PDA
View Full Version : Ignition/Tuner/ECM/Fuel Injection
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90
  1. 07 TC96"- Is my voltage regulator going out?
  2. Electra glide Ultra classic 2008 (TC96) - LIMP MODE
  3. 2001 Sportster 883XL aftermarket ignition install
  4. Random rough running tc88
  5. Throttle sticking when running only...
  6. Tune needed?
  7. 2021 Low Rider S - DLC Location???
  8. FP3 Issue
  9. Heated O2 sensors question
  10. V-thunder TC-3101 cam dyno
  11. Redshift 575 HELP!!
  12. spark ping
  13. Flashing ECU back to BONE STOCK.
  14. In need of 32423-99 ecu for 1999 ultra classic
  15. P0113, P0118, P0123 Sportster Codes
  16. 2020 Ultra Limited won’t start
  17. PowerVision Auto-tuning ride hard or easy?
  18. Plug wire question.
  19. 2002 road glide fuel pump
  20. TTS cam data, opinions.
  21. Not getting spark 95fxdl
  22. Ultima Ignition Module & Kits???
  23. m8 107 ss475 pv map needed
  24. Electronic Distributor Suggestions?
  25. replacing sensor plate on '87 883
  26. 5 pins in 6 pin can bus
  27. broken fuel rail
  28. Couple knocks showed up in PV
  29. ECU Failure?
  30. TC88 Ignition module alternatives
  31. Daytona Twin tec Ignition TC88 vs TC88EX
  32. Cables
  33. 71 XLCH wiring
  34. making the tc103 start easier... hints?
  35. full throttle problem
  36. 2021 California bike Tuners?
  37. Fuel Pak 3
  38. 93 flstc no spark
  39. SE Supertuner Software download & Web Based Training URL shutdown
  40. 98” Big Bore PCV Map Needed
  41. 2020 Road King Special FP3 issue
  42. Fuel pump will not prime/starter will not turn over
  43. Surprised by Fuel Moto
  44. PCV map for 88ci with Andrews 26 cams
  45. Sepst
  46. Cam upgrade issue 2020 SGS
  47. 07 FXDB street bob cold start problem
  48. 2021 Road Glide Limited Automatic Pro Tuning Module
  49. Rev limiter MM pc3
  50. Powervision II & the target tune
  51. 2005 Fatboy can i get rid of TSSM?
  52. Where to find my Fuelpak
  53. Is tuning needed when adding an air cleaner?
  54. Changed handlebars, now wont start
  55. Break in period PC V?
  56. Is Testing different maps dangerous?
  57. 2005 EFI RoadKing Sputtering.
  58. Fuel moto micro efi tuner
  59. TC 88 2003 module in 2004
  60. Fuel issues
  61. PCV map download
  62. 2021 Centurion ECM ready
  63. Hard to start cold/ check engine light
  64. Map sharing for PCV
  65. Back to stock ECM from ThunderMax
  66. Power Commander V
  67. Winter storage
  68. SE Pro Street Tuner cal files - new SE 2:1 pipe for softail
  69. Cali Fuelpak vs others
  70. Configuring PV not hooked up to the bike
  71. Help no power after about 3 seconds
  72. PV engine temperature gauge
  73. Thundermax fuel mileage drop
  74. I just discovered second tuner on my bike
  75. Debating on a dynojet power vision
  76. PCV and external Breather
  77. High RPMs on startup after loading Fuel Moto PV tune
  78. SERT Question 2003 Heritage FI
  79. Tuning Questions... SEST, Smart Tune Pro
  80. 2020 fxbb - fp3 - big radius - loose o2 bung
  81. NGK Sparkplugs
  82. fp3 issue ??
  83. Comprehensive tune
  84. Lean Early RPM after Dyno
  85. Less traction control
  86. Tuner for 03 Heritage?
  87. Best programmer to use
  88. Cannot get tts dialed in after cam upgrade
  89. Powervision WINPV table size?
  90. Target tune wbo2 reading at idle
  91. ECM Swap
  92. FP3 installed 2016 FLTRU
  93. Dyno recommendation
  94. At what point do I need bigger injectors?
  95. Starting problems
  96. Help winPV update client
  97. Wrenchers, I need feedback please
  98. Does this cam sound like it's off
  99. 2001 road king
  100. Starting problems-Electrical?
  101. Key & FOB
  102. Code reader for 2002 Softail with carburetor?
  103. 2021 bikes
  104. Tuner recommendation
  105. WIDE BAND O2 How can I tell?
  106. Extened cold cranking 2008 UC
  107. Help
  108. Forcing ECM record
  109. Streetglide knocking
  110. programming HD 32534-11 BLANK ECM
  111. 2015 Harley Sportster 48 Fuel Injected 2 wire Wiring help
  112. what to look for
  113. I finally did it, got a PowerVision tuner from FuelMoto
  114. TechnoResearch VCM-TR4
  115. High IAT, VE's coming in really odd
  116. Lcd Fuelpak on switchback
  117. harley air filter breather yes or no?
  118. '17 Ultra Ltd. IAC
  119. PC 5 from touring/dyna for a softail??
  120. California emission tank removed leads to bike not starting
  121. Removed california emission tank leads to battery code, now bike won't start
  122. will these SE2 mufflers fit my 2006 dyna?
  123. TTMS 2007 on 2005 wiring
  124. 2009 ultra/ Explain the pump/transfer tube interface , how it works ?
