- HELP!! The Good and the Bad (SERT)
- Help! Electrical ? for my '00' softail
- brisk plugs
- Champion Spark Plugs???
- more 8 degree questions
- New 06, should have found this site earlier!
- Magneto woes....
- ? on SERT Flash
- Maxi-Fuse?
- New Cams and Pipes on a 99 Ultra
- 06 Race only Download
- Fuel Injector or Connector Problem?
- cv carb on ironhead
- Dealer Denied replacing 8 degree injectors
- Major Frustration...Need ideas
- won't start
- is it a must to have a sert or p.c.
- Which PC map?
- Ignition WOES
- LED Brake/Running Light Install?
- Voes Question
- leaning out a rich running 1996 Fatboy
- Sert map question
- Race tuner for carbed bikes
- Turn Signal Wiring Issue ???
- rear cylinder wont fire below 2000 rpm
- spot light bulbs??
- Thunder Max ,power commander III or ?
- ach opation. Any ideas?Tach inop
- Power Commander or Sreamin Eagle Pro Race Tuner?
- Yet another PC PC3USB Post
- Please delete
- 2000 Soft tail check engine light, need help
- Timing help
- Fuel Gauge Stuck on Empty
- speedometer, brake light, directionals not working intermitently. Solved.
- SERT and VIN
- How do I take this off?
- Dealer broke my bike((UPDATE))
- Removal of tssm on nighttrain what do l need to do
- 25 Degree inj. Cals....
- Garage Door Opener Kit
- Dyno Question
- Which PowerCommander MAP for 2005 Softail
- Overheating headlight???
- why is the fuse blowing?
- SE ignition Module
- Speedo / lights were going crazy
- stage 1,is it worth it?
- EFI-closed loop versus open loop
- Security (red key) light
- Fuel Injection and altitude?
- another 25 degree injector question
- HELP-No Front Turn Signal After Bar Swap
- where is timing derrived from 88B
- I need help with my SERT!!!!!!
- New Tank for 06 Street Bob - External Fuel Pump??
- Carb SERT
- More F/I stuff
- Race Tuner / Race Fueler
- V&H Fuel Pak
- Need help wiring passing lamps
- Problem starting immediately after shut down.
- 1975 Sportster WIRING DIAGRAM
- maine SERT/Dyno tuners?
- Wiring for Tour Fan Kit
- grounding to battery pos. problem
- High Performance Ignition System Question
- Do I have a lemon?
- SERT Question
- Hooker Headers 2ΒΌ" + Stg 1 on 06 Softail?
- 93 XLH1200 Ignition/Starting issues
- Best price for SERT???
- Galloping idle
- Cruise Control Servo Motor Life Expectancy
- Wiring Turn signals for 79 Shovel
- Phx /Mesa AZ area PC III tuner?
- Terry Components for Fuel Management
- Starter gear noise
- Engine turnover/starting
- SERT: USB to RS232 Cannot connect to ECM
- "flashers before starting"????
- No engine light
- tuning 05' SE Fat Boy
- KURYAKYN WIRE ADAPTER
- Getting 25 degree injectors
- intermittent loss of ignition
- Here we go again
- 2006 FLST Tach
- Which hot wire for passing lamps?
- PCIII w/ '06 8* Injectors & Mods?
- Idle RPM's
- Power Commander - Worth it for a stock bike?
- SERT Map Starting Point
- SERT maps - Injector Size
- Wiring through Handlebars
- Installed alarm, now bike will not run
- Light Switch
- Wiring diag?
- 2006 Dyna 02 Sensor Info
- Fatboy starter
- Thundermax ecm module
- Ignition table 1
- '06 download worthless??
- No speedo light, turn signals or brake lights?????? HELP!
- What is this clicking?
- Elec. Ignition Prob. !!
- Boston-area Dyno
- Ultra Classic short
- 02 sensor
- vib rider
- Preinstalled PCIII map
- How to tell what injector you have ?
- Decel backfire and...
- charging system
- a rich or lean map
- Tuning Fuel Injected Bikes
- cost of a stage 1 on a new bike
- V&H fuel pac for 06 Dyna
- 98 cruise cntrol wiring harness
- pcIII usb connection failure
- Injector Cleaning?
