PDA
View Full Version : Ignition/Tuner/ECM/Fuel Injection
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90
  1. Gear indicator and cruise control
  2. Please help. Codes P2300/P2303
  3. No Spark or Fuel
  4. Finally Captured a Smart tune File
  5. Obd2
  6. Wide band o2 sensor
  7. Best Websites to Learn About EFI Tuning??
  8. 09 sportster wont crank after wreck
  9. Screaming Eagle Ignition Tuners
  10. Thundermax Tuner firmware upgrade
  11. Fp3 sale
  12. 2001 heritage no spark
  13. Tick&die
  14. 2001 Fatboy will crank no fire
  15. No gas
  16. Returning bike back to stock tune with Screamin Eagle Pro Street Tuner
  17. SEPST Software question
  18. Changing Gear ratios in ECM
  19. FXSTDI won't fire
  20. Whaddaya call those little...
  21. Spark plug US/EU
  22. Diag4Bike / Diagnostic Tool / Looking for recommendations...
  23. 2K RK Injected, Cam Tensioner Upgrade with 203 Cams Hard Starts.
  24. Tuner Change Over Question
  25. RPM going up when clutch pulled in
  26. Powervision or Technoresearch- dyno or no?
  27. 97 RK EFI running to rich.
  28. BCM code
  29. Stage 1 with Stock Pipes?
  30. '17 roadglide (fltxrs) intermittent stumble pulling away from a stop.
  31. MyTune Software
  32. O2 eliminator for 2013 Softail
  33. 1200C Sportster Fuel Injected Stalling Coughing Backfire?
  34. 07 Dyna idle issues
  35. Coil/Ignition wire swap
  36. No Map for SE255 Cams on SEPST??
  37. Riding with Power Vision
  38. Need help with a timing map. 103HO 255 cams
  39. 2001 Electra Glide Wont Start
  40. Does tuning affect vibration?
  41. 2-2 to a 2-1 using same tune?
  42. How often do you change the air cleaner breather tubes?
  43. Help! 883 dying, lugging, bad!
  44. One thing after another
  45. SE Tuner Question
  46. Codes after cam change
  47. Idle cadence
  48. Looking for suggestions for fuel controller
  49. occasional code
  50. Dynojet PCV issue
  51. Uninstalling Power Commander V - trouble code issues
  52. Power Vision
  53. 05 fatboy popping when you crack the throttle
  54. Vance & Hines fp3 on a stock m8 questions
  55. My h
  56. Sportster ecm relocation?
  57. 09 Street Glide Throttle
  58. 70 sporty bare minimum wiring
  59. Xied For 2013 Slim, Uh Oh
  60. Can't Remember
  61. Need a tuner
  62. power vision vss settings/pulses/km help
  63. power vision vs se pro??
  64. Tsm 68920-07
  65. 07 SG. Power Vision install. Now throwing u1301 code
  66. 5k RPM on startup after SE high flow
  67. Screaming eagle auto tuner
  68. Any opinion on Arlen Ness Velocity Intake?
  69. Powervision autotune Pro Advise.
  70. PCV Maps for '04 Dyna with Ness Big Sucker?
  71. Lug adjustment
  72. How Remove the neck lock from the ignition switch???
  73. alternator stator life
  74. FP3 canned map for Rinehart 4" xtreme True Dual
  75. Thoughts on Fl-ViEd
  76. Q for the computer experts: SEPST
  77. Wondering what hose I pulled out.
  78. lost key fob and key
  79. Local Tuner
  80. 2001 Twin Cam EFI to carburetor
  81. Spark plugs and wires
  82. Breakout 2019 brand new - hissing sound from fuel tank
  83. Bought 41000008C TUNER FOR 2020 CVO TRIKE
  84. Terrible decel popping - tmax 2020 fltrxs
  85. Crank, no start
  86. Scan tools for 2020's
  87. M8 false knock retard?
  88. Looking for some wiring help
  89. Running rich, power vision help Please!
  90. ECU Tuned?
  91. SEPST Stage 4 maps
  92. Stoiciometric with methanol
  93. Need a tune for a PC5
  94. M8 124 startup map rich at idle
  95. 17 FatBoy S No Start
  96. Power Vision Gauges
  97. stock M8 107 tune
  98. stock M8 107 tune
  99. No start
  100. Opinions on Ignition Coils, please.
  101. thick gas smell (PV tuner)
  102. 2004 Dyna FXDI sputters and won't idle after warm
  103. Front cylinder intermittent firing
  104. FP3 or Power Vision
  105. Pv2 o2 sensor
  106. Harley PF4C TPS cleaning for evo's
  107. Will my RK run better?
  108. Ecm codes
  109. 2000 Road King Idle high after change of throttle cable
  110. 19’ 114 stage 1 TTS map help.
