PDA
View Full Version : Ignition/Tuner/ECM/Fuel Injection
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 [51] 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90
  1. Wy do threads disappear from this subject after a few days??
  2. ? on switchs for switching between maps on a PC-V
  3. Intermittent front cylinder firing.
  4. Looking for a good dyno tuner in mainly IOWA..on the river.. Wisconsin...Illinois
  5. Speaker noise with radio off
  6. SEPST Cord
  7. My lights stay on when I turn my ignition switch to accessories. or Left?
  8. How does the PCV handle the in between numbers on the various tables
  9. 01 RoadKing Electrical is DEAD
  10. Random Electrical failures
  11. Help with a ghost
  12. High idle
  13. Looking for a good dyno in my area
  14. Idle drops to 500 RPM, whats up?
  15. Best TTS canned MAP to start with for stage 1 ?
  16. TTS tune questions from a newbie
  17. Fuelmoto PCV ...... two for two
  18. Initial break-in canned map??
  19. SEPST MAP 2009 Ultra
  20. TTS on the Dyno
  21. anyone know what im talking about?
  22. Engine light coming on intermittently
  23. 88 FXR Starter Drive
  24. tuner wants to eleminate my 02 sensors
  25. Disarming the 2006 Alarm
  26. Disarming the 2006 Alarm
  27. TTS download...now no 6th gear light?? WTF??
  28. smart siern 2 FOB
  29. power commander III accelerator pump question?
  30. air fuel gauge
  31. race tuner hic up ??
  32. TMax Data cable?
  33. Nothing happens!!
  34. Pulling myhair out.
  35. Electrical Problem: turn signal, break light & speedometer
  36. Need a map for Bub 2 into 2 exhaust - for 09 vrod
  37. CB Interference - Popping and Crackle
  38. p0pping, spittin, backfire, missfire
  39. Pleas help do I need to remap my flhti
  40. Why no HD alarm avail. for 2000 RKC???
  41. pc3 on a 2010 motor
  42. 07 ELE Glide STD Battery.
  43. Trouble in daytona
  44. 103 is it enough ????
  45. Tuner suggestions - Greater Sacramento Area (California)
  46. Screaming Eagle tuner?
  47. No power to fuel pump
  48. Is it good a CV40 on TC96?
  49. Battery questions.
  50. streetglide headlight
  51. ThunderMax w/ autotune & Rush Slip-ons completed on 2010 CVO Convertable
  52. 40 amp test ?
  53. Tab Performance Fuel Manager
  54. PCIII map suggestion
  55. Harley Aermacchi x90/z90 help needed. Runs like crap.
  56. ThunderMax Feedback
  57. Fuel Pump Not Priming
  58. Starter Problems
  59. Transient Supression - Blown Passing Lamps
  60. Checking the throttle position sensor
  61. Anyone using HID Auxiliary/Driving Lights?
  62. Dielectric grease for Power Commander connections?
  63. New Build – Help question.
  64. blown fuse
  65. Need a PC III map
  66. dobeck performace TFI-EJK
  67. Fuel Moto EFI Tuner
  68. Question on auxiliary lamps on 05 Deluxe
  69. Please explain the rear running light conversion to me.
  70. changed front brake switch now blinkers
  71. 06 injected softail exhaust + stage 1 help
  72. Help with Magneto wiring...
  73. TuneMyHarley.com Question
  74. Led taillight suggestions
  75. TTS map CAA179-02
  76. 05' FXST (Softail Standard) Electrical Help
  77. Fuelmoto PC Tuner
  78. Ultima agm batteries?
  79. Sportster Speedometer issue
  80. Speedometer reed switch location? Also question about grounding speedo
  81. My 98 883 wont start
  82. 2007 FXDB Electrical woes
  83. Is the SE Pro Super Tuner worth it?
  84. Cobra Fi2000 from Cobra Exhaust
  85. EFI Tuning
  86. Issues Starting Up Bike
  87. HD fairing install on my RK; Can I make my own wiring harness?
  88. Need ignition help
  89. Tech link digital technician
  90. TTS Speedometer and Odometer Question!
  91. Good tuner in Texas
  92. Aux Power point not for FLHRIC
  93. 07 up Sportster and Dyna fuel pumps
  94. Vance and Hines Fuelpak....Remove it?
  95. Alternative to factory turn signal module?
  96. NightRider's XiED/ViED NB02 Gizmo question...
  97. won't start
  98. Smp ignition? Good or bad
  99. Ignition switch
  100. problem with turn signal lights!
  101. TTS Mastertune - VTUNE run question
  102. Anyone having a problem with their electronic key being dead and not starting??
  103. Installed Fuelpak and now have Alarm issues
  104. wireing help
  105. Way to convert MT6 to MT0?
  106. USKool Lines-Worth the price?
  107. Tach and Dyno
  108. tuner needed?
  109. Spark plug wire question
  110. Dyno tune in MI
  111. Which ECU Flash?
  112. Dyno Results: Rinehart, Stage 1 Ness, TTS, and tune.
  113. Throttle Body Question
  114. Thunder-Max or the like
  115. Spreadsheet.
  116. Finding the little booger called a "SHORT"
  117. Really need some help with the new SERT
  118. Ideas
  119. TTS Calibration Question
  120. Left Turn Signal Bulb Blowing
  121. PC 3 MAP for 96" se 255 Ness BS VH Big Radius
  122. AFR / Heat ?
  123. head light power fading
  124. SERT comparison to PC V
  125. battery dying please help!
