- Smart tune- now change the AFR or VE?
- 2004 Heritage Classic FLSTCI Tuner
- Quick connection HELP
- 2007 HD Nightster
- 2004 wgi won't start
- Going Back From MT8 to MT7?
- battery current draw
- Dyna ignition switch to Softail ignition switch help needed!
- Where is the TSM on a 1998 Fatboy?
- Just curious about my ignition system
- 1996 Sportster wont start
- 1976 Shovelhead ?electrical? issue, when in gear.
- 08 heritage efi question
- Smart tune questions
- Tachometer signal wire location--'06 Road King
- Boom audio
- Tuner opinions wanted
- Electrical Wiring Question- Grounding Wires
- Blowing accessory fuse
- Decel Popping and 0 throttle position
- Thundermax issues
- Looking for opinions on the V&H Fuelpak....
- Speedo don't work
- Tightening spotlight mounting nuts
- Tuning ??
- 02 FLSTCI still sputtters at low speeds after top end rebuild
- Need help with cv carb?
- Fender tip light out
- How can I wire additional signals (independant) with a run/turn/brake module?
- which spark plugs to use ?
- ECM Part number
- 99 dyna wide glide... no spark..advice please
- More than just the speedometer not working
- Single fire Crane ignition on a dual fire Harley?
- Need help Setting up PC USBIII
- Fuel filter change manual is wrong
- looking for ballpark ideas on HP & TQ for 2007 nighttrain after PCV, VH, and freeflow
- 03 roadking tuner map question on setup
- No speedometer/odometer
- coil size
- "wet" rear cylinder sparkplug
- Cobra Fi2000 Powrpro Tuner
- Runnin Rich
- sometimes i have spark, sometimes i dont... your thoughts?
- Electrical advice needed
- pc3usb questions about numbers
- Power Commander V Map needed samson true dual !!
- Bad Charger
- PCIII Is it married to one ECM?
- Power Vision + Autotune
- Drive By Wire help
- Bike won't start, battery good, loud ding *videos*
- Throttle body, high flow injectors 2011 CVO 110
- Starter short
- Battery Terminals ... an easy question
- Backfiring, Decel Pop
- Some help with Crank Position Sensor Pls.
- Biketronics BT1000
- realtime afr
- once in a while just goes dead
- Wont Start - Help Please
- Foxguard M16 Alarm - 1997 FXD
- Ignition interuption
- 07 street glide loss of idle when hot
- Need Electrical Diagnsis Help
- stumped.
- 92059-07 troubleshooting
- Lojack service
- what map to use on 2008 SB
- Chopper electronics,wiring help needed
- Security System/ No FOB's
- possible electrical problem
- Turnsignal Question - Wiring
- Map Help
- 2011 Softail Tuner Options
- Occasional misfire at cruise
- HELP! Where is the turn signal control module on a 97flh?
- 1999 FLHR Carb ICM
- tailight problem
- Tuning Question for 2011 Blackline
- Electrical help for a friend
- 2010 roadking
- Dynamic Clusters LEDs Problem
- Too rich or too lean
- ThunderMax Tune for Better Gas Milage?
- TTS Purchase
- Arlen Ness 90 Degree Filter/Stack?
- Throttle problem.
- Help! No speedo.
- sert tuner & O2 eliminators
- Super Tuner Question
- Rear Signal Lights Problem
- dynatek ignition parts?
- 2009 fxstc. Wont start
- TTS Cam Selector
- 1997 roadking low idle
- Tuner Install Problem - limp mode
- Anyone using RLINK SR-i1100 alarm system?
- Terry Terminal Velocity 3 Install Problem
- HQ pro tuner, opinions appreciated
- will my SEPST work on a 2011?
- turn signal help needed or will go insane
- flush mount Harley gauge
- Need Dyno tech.
- Need ECM mount part number 07 RK
- 2005 Classic driveability issues
- Help with SE Pro Tuner
- TTS MasterTune or HD Dyno??
- Help with Fuelpak, SE heavy breather installed
- Help with SERT map
- New battery
- Anyone else running a Thundermax on there boosted bike ?
- Ordered PC-V and AT-100 from Fuel Moto
- flutter sound from throttle body
- switch from a fulpak to a PC worth the jing?
