- Crank no start
- ECM Part numbers (have they all been superseded by 32534-11)
- Throttle Body question
- How much cross over is there between models (fuel injectors)
- Carb tank on efi "chopper" dyna?
- Idle up to 3K and No Throttle Response, Some Trouble Codes
- 2001 SPORTSTER 883 HUGGER no spark/dies when hot but lights still work
- Dynojet / Engine Codes P0132 & P0152
- Bad ignition switch?
- What is this part?
- Crossbones fuel pump not priming
- Retrieving CEL codes on 98 Road King FI
- Can not hear fuel pump prime, but bike runs fine
- Have power but motor dies at 14.5 volts
- Weird smell after plugs/wires install
- 2015 XL1200X Sportster 48 12,000 miles on bike
- Could my starter be bad
- Internal ignition module burning up and my 88 FXR
- Dyna starts for 2 second then dies
- Wont start hot...
- My bike is starting strong then just dies
- limp mode
- Dyno tuning vs tuner brands.
- Fuel Injector Problem?
- Hot start poor idle/misfire
- injector size?
- Stage 1 tuning question.
- Fuel pump priming, leaking in tank video 2015 Iron 883
- 2002 Ultra Ignition Coil Replacement
- FLHX Won't Start
- FP3 for 2021 softails
- 1985 FLHT Hard Starting
- Vancouver, Canada area tuners?
- FP3 - ECM comms failure
- PV valve degrees to crank tooth
- Anyone familiar with TTS Calibration 176? tc88 For adding a 05 ecm with 02 sensor support.
- Does anyone have the twinscan Excel Sheets for the TTS mastertuner?
- Newbie With a Dumb Question
- 2009 Electra spark issues
- SE Race Tuner Stage 1 selections
- ignition switch problem
- Unresponsive throttle,rpms stuck it 1500, check engine light on
- NGK iridium
- Is a tuner a good idea for a stock bike
- 2007 Ultra Classic issue help
- Power Vision Auto Tune?
- Auto Tune Again after Timing?
- Help! Electric issue
- Plug heat range vs mods.
- Ignition switch Wire
- Dynojet PV & WinPv update notice
- 2016 48 gasping
- 120 screaming eagle
- Bike cranks no spark
- 1985 FXWG Ignition module
- No spark in front cylinder
- PV & 2008 Road King
- Horrible Decel Pop on PV Dynotune
- Ignition Coil
- 2005 O2 conversion
- Screaming Eagle Pro tuner
- Power Commander V - Think twice!
- Power Vision with FuelMoto map
- ECU question
- Is this correct? TPS Sensor
- 2014 Dyna Low Rider Sometimes Starts
- Think my deuce is lean ?
- 2005 Sportster wont start
- 2007 FLHTCU diagnostic plug
- 99 Classic - DVOM testing
- FP3 Tuners seem to be hit and miss
- TC 88 Just Not Idling Right Need Some Help
- Can the Smoke mess with Range and Fuel Mileage?
- anyone has a good map for the 117?
- 03 Heritage FI
- Tuner Question
- 2016 Softail Slim FLSS S Code U0142??
- need 01 rk ecm
- 2001 Dyna Wide Glide Ignition Issue
- Bike Wont Start: Blinking engine, odometer, neutral lights
- Blinking engine light, odometer, Neutral light and oil lights at at the same time
- Key Fobs
- aftermarket tachometer
- Ignition help on 06 bagger
- 2009 ElectrGlide Classic Starts then dies
- Tuning out spark knock/ ping
- TechnoResearch tuning??
- New ECM Module for 2021 Bikes?
- FP3 map edited but not updated
- EJK didn’t fix problem
- Fuel injection Pre-Light
- bike not starting cold
- 2003 Road King AFR's much lower than ECM programming??
- 2nd Map for Fuel Economy
- Won’t start
- maps please
- 1997 Road King Bad ECM?
- Leaky Intake Seals
- Power vision tune low rider s 2017
- TTS Mastertune help
- Compression release specs
- 2006 Dyna Low Rider
- 1997 Magneli Marelli
- Revtech setting
- Different heat range NGK plugs
- Are all Stage 1 air cleaners the same as far as tuning??
- 883/ 1200 hooligan kit post install issues
- Autotune
- PV knock retard events
- died, no start
- Ignition switch replacement 93 dyna side ignition
- Replacement Injectors on converted SE110?
- 2018 Iron cough and stutters
- What coil for SE ignition module?
- UPDATED Harley M8 Diagnostic Fault CODES
- Random TPS code
- Ignition timing at idle
- Fp3 can't be used
- 06 Road King sputtering and misfire...
- S&S header tune
- looseing power
- Wideband O2 sensor problem
- Builders in Reno Area??
- Map Sensor O-Ring Seal
- Change it or leave it?
- Can a tune "slip" ?
