- Possible Night Train purchase engine cutting out
- Lock knob doesn't turn on 99 Ultra.
- Bike won't start - Code P0374
- coil
- Specs, Specs...Who's Got The Specs?
- Big Bore initial start up with SERT?
- Bike will not start
- 'pop' or 'misfire' in EFI
- security on
- Alternative to PC III USB? Tuning by O2 sensor?
- Heated Grips always on!!!
- PC 5 question, idle is way off?
- Power Commander V or Terminal Velocity-3?
- Fuse Box Removal
- PC3 device error 39 and stalling
- Who knows stock AFR for 2001 Road King?
- Got U1046 TSM CODE - Now What?? HELP??
- Whats wrong with this AFR line?
- Ad Quiet Baffles = retune?
- Stage 1 ECM Flash... What exactly is in it?
- H-D SEST Tuners - How Simple To Use ?
- Screaming Eagle Ignition question
- LED tail light
- Need experience with Daytona ECM
- Add a Second Security FOB
- Map search for race tuner 476
- Two-step for 06 Dyna?
- Today I begun making tuning device for my bike.
- When should I buy a new battery?
- turn signal problem.
- Electrical problem
- turn signal bulb will not fit
- SEST User guide
- 2007 FXSTC EFI Question
- Bad ignition switch 2000 Sportster
- Engine runs perfect but I am not happy.
- making changes to a map
- starter help
- '08 ST Fatboy..extra watts?
- What cables does the new Screaming eagle race turner need?
- Rear Light Harness - 97fxdwg
- 04 deuce fi rough cold idle fixed
- Bike dies at idle
- 95 evo electrical problem electraglide
- 09 FLRH / I read that you do not need a Tuner?
- Spark plug wire holder. New wires are thicker.
- engine miss and backfire
- where do you hide you wiring on a custom build?
- 2007 FLHR Injector Information
- Bike starts in gear w/o pulling clutch lever.
- Gerbing Dual Temp Control mounting?
- 2000 EFI on Ultra
- PCIII USB canned maps question
- Ordered wrong switch?
- Powercommander Autotune
- 2010 FLHX stock
- Brake light stays on, and battery spark
- SEST SOftware Issues
- Just became a sponsor
- Will removing the battery set off the alarm?
- SEST Smart Tune Feature...
- ICM modules
- head lights and spots quit working?
- Why lean AFR makes engine hot?
- security/battery issue
- power gains with SE heavy breather?
- thunderheader combo recomendations
- T-max vs. Dyno tuned stock ecm
- general running problems
- SE air kit install?
- Hypercharger question
- PC III tuning for cheap guys like me (non O2 sensor bikes).
- SEPST Training DVD
- LED Turn Signal Problem
- 96" Upgrades
- PCIII maps
- Will Saturn coil work for my 99 Ultra?
- Lifter Failure Question!
- Voltage Reg. problem ....I think!
- Rear cylinder stops working at idle speed.
- ignition switch bad?
- Smart guys! Look at my 2 PC III USB maps.
- boysen x wing?
- need advice on tuner
- When was first year of PC III USB?
- Do you trust maps from PC III web site?
- Battery tender
- How much previous owner paid for engine upgrades?
- Blown Battery Fuse
- Signal Light 1, 2 or 3 wire
- Grounding Aux. Lights
- Does coil polarity really matter?
- TTS Mastertune for best gas mileage
- Points and condenser
- How often should plug wires be changed ?
- relocating turn front turn signals
- Starter Problem
- electrical short
- Should I change ignition?
- Super Tuner location?
- supersmart battery tender
- I installed 2 auto flashers.
- need help with battery
- Right Turn signal?
- harley ignition
- Where does the green wire go?
- Don't Idle below 900 rpm
- How to reprogram the PIN for security systems with push button key fobs
- rinehart vs sampson fishtail
- help with brake light
- The Idle is driving me nuts
- Turn signal doesn't blink. Light stays on.
- Three buttons on power Commander module.
- Where to buy frame adapter for aftermarket radio?
- ABS Light ON but ABS on this Bike
- can i reprogram security code without knowing current code?
- Sick Evo in need of Help!!
- Best Evo Ignition
- Where is your Power commander?
- ignition help
- download?
- Hazards Do Not Work in ACC mode
- ABS lite
- 07 Fatboy running poorly. Stage 1 with SERT
- voltage problem
- 03' nightrain rear running light not working.
- rev/speed limitation 08 SG
- 07 RK Dieing at idle
- Radio cover for automotive CD player
- Ignition lock cylinder release button stuck.