  126. Turn signal, running light issues
  127. Power Commander throttle reset. Engine running or off?
  128. Blue plug wires????
  129. wiring connector question
  130. Personal Tuner
  131. Nightster doesn´t run after SEST.
  132. Good tuner close to KC?
  133. new signals wiring
  134. Good dyno tune in south KY/north TN area?
  135. Tuner in South Louisiana
  136. starting trouble
  137. flasher is not working
  138. Cruise Control Problems!
  139. 97 Road King - Ignition Issue - Need Help
  140. any tuners in the St Louis, MO. area
  141. Bike cut out
  142. heat
  143. PCV map for S&S 106
  144. efi map tune??
  145. Big Ovals on a road king is a tuner needed?
  146. HELP!! Main Breaker??
  147. How long should a battery tender be connected?
  148. ?? bout stage 1 ECM / SE AIR BOX& PC3
  149. Hows this A/F ratio look ?
  150. Audio headset Connection Problem
  151. Remove 2010 softail gas tank
  152. put new grips on...now no rear brake light?
  153. Dual or single
  154. Slow bike ?
  155. Very Strange
  156. no spark on number one cylinder
  157. battery connectors
  158. tuner info needed in ohio
  159. Need TTS help In South Florida..
  160. Help, dead sportster
  161. Installation of Harley Security System
  162. Needing PCIII Map HELP
  163. looking for PC-3 map
  164. Question for those of you with MasterTuneTTS (Hardware Related)
  165. Harley EFI Equipment
  166. Vance & Hines Power Commander III Failures
  167. Is my AFRs correct?
  168. 02 sensor
  169. Historic code- Input please.
  170. Cranking
  171. 2006 Dyna won't prime
  172. 2002 Heritage fuel guage
  173. installed 95 kit and cams-wont start
  174. fatboy that just stops randomly
  175. Please help. Front signal turns on randomly or when bike is reved.
  176. 2010 Injectors
  177. To tuners. Does AFR fluctuate?
  178. Found "Harley tuning" video on youtube
  179. air cleaners
  180. Reading Plugs on EFI Bike
  181. Xied to fix fuel inject woes?
  182. Fuel Regulator Housing
  183. speedometer problems
  184. Battery issues
  185. 2006 Road King Gauge / Speedo / Odometer not working
  186. Navigation
  187. It wasn't the coil
  188. Dyno Tuning Victorville
  189. '08 1200 Low battery dying
  190. ACC Fuse Shorting -Heated Hand Grips
  191. SERT vs. other Tuners?!?!?!
  192. Question about air cleaner changes
  193. 08 Fat Bob with 09 CVO Tach
  194. PC or SERT needed???
  195. SC air cleaner 09 Ultra
  196. Can the SE backplate cause my problems??
  197. ECM download question
  198. carbs
  199. which buttons do you push ?
  200. Replaced Battery - Bike Won't Start
  201. 09 Ultra Replacement Bulbs
  202. 2005 Dyna Low Speedometer 67403-04
  203. Starting problems
  204. Stupid Power Commander+Autotune question
  205. Question for a Tuner
  206. O2 sensors disconected`
  207. Battery question
  208. changed bars now bike wont start HELP
  209. Super Tuner software.
  210. H-D SEST Maps (09 Touring)
  211. AFR maps
  212. Problem with LED lights
  213. Strange Turn Signal Problem
  214. need some help
  215. Cross Bones Electrical Problem
  216. kill button NOT SWITCH wiring
  217. Fooling the ECM or just fooling myself??
  218. 05 roadking ign. cuts out
  219. TTS Master Tune Question
  220. Good price on TTS Mastertune
  221. Adding "back off" lights
  222. 1987 FXSTC hard starting..new batt and starter
  223. Down load gone
  224. Dealer Download or SERT?
  225. Automotive machine 105
  226. Replaced fuel filter 07 Ultra, now fuel gage reads full
  227. Heated grips - throttle side not heating
  228. amp connector
  229. 1999 flhtci fuel leak...need help PLEASE!
  230. Intercom. Does it work?
  231. Starting problem- '06 Road King Custom
  232. ***Mapping my Fatboy 03***
  233. Leaner AFR, later ignition? 100K miles wideband sensors?
  234. Solenoid Cover Question
  235. Horn Hookup --- PLEASE HELP
  236. Top end power loss
  237. stator
  238. Screamin Eagle ignition and coil
  239. Tuner Choice Advice
  240. Super tuner
  241. Help me to find small digital voltmeter, I will use it as temp. gauge.
  242. Road King 113 Super Tuner MAP
  243. Question for tuners.
  244. Disabling stock alarm and immobiliser - Help!
  245. Where does this go??
  246. SERT Training DVD
  247. Lights off while starting
  248. SERT/ ECM Meltdown
  249. Stock ECU AFR controler
  250. tachometer installon 99 dyna, anyone have a wiring diagram?