- Strange brake light malfunction
- 08 Fatboy Headlamp wiring
- TTS Mastertune Dyno Tuner Recommendations
- ECM Flash
- Need new TTS starting map-TW 555
- 07 Deluxe quits running down road
- EFI problem
- Original HD file name ?
- Loss of Mileage, Engine 'seeking', 2011 RGU
- Complete Power Shut Down
- Lost fuel pump@ start up
- How to disconnect the running lights in blinkers?
- Heritage Hic-up
- EFI Idle RPMs in the 800's?
- 93 Evolution Timing
- omg please help
- ways of adding Fuel in SEPST?
- TW 555 and TTS
- can someone look at these sheets and tell me why??
- check engine light
- Need SERT Info
- What brand of battery
- Sert help!!!!!!!!!!
- Dead spot at low RPM's
- How to tell if it's been tuned?
- will not start after top end rebuild
- What controls the fuel
- Comm Not Installed
- TTS CAA 176 map - be careful
- Power Commander Advanced Gear function
- coil
- Fixed one problem only to cause another.. HELP PLEASE!!
- Bike not charging again
- bag lites
- Ignition Timing
- 93 evo backfire through carb
- TPS replacement? How often?
- Dtc p0641
- SEPST connector?
- PC-V Gear Map Set up?
- 03 Deuce no voltage at the coil
- LED turns signals not working
- SE Super Tuner ERROR
- S/E Adj. Race Ignition Module - how to test
- Hard shift damage speed sensor
- Late model speedometer in older bike?
- Harley Diagnostic Codes
- Ignition standoff screw stripped
- stupid question but will ask
- Power Vision compare stock with custom tune
- XIED's and V&H pipes?
- removing fuel pump - Softail - tricks?
- How can I tell if electronic control module bad
- Crank no Start
- Installing fuelpak iron 883
- Baffled on this one
- Tach/speedo gauge sticking, need help
- HD lED tail lights diagram help
- Thoroughly Confussed
- Signals not flashing on 97 FXSTC
- Dump question
- 2002 flhrsei fuel issue
- SE ignition module for Dyna Sport
- 2001 Road glide EFI
- bike doesn't start when hot
- electrical problem
- Sputter issue
- To Tune or not to Tune...
- starter relay diagnosis
- not compatable with ECM
- fuel gauge stopped working
- Low voltage on gauge but 14.2 @ battery
- FuelPak?
- racetuner downloading problem
- idling
- Ignition woes on EG Classic
- Computers on the bikes
- Decel popping! What negative value to use on PCV?
- Breaklight flashes (probably an alarm-issue)
- Stage 1 or Stage 2 ???
- Had bad battery, swapped out, still won't turn over
- Circuit Breaker
- Main fuse blows
- Do I Need A Tune???
- starting issue
- MM FI Injectors
- Joker 5 point headlight
- Wire diagrams (lighting)
- street bob LED tail light on a 07 dyna
- 2001 Sporty - No spark at plugs
- Engine code 61006/61007 or b1006/b1007
- Ignition issues
- New to EFI...quick question about pipes.
- Fatcats to Supertrapp - New Tune?
- TSSM- Code
- New PCV
- TSSSM problems No Start
- Cobra FI2000 PowerPro
- Tuning concept
- Map Help - Rush Pipes
- Help - Vrod VRSCX no power on the speedometer
- EFI for absolute beginner for 2011 fxdb streetbob
- Fuses and idiot lights...
- Need good dyno tech
- Handlebar Controls
- Power Commander Map Help
- Troubleshooting an Electrical Problem
- Taylor made wires
- Need 6 pole ignition switch wiring diagram or description
- Blinker just stays solid
- Electrical - All codes show up
- New owner needs advice
- battery change
- Spark plug deposits
- Fuel Injector Cleaner
- 77 flh starter issues
- headlight/turn signal wirering softail
- Systems relay 09 Dyna
- Please help! I can't reprogram my VCI
- Fuelmoto turner or h.d flash
- ticking, clicking noise from my 08 flhr
- No Ignition Going Back To Stock Speedo
- New Power Commander III Not Communicating
- No spark issue
- Thunder Max AutoTune Self Install
- Need TTS tuner dongle
- Remove O2 sensors with fuel pak
- 2000 RK MM EFI Help Tuning???
- Need a copy of installation instructions for a
- timing trouble
- Question - Starter issue
- What have I fried?
- question about daytona twin-tec
