- SERT For 08 Street Glides etc.
- Check engine light, code p0661
- '08 electronic throttle
- smoked something
- Need some electrical help....(Digtal Dakota Gauge on Road King Classic)
- Sert map
- SPEEDO AND ODOMETER
- Sparks out my starter
- TMAX with thunderheader
- SERT INSTALL
- all electric gone sept headlight
- ultra classic electrical problem
- Daytona Twin Tech Ignition
- Any new word on '08 SERT?
- Power Commander MAP Database PC
- Speedo light won't go off
- race download????????????????
- HD garage door sending unit
- SPEEDO / TRIPMETER FLICKERS
- Terminal Velocity 11
- V/H MAP Help
- 883 speedo inop.
- Tmax vs. Twin Tech vs S&S VFI vs PCIII
- 98 octane & Fuelpack
- Cool PCIII map feature
- Anyone used Speed Performance Plus
- Brake Light Wiring Help Needed...
- Sylvania Silverstar Update
- any body with 07 and a tmax with auto tune got ride of your pinging
- The Arlen Ness Big Sucker
- Fuelpak settings
- I have no powre after 3700 to 400 Rpm'S
- SERT HDI differences
- need help about ignition
- Fuel Injector Cleaning
- Electrical Help Please No Turn, Brake or Horn.
- EFI Race Tuner and XP OS
- Timing advance at idle
- Rear Turn signal question......
- Spare Maxi Fuse
- Marker / Signal Light
- SERT for sale, new in box unopened
- Need Help Adjusting Points
- Home made AFR meter? Possible?
- Iridium Plugs
- Help! 07 FXDB wont start!
- Custom Chrome Headlight Wiring
- '07 Roa Glide, cruise and sinals inop.....
- Crane Ignition on '92 Evo -need help!
- 100 octain at 76 = 6.49 a gal.
- HD SERT DISCONTINUED????
- Need Education on EFI
- retrofit project(digital speedo)
- How to map efi @ home
- Latest SERT software version?
- Download!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Ignition -I'm stumped...
- Brake light switches - adjustable?
- Dyno Tuner in MD, Del area
- Tuners in Colorado
- Directionals not working properly????
- Turn signals flashing way too fast
- 2007 pinging
- CLB table
- 2001 sportster blowing ignition fuse
- 2001 softail efi starts and dies
- ECM trouble
- Engine light on, speedo/odometer shut down
- Help with wiring gremlin
- Best way to connect GPS (Garmin Zumo 550)?
- Police Tach
- Left turn signal ghosting
- Pulsing lights
- No hi-beam indicator light
- Can I use a dyno tune on a different bike same configuration?
- screaming eagle race fueler?
- T-Max maps for 06-08 Dyna's!
- Cobra FI 2000?
- deutsch connectors
- What map for kerker slip ons?
- DTT ignition settings
- Performance Ignition for 07's?
- sert canned map?
- Daytona Sensors Twinscan2-Plus-Kit
- Exhaust leak
- Hmm I wonder
- Hmm I wonder
- ECM recalibration
- 883 or 1200 Scremng Eagle ECU
- 98 Dyna wont start
- 05 se cvo flstf
- Another SERT question/warrenty question..
- PCIII 04 Wide Glide
- Plugs
- My Cruiser quit Cruising
- Diamond Star Headlight modulator
- 07 Softtail Custom ?
- need info about 3 phase alternators
- HDMAPS.COM
- Fuel Pak
- SERT TUNING QUESTION
- Can loose connection cause Overcharge?
- engine stall
- Fuel Pak vs. Big Shot vs. Power Commander III
- 2008 Street Glide Tuner Question
- What is the Stage One download?
- Voltage regulator?
- how do you know it is truly running 13.5
- What Size Are The Stock Injectors?
- Starter or Solenoid?
- CRUISE CONTROL
- Thundermax software update
- SERT map for 07 Street Bob and 2-1 exhaust
- charging system problem
- Removed/reinstalled gas tank now it won't start
- scoot won't start..but starter is chattering
- Driving lights keep failing - anyone else ?
- SERT 07 map on 06 Dyna?
- 2001 Heritage softail classic EFI (ecm fuse blown)
- Installed DFO on '08 !!!!!
