PDA
View Full Version : Ignition/Tuner/ECM/Fuel Injection
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 [29] 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90
  1. '12 Wide Glide with PC-V stutters on acceleration
  2. 86 FXR Hard Start
  3. 2009 FLHTCU Automatic Compression Releases
  4. 92 sportster turn signal problem
  5. Eating Batteries
  6. Daymaker Headlight
  7. Stubborn silver bullet
  8. calibration file
  9. Road Glide to Street Glide
  10. TTS Maps
  11. Battery Mishap Help
  12. 2006 Ultra Classic Low/High Idle Stalling
  13. Bad Hunting at Idle
  14. 2001 EGC Error Code 31
  15. Accessory plug-in on '00 FXDWG?
  16. help with wiring 08 rear lightbar on 03
  17. Flashing Headlight, no signals
  18. Carburetor problem 1998 Evo
  19. '95 FXSTSB Re-ignition Issue
  20. Alarm system help needed please!
  21. Brake light headache
  22. help with code p1356
  23. 08 Streetglide Voltmeter
  24. battery sparking issue
  25. speedo problems
  26. hi/lo hid ballast
  27. Is the ecm choice this difficult?
  28. relay buzz
  29. FLHTCU Rear brake problems...
  30. Police RK Tach Plug/Harness for 67042-04
  31. 1996 FLSTC Starter Re & Re
  32. Carb Overflow Leak
  33. Melted battery terminals and bad service
  34. Harley - DYNA S ignition - how to connect
  35. Wont rev up.
  36. A miss in the motor
  37. voltage regulator
  38. 07 Dyna - Unusual Fuel Pump Noise and Fails to Hot Start
  39. Road King Electronic Problem?
  40. Brake light problem
  41. Signal & Horn not working on 95 FLSTC
  42. 80 shovelhead lowrider question
  43. 1980 lowrider timing
  44. Wiring Auxilliary lights.
  45. Fi2000 powerpro tuner?
  46. Is my crank sensor bad 93 EVO
  47. Lightbulbs
  48. Speedometer and Tachometer backlighting flickering
  49. 2000 Ultra Intermittent High Idle after Starting
  50. Gas Mileage Gone Bad After New Slip On Install
  51. Fuel smell
  52. rich fuel smell after hard ride
  53. Repairing Bosch connector
  54. Is this 'pinging'?
  55. ignition tune with cams?
  56. TTS Mastertune Base Cal Map for 2006-2011 TC96" with SE204 Cams
  57. O 2 Sensor Wiring
  58. 95372677.
  59. 2004 Ultra-hot battery post-cycling breaker
  60. One step forward, one step back... 82 shovel
  61. Strange things happening with 06 FLHTPI
  62. To Tune or Not
  63. 2001 flstc diagnostic codes
  64. after market odometer?
  65. Looking for turn signal answer
  66. Regulator/rectifier issue
  67. Best m/c battery 2 buy
  68. Electrical issue - dimming lights
  69. VSS wire colors or ECU pin number?
  70. $3300 to replace a wiring harness on 95 road king?
  71. The dreaded 103 PING and How I got rid of it!
  72. Cam Position Sensor
  73. Off-run and start button queston
  74. Trouble with Kuryakyn Panacea LEDs
  75. New guy wanting to fix his bike/learn something (Sportster won't start)
  76. throttle position sensor test
  77. code p1356 help
  78. PC IIIr
  79. '07 FLSTCI intermittent Idle issue
  80. Speedometer cuts out
  81. Remote monitor for TTS
  82. Need Help with Auto Tuner.
  83. Rear cylinder no fire code
  84. Power Commander V cable question
  85. 09 Ultra-rough running after restart
  86. Solenoid replacement
  87. 1973 Sportster – Starter Solenoid
  88. Engine (Head) Temp Woods 555 Cams Question
  89. 08 Softail stator grounded
  90. Time for a new starter
  91. 2013 XLC 1200 Sportster
  92. PC V 15-003 On a 2013 Road King
  93. 94 evo will not rev
  94. need fuelmoto 107" base tune
  95. Won't start
  96. Need a Tune for a PV-1
  97. 88 low rider turn signals
  98. Yet another headlight question . . ..
  99. How to adjust timing . . .
  100. Single or Double fire OEM coil
  101. SE Pro Super Tuner can it be un-married
  102. Help me interpret my Dyno MAP
  103. Help with SE pro tuner
  104. 2006 Ultra Clasic rough idle & slight backfire/pop
  105. Dyna is confusing and not amusing (p0502)
  106. Tri-bar problem (Help at 110th)
  107. 1995 odd starting problem
  108. Sportster 1200S Rotor Cup / Trigger Rotor
  109. Which o2 sensor goes where
  110. Installing O-rings on fuel filter lines
  111. 98 springer losing a cylinder?
