PDA
View Full Version : Ignition/Tuner/ECM/Fuel Injection
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 [89] 90
  1. Got-ur-done
  2. Vance & Hines Big Shot Longs and fuelpak
  3. hazard warning lights
  4. More on Chrome Voltage Regulator
  5. sportster passing lamp wiring
  6. turn module
  7. Dyno tune or bust
  8. Chrome Voltage Regulator
  9. Changing Screamin' Eagle Baffles
  10. Removing baffles
  11. Vibe rider
  12. Crane Fireball Hi-4e ign settings
  13. starter question
  14. Can the SERT be bypassed to use on more than one bike?
  15. Just joined
  16. Charging problem
  17. Parking Lamps problems.
  18. adding new Vance&Hines to my '05 FLSTFI
  19. se racetuner vs power commander
  20. catalyst mufflers
  21. Tail-light lens
  22. Sneezing and Backfiring on 06 Ultra
  23. cinister cycle(sp)?? in vegas........anyone use thier services?
  24. Wet Bike wont start!
  25. Electrical Issue
  26. Ignition Switch Problem
  27. Light Problem
  28. MOVED: '71 shovelhead
  29. running rich w/EFI?
  30. Internal Wiring
  31. Harley race tuner and decel popping
  32. Voltage regulator Output Ripple Waveform
  33. Stator Voltage Outptut Waveform
  34. stage one vs. stage two big bore
  35. Magic Temperature
  36. NEW STAGE 1 KIT
  37. I want to remove the battery from a sportster
  38. Is it a difficult job to hook up the Digital Gas and Battery Gauge Combo?
  39. Question about installing a GPS wiring.
  40. sportster eating plugs???
  41. Pipes Glow RED
  42. SE Ignition Race Tuner vs. Crane HI-4TC
  43. SE race tuner xl1200
  44. ROOKIE QUESTION
  45. Starting problem after riding awhile
  46. DFO/TFI
  47. VOLT METER
  48. setting timing
  49. Twin Power efi calibrator
  50. 2006 PowerCommander Maps
  51. 05 Ultra - really really poor gas milage (30 mpg)!!!
  52. New Exhaust and Mapping
  53. Possible Loose Battery Terminal
  54. Good Price For TFI/DFO Fuel Management System & More (new source)
  55. Accessory wiring harness 2003 Road kIng
  56. scared to upgrade
  57. SE Race Tuner
  58. EVO - What is your favorite Ignition System
  59. 06 TSSM Update Info
  60. Rear turn signal/brake light conversion
  61. Power Commander III...DIY???
  62. anyone (self)installed a efi race tuner?
  63. Check engine light came on
  64. Battery harness
  65. 2000 roadking no spark... no neutral indicator
  66. efi elevation sensitivity
  67. EFI Dynojet PCIII USB Accelerator Pump useful/useless???
  68. Electrical System Output
  69. More Stock Power
  70. Combo Spark Plug and Head Bolt Covers
  71. 88 FXRS Electrical Failure
  72. PCIII usb fuel accelator
  73. msd 8.5mm spark plug wires
  74. Fuel Injection Answers
  75. 05 FLHTCUI with PCIIIUSB???
  76. TFI/DFO Updated Info
  77. Starter Problems
  78. Fuel Gauge
  79. High speed surge
  80. Won't Start
  81. Tach pickup term.# 3--'04FXST
  82. Australian Closed Loop Fuel Control 2006 MY
  83. security keybutton
  84. Race Tuner Opinions
  85. Dead Battery and not charging
  86. Platinum Spark Plugs
  87. shorting out batteries help!!
  88. Speedo Problems (AGAIN)
  89. starter relay bad? or something else.
  90. Preserving battery
  91. Odometer questions
  92. Starter starts by itself ???
  93. 1993 FLHS Cruise Control Final Post
  94. extra lights
  95. Bad gas blues
  96. 1993 FLHS Cruise Install Part IV
  97. Stocker from stage 1
  98. No Voltage to Coil Plug
  99. 1993 FLHS Cruise Control Part III
  100. Throwing Diagnostic Codes
  101. Revtech TFI vs Power commander, and K&N fuelpak
  102. Wiring up fog lights to a HARLEY QUESTION
  103. 1993 FLHS Factory Cruise Control Part II
  104. Spark Plugs not Firing
  105. Front driven speedometer
  106. 2-part question
  107. 1993 FLHS Cruise Control
  108. 05 Wide Glide EFI dies while riding!
  109. Circuit breaker location,s ?
  110. sparks and breaker switch
  111. I need some help wiring my 1979 FXE
  112. miss or not
  113. Fuel injector stays open
  114. Rear Turn Signal Connector - FXST
  115. How do i replace a battery
  116. Power Commander install problem..
  117. electrical problems
  118. Confused about SEII Slip-on's
  119. Any one have the Electra Glo rider Footboard edge light kit(50743-04) and can show pics in the dark
  120. Aftermarket Indicators
  121. 93 sporty still not charging
  122. 97 softail ignition rotor and cam position/attitude sensor
  123. Updated stator questions.
  124. Power Commander Explained (PC III)
  125. 93 1200 sprtster charging prob .......