  111. Stage 1 better ?
  112. Can't clear the codes
  113. Fuel Light on Gauge Question
  114. Pcv
  115. your experience
  116. 2017 M-8 idle
  117. TTS V-Tune?
  118. South Carolina/Georgia Dyno Tuning
  119. Fat bob probs
  120. How do my spark plugs look?
  121. Bad map sensor ?
  122. 2018 RG 107 M8 High hanging RPM initial start + then low rough run after upgraded exh, a/c & tuner
  123. Retune after 35kw restriction
  124. Can't get ignition lock out 2014 ultra
  125. "P0113, IAT sensor open/high! error where IS THE LOCATION
  126. spark plugs
  127. 2013 street glide no fuel pump or engine turnover
  128. Engine dies when i shift to first gear HELP
  129. 2013 street glide no fuel pump or turnover
  130. 2007 Road King Fuel Injection Issue
  131. Worse Performance after Stage 1?
  132. 07 softtail custom, no fob, bought new one,
  133. Power to the Fuel Pump
  134. No power to fuel pump fuse
  135. Noisy Fuel Pump after Startup
  136. S&S Power Package 124 - Poor Gas Mileage
  137. Cam/Ignition Timing??
  138. P1003 and U1016 DTCs after adding PCV
  139. Did I mess up my PCV cable?
  140. Did I mess up my PCV cable?
  141. Power Vision Autotune Problem. Ideas?
  142. M8 Fuel Injectors
  143. No spark 99 road king carbed
  144. FP3 problems
  145. High Idle After Powervision Install
  146. Throttle Position Sensor Issue
  147. FXD starting rough
  148. SE Super Pro Super Tuner
  149. Dynojet tuning in Cincinnati
  150. FXR won't start
  151. 2007 Street bob starting problems
  152. '09 FLHRC Fuel Pump dead?
  153. Powervision invalid file
  154. I need some serious help with my ignition please
  155. wana strip parts before trade in ,,,,
  156. SEPST and McAfee issues
  157. ? Re 2014 a/c on a 2010
  158. High flow filter/Tuner questions
  159. HPI throttle valve sticking
  160. FP3 and Stage2 upgrade
  161. Won’t start !!
  162. Dynatek Ignition :icon_shrug: Which one?
  163. My Experience with the FP3 on the Dyno
  164. Cycle Rama CR 570-2 and fp3
  165. 2011 Ultra Classic SE stage 1
  166. 07 Fatboy dies when off throttle
  167. Stutter when accelerating fast
  168. Is there a map available from SE pro street tuner with V&H power duals and exhaust ?
  169. SE Super Tuner Pro
  170. trouble with tmax preloaded map.. anyone have a map with 777'?
  171. Thundermax - Rookie needs advice 🙈
  172. Probably a dumb question but....
  173. Engine light
  174. Faulty Speedo on new 107 Deluxe 2019
  175. coil is good no spark
  176. Question for Tmax users.. autotune and crank advance
  177. 2011 Fat Bob
  178. The fuel line disconnect leak...
  179. Exhaust pop issue. But not on decel?
  180. Exhaust pop issue . But not on decel?
  181. Tuners and the ABS modules.
  182. ACR Fell out. Is this common?
  183. Tune it or not ?
  184. afr gauge??
  185. M8 spark plugs.
  186. Do I need a tuner?
  187. 2000/2001 Magneti Marelli EFI problem
  188. Clueless in Oregon
  189. Clueless in Oregon
  190. Anyone have??
  191. '13 FXDF suddenly stalling at every stop - idling too low when stopping
  192. 98 Road King MM EFI
  193. 2005 CVO cranks, sometimes 3-4 times before STARTING
  194. restoring ECM to OEM
  195. Fp3 help ?
  196. TTS Mastertune
  197. Whats the best one
  198. Thunder Heart Performance
  199. Compu-Fire 20200
  200. Looking for a good tuner in the Phoenix area.
  201. does a stage 2 require bigger injectors ??
  202. 95 fatboy electrical issues
  203. Leak from fuel check valve area
  204. 2006 Electra Glide running on intermittent rear cyl.
  205. SE Tuner and no Stage changes
  206. Spark plug screw on tip
  207. Still Clicking.....
  208. Power Vision price dop
  209. Drained gas tank to empty, do i need to prime the fuel pump or anything prior to next start?
  210. Daytona Twin Tec question
  211. Is my tuner still paired to my bike?
  212. idle speed
  213. V E tables for s&s 475 cams
  214. Ignition possibly?
  215. Hose problem.
  216. 2009 Rocker C HELP!
  217. Starter issues
  218. Saving stock map with SEPST
  219. FP3 good enough?
  220. Cranks, won't fire. ACR Issue?
  221. Cruise control ?
  222. Tunning 2016 Dyna with FP3
  223. Base map for FM 110 Outlaw
  224. Limp Mode
  225. Power Vision table question....
  226. Twin Cam 88 swap EFI help.
  227. Zippers customer service is junk
  228. Tuner Question
  229. any 117" upgraders have an SEPST base map for me?
  230. DynoJet Autotune Question 2004 FLHRI
  231. Map for Super tuner pro
  232. Thinking of a Professional Dyno Tune and have some questions.
  233. Fueling 4.9 gm/s hi-flow injectors
  234. Starter Clutch Needed, What do you recomend?
  235. Trying to decide but need help!
  236. 2014 softail; motor shut down while riding. Ideas?
  237. 04 Deuce TSSM
  238. Screaming Eagle Pro Tuner help !!
  239. Difference between Street Tuner and Automatic Tuning Module (ATM) and just the V & H Fuel Pak?
  240. Poor Running after Fuel Sender Replacement
  241. PowerVision vs Professional Tune
  242. Help needed
  243. 2019 Road Glide Special, RS 468 cam, Fullsac exhaust, and FP3?
  244. tuner software on phone?
  245. Ignition Timing
  246. Which HD tuner for 2019 Ultra Limited
  247. What is a good tuner for mostly stock 04 EGC ?
  248. 2011 ultra target AFR help
  249. No spark need help
  250. How Much Benefit To A Stock Bike?
