PDA
View Full Version : Ignition/Tuner/ECM/Fuel Injection
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 [37] 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90
  1. 91 Octane
  2. stall at stop issues
  3. Tssm
  4. Which side does float arm go ?
  5. Voltage Gauge is nuts...
  6. Which relay needed for 2 electric horns ??
  7. Options?
  8. Click goes the starter
  9. starter issue
  10. Power Loss
  11. DTC (Diagnostic Trouble Code) Help
  12. Help
  13. Am I being taken for a ride?
  14. Silver faced fuel gauge
  15. Pan Shov,Ignition issues
  16. turn signal/cruise control
  17. 1985 H-D FLHT won't start.
  18. economical tuner options
  19. 2000 road king police bike electrical problem
  20. How does the TPS work?
  21. Dyno Tuning
  22. PCV Map Help
  23. SE pro tunner new softare compatable?
  24. 07 Dyna FXDB turn signal bulbs.. simple Q: Looking to get chrome bulbs
  25. Question about ECM flashing protocol
  26. My 1995 FXDL has me stumped (& frustrated)
  27. '04 Softail Standard Starter Issues??
  28. what is wrong with my 71 sportster 900
  29. I'm Not -2- Sure On What Gauge Wire -2- Use
  30. Not Sure What Gauge Wire 2 Use
  31. Cobra fi2000 auto-tune ?
  32. 1985 FLTC lost all power on a ride, now no spark
  33. Starting
  34. Shorting out on my left handle bar controls
  35. runs for 1 minute and blows ignition fuse
  36. Road Glide headlight issues
  37. ECM connector damged
  38. ECM Hacking
  39. Bike is Dead, No Juice
  40. High Beam Indicator Light Not Working
  41. mini tach connect help
  42. XiED
  43. PC III Map Request - Softail, SE-254 Cams
  44. Need HELP With ECU wire colors
  45. cam change and bike wont5 start
  46. TSSM Question
  47. Does Anyone Know Someone Who Works For Zippers?
  48. Lost Harley Race Tuner - 07 Touring - HOT/PINGING/LEAN :(
  49. Front turn signal loose
  50. Just How Do I Hook-Up That Air Horn
  51. Front blinker/light
  52. Please Help , Can't figure out?
  53. HELP I have a charging problem
  54. B1121,B1126 Help
  55. Magnetti Fuel Injection 2000 Ulta Classic
  56. Numbers jumping around on Power Vision possible intake leak?
  57. 96 to 103= must have tuner?
  58. Surge and codes on 08 ultra
  59. What is causing Error codes P1510 andP2127
  60. Performance Chips
  61. Best T-Max map?
  62. How fragile are voltage regulators?
  63. Battery Tender/Charger Recommendation Needed
  64. Im baffled!!
  65. Do i just have a crumby tune?
  66. Something different.........
  67. EFI Tuning
  68. no fire
  69. Doc is your guy for MasteTune
  70. stage1 without computer upgrade
  71. Performance issue
  72. 1989 FLHTC ignition lock removal
  73. Factory Wiring, New Turn Signals?
  74. 2001 RKC ignition problem
  75. speedo problems
  76. Psspt code p0562
  77. Dead Gauge's / electrical Issue.
  78. Super tuner questions
  79. TTS question
  80. SEPST - smart tunes but now bike is slower
  81. Wiring diagram 78 FLH shovelhead
  82. Rear signals flash together?
  83. lost turn signals
  84. rear cylinder cutting out
  85. running on one cylinder
  86. AFR and other diagnostic data
  87. Air cleaner
  88. X90
  89. 08 Gauge changeout
  90. Bike won't start
  91. Not Sure IF I Need A Tuner Or Not
  92. dobeck GEN 3 settings
  93. 1993 Evo - Do I start with the switch on "Ignition" or "Lights"?
  94. 06 with 8A injectors and Power Vision
  95. ETP Speedometer Code
  96. charging issues on 1999 night train.
  97. 04 softail
  98. 2006 street bob speedo/rev counter
  99. 07 street bob starting issue
  100. Thundermax Ping Tune
  101. No spark and no Engine light
  102. installed voltage indicator?
  103. OEM Speedometer input Signal?
  104. fob install
  105. PM’s clutch and brake switch help?
  106. Speedometer
  107. DTC trouble
  108. fuel gauge
  109. Basic wiring diagram for my '62 panhead
  110. LED question
  111. Bike will not start
  112. Possible loose ground?
  113. 1994 FSXTS Tail light circuit breaker location
  114. MM to Carb conversion problem
  115. Speedo bulb change
  116. 1963 hd 250cc sprint/not running
  117. Fuel pouring from Air filter !
  118. Softail 2 wire to 1 Wire turn signal??
  119. Question about adding a King Tour-Pak with lights to a 2008 Road King
  120. starting problems
  121. DTC trouble
  122. Rear Turn Signal Issues
  123. Techlusion DFO / TFI...I think I'm done with it.
  124. Misfire
  125. 2007 Ultra dead on the side of the road!