  126. cracked speedo lens
  127. Bulb Replacement
  128. Bike won't start
  129. '76 FX 1200 questions...
  130. Problems with `06 Ultra.....FYI
  131. check engine light
  132. 05 pc map for pythons
  133. Exhaust Temp Sensor Values *
  134. Speedometer Values
  135. Engine Sensor Values Chart
  136. Need Tachometer Help
  137. How long to Dyno Tune?
  138. voes switch
  139. Air temp sensor
  140. Dead regulator maybe?
  141. Wideglide won't start- HELP!
  142. Idle down issue
  143. Convert XM Satellite to Sirius Satellite Radio??
  144. My Forks Wouldn't Unlock!!
  145. Marrying NEW TSSM To Bike
  146. Starting Problems
  147. Road King break up
  148. hot battery softail
  149. DFO/TFI -PC III Comparisons
  150. neutral switch melting
  151. Problems Galore... Wiring this time!
  152. Rear signal lights - BRIGHTER??
  153. regulator
  154. Stage 1 or PC
  155. Custom Map?
  156. 2001 Deuce watt draw?
  157. HD Garage Door Opener Kit
  158. Backfire Galore
  159. Problem with my ignition module
  160. How to revert to stock map?
  161. Radio display stays on
  162. Single-fire Ignitions
  163. Handlebar Wiring Extension Kit
  164. 96 flhtcui efi idle problems
  165. Does you FI light come on briefly AFTER starting the bike?
  166. 2005 RK map question
  167. Is this thing possessed?
  168. Fuel Gauge
  169. 1550 15 th fat boy
  170. Kill switch died !
  171. all my lights keep going off
  172. Rear cylinder stops firing at random
  173. Battery Tender Jr.
  174. Engine code 16
  175. Question about big bore gas mileage
  176. intro.
  177. 2005 Jetting
  178. Vance and Hines fuel pak
  179. Turn signal light but don't flash
  180. Accessory fuse blowing
  181. Fried Ignition Coil
  182. Question about Stage 1
  183. Daytona Twin Tec Harley Scan Tool
  184. Turn Signal........ HELP!!!!!!!!!!!!
  185. Stage 1, V+H slip ons- Cause a Miss on warm days at low RPM
  186. Fuel Gauge Inoperable
  187. Auxiliary brake light/turn signal conversion kit
  188. Turn Signal Cancel Module
  189. Rev limiter......
  190. Ignition switch shorting on the frame
  191. SECURITY AND BATTERY UNDONE
  192. Sportster dies at all speeds
  193. Keeps burnin' out signal light bulbs
  194. Radio swap question?
  195. 97 Fat Boy engine misses sporatically
  196. Sony 5710
  197. PC for my RKC
  198. Turn Signal Question
  199. Engine light?
  200. EFI -running rough low rpm
  201. Fuses
  202. Speedometer Sensor Replace
  203. Ignition switch "sticking" FLHT
  204. Power Commander vs other systems?
  205. Help getting aggrevated
  206. remaping
  207. Electrical 12 volt power adapter
  208. Turn signal blinks when started.
  209. Overloaded??
  210. Speedo/Tach Combo
  211. question on power commander 3
  212. TC 88 Shuts Down
  213. Intermittent Horn
  214. Charging Problems Still
  215. Charging system
  216. Power Commander
  217. SE Stage 1 Flash & Security Code
  218. Starting / Light Problems
  219. After-Market Wires - Worth It?
  220. stage 1 map
  221. Roadtech radio on Road KIng
  222. brake light weird problem!
  223. 77 Sportster electronic ignition systems
  224. Ignition issue ?
  225. Weird Electrical Problem
  226. NO SPARK
  227. How to replace stator/rotor in FLHTCU evo?
  228. Electrical/charging question
  229. BEWARE THE WATER HOSE
  230. Backfiring after PC download
  231. Cruise Control Initialization, Diagnostics and Codes
  232. Cruise control kaput
  233. Check engine light w/ PowerCommander
  234. EFI trouble, bikes dead.
  235. 06 dyna will have 02 sensors
  236. Relocating turn signals
  237. Stage 1 complete.
  238. bad sensor connections?
  239. The Cobbler's Kid's Shoes
  240. ICM Update? Find out
  241. 05 Flhr, security light flashes at stop
  242. PowerCommander Accelerator Pump question
  243. Kuryakyn LED woes
  244. voltage regulator
  245. That's all there is to it??
  246. Headlight Bulb Recommendation
  247. Power commander map needed Stage II heads, cams etc.
  248. 05 road king, security light flashes at stop signs.
  249. TFI/DFO Settings
  250. Circuit breakers 93 Heritage
