PDA
View Full Version : Ignition/Tuner/ECM/Fuel Injection
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 [65] 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90
  1. Problem wiring turn signals
  2. NEED HELP BIKE WONT START
  3. Map needed for my Rocker
  4. XiED"s
  5. Stoich & E10 fuels of today
  6. Need help. RPMs drop passed idle on decel.
  7. DYN OiED's not working on my '06 Dyna
  8. Police FLHTPI passing lights wiring question
  9. Help need map for tmax
  10. delete
  11. Lyndall Racing Brakes Z-plus front pads for '84-99
  12. alarm output low
  13. Need SERT Map
  14. Roadglide electrical Issue
  15. Drag Bar Install
  16. Now What??
  17. Dyno in austin tx
  18. Need help with electrical problem
  19. good combo for my bone stock tc 96 ?
  20. Wire Gauge
  21. Tach/Speedo not working
  22. AFR and 2-1-2
  23. Stock 88B HP/TQ numbers
  24. 2001 SE Roadglide
  25. ied's
  26. xied's or ied's
  27. DYNA ULTIMA 2000i SINGLE-FIRE IGNITION COIL KIT HARLEY
  28. HELP power comander fuel %
  29. Can you convert a 1999 springer to fuel injection??? How much $?
  30. Fuel Guage working iradically
  31. Bub 7 true dual/PCIII
  32. Battery not charging???
  33. tmat ?
  34. got map?
  35. 2006 ROAD KING POLICE
  36. Looking for PCIII map for 06 Dyna 95" build
  37. Replacing Crank Sensor
  38. Hard Starting on 2000 Roadking
  39. Do I need to increase the rev limit on a stage 1
  40. Part Number for 2008 Touring ECM
  41. EVO Ignition
  42. turn signals brake lights and horn not working
  43. looking for a tweaked PCIII map
  44. 2008 Deluxe Sputtering
  45. Sert Pro or Direct Link????
  46. tour pack lights?
  47. Fuel Guage Reinstall Help. I'm a Dumb A**!!
  48. TERMINAL VELOCITY II™ FUEL MANAGEMENT SYSTEMS - WARNING!!! DO NOT PURCHASE THIS PRODUCT!!!
  49. Dynojet POWER COMMANDER III w/ USB
  50. Auxiliary Lighting Kit not working
  51. Is the Stage I download necessary?
  52. PING, CHIRP, KNOCK...ethanol?
  53. Tmax Base Map for a 107"
  54. xied/mufflers/ air cleaner
  55. seeking a dyno tune
  56. NEED PCIIIUSB for Dummies help
  57. Ignition timing advancement
  58. sert. ?
  59. PCIII Rev Extender
  60. Cig Lighter Inop
  61. Starter???
  62. DTT and FatCat 2-1...Any reversion issues?
  63. I loaded Basic Map to PCIII how do I do andvance
  64. Dyno cost ???
  65. Stage 1 Fuel Management - AIM called out
  66. 117" SERT Help.
  67. Problems with Gold (6R12G)Spark Plugs
  68. speedo/tach swap
  69. Plugs
  70. Smoky Moutain HD What a Joke
  71. SERT Tuner in Seattle area....
  72. Cobra Fi2000 w/o2 Sensors and I'm not...
  73. Need map for 95" build!!!!!!!!
  74. THINK I SCREWED UP...TURN SIGNALS
  75. SERT and Computer gurus
  76. Check engine light
  77. Washing bike with the Seat removed.
  78. Cruise Control Surging
  79. Please Critique
  80. ping i think
  81. HELP need a PCIII map for a FL with big radius pipes
  82. idle or throttle problem? Or something else?
  83. stock evo hd ignition
  84. BEST PRICE FOR O2 SENSORS
  85. Cylinder temp difference - ignition problems?
  86. Tour Pak Power
  87. Latus HD maps?
  88. Vacume leak or the norm?
  89. Any news on the new TTS tuner?
  90. Removing Turn Signals
  91. 10K Service & Spark Plug Replacement??