- Speedo Pin Out
- intermitent electrical fault
- Restart after tip
- fuel injection
- Wire diagram for ignition module32405-91A
- 2006 Eating Batterys
- PIAA H3/Lighting issue with my Softail
- Multilock Crimp tool
- Adding fuses ?
- Security Key Light sync with Speedometer Light?
- Reverse polarity connection of battery charger
- Have Power Commander 5 for Softail - will it work for Dyna?
- 2007 Sportster 883 not functioning
- Where is turn signal module in 99 Ultra?
- TTS and dyno?
- buss er fault
- cruise problem
- 6th Gear Light and Tmax
- I am going to steal a Harley tomorrow!
- Where is start relay on 99 Ultra fuel injected?
- carb guy going EFI, 3 Questions
- stalling problems
- TTS Master Tune S. Florida Help
- Restarting an EFI bike after emptying/removing tank
- How to convert mechanical speedometer to electronic?
- 4 EGA Tuning vs A/F ratio Tuning
- Fatboy rear turn signal wiring harness is there a part #
- '96 dyna wide glide speedo
- 07 Ultra Idle
- V&H fuelpak with Rinehart TD's?
- Problems with SE Stage IV kit/58mm Throttle body
- 07 Street Bob misfires
- 2001 night train problem
- which calibration file for TTS Mastertune
- Low RPM misfire-cough
- Help
- Help needed: Fuel management modules for Cross Bones
- to plug or not to plug 02 sensor
- code appears on my odometer
- LED stop/taillight
- main bat. circuit breaker problems
- Where is the TSM on a 2000 Ultra????
- ECM allen head Bolts
- Good dyno/tuner in Kansas City area
- VE set at 13.2:1 WHY
- Wiring issue
- 2007 Electra Glide Dies when cold
- Where best place to get TTS Mastertune?
- Running light not working
- FEET HURT 2001 Roadking Classic EFI(Low to No Spark)
- Sportster 1200XLC will not start when its hot outside
- Speedo sensors (VSS)
- How To Remove The Battery - FLHX
- Speakers on FLHTCI 2003
- Auxilary Lights/Passing Lamps
- Fuel pressure regulator question
- Security light/no speedo/no blinkers
- Tuner/EFI options?
- Where is check engine light on 99 Ultra?
- Need help installing rear turn signals
- Blinker issue
- Turn Signal Problem
- Oil pressure gauge pegged
- Help please no spark
- one SERT cable lost
- Handlebar Switches stop working
- Tuning SERT for better gas mileage?
- fair price...
- Tuning a Edelbrock RPM performance Kit
- 04 FLHRCI DTC Troubleshooting help
- Help With Dynatek Curvemaker Please
- Tail Lights out
- New battery, what make/type is THE best??? (and how do I stay away from the Vette???)
- Throttle by Wire
- Updated software for TMax
- Electrical Help with my 2002 Dyna Lowrider
- help with ignition module
- EFI Enrichment Device
- "Engine" light comes back on after start
- Need input- ECM ?
- U1097 Loss of Speedometer Serial Data. What does it mean?
- DTC U1040 ?? What is this ??
- 2005 Sportster 1200C Tachometer
- TTS & VE tables
- Battery tender wiring
- European radio frequency for FLHTCI 2003
- Clutch starter interlock
- Help Bought TTS Master Tune, Have Map
- Questions on Kuryakyn Panecea lights
- Turn signals not flashing?
- Are EFI maps exact to aftermarket part combinations?
- How do I get rid of my TSSM
- PC-V map with cams..
- Problem with bike and security system
- Thunder Heart's stand alone ignition system.
- Help with 04 FB
- Fuel Pressure Adjustment '08 models?
- HELP! My 02 RK has a ghost.
- Stage 2 with SERT to be installed, Advise?
- Starter problems.
- Deutch connector access
- 97 flhtcui no running lights
- Hard start in cold
- '08 Nightster Bus Err... HELP!
- Fed up with EFI.
- 08 streetglide turning off
- Possible electrical problem - please help
- spot switch
- 2008 Streetglide Fuel injection management upgrade
- Starter Motor 101
- Black Smoke from exhaust on cold start
- Feul managment
- Check Engine Light on 2000 Dyna Low
- Live In Alabama
- 1995-1999 Dyna wiring diagram
- Very strange electrical problem.
- Zippers Thundermax with Autotune
- Do I need a Tuner?
- Wiring diagram for 91 flhtcu