  112. Fuel and timing
  113. Softail Light Issues
  114. Please help with stage 1 question
  115. BCM Code 62121 & 62173
  116. wired switches on bars internally now nothing works
  117. No start condition 2005 EGC, fuel injected
  118. Error Code P1357-What caused it.
  119. Stage 1 download or not?
  120. Speedometer not reading
  121. TTS Mastertune I (black) vs. TTS Mastertune II (blue) differences?
  122. New 2013 Road King - Need Tuner Advice
  123. Dyna help
  124. 2014 FLHTK Fast Idle Help Please
  125. Tuner or not/whos correct?
  126. 2010 Road King starting problem
  127. led turn signal help
  128. 04 Fatboy spark issues
  129. bike went dead. now won't start twin cam
  130. Everything went almost dead
  131. Misfiring and hesitates during acceleration
  132. Changing Air Cleaner
  133. ACC Fuse Keeps Blowing with Turn Signal
  134. Power vision how to tune with data log
  135. Help with Power Commander V
  136. Vance and Hines exhaust decel pop
  137. ignition coil relocation
  138. Best Tuner - TTS, Power Commander, Screaming Eagle ...
  139. Engine Operating Temp - Should I be concerned?
  140. FXDWG Data Port issue
  141. Strange part number on invoice
  142. Fm micro tuner mystery
  143. Joker Machine turn signal HELP
  144. Huge Favor....
  145. Need Help with 78 shovelhead firing on one cylinder
  146. Spitting back through the intake?
  147. Brand New Slim Running Poorly- Low RPM
  148. 2009 Fatbob starts by itself
  149. Little help please
  150. installing a USED Combination Digital Speedometer/Analog Tachometer #70900274
  151. questions about Power Vision
  152. Power vision help
  153. help about power commander v
  154. speedometer and odometer quits working
  155. 1987 sportster 883 loses power
  156. A big throttle problem
  157. Deutsch connectors
  158. 32111-13 information
  159. TBW question
  160. Heritage Classic Loses Idle - Why?
  161. Starting up problem. HELP eelcome
  162. Squeeze Clutch and Starter fires
  163. Vance & Hines FuelPak?
  164. Engine light in traffic
  165. I have some issues 2001 ElectraGlide
  166. Question on current draw on battery
  167. Stater issue on 2000 Road King
  168. Should I go ahead and get the Software for my SERT
  169. ignition timing
  170. Problems programming ECM using race tuner.
  171. PCIII and rear cylinder values?
  172. Please help me tune my bike with TTS
  173. Truble with Panacea lights
  174. O2 optimizers
  175. Installed Big Shot tuner and now fuel pump doesn't prime
  176. Elm327
  177. accessory connector part 91843-97 - Deutsch connector - what Deutsch part number?
  178. 99 EVO 80 Ignition question
  179. Cobra fi2000 versions
  180. voltage regulater
  181. Softtail Slim Exhaust upgrade + HD Dealer Dynatune
  182. Ignition systems
  183. Can anyone shed some light ?
  184. '96 FLSTC part ID please.
  185. Starting my 2005 Road KIng (Fuel Injected)
  186. No response!
  187. Thunderheart ignition - timing settings?
  188. Stator Failure
  189. '07 FLSTCI intermittent Idle issue
  190. Heritage running problems
  191. PV2 Question
  192. Cam upgrade questions '11 FLSTF 96"
  193. need help with issue
  194. Bus er comes up on odometer
  195. Weird starting problem - 2008 Fat Bob
  196. Screamin Eagle Pro tuner help
  197. Cold motor knocking
  198. Starter Question... can they slowly die?
  199. No Fuel Management Mods for High Flow Filter. Really?
  200. Starter won't engage when Bike is hot, Battery is good. Starter will engage cold.
  201. My Battery is Bi-Polar
  202. Intermittent charging system issue
  203. Road King died
  204. Road King Problem
  205. Lights added to FLHTC continued
  206. Lights added to FLHTC
  207. Security System Icon in On Bike wont start
  208. Stator or regulator
  209. '07 FXDL Starter and Engine
  210. M&m fi
  211. Marvel Mystery Oil
  212. fuse block location
  213. '13 Road King 33MPG with fuelpak?
  214. regulator or battery???? Help expensive!!!
  215. Street Glide Won't start. Help?????
  216. 71 Shovelhead breaking up between 25-3000
  217. SEPST Software
  218. 2009 Street glide engine died and will not start
  219. Could wrong dealer computer download 103cu into 88cu cause damage?
  220. Brand New Regulator Crapped Out
  221. Is Xied/ Vied a waste for my bike ?
  222. Power Pro fuel Mangement
  223. Pc3 map
  224. Split second loss of power, drops a cylinder.
  225. convert pcv maps to to spreadsheet
  226. Disconnecting oxygen sensors
  227. lose all electrical
  228. Wiring issue - brakes light up turn sig
  229. Lights Turn Off at Speed
  230. Throttle position gauge - Power Vision
  231. Indy Sez, PCV Does Not Change Igition Settings
  232. 2 Heavy Breather differences
  233. Ignition coil question
  234. Dual filament rear signals
  235. New saddlebag light wiring
  236. Power Commander Map Source?
  237. back firing and missing
  238. Warning lights
  239. remapping question
  240. Brake light question
  241. need current disc for Power Commander V
  242. Locating an Electrical Short
  243. Do I need ?
  244. This is a stumper help 1987 FXST
  245. Drop in voltage
  246. Neutral switch - poor connection
  247. Oooops
  248. power vision map request
  249. fuel pump supposed to run every time switch turned on?
  250. Question on plug wires
