PDA
View Full Version : Ignition/Tuner/ECM/Fuel Injection
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 [76] 77 78 79 80 81 82 83 84 85 86 87 88 89 90
  1. Air temp gauge
  2. Ignition switch stuck
  3. Dyno Tuned!
  4. unable to install bootloader?
  5. Tach set-up
  6. Starting problem
  7. What Brand of Battery
  8. latest version of sert disc
  9. Speedo problem? VSS?
  10. Running w/o using o2 sensors..
  11. Poll on EFI Tuning in Dealerships
  12. sert question
  13. Talk with Jame @ Fuel Moto about PCIII
  14. My Bike will not start!
  15. POLL from Doc 1
  16. rear turn signals
  17. What Brand of Sparkplugs are you using??
  18. Thundermax or Download
  19. I need some Help!!!
  20. TMAT Question
  21. 07 softail sert map help
  22. need advice on turn signal issue.
  23. SERT Wont Connect...HELP
  24. Need FLSTCI PC III USB Map help pls
  25. Bike starts, won't stay running
  26. Ground issue i think.....
  27. How to upgrade Tmax map....
  28. SERT VE
  29. Fuel MAP help or suggestions?
  30. engine codes
  31. FXDBI that has no sprak but new Crank Position Sensor
  32. Dyno Tune, Am I Ready?
  33. electrical problem-88fxrs
  34. Thundermax help - AIR/FUEL RATIO vs TPS question
  35. wont start when hot
  36. Any experts on power commanders for 07 flstc
  37. Does anyone know what size
  38. Thunder Max Install and new radio question?
  39. 06 FLSTNI Deluxe Won't Start
  40. I plead with you experts for help on my sert
  41. Looking for best Nor-Cal Dyno Tuner for SERT
  42. Direct Link 1
  43. Dynojet in NJ???
  44. VE Tables explanation...
  45. battery replace/change?
  46. Clarification TMX
  47. Thunder Max Question
  48. Help with turn signal disassembly
  49. 2002 electraglide classic problem
  50. 203 cams in 15th Anniversary FAT BOY 95 cu in
  51. Street Glide facsia
  52. pcIII
  53. Speedo/stalling
  54. TMAT Rocks!!
  55. PC III USB - Device not communicating
  56. 1998 Road Glide Speedo Troubleshooting
  57. lights shutting off while riding?
  58. starter prolblems-getting pissed-84 fxst
  59. Thundermax-6th speed indicator not working?
  60. 07 reflash for exhaust slip on..help please
  61. Looking for Map SERT
  62. VOLTAGE DROPS
  63. Thundermax and Idle RPM
  64. engine voltage codes
  65. electrical problem
  66. Need help with electrical problem 07 RKClassic
  67. Which Injectors do I Have??
  68. Help! need pcIII map for 05 15th ann. Fatboy
  69. dtt bung location
  70. Will not Shuit-Off
  71. 1987 FXRS Misfires
  72. Round & Round She Goes...
  73. SERT ?
  74. New PCIII and pinging...etc.
  75. lighter
  76. warmed up rough idle
  77. Help understanding Sert map....
  78. Right turn signal troubles?????
  79. Starting problems
  80. Thundermax-holy $hit! and a question
  81. Check engine light on
  82. Thundermax and 2007 Wideglide questions
  83. Which PCII to buy??
  84. Securing FuelPak Wiring on "06 Road Kings
  85. Red key Idiot light stays on
  86. looking for a map
  87. V&H Fuelpak w/ 2007 Deluxe S1 ECM
  88. frt turn sigfnsals install on rear
  89. Speedo quit working? 2001 Super Glide
  90. cold idle problems on 01 electra classic
  91. 1200R Tach to a 1200C?
  92. please look at my dyno run
  93. Right map?
  94. fuel light on
  95. DYNO SKILLS AT LATUS HD
  96. fuel inj to a carb
  97. tc88 cutting out
  98. Front cylinder still a little lean, rear looks just about right
  99. Too much Cruise Cable Lash
  100. TMax and cruise control light staying on??
  101. Thunder Max On or Off
  102. should turn signals turn off on 2000 RG ?
  103. DTT and Thundermax
  104. Replacing O2 sensors to reduce heat on 07's
  105. Battery going dead- will not start
  106. looking 4 tuner near st louis??? help
  107. SE RACE TUNER 32107-01F
  108. Disconnecting the battery and ThunderMax concerns..
  109. Voltage divider for 2007's to cool engine?
  110. Power Commander,,,Yea..or Ney
  111. bypass rev limiter
  112. SE spark plugs
  113. SERT map for Supertrapp 2:1?
  114. SERT Map Help?
  115. battery to voltmeter meltdown
  116. Just Ordered TMAT...
  117. Another option????
  118. plugs and wires
  119. SERT
  120. Security Key won't turn off
  121. turn signal issues
  122. rev limiter
  123. Bob won't Idle.
  124. 07' Wire harness extension question
  125. No spark when engine gets hot
  126. Deutch Ecvectrical connector [187]
  127. High idle after restart when hot.
  128. Ignition Failure-1992 FLHTC
  129. Red Security Light Stays On!!
  130. help!!!