- Wont start, starter "sparks"
- Bank Sensor (Tip-over module) 2000 Night Train
- kury 4825 TS issues
- 05 FLSTNI WONT START
- 2007 Fxstc Battery light
- Ignition Switch trouble
- 07 SB Dyno Tune complete......unhappy, need help
- Looking for a PCIII map
- Help Please- bike cuts out while driving
- Headlamp dimming intermittently
- Where to tap hot lead for aftermarket radio?
- Ignition switch installation help needed
- O2 clearance from the heads with thunder max
- 88 sportster ignition problems
- Turn Signals
- TROUBLE CODE 16
- '03 night trian needs your help..
- signal light that have only one wire
- Ignition Key Knob Install trouble
- PCIII timing adjustments
- 2000 Ultra cruise
- 97 Electra Glide Won't start no spark
- tmax 08 softail
- 08 tuners that hook to injectors
- ThunderMax MM EFI kit
- Radio Problem
- H&V straightshots slip-on map
- ThunderMax Reports
- ThunderMax open loop
- Stereo, Turning Signals, & Stator???
- ignition breaks up at idle and while riding
- Stator Went, How Common?
- Warm Engine Starting/Throttle Problem 07 FLHX
- 84 FLH turn signal question
- PCIII map request
- pcIII of fuelpak????
- Starting problems 2000 Electra Glide
- Pro R Hypercharger, Big Radius and Tmax Installed
- cables with sert
- SERT install still pinging
- PCIII question...
- SERT Maps
- Intermittent Brake Light Problem
- Quick help appreciated for PCIII
- Rinehart Performance Baffles True Duals - Touring
- Battery and ECM memory
- Dakota Digital 6 Gauge Pac, Any advice?
- SERT Map Questions for 07 Ultra
- 883 loses fire
- SERT Map Request
- SERT Map Request
- SERT Questions
- race download
- Fuel Pak
- Adaptive Fuel
- SERT G or SERT H
- Ignition Coil connection point - Sportster
- dynoed for the newbies
- is air/fuel mix 14.6 bad for bike?
- Full time running lights and Alarm?
- Dealer SERT Flash
- Spark Plugs
- backfire/won't start
- PC III Decel & 0% TP question
- New Member/Tmax Question
- 05 Sportster loosing battery charge ????
- back fire
- SERT Question
- SERT Map Request
- random stalling
- Ignition timing
- 92' heirtage doesn't start
- Front fender tip light ?
- 07 Brake Light not working
- PCIII map
- engine to hot
- Plug-in for Road Zep?
- Stage I - new bike
- Which map for SERT
- Where is Turn signal module on 2000 HSTC?
- Which one is the Brake Light Wire??
- Removed Football Cover - PCIII Adjustment Needed?
- Need help in identifying Screamin' Eagle part
- New T-Max map, new exhaust, better mileage!
- Fat Bob Dash Question
- Tail light Problem
- REVTECH DFO FOR SOFTAIL '07 & '08
- Sealed Bean, Halogen Headlamp Bulb?
- rev tech dfo instructions
- Power Commander&Ecm issues
- turn signals mucked up
- ThunderMax with AutoTune, sounds good anyone try?
- S/E Air Cleaner Backplate Changeout
- Need Tuned SERT Calibration
- Question; Can I install floodlights, spotlights to my new 08 FLXH?
- Dyna Tune Dealer in AZ
- Starter info
- SERT starting point
- need help on my 05 standard
- New PCIII USB install - couple of questions
- Red instrument gauge bulbs ??
- V&H fuel pak and stage 1?
- MAP for SERT 103" Procharged Fatboy
- Need a New Battery, Need Suggestions, HELP
- 97 electra glide trouble codes
- 2006 et al SERT tune available via email
- Screaming stator
- Tmax Purchase
- Front stop light switch
- 2004 883 Battery Fuse Blows as soon as placed in
- Replacement Starter
- EFI ingnition tuning ?????
- Head light
- PCIII and fuel blending
- Cruise SET switch blows accessory fuse on 03 FLHRCI
- marine temp sensor and gauge on Harley
- Replace rotor when replacing stator?
- Advice re charging system diagnostic results
- Firing on 1 cylinder, NEED HELP!
- Nutral light
- FROM900rpm to 4000 no reason 1996flhtc
- Screaming Eagle Ignition Programmer???
- Sudden Hard Starter When Hot? Ideas?
- ENGINE TUNER
- Engine loses spark now and then
- anyone using ICT Talon with MM ife system
- loss of All power
- Anybody from North Dakota?
- PCIII Question...