  126. Gasoline odor after riding
  127. nology wires
  128. help
  129. Smart Siren II on a 2012 ABS equipped FLHX
  130. How do you tell if you have a staged ecu?
  131. P0261 p0263 p1002 codes
  132. FLH inside gas tank fuel filter
  133. Problems with 95" upgrade
  134. Wiring The Joker Machine LED Turn Signals
  135. P0261 p0263 p1002 codes
  136. Current drain
  137. Crane electronic ignition module
  138. Oil pressure zero at hot idle
  139. Neutral light comes on in gear
  140. Brake lights and turn signals
  141. Flashing head light
  142. efi fuel injection
  143. '04 Dyna Total Electrical System Failure
  144. Question on Deltran trickle charger
  145. 3 Batteries Killed! I need electrical help
  146. 3 Batteries Killed! I needles trial help
  147. Never Make This Mistake with Your Heated Gear
  148. No throttle Response
  149. electrical gremlins touring
  150. Power Commander Auto Tune
  151. 1999 Road KIng PCIII map help
  152. Auto Tuner Questions
  153. Trailer Brakes
  154. Help! I think I done broke something...
  155. led problem
  156. TTS Updates
  157. Street bob running lights not working
  158. Alarm locked up
  159. IAC problems?
  160. Hit starter, now everything is dead - 92 Heritage
  161. *Challenge* 2002 Softail Taillight Issue.
  162. Bad ECMs In some 2012s??
  163. Odometer not flashing to enter password. Help.
  164. Turn signal eliminator problem.
  165. No Spark!
  166. Fuel Gauge not working
  167. EVO ignition upgrade
  168. Low fuel light
  169. 2 plugs 1 coil
  170. SuperTuner re-use
  171. Vance & Hines Power Duals Montser Ovals Dyno
  172. what trim numbers are we looking for on pc v auto tuner
  173. Rear cylinder too hot?
  174. Battery not charging fully.
  175. Advice Needed - Limp Mode?
  176. Trying to get rid of decel pop with Power Vision
  177. Fuel moto map question
  178. What should stock dyno numbers be close to on stock 96ci engine, no mods?
  179. Sert????
  180. Garmin zumo 665
  181. 2007 Ultra Classic-Power Commander III USB
  182. flh switch
  183. Turn Sgnal wiring help
  184. any ideas
  185. Dobeck vs. PCIII???
  186. burned up another run/brake/turn module
  187. 90 fxst ignition mod to sensor plate connector
  188. turnsignal module testing?
  189. Backfire then wont start
  190. 02 fatboy efi slow dropping to idle
  191. PCV AT-100 Trims not going down
  192. My Power Vision doesnt show as many tune items
  193. codes 24 & 25 ignition coil problems
  194. Cam Position Sensor
  195. will I be ok with a Stage I program???
  196. SE Super Tuner vs Download
  197. The best Spark Plug?
  198. '97 Road King - Issue with Battery?
  199. Speedometer dead
  200. Swapping Speedo
  201. 2005 FLHRI On/Off CC Switch Wiring
  202. 97 dyna fires but wont start
  203. 2012 RK O2 plugs
  204. EFI Fuel Pump
  205. Bike just dies...
  206. thundermax with auto tune mpg
  207. Full throttle
  208. 05 fatboy with codes p0113,p0118
  209. Eating Ignition Fuses
  210. 1100 '86 Sportster ignition timing?
  211. 2008 street bob tssm questions
  212. Ngk dpr8e and dpr8ea
  213. O2 plug question
  214. front cyclinder not running
  215. Starting Issue
  216. 03 flhtcui rebuild to 103 ci needs remap
  217. tts map
  218. Idle RPM setting with Power vision
  219. fat bob with thunderheader and heavy breather map
  220. charging dtc code p0562,563
  221. pcIII or timing problem?
  222. Starting problems
  223. Where are all the Power Vision tune maps?
  224. 2007 FLHTC Speedo acting wierd.. reading Slow and glitching
  225. loss of voltage to everything
  226. Lots of Tuning questions in the Dyna Forum lately.
  227. wiring diagram for 96 dyna?
  228. Single power cable to batwing fairing
  229. Battery Suggestion
  230. Codes reading help.
  231. when i pull the clutch in on my super glide
  232. Engine Wants to Shut Down after Full Throttle
  233. Engine Wants to Shut Down after Full Throttle
  234. Help!!! Spotlight/turn signal wiring.
  235. How to troubleshoot starter??
  236. 2002 Fatboy security/blinker issue
  237. How do you adjust individual cells in a map?
  238. sportster engine cuts out
  239. 2007 fatboy pc3 map request
  240. Help with rear wiring harness
  241. back fire after rebuild
  242. Wiring left hand switches
  243. Ignition probs
  244. Security signal / blinker problem
  245. Cobra Fi2000 PowrPro
  246. question about adjusting timing with super tuner...
  247. Cruise control has a mind of its own
  248. Stage 1 ECM... How do I know if my bike has it?
  249. New member, EFI Tuner... whole new ballgame
  250. 97 Road King MM injection