  125. Quantum Fuel Filter, can I trust it?
  126. Bad fuel injector?
  127. 1988 flh ci
  128. Throttle Body Wiring
  129. Deceleration pop
  130. Ignition module
  131. won't start
  132. is it worth tuning?
  133. 1995 flstf fatboy
  134. Need a link, Fuel Lines inside tank 2009 Ultra Classic...
  135. o2 sensors..?
  136. 2007 Streetbob , starting issues , bike won’t start
  137. 1997 FLHTCUI Cruise Control Part Number Advice Needed
  138. 01 Ultra Classic EFI issues
  139. 07 sportster 883 custom won’t run
  140. 98 road king classic cam sensor needed
  141. Replace a Power Commander 3 with Power Vision without O2 sensors?
  142. FI Question, SERT related
  143. Need OEM Spark Plugs 2009 Ultra...
  144. 1st streetglide
  145. 2018 flhxs 107
  146. Ignition System Went Out.
  147. Have good spark while cranking , not firing Code P1001
  148. Anyone recognise this ignition?
  149. Post Cam Upgrade 1st Gear Issue
  150. Gas smell post tune
  151. Mild '98 Road King performance
  152. 2019 fltrxs. Stage iii. Bassani. Smart tune
  153. stalling when cold.
  154. Dyna Super Glide 2006 1450 88TC - Original File Wanted
  155. Help needed with hooking up Ultima dyna 2000i ignition
  156. ECM failure/No Spark related?
  157. Converting over
  158. Problems starting
  159. No start issue
  160. Map vs. Dyno
  161. Frustrated
  162. Idle flare up with PV
  163. Ultima 53-50 Single Fire Ignition
  164. Used Dynojet Power Commander V
  165. Active exhaust control valve
  166. Fuel Issue
  167. 2016 dyna fat bob starting issues
  168. Interesting annoyance. . .
  169. Tuners on stock bikes
  170. Problem Starting
  171. sportster 1200 timing
  172. Do injectors go bad?
  173. Fuel injectors
  174. knock knock whos there
  175. M8 SE pro Tuner MAP Question
  176. 2020 Ultra ECU and Odometer
  177. Dyno tune or Power Vision tuner?
  178. Got a good map from Vance & Hines for my FP3 - Magnaflow Hitman and K&N Air Cleaner
  179. Will FP3 copy tune done outside the app?
  180. 103 TC Stutters hesitates at idle during warmup
  181. Fuel pump not priming - another one
  182. Purge 2016 FLHR fuel line
  183. Check Valve Leak at Tank
  184. New T-Max install, get ck light, no codes
  185. are tts can 6 pin cable same as screaming eagle
  186. my brothers please. help... lol
  187. Fuel Pak 3 gauges
  188. Will harley hardware work on big sucker ac for m8
  189. FP3 map for 09 sporty 1200
  190. BCM Options
  191. Electrical shutdowns again.
  192. 2015 street glide not starting
  193. Having Trouble Getting Started with the TTS Mastertune 2
  194. Can't program new BCM with TTS installed
  195. Gear indicator issue resolved
  196. low fuel pressure
  197. FP3 map with Fullsac
  198. Fuel pak 3 stuck in auto tune and app crashing
  199. Ever used a knitted hat to help tuning?
  200. Lack of power issues...
  201. Tumbler in Ignition Switch
  202. Tune after .030 head gasket/bump in compression
  203. P0051 code
  204. I have a choice of two tuners - not sure which one to go with
  205. 1996 Fat Boy burning ignition coils.
  206. Check Valves fit question.
  207. Power vision not being recognized by computer
  208. Xieds on a 114 M8
  209. Power vision new license California
  210. Running poorly, sputtering backfiring thru intake
  211. SE Pro Street Tuner Stage 1
  212. 07 wide glide
  213. PowerVision autostart in gauge mode?
  214. Question about 02 sensor readings .
  215. Which Tuner
  216. Hard Starting and Fuel Pressure
  217. Dyna TC88-2P device
  218. 08 E Glide/ PCV/ hard starts and unknown plug
  219. spark plug
  220. SC Tuners
  221. Excessive popping in backfiring on deceleration
  222. 05 FXTBI Night Train runs rough after wash
  223. Misdiagnosed charging issue
  224. ECM reset
  225. Throttle body 27985-11A work on 2012 FLHR?
  226. B2201 2014 softail deluxe
  227. Doing a custom build I've got an electrical nightmare on my 103 dyna need some need h
  228. Road King 2001 Won't start anymore!!
  229. Flex fuel e85/91/93 pump gas
  230. M8 CVO 2019 Cutoff PV tuner
  231. Help me understand DYNO tuning costs
  232. CVO 117 Stage IV
  233. Desperate for a simple answer...
  234. indy/dyno in Ct area
  235. Battery Tender PSA
  236. Anyone running a Thunderheader with FP3?
  237. Smart Tune info needed
  238. Idles hard and rough, no power 2012 FLHR
  239. 09 RK ECM module compability?
  240. 2002 ultra classic
  241. Iron 883 won't start after changing grips
  242. 2012 wide glide firing problem
  243. SE 58mm with ?
  244. 2006 Stage 1 Road King Issues and Questions
  245. Fuel Spray in Tank. Is This Normal? See Picture
  246. Error codes 1999 road king classic
  247. 93 dyna starting and electrical prob
  248. Ultima ignition hookup
  249. Fuel Pump/regulator/filter/ hose problem?
  250. V&H FP3 - "Not linked to this bike but linked to..."
