PDA
View Full Version : Ignition/Tuner/ECM/Fuel Injection
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 [63] 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90
  1. Dyna S Ignition in Evo
  2. Is timing my problem?
  3. engine light on
  4. Turn signal flashing
  5. Tmax under one forum heading ?
  6. map suggestions for pcIII
  7. SERT Which setting to adjust
  8. not charging battery? stater? not regulator.
  9. SERT Map for RK stage1 Supertrapp
  10. 77 sportster ignition problem
  11. SERT Tuner in Alabma, GA, TN, or MS
  12. Fuel Degradation-Ethanol
  13. High Speed electrical shutdown
  14. Need Help w/WEGO III install
  15. Nightster 08 Idle Problem
  16. 1977 xlh progressing power loss
  17. 96 RK high idle problem
  18. No/low power
  19. !update!-Bike wont charge battery
  20. T-max maps
  21. No Response from ECM
  22. Sirius power cord question
  23. Fuelpak Jake Brake
  24. 08fxd
  25. sert no start help please
  26. Dumb Question
  27. no ck. eng. lite
  28. oxygen sensor engine light
  29. PCIII not communicating......
  30. PCIII Question.
  31. SE Pro Super Tuner Question
  32. Switch cap replacement, grrrrr
  33. sert any
  34. Electrical Shutdown
  35. Stage 1 ?
  36. Question about the VOES
  37. Compatible exhaust to Supertrapp
  38. low charging voltage
  39. Stupid closed loop question
  40. terry comp velocity II or velocity III
  41. PCIII and IED's
  42. 08 Sert
  43. HD Part Number help
  44. Engine light comes on after starting?
  45. PCIII O2 elims
  46. speedo problems! dont think its a sensor though
  47. Map Needed/RH True Dual AN Big Sucker 08 SG PCIII
  48. help!! electrical problems
  49. flashers blink when turning the bike on
  50. best ign coil for 72 ironhead?
  51. Codes 24 & 25 shorted/open coils
  52. Tmax (Thundermax) Advanced Software
  53. 08 Ultra Dying Problems
  54. TMAX wont work
  55. covering wires
  56. Need some help
  57. Dynotune in southeast Arizona
  58. spark plugs
  59. 2001 Deuce Starting Problem
  60. carb to fuel injection
  61. HD air filter
  62. TOTAL Electrical shut down
  63. Map for PCIII USB
  64. Daytona Twin Tec AFR Tables
  65. SERT SOFTWARE
  66. dyno tune
  67. Stock ECU and Heat Wrap ?
  68. Rough ride with a PC III-USB 2007 Fatboy
  69. Service for a 79 LowRider
  70. HARMAN KARDON "RADIO NOT DETECTED" ECM?
  71. popping
  72. Thundermax on '08 Dyna
  73. L.E.D. turnsignal trouble
  74. Keys
  75. Green Corrosion Alert
  76. ignition module signal
  77. Delete
  78. power comander, race tuner,thunder max ?
  79. EFI on 1999 Road King
  80. Starter solenoid?
  81. clutch handle sparks
  82. Thundermax connect porblem
  83. Bike won't start
  84. Throttle positioning
  85. pc111 couple questions
  86. ignition timing 1967 electraglide
  87. 07 1200 Custom key off current draw
  88. TSSM 31
  89. battery tender
  90. Do i have to tune a PCIII, im new on this....
  91. glens, start your own thread here.
  92. andrews cams need pc3 map
  93. 08 high idle hot
  94. dead speedo
  95. mini tacho stopped working when i installed a fuelpak
  96. 94 Sportster ignition switch wiring
  97. Need DTC Code help
  98. T-max went T U!!!!!
  99. breather belch
  100. Bike won't start
  101. 08 Alarm Sensitivity ?
  102. Stop Switch RUN/OFF Help
  103. SE Pro Super Tuner Kit
  104. MM Conversion Kit
  105. Got a problem need help please
  106. Alarm Question, HD or Scorpio
  107. ENGINE,OIL.BATT,LIGHT COMES ON ?
  108. Security System
  109. PCIII throttle position mess up
  110. race tuner map
  111. electrical/stalling issue on '99 Road King
  112. xieds for 08dynafxd
  113. trerry comp velocity III
  114. Plug Question
  115. IED's or download?
  116. fuel management
  117. Battery Tender
  118. Electra Glide Ultra Classic Wiring
  119. Seattle tuner needed...
  120. need help programming sert
  121. flt will only start with a jump?
  122. Dead Battery ?
  123. kuyrakyn rear light conversion
  124. pinging 91 E Glide
  125. Speedo reading high
  126. loose pipe
  127. Magnety Morelly fuel injection Questions
  128. 1994 Electra Glide Problem / Backfiring
  129. cam timing sensor wire color code
  130. softail tach installation ???
  131. fuelpak values...help!!!!
