PDA
View Full Version : Ignition/Tuner/ECM/Fuel Injection
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24] 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90
  1. Changing air filter size.
  2. Lambda Desired - TTS ??
  3. Heavy Breather VS Ventilator
  4. Cobra FI 2000 Power Pro and cam change
  5. Intermittent Starting Issue
  6. 07 sotail won't start
  7. Spark advance question / clarification
  8. check engine light came on with codes
  9. 99 softail key switch problem "fell out"
  10. Tunner help
  11. School me on Dyno Tuning
  12. Annoying 1800 rpm decel pop
  13. Converting '04 FXDLI to '08+ touring intake
  14. Unusual System Check
  15. Need Induction Module Kit Part # 27200003
  16. Looking for a map
  17. Recommend a tuning guru in WA
  18. Help needed with 08 Road King
  19. Revtech DFO question. HELP!!
  20. Tuner questions from new HD owner
  21. Issues with WINPV software
  22. Not sure what it is? HELP!
  23. HELP!!! 4 sensors showing on check engine check.
  24. Hi-flow vs Stock Injectors
  25. Misfiring
  26. Power Commander Problems...Not to HAPPY!!!
  27. Problem in my Dyna 2005 FDXCDI
  28. Sportster 883 down, throttle stuck open, now wont push start
  29. Help! 79 sportster starter solenoid noise
  30. spitting and sputtering off idle
  31. Won't start, dry plugs
  32. Help! Bike stranded me and I think it is the ignition switch
  33. Cold start Idle
  34. S&S VFI ecm
  35. Lower fuel mileage
  36. cranks great but no start
  37. Questions About SERT Software
  38. throttle control actuator connector pins
  39. Magnetti Mareli Problem
  40. One cylinder after restart hot.
  41. Component identification before getting tuner
  42. Engine and Battery Light
  43. Power Vision tune
  44. 2014 Deluxe Dyno results SE Stage 4 Race Kit
  45. at what mileage should I change my fuel filter ?
  46. PV Indicated Temp
  47. Cant get rid of front cylinder knock..
  48. Vance and Hines fp3 tuner in New Orleans?
  49. 2005 Vrod Module Set
  50. Road Kings runs a bit rough
  51. Power Vision "Speedometer calibration" question.
  52. Help! Battery cable melted' bike won't start
  53. oxygen sensor
  54. Error Codes 2013 FXDC Required
  55. Rush slip ons with se efi pro tuner
  56. Stage-1 Then Install Cams [TTS]??
  57. EV Timing
  58. Tuner and o2 eliminator installed...ECM engine light still on
  59. TTS MasterTune Accel Enrichment Table ??
  60. Please Help me identify this relay.. It's the only one that works.
  61. Understanding VE Tables and why need to adjust
  62. POwer commander V map help
  63. 1988 sportster 883 no spark, inspect my ignition sensor and rotor (pics)
  64. Hard starting Road King
  65. DTC code P0505 (loss of idle speed control)
  66. questions on a (bad) power vision dyno tune
  67. 2010 FLHP fuel cutting out
  68. 2011 heritage b2272 code
  69. 2014 fxdl vance fp3 advice
  70. 2015 Road Glide map/slip ons
  71. 2006 FLHX starter wont spin or engage
  72. 95 ultra with efi
  73. H-D SE Tuner vs V&H FB3
  74. Disconnect battery. Will this cause ECM to relearn?
  75. Searching for a Power Vision Map Sportster 883, Patriot Defender an Big Sucker
  76. ECM on a 2005 sportster custom
  77. Bought TTS, Then told no Maps - Not Happy
  78. Help! I need some gas for my 04 night train
  79. P0152 Code?
  80. Explain FL-XiED-10 to me?
  81. Switching from TSSM to TSM
  82. Do I need a new tune?
  83. Need help with changing out my tuner
  84. Power Tune Basic Auto Tune guidance.
  85. No Cruise/CkEng_Light/O2Codes
  86. Repost Difference between 1450 & 1340 Fuel Maps
  87. tc-88 timing question
  88. New SEPST softaware is available
  89. Power Commander V Status Light?
  90. best tuner for me?
  91. Looking for a GOOD tuner in the Atlanta area
  92. Bus er comes up on odometer
  93. Dyno tune
  94. Base Map for tuning
  95. Bike won't start, TSSM maybe
  96. Prof tune vs Auto tune
  97. Need help with PV map
  98. What is the 2 wire connector under the air cleaner for?
  99. Help. Posted in the sticky but traffic must not be high in there
  100. Starting problems
  101. crank sensor/IAT codes
  102. The Pv monster sticky makes want to cry!!!!
  103. Difference between 1450 and 1340 Fuel Files
  104. Streetglide surging
  105. PV tuning HOT when cruising
  106. Possible fuel problem
  107. No runability
  108. Fuel Problems 2004 FLHRI
  109. Fully Charged Battery..no ignition?
  110. 1632 code
  111. O2 sensers put in wrong bungs? (backwards)
  112. P0108 & p1353 codes
  113. 52mm throttle body
  114. 2000 road glide engine code issue
  115. DynoJet s*cks, I need a Thundermax
  116. 2013 Roadglide
  117. 2013 Roadglide
  118. FXDF! There are questions! The help is necessary!
  119. Type of tuning
  120. Terrible dyno results
  121. No Spark to start 2013 Rdglide with stage 4 race kit
  122. Quality Dyno Tuner in Arkansas?
  123. in need of a map
  124. cobra tuners
  125. how to use PowerVision on two bikes - "Dual License"
  126. Remove Ignition Coil - 2009 Rocker C
  127. Fuelpak and/or ECM problem
  128. misfiring and stalling suddenly
  129. running like crap with fuelpak after ape install NO CODES
  130. PCIII USB settings for Arlen Ness Inverted A/C and Rinehart True Duals
  131. Power commander usb map request
  132. starter issues 2010 electra glide classic ultra
  133. Fuelpak3: Auto Tune and decreased fuel economy
  134. 2003 Ultra stumble between 2100-2300 rpm
  135. reading and clearing codes on 03 carb Dyna
  136. Stage 1 tune, MSL to Elevation detonation
  137. Review of manual idle control for fuel injected Harleys
  138. twincam deck height?