  92. Left turn signals shorting
  93. No spark - '93 Sportster 1200
  94. tuned and still pings
  95. GAS PING QUESTION
  96. ? on the new Super SERT
  97. Ignition
  98. Help - throttle position reset for PCIII
  99. charging problem
  100. Easier to replace harness or wire?
  101. Big Mistake
  102. The king died today any thoughts?
  103. Cylinder head temps??
  104. Tour Pack Wrap Around Lights Question
  105. Nightrider XiED installed tonight
  106. Help me smooth out my last SERT bump
  107. Battery Removal & Smart Siren II
  108. Check engine light
  109. I need SERT help
  110. V&H fuel pack install
  111. No SERT problem after all (Issue Resolved)
  112. Thundermax MPG?
  113. PCIII - cylinder 1 and Cylinder 2
  114. Version 4.77 for HD SERT program
  115. ignition switch knob
  116. 3 codes on 07 sg
  117. truoble uploading my dyno guys map
  118. Help - '83 FLHT Shovel
  119. irregular voltage output
  120. PCIII throttle position adjustment assistance
  121. Toggle switch for batter --> starter solenoid?
  122. Power commander 3 Map for 103/ 2000 Twin Cam
  123. Anyone had a bike tuned at Gengras in Ct?
  124. cam timing sensor
  125. Radio Shack Alarm installed
  126. PCIII USB Hub and Map switch
  127. Basic PCIII ?
  128. Power Commander.. California vs. other
  129. Newb question: HDI calibration?
  130. Anyone With IEDs/XiEDs Still Getting a Little Surging?
  131. MAP???
  132. How to test a 1986 FLH starter?
  133. Battery charging - is it normal?
  134. Battery not charging 1998 FXSTC
  135. Just got my Twinscan II Plus w/wego
  136. SERT, pipes, and USB converter
  137. Dyna Died/Won't start!
  138. Need SERT Map: 2008 Street Glide, D&D FatCat 2-1, Hi-Five AC
  139. Which Canned SERT Map to Use?
  140. SE Hi Flow Injector Fitting or Bigger Holes
  141. tuning power commander 88" 2003 electra glide classic
  142. My fix to the PCII usb
  143. need map for 06 Ultra Classic
  144. ignition problem with 97 sportster HELP!!!!!!!!!
  145. need map for 05 road king
  146. Pro Tune II
  147. HELP 08 FXD codes
  148. code reader?
  149. speedo idle check engine light
  150. Stage1 - remap or not??
  151. Looking for SERT map for Rocker
  152. More Recent SERT Calibrations?
  153. SERT-Closed Loop to PE mode transition ?
  154. 2007 FLSTSC speedometer freaked out!?!
  155. Speedometer Staying On
  156. solid state regulator
  157. Help with PCII map
  158. Softtail died
  159. EFI light
  160. Map recommendation
  161. Suggestions on getting the timing "just right"
  162. SPEEDO?
  163. Problem with Terry Components TVII
  164. 02IED or XIED
  165. Confused about charging.
  166. Phase 3 Ignition Module for 88 Softail
  167. Fuel spraying inside of tank??
  168. 95' FXD turn signal problem
  169. Alarm light stays on....
  170. Opening a SERT map attachment
  171. intermittent electrical problem
  172. Speedometer went out during ride
  173. Help - SERT popped ECM!!!
  174. new Super Tuner- no CD?
  175. engine light on, normal?
  176. EG starts then dies
  177. Leaving mt sert alone?
  178. Quit while riding & now wont start
  179. '07 Security system on older bikes?
  180. SERT cable connection
  181. CAN'T KEEP BATTERY TERMINALS SCREWS TIGHT
  182. coil needed for my new driveline
  183. Stage 1 down load
  184. Need a MAP! (06fxdbi+SE+Supertrapp)
  185. Shout out to Shovelheadbob!
  186. 2006 FXST miss
  187. No Spark
  188. Not starting
  189. Hot clutch handle during startup...
  190. Tuner and Socal...sucks.
  191. is it safe...advice!
  192. keys
  193. HOW DOES THIS HD TUNED STAGE 1 DYNO CHART LOOK? SHOULD I BE SATISFIED?
  194. Daytona Twin Tech install now engine light comes back on
  195. Electrical Problem
  196. SERT Tuner in Phoenix/Northern ARizona area?
  197. softtail battery going dead
  198. Sert Advance Table
  199. Battery runs down
  200. Limp Mode
  201. Indicator light module
  202. Requesting PC map for springer 110 with any 2 into 2 exhaust
  203. Cal. 75 & 77 Spark advance tables SERT
  204. WIERD START STOP Think it is electrical
  205. almost got it
  206. MPG for 103"
  207. Fly By Wire
  208. Looking for a competent SERT tune in DFW, TX
  209. Hey Doc1 which is better pcIII,sert,or tmax
  210. Leaned out PCIII for better mileage
  211. Running out of gas with EFI
  212. Help - Electronic ignition for a 1340 EVO
  213. Terminal Veocity II
  214. problem
  215. My "MOCO trained" Dyno tune results.
  216. Kuryakyn fuel gauge and cap
  217. Speedo took a dump
  218. tachometer questions
  219. No Speedo, turn signals and rear/brake light
  220. Deuce Fuel Gauge Failure
  221. scanalyzer?
  222. Battery Issue (also in general section)
  223. how do you know its time to Dyno PCIII??
  224. Wiring Has Begun (PICTURES)
  225. WENT TO STAGE 1 SUPER TUNER AND NO MORE CRUISE CONTROL!!
  226. Understanding SERT tuning/data .
  227. led fuel guage not lighting completly
  228. Electrical problems
  229. too rich or too lean
  230. Where is the best source to learn carb/efi tuning
  231. starter/battery probs
  232. calibration for SERT
  233. HD RACE TUNE SOFTWARE 32117-01J OR 01N
  234. which sert base map with fatcat or use T-MAX
  235. pclll question
  236. disassemble Deutch Connectors
  237. SERT? Is this Harelys version of PC/3 ?
  238. Sert Spark Advance table
  239. Orange Ignition Cables for EFI Bike
  240. PCIII ... is it true?
  241. 07 dyna lunges forward on startup
  242. Bike stumbles under power
  243. shortshots without tune?
  244. Location of O2 sensors
  245. Super SERT install instructions
  246. Need suggestions and help with SERT tuning
  247. TMax Tuners in SoCal (LA area)
  248. Thundermax--new install
  249. Check engine light question for a 08 Ultra
  250. Installing Aux Light kit 69286-05A suggestions