  132. Wiring diagram for 1996 FLHPI
  133. Vance and Hines Fuel Pak
  134. possible dumb question about ECM
  135. 2004 electra glide computer
  136. How to adjust high idle when slowing down
  137. Speedometer and self cancel
  138. Good Dyno service in WI.
  139. Four-way Flashing with Security
  140. Engine Cuts Out
  141. slip ons for 08fxd
  142. New ECM
  143. 03 FLSTSI No SPARK, No FUEL PUMP, Cranks GOOD!
  144. Smoked fender tips LED light question.
  145. 99 sportster 883 runs 30sec and dies
  146. 08 Ultra dyno numbers
  147. No oil pressure...
  148. LED issue
  149. Turn signal/Running light combo????
  150. Volumetric Efficiency
  151. 1550 downlaod on 06 dyna 1450?
  152. Oil light on, could it be a sensor?
  153. DIY - Nightrider O2 IED's..
  154. 8 degree to 25 degree injector conversion for pre 2006 TC
  155. Code help!!
  156. Tmax Question
  157. Part Code wont clear
  158. 05 Heritage Headlight Wiring
  159. Ran my superglide lean for 300 miles.. Damage????
  160. SEST Calibration Files
  161. What should a good tuner do exactly?
  162. Air filter identification
  163. 883C engine smoke?
  164. cams and exhaust
  165. Digital Tech ECM Calibrations for 06 Dyna Intl Models required
  166. Oil leaking from Sparkplug hole
  167. 08 TMAX Availability
  168. '02 Heritage Keeps Blowing Fuses
  169. blow by
  170. 2000 883 PLEASE TELL ME THERE IS A SENSOR IN THE PRIMARY THAT KILLS SPARK IF IT'S DRY!!!!!!
  171. Stage I ECM Flash CVO?
  172. "no rsp" from ECM?!?
  173. Pinging T-max has me Fuming!!!!
  174. LED Brake, & turn signals
  175. EFI
  176. Throttle Adjust ** Redux
  177. Shovel Dies out no power/electrical
  178. Need shop suggestions in Jacksonville, NC
  179. Softail heritage classic 2007
  180. bike surges
  181. GAS GAUGE
  182. starter?
  183. Speedo/Turn Signal Cancellation, Poor Performance Problem Solved!
  184. What to do with the Super Tuner
  185. Power drain
  186. When bike is cold it starts in 1 crank, when hot it takes about 7 cranks to start Why?
  187. Thundermax... give me negatives.
  188. Normal head temps??
  189. What is the easiest way
  190. Fuel system not pressurizing?
  191. Doc-timing ?
  192. Best Dyno Tuner Technician around Nashville Tn?
  193. Bolt in dash broken
  194. 2001 Electra Glide Radio Upgrade
  195. magneti marreli performance?
  196. ignition cutting out
  197. cd radio on a heritage?
  198. Dyno test problems FBW throttle control 2008
  199. V&H Fuel Pack question
  200. Which version SERT ?
  201. 1965 xlch Sportster electronic ignition conversion
  202. This issue has got me BAFFLED......
  203. Whinning sound when trying to start
  204. anybody got a pcIII map for an 08' softail
  205. 0-50 mph in 0.9s
  206. 06 FXDCi Running hot.. SERT, PCIII, OiED????
  207. Left Turn Signal Indicator Out
  208. Bad magneto? Conversion?
  209. Should I get the stage II flash or not ??
  210. Charging System
  211. Need Advice
  212. Plug wire arcing on engine
  213. stage 1 download / error codes
  214. ECM TROUBLE
  215. power comander
  216. Timing Question
  217. RG Engine heat, I just need to know...
  218. Headlight & Instrument lightss modulating
  219. Aftermarket Cruise Control?
  220. (98 road king shuting down
  221. Need help to uninstall smart siren 2
  222. Fast idle
  223. What is this connector/sensor?
  224. Help 06 Night Train only one cylinder firing
  225. PC III install comments
  226. Front cylinder misfiring ... REPAIRED!!!!
  227. tssm
  228. How can I modify the turn signal conversion kit
  229. High Idle should I reflash with my SERT
  230. Delete
  231. '07 Heritage - connect 12v aux. pwr socket?
  232. Flush LED fuel gauge problem
  233. Fuel Injection
  234. Race tuner
  235. SPEEDO
  236. Where is my race tuner
  237. 03 fatboy speedo turn signals
  238. TMAX with autotune ?
  239. No spark
  240. Chrome Switch Housing
  241. Help LED LIGHT WIRING ISSUES
  242. SE Heavy Breather vs Hyper Charger
  243. Power Commander Newbie
  244. sputter
  245. T-Max Stutter on warm up
  246. Electrical Mystery. Need some help.
  247. pcIII and starting bike
  248. 07 iIGNITION FUSE BLOWS
  249. CPS Code /DynaJet Power Commander
  250. turn siginal problems