  131. dyno tune...yes or no???
  132. Bike died three times!
  133. PCIII Map question
  134. Thundermax - What are your guys head temps?
  135. Sert - anyone know what they are doing?
  136. TMAT or DTT
  137. HandleBar wire extensions.
  138. Voltage drop while riding
  139. 2003 road king classic cruise control problems
  140. Decel pop gone!!!!!!!!!!!!!!!
  141. Passing lamp light bulb
  142. Thundermax help
  143. Need Help Diagnosing Problem
  144. programable modules?
  145. SERT Maps
  146. Brake Lights - 05 RG
  147. deleted post
  148. Turn signal switch part number?? FLHRCI
  149. Speedometer Erratic
  150. To SERT or not HELP HELP PLEASE
  151. Can you use a SERT to tune without a Dyno run?
  152. Shovelhead firing issue
  153. sert question
  154. Recent SERT buyers come inside
  155. PClll with alcohol
  156. Bike won't hold a charge
  157. From SERT to PCIII
  158. ThunderMax Set-up help please..
  159. PCIII question...
  160. Where is the map stored???
  161. PCIII Poll
  162. EFI tuning help!!!
  163. Question for SERT Guru's
  164. Where can you see what maps are available-thundermax
  165. ecm blues
  166. NONE
  167. TMAT Issue...any suggestions?
  168. No turn signals
  169. Thundermax Help!!!
  170. Where's my tuner?
  171. Question for you pros.
  172. Removing Security System
  173. P0154 DTC Code
  174. harley can not solve this
  175. 2007 Shriner Edition FLHTCU HELP
  176. 07 handle bar wire connectors
  177. PCIII software:
  178. I give up. Bought Thundermax
  179. WTK: Typical Battery Voltage
  180. Old style EFI
  181. Turn Signal Problem..
  182. High Beam
  183. Starting issues
  184. P0118 Engine Code
  185. Charging dead batt - question
  186. Howards hog horns relay install
  187. Blinkers/Help
  188. Fat Boy 07, 103cui
  189. One Happy Camper!
  190. Speedo Question
  191. PCIII USB Question-Experts Advice Needed
  192. Plug reading on TC96B
  193. EFI and Drag pipes
  194. Lights off-runs good, Lights on-runs bad
  195. Crack the throttle...ping
  196. PCIII map needed for Andrews 26, Rush, '07 FLH
  197. Slip on pipes
  198. Switching to carburator
  199. help security system
  200. Starter? Ignition? Short?
  201. SERT = ECM will not allow access?
  202. 88 Sportster turn signals
  203. 02 ultra sputter
  204. Fuse issue - 2002 VRod
  205. Any one use te Daytona-Sensor Exhaust Sniffer???
  206. Heated grip prblm
  207. 92 fxrt running on one cylinder
  208. 96 cu engine
  209. Dynotuning Question
  210. engine breathing noise
  211. Posting of maps on this site anywhere??
  212. Will a ThunderMax Generation II ECM with Auto-Tune give as good a tune as a SERT?
  213. Power Commander Map
  214. Does
  215. LED Tail, Turn Front and Rear
  216. NEW DTC for 2007
  217. spark plug wires
  218. Very low tech solution that may help someone
  219. Update: FIXED w/o H-D Tool! was: Ignition switch alignment tool???
  220. simple timing question...i hope
  221. 2003 Heritage Fuse problem
  222. Tuning Question
  223. INJECTORS....
  224. Ignition timing
  225. EFI Woes!!!! To Tune or........
  226. Question about SERT
  227. 1981 shovel troubles - electrical ignition
  228. Regulator install help...
  229. Replacing the Stator
  230. looking for tuner in mid west
  231. Will disconnecting the battery
  232. alarm pager batt life
  233. Red "key" light on the dash?
  234. Another PCIII Question.
  235. Looking for builder/tuner in the South.
  236. Colder Plugs ?
  237. Technical question...
  238. PCIII Timing etc ?s
  239. Best Tuner for 07 SG?
  240. Tachometer set up for 07 Fatboy
  241. Tracking down a short
  242. PC III USB EX - The EPA has won
  243. SERT Connectivity issue
  244. ignition ground
  245. DOES FUEL PAK "RESET" IF REMOVED?
  246. Can someone explain what happened?
  247. Might be a stupid SERT question, but...
  248. Need TMax install help in Nashville
  249. RPM vs MPH Values for 2007 softail
  250. V&H Fuel-Pac