  139. Anyone dyno a 14 LTD w Stage1?
  140. PLEASE HELP A GIRL OUT - bike starting issues
  141. proof positive my bike has been flashed? also, XIED info please?
  142. TMAX Injector Compensation Question...
  143. should a dyno operator monitor fuel pressure and injector duty cycle?
  144. Supertuner calibration for 2013 CVO Breakout with 1800 pro upgrade kit
  145. Should I run points?
  146. O2 cross talk???
  147. convert to points ignition 1982 xlh 1000
  148. Power Vision users (2002-2005) please read!
  149. low rider electrical problem
  150. 2005 Road glide tuner
  151. Ignition on 75 FLH
  152. 30% throttle?
  153. When gas tank is low on fuel the bike spits , sputters
  154. Finally bit the bullet..
  155. power.commander 5
  156. What to expect
  157. mystery gasket in Fuel Moto AC kit
  158. Open/Closed loop, AFRs & Power Vision
  159. Fuel issue
  160. Selling bike can I remove PV autotune pro?
  161. Spark plugs are not firing.
  162. Tts
  163. 2014 FLHTK ECM Tuning
  164. Confused about Techlusion/EJK from Dobeck...
  165. fuelpak fp3 experience
  166. cobra fi2000 tuner
  167. I'll travel 500 miles to find...
  168. New to Power Vision.. Need help
  169. 2013 fatboy running like crap
  170. Can't buy Super Tuner on sure?
  171. 09 FLSTC - no fuel pump - no starter
  172. PV Autotune - any driving tips for best data collection
  173. Night Train dies when given throttle.
  174. Screamin Eagle 50mm intake flanges
  175. Tuner in /near delaware
  176. Buying a used Power Commander
  177. Pc3 maps
  178. PV1 log tuning
  179. Cannot flash modified MAP with SEPST
  180. Quick shifter installation adjusting stock rod
  181. Powervision original map recall
  182. 1997 bagger efi idle too low
  183. 2006 dyna wide glide cuts out
  184. PC-V Trouble
  185. tts Ign timing maps
  186. No injection pulse
  187. 2013 fatboy HELP!!!!
  188. High Oxygen Sensor Voltage Problem
  189. 2009 Sportster 1200 Classic
  190. Installed AT110 fuel mileage dropped by 9 WTF
  191. 2007 Ultra Classic starting trubs
  192. Anyone used a quality Dyno tuner around modesto Ca.
  193. Fatboy runs fine for a while then dies.
  194. starting problem
  195. Calling All FLHX Owners With TTS Calibrations
  196. Dyna Low Rider w/ Power Vision and Autotune
  197. Help - Lost Power and now get decal popping
  198. Intermittent miss
  199. Sert 4.77
  200. Milwaukee area tuners??
  201. Dynojet Power Commander V
  202. 2014 iron tune issues
  203. 98 Fatboy grinding on start
  204. Bike just stopped on me.....
  205. pcv on a bike with sest stage 1
  206. vrod vrsc wide wheel tickover high
  207. v rod vrsc wide wheel abs issues
  208. How do I know if my engine has the SERT?
  209. red liquid behind tps?
  210. Bad misfire/backfire
  211. Screamin eagle 50 -54 throttle body on 107
  212. Bassani Road Rage and Screaming Eagle Ventilator
  213. PC-5 Map for 2012 Street Gluide
  214. Missing/Spitting on startup/idle - video inside.
  215. Power Vision - popping on decel
  216. magneto help
  217. Tuner
  218. 05 fxstbi fuel pump issues
  219. MAP Adjustment?
  220. Dobeck Gen 4 AFR Plus
  221. Magnetit Marelli replacement
  222. PV 1 Autotune basic
  223. High RPM upon starting
  224. Stage 1 and fl-xied-10
  225. TTS - AFR During De-Acceleration ??
  226. P0502 VSS High/Open Carb - would it make it backfire?
  227. no power on a 02 Dyna
  228. Superchips Review Submissions
  229. barry
  230. 2005 sportster 883. jetting question
  231. Screaming eagle pro
  232. PCV Map help...
  233. omaha/council bluffs dyno.
  234. Starter Grinds--Why?
  235. Canned map loaded with SE tuner
  236. Hesitation and PO codes question
  237. ? about ecm.
  238. Do I Need to buy the Auto Tuner AT-110 ??
  239. Which Tuners can Calibrate Speedometer???
  240. sensor problem
  241. PC3 with thunderheaders
  242. Direct Injection Engine for HD?
  243. Datamaster Spark
  244. ignition or fuel? help
  245. TTS MasterTune Calibration File for Fuel Moto 107
  246. 2012 ultra classic
  247. SEPST Map Request. '13 Softail 103
  248. Question About TTS or Power Vision
  249. Tuner ?
  250. ned help with power vision