- tach on 05 1200 custom
- Crane HI-4TC or Daytona Twin Tec Adjustment
- HD Download and stage one breather ?
- Sert version E at Hale's HD
- SERT - MT5 vs MT6 File Format
- ecm fitting
- absolutely dead
- PC III install instructions
- Stage 1 and my Dealer
- 99 1200c /S E Ignition Model 32839-00
- SERT, what will it do for me??
- Starter Problems
- Is there a site to download SERT maps?
- Turn Signals
- H-D Pager for Smart Siren II
- What is the bore size on a 2005 SE throttle body #27600-01A?
- Relocating Front Directionals
- Using SERT and ECM on another bike??
- Lean motor question
- 8 Degree verses 25 Degree Injectors
- Re-wire for '04 DWGI Handlebars
- 8 degree original injectors.
- race fueller settings
- 2006 Dyna DTC Codes (Diagnostic Trouble Codes)
- Harley Remap?
- NO SPARK!!!!
- EVO Ignition Sensor
- S&S Intelligent Spark Technology
- SERT EFI VS Carb
- Thunder Max Ecm
- Check Engine Light
- Check engine light and PCIII
- turn signal switches
- program new security fob
- help--update--
- 25* injectors installed updates
- Checking TSM/TSSM Trouble Codes
- 1971 xlch sporty with starting problems
- Alarm Auto Enabling/Disabling
- wiring diagram
- Fuel Line Repair & Setting Idle On MM Systems
- Security light stays on?
- blue indicator light for high beam???
- Fault code 16 and 56
- wiring diagram 2001 dyna
- Which EFI System?
- Does this sound right?
- Race Tuner & Stage 1
- Is it worth it - SE A/C without pipes?
- 06 RK 25 degree INJECTOR ?
- TFI/DFO Setup & Installation (video)
- SERT Map needed
- Stage I download question
- EFI for the novice
- Map needed for PCIII
- CVO injectors again
- Turn Signal Question....
- To many wires!!!
- CVO Injector order time???
- How do you retreive 2006 Dyna trouble codes
- speedo flaky-killing battery
- Repairing snipped wires...
- Won't start after rebuild
- Sert part # question
- disabaling the security system
- o2 fat boy no start
- what have Idone
- Will lean-running w/ *8 injectors hurt me?
- SERT - Now what?
- Advice Needed
- Turn Signal Blues....
- battery
- Ignition Switch Question
- IGNITION SWITCH 2006 ULTRA PROBLEM
- LED turn Signal Lights
- new control module won't work?
- 03 heritage no timing advance/retard ????
- Night Train electrical output
- Electra Glide Radio Problem
- Modifying pipes, intake and cams - what to get performance..
- Ignition module wiring on a custom
- Tuners and Warranty Issues?
- Im confused about exhaust programs...
- Screaming eagle tips
- SERT and warranty
- Vance and Hines Fuel Pak
- where did you get your sert dyno done
- Understanding EFI Better
- 06 Fuel Injection from a Service Writer...
- Running lights/trun signals
- EFI Not firing one cylinder
- SERT Users Manuals
- idle speed on FLHTCUI
- ULTIMA 1.4kv starter
- I need a map for this...or at least something close
- SERT success at last!
- Tuning questions
- Brake Light Problem
- Road King died and want start
- Wiring diagram for 1999 roadglide
- what kind of spark plugs does everyone use?
- Stage 1 Question
- Dr. Dyno
- aussie vs usa
- New H-D download
- harley no-service
- SERT - need one
- turn signals on 98 Fatboy problem
- PC III supertrapp map
- EPA regs = Lean condition?
- '06 EFI/ECM service bulletin
- 06 RK FLHRI Cold Start Question.
- TFI Installation On 05 Bike (Video)
- Double duty turnsignals & ditching the taillight
- Turn Signal problem. please help
- 32107-01D SERT vs 32136-05A
- SERT and stock maps
- Error Code 25 Fixed
- SERT hardware
- Got my first Harley and my first...
- SERT - help with MAP
- Security Light on
- single fire vs dual fire
- Is it normal?
- paint code
- 06 RKC Just so lost ??
