something in engine
- Clock set
- Fuel Pak questions 2007 Ultra Classic
- Top 6 Data Centre Cabling Tips
- Trouble with my dynamic timing.
- Short in fusebox
- Looking for a PC3 Map for the Bagger
- supertuner map question
- I cant get an led light on my bike
- Map fine tuning
- Switch between tunes & baffles with SEPST
- Best dyno tuner around Minneapolis Minnesota
- Tuning my power commander III
- No Spark! Coil? Module?
- 6 gear light
- 1999 1200 W/dual spark plugs problem
- No dash panel power, engine does not turn
- Autotune or Laptop ?
- Weird sound when I cold start my FXDB
- chargin problems
- Help with Custom Dynamics Plasma Rods install on 2011 Street Glide
- Spark plug wire size, 2003 Sporty
- Power com v accessories ?
- Power commander v
- Fog Lights Switch ??
- 2008 Electra Glide Sputters
- Fat Cat Baffle Change
- Low idle ?
- cold idle adjustustment 1999 ultra
- SE Pro Tuner Have Canned Maps?
- 2012 RG going into limp mode
- Loading a map into Powercommander
- break up
- Look before you drill- bobber seat mount through backbone into wiring
- 07 Road king wont start
- Stator replacement
- 1986 Electra Glide Speedo/cluster problems
- Voltage Regulator
- 1993 flhtc electrical issues
- best price on the TTS Mastertune
- Problems with Regulator Replacement
- Is there really big difference between maps/diff slipons
- Chasing gremlins
- Electrical Problem NEED HELP
- Alarm or Security issue not allowing lights to come on
- Timing off?
- Etc
- BC Gerolamy???
- Using an XiED
- Is a Tune Needed After a Cam Change?
- what charges the battery??
- Louisiana Tuners
- Question about my 2012 fat boy lo
- Power Commander III USB Heritage 03
- Sputtering sportster
- Se pro tuner map ?
- Tachometer connections - Help Please!
- Power commander/auto tune/engine check light ?
- Overvoltage ? issues
- Started with just popping on decel
- Compression testing for XL1200S
- PCV +AT Installation Help
- Check Engine Light comes on, then loses Throttle
- Electronic Throttle Control not working
- 97 EVO rear cyclinder stops firing
- Question regarding battery use
- speedo sensor location - 6 speed tranny?
- 1990 Ultra cracks won't start
- Trouble Codes With Fuelpak
- limp home mode????
- Power Vision Issues
- HELP!!! Elect issues..
- Power Commander maps in Power Vision?
- 07 rk fuel consumption and popping question
- Cobra PowerPro tuner issues.
- 1989 FXSTC starter solenoid
- 2008 xl 1200c electrical drain
- Map for 2005 FLHTI and PC3
- 1998 Ultra Classic MM fuel line fix
- Side mount brake/tailight
- XEID advise please
- Frayed Wire
- electical question ?
- 04 Fat Boy won't start - P1004 code
- P0505 code
- street tuner
- Mid range rpm sputtering
- 2005 FLSTCI Backfiring
- How to save existing map?
- Dynotech, Las Vegas feedback?
- Blowing a fuse
- Harley Lighted Mirrors
- '06 DYNA TSSM causing ELECTRICAL/NOT POWERING UP?
- Help with possilbe fuel pump issues!!!
- Front brake line went to ground?
- Slip On Exhaust
- Recurring Error Codes - any help please!
- cost for this kind of repair?
- hand control wiring
- 2012 Ultra Limited Died twice today
- Mounting a Power Vision
- Throttle Body 2010 Heritage
- PCV (5) and ACR's?
- no throttle
- 2001 FLTRI possible short in wiring??
- Headlight Problem
- Help with S&S 124
- A few quick questions..
- No spark !!! Crank but no start !!!
- cables
- 1999 flhrci ecm 32423-99c help/info
- spits and sputters at 2000 rpm
- Strange Idle on 110 CVO
- snorkle for HD heavy breather- cant find
- Looking for a solid Power vision tuner in Iowa
- SuperDumb Battery Tender
- 80 Shovel Battery Cable Fire
- So is this acceptable????!
- If you disconnect the battery do you lose...
- Extra Connector??
- Fatboy 2008
- Fatboy 2008
- Fatboy 2008
- Battery Voltage Drop
- 01 softail standard
- power commander v map
- 2000 dyna not charging
- throtle issue
- Replace battery on fat bob 2012
- No engine check light on my '00 Dyna FXDX carb.
- Vance & Hines TC Adaptor (for exhaust valve)
- engine light on and off engine ideled way high 2002 efi road king
- Best Tuner for Future Mods?
- 3 phase stator test and odd results
- 2010 Road glide tri bar light
- Tac wiring info needed
- Speedo/Gauge Lightbulb
- Not starting- misfire through throttle body
- 2013 Sportster 48
- Headlight Pulsating
- Accessory position and lights question
- HELP -PCIII usb map 103", 9.5. Andrews 37b (SE204) for starters ???
- dealer download question
- Ichef4u
- Retuning Required If Baffle Removed?
- Freight train nacelle ...
- Dual runner
- fuse wire removal
- Sticks On Fast Idle
- Map question
- O2 sensors 12mm vs 18mm
- Weird= Left turn signal makes hazards?
- Check engine light
- DTC U1301 - Speedo and Tach Blanking Out
- need advice on wifes sporty
- 07 softail deluxe wont start...
- 10 electra glide startup issue when warm PCV
- PC-V without Autotune
- dash /speedo illumination
- smoke
- '02 FLHTCI shuts down when overheated
- Dyno Power Toledo
- 1998 sportster 883 randomly backfires and quits while riding it
- pv question
- Volume control
- Ignition switch Access or other? gremlins
- What's this?
- For Those With Power Vision on Bars
- Fatboy will start.
- 2001fatboy light issues
- HELP needed flashing ECM with power vision
- Speedo & Tach Lights stay on
- Heritage Softail DTC codes HELP
