PDA
View Full Version : Ignition/Tuner/ECM/Fuel Injection
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 [48] 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90
  1. 94 Lowrider custom loses power when hot
  2. TMax and Power
  3. 1989 sportster?
  4. 99 sportster 1200 will not start
  5. ECM test
  6. PC III fried!!!
  7. bike just shuts off....
  8. Ideas for Smoothing a Vibration with TTS
  9. erratic idle
  10. 2010 tri-glide running hot
  11. 03 FLHT CB Question
  12. O2 sensors with Power Comander V
  13. Speedometer interchangeability
  14. Left turn Signal Trouble
  15. Any one with a map download CFR slipons
  16. Fuel Injector Additives?
  17. Screaming Eagle Heavy breather...
  18. differance between hdi and mod
  19. Spark
  20. 2006 Ultra Classic blown headlight fuse
  21. Eng cuts out @ 4,000 rpm
  22. 73 sporty no spark
  23. Bike not starting
  24. HELP!!! Finding out what this wire does and where it attached to
  25. PCIII w/Decel Pop
  26. I have another post in the Dyna forum so If I am wrong for posting here
  27. Need electrical wiring advice - Not too bright!
  28. need new starter
  29. Clicking noise when turned over
  30. Tested my stator.. advice?
  31. Tuner in southern Indiana
  32. 1991 Sportster Turn Signals stop working
  33. Help: Late for work... Brake light question...
  34. Bike stalled at 55mph, now no power. Battery is fine
  35. 1997 Road King Police EFI help with no start, turns over but no fuel
  36. will not run unless choke is on
  37. 07 street glide
  38. Solid FOB key light. Bike won't start!
  39. trouble with starting
  40. 73 sporty- no rear spark
  41. PCIII USB vs. Fuel Moto EFI Tuner
  42. Really, Really Dead Battery
  43. pcIII map
  44. Turn Signal Module
  45. 04 road king flhr
  46. Spring Removal
  47. Oil light
  48. Noise in GPS from power outlet
  49. Help me understand coils.
  50. Dead battery killed something else....
  51. Got a tail light problem
  52. Speedometer doen't work
  53. hot restart issue
  54. Replace Factory Key w-KEY FOB Ignition Switch
  55. running terrible when cold
  56. Terminal Velocity 3 with cams??
  57. 08 softail high idle
  58. Newb with complete loos of electrical power on 91(?) ultra
  59. Magneti Marelli Tuner sugestions
  60. 02 ultra check engine light
  61. 07 FXDB is running rich with SERT, anything I can do to correct it myself?
  62. Ethanol vs Non Ethanol gas
  63. 2008 Electra Glide runs rough
  64. 2005 ultra with a miss
  65. power commander 3usb...timming adjustment?
  66. enough w/ starting woes!
  67. power commander options and suggestions?
  68. Screamin Eagle Ignition Module
  69. ignition change
  70. Problem solved, thanks for help
  71. 2009 Fatboy SEPST Stage 1 map help
  72. Alarm output low on bike with no security?
  73. Starts then dies
  74. MM injector specs
  75. sad day fer me
  76. New member needs help with ignition problem
  77. Need QUALITY Tuner in S/E Michigan or Toledo
  78. HELP.. electricl question. Have a friend broke down
  79. Which Power Commander Map should I use
  80. PC-V with autotune map switch wiring
  81. Home Made Tune
  82. Light problem
  83. Spyke Single Fire
  84. aftermarket tach for 09 sportster 1200c help!!!
  85. Alternator wires arching
  86. 1982 Shovel head hard tail near complete
  87. Need a good tech in the Puget Sound
  88. Bike loads up when hot idle
  89. 2002 Electra Glide Classic
  90. High idle problem, in need of help badly
  91. Please HELP! MM flat spot
  92. 08 Street Glide Check Engine Light Comes on in 6th Gear?
  93. BAS code wont clear
  94. '94 flstn
  95. Another MM Issue
  96. Headlight and rear light went out today after a bumpy ride
  97. o2 sensor unplugged!!!
  98. 6v vs 12v
  99. grounding coil
  100. HELP! I can't diagnose starting issue!!
  101. hazards not working when on accessory?
  102. 77 FXS wiring issues
  103. Starting 2000 Electra Glide classic
  104. 2007 Softail won't idle
  105. SE STage IV installed my map is not right.
  106. 2010 FLHX PC-5 Map
  107. 2002 heriage softail starting issues
  108. need some help on my tune, Power commander 3 USB
  109. cam position sensor
  110. 07 ultra charging trouble
  111. voltage regulators
  112. Sputtering When Hot
  113. Which 58mm tp to use??
  114. 55mm or a 58mm tp?