- Power Vision tune for Bassani 2 into 1
- I want to unlock the TTS from my bike and use a Powervision - a couple of questions
- regulator with red/yellow/green vs 3 black?
- For Someone NEW TO RIDE-N-TUNE with the TTS and no screen to see while riding
- Cranks but No Start
- Ecm factory re flash
- Crank no start 2001 harley
- 04 fatboy fuel check valve
- Road King wont start
- Injector flow sheets
- Another Fuel leak question
- bought a used 09 crossbones, does it have a tuner?
- Possible fuel pump issue- Please advise
- ECM and Fuel pump fuses blown
- 2000 Dyna converting to EFI and ThunderMax
- System relay clicking
- 2018 RK stage 1&2 questions
- ‘09 Sportster Electrical/Starting issue
- DynaTek DSPT-1 Instructions needed
- 2011 Fat Bob and Throttle Position Sensor
- Backfire
- No Fire / sometimes
- Puzzled with DTC's
- TTS base map for S&S 124 with 64 intake and TB - 5.5 injectors, stock heads, two to one exhaust
- Ddt tc 88
- Fuel issues
- 2021 HD's and available non-HD tuners
- How much elevation compensation can the ECM handle?
- hard start won't idle well
- Detonation on 2015 Fat Boy Lo
- PO562 with a high idle. Need Help
- TTS MasterTune - Need Expert Advice
- boosted twin cam 96 ci did I fry something?
- Smart Tune Pro and a Stage IV 131 ?
- Ongoing Muffler Saga
- FAt boy not starting
- Cam position sensor starting to melt
- Bike wont start plz help
- S&S 113 with no power and a cracked coil
- code U1016
- my bike 08 ultra stated miss fire
- 2020 Street Glide Throttle issue
- Some one save this bike!!
- Twin cam ignition timing.
- 2006 Harley Electra glide ultra classic crank no start.
- 04 EGC intermittent codes, need help
- 2001 fatboy will not start
- Tuner needed for a carb 95" v-twin FXST Softail Standard.
- Ping / knock issues I can't get resolved.
- OEM Spark Plugs
- sputter/dies
- Was I Running Lean?
- Question on 2007 Streetglide
- Power Vision tuner 4 pin vs 6 pin
- clutch
- Bank angle sensor code?
- se pro vs power vision ??
- Acceleration Enrichment...
- Losing power on acceleration
- Decatted headers or free flowing muffler
- power vision autotune
- 2021 Low Rider S O2 Sensors
- M8s and "stage 1"
- bike so hot afraid to ride it
- Search hasn't helped, trying to find timing/detonation thread...
- Ignition module needs replacing
- Vance and Hines FP3 on California Bike
- Does the 114 Stock Ventilator Count as "Stage 1"?
- Molex connectors
- trouble codes
- Power Vision warranty question
- Power vision turn on.
- No spark on S&S V-96
- PowerVision And Hot Starter KickBack mystery solved
- S&S ignitions - old style rotary adjustable and pre-programmed modules questions.
- Security fob battery
- Fuel issues? But only when starting??
- Intermittent Engine Cutting Out
- SEPST Wants Me To Raise My Displacement
- Help! M8 stage II Fuel Moto tune problems
- need stock tune for PV 96' 2010 touring
- Strange results after losing my key and fob
- cam upgrade
- Taking a FP3 beyond its comfort zone
- ****Help!!!*** starter issues.
- Diff of NGK plugs
- M8-FXLR-HD ::FP3 vs Fi2000 vs PowerVision vs Thundermax Compare::
- 06 wide glide ignition gremlin
- M8 idea speed with PV
- SE Tuner and 2 into 1 exhaust
- BCM question
- Bored out 2000 Road King needs Help!!!
- 2021 Wideband calibration files
- Going bald from scratching my head
- Misfire - Backfire
- Can someone help me
- 04 egc tuning question
- Starter gear
- 2000 Road King - replace fuel pressure regulator “while I’m in there”?
- Sputtering and backfiring after cam, pipe, and TTS tuner need help
- Autotune pro powervision not getting hits
- Replacing Gas Tank.......
- TechnoResearch for 2021's.
- Etms with a t124
- Tri Glide starting issues
- Starter Problems
- General questions concerning VE Numbers and Fuel Injectors
- No fuel, I'm stumped.
- 1200 fuel injection EVO: the ECU and running a single cylinder
- 2013 stage 5 tire shredder and powervision tune
- 2001 Road King Classic Internal tank hoses
- Bike shut off
- question for those who have tuned built big bores w/pwr vision (hard starting)
- Intermittent Spin over no Start
- 2013 RKP cruise control - How to Activate
- Check Engine Light
- Bar swap
- Popping, cutting out, and then shutting off! pcv?
- Is there anything auto about autotune?
- 07 RoadKing CVO
- Ecu ?
- Causes for ACR low code
- Street glide tripping codes