  115. 06 Street glide, conflicting info from techs
  116. Tuning Cost
  117. 2000 Heritage Engine Light
  118. Aux lights stay on
  119. If temperature of rear head is higher, maybe it make sense to attach fan to rear head
  120. P light in the tach
  121. Turn signals flash rapidly after 4 times at normal rate
  122. k&n air intake/cobra fi2000r settings
  123. Electrical Connector Suppliers?
  124. Pinion Position Problem
  125. speedometer 98 rk
  126. Vance and Hines Fuel pack
  127. hot weather
  128. Remapping requires Race Tuner???????
  129. Electrical issue anyone???
  130. Volt gauge question?
  131. low hp low fuel mileage
  132. 02 RK Decel popping, engine vibration, high idle, no codes!
  133. Diagnostic codes
  134. Bike dies during riding...help with diagnosis...long long post.
  135. ABS light
  136. Low Fuel light stays on
  137. 2007 Street Glide won't start
  138. running problems
  139. no spark at plugs
  140. A Must Have?
  141. Alarm bypass unreliable
  142. Still have stalling issue.
  143. Why do my hazard lights flash?
  144. 1990 electra glide fuses
  145. no spark at the plugs
  146. tts mastertune questions
  147. PC III on 05 Road King
  148. no spark need help
  149. Help with Auxiliary Running Light / Brake Light / Turn Signal Conversion Kit
  150. 2010 SESG electronic throttle dead
  151. Battery not charging
  152. 06 Night Train Dyno
  153. Speedo, tach, brake light and turn signal fuse
  154. SE Super Tuner Pro Question
  155. American Cycle Performance - Glen Burnie
  156. Suddenly wont start
  157. Battery Died WTF???!!!
  158. 1993 coil question
  159. 3PH compu fire voltage regulator
  160. Data Link and codes
  161. running lights
  162. 2002flhtcu bad mistake help??
  163. starter or relay bad??question
  164. Blowing 15A ecm power fuse
  165. Someone help.
  166. Lowering idle speed on FI bike.
  167. Closed loop, Open loop, SEPST and AFR
  168. 2006 FatBoy died at red lights
  169. Chopper/Bobber Rewiring
  170. k&n air intake intallation
  171. voltage regulator
  172. FLHTC Turn-Signal Dash Indicator Bulb.. Is That Really All It Is?
  173. 2000 Deuce voltage regulator question
  174. Installing an ACR harness with PC V
  175. Twin Tec and Autometer hookup woes
  176. 2007 Road Glide Acc. Switch Issue
  177. Throttle posistion sensor question
  178. 2000 Ultra Classic 22450 miles
  179. bike stalls riding down the road, re starts tho
  180. 2004 Road Glide turn signal problem
  181. Turn signal glitch driving me nuts
  182. I thought my circuit breaker issue was resolved...
  183. oil pressur guage works backwards
  184. MAP sensor
  185. '09 Softail Hesitates/Pops
  186. Electrical-Ignition problem, any ideas
  187. 2010 FLTRX Timing and Map questions
  188. Quick SERT question
  189. 1989 flhs just stopped running - lights out!
  190. 1989 FLHS just stopped running - like that help?
  191. MAP sensor
  192. Starter issues! ! !
  193. power commander 3 or fuel moto,s version?
  194. TSSM Question
  195. PCIII map for 06 Deluxe w/true duals?
  196. Map?? Pc iii
  197. scorpio alarm system key fob?
  198. Speedometer wrong at times
  199. 2001 FLHTCUI alarm system mood swings!
  200. SEPST experience and questions
  201. Blue Lightning Spark Plugs
  202. Early starter on 95 bike Jackshaft problem
  203. Replacing Front Stoplight Switch
  204. 96 Roadking acts up after warmed up.
  205. Efi bike only starts if throttle is wide open
  206. New Tune @ JD Cycle Works & TTS
  207. Passing lights
  208. Hiccup
  209. Throttle Body Valve Close Adjustment
  210. a big thank you!!
  211. Ness Stage II sucker Kit??
  212. which tuner???
  213. Engine Light Coming On
  214. Fuelmoto
  215. ignition timing
  216. Another sert??
  217. powercommander died
  218. maps for cams
  219. Daytona twin tec TC88 settings
  220. speedo, brake, tail lights short
  221. Hotfire High Performance Plug Wires
  222. SESPT Technical Question
  223. HELP!! 2002 FLSTCI Intermittent Won't Start
  224. 1998 Lowrider
  225. XIED innards
  226. SEPST arrived today
  227. sportster - loses power intermittent when riding
  228. 2 questions
  229. No Power on My '80 Super Glide
  230. PCV maps
  231. 883 sportster with no power
  232. engine light comes on during deceleration
  233. New RK owner needs part number help
  234. Strange Electrical Madness....please help.
  235. Question About Fuelmoto's Timing Strategy
  236. help with S.E.A/C kit
  237. cover
  238. electrical problems
  239. SE Ignition problem
  240. Rough idle and "sputter"
  241. fuel injection question
  242. ACC switch help!!!!!!!!!
  243. Simple PCV Question
  244. SEST question
  245. No spark, no fuel pump priming
  246. 98 1200 quits when hot
  247. Battery for BIG V-twin??
  248. Replacements for TMax O2 sensors
  249. Plug Color, Whats Normal?
  250. No spark screaming eagle ignition module
