- Software for 2010 Screaming Eagle
- 2005 Ultra Starts Misses & Sputters
- Running bad
- Bad Target Tune Module????
- System Relay Coil Voltage
- Road King randomly shuts off
- Don’t know if I’m posting this In the correct place
- 2009 Low Rider P1353, P1356 (front and rear cylinders no combustion)
- Help Quick SEPST Question
- Harley Davidson Magnetti Morelli EFI
- Can a dealer flash a used BCM without the PIN?
- Ping sound
- Is it dead
- misfiring / running terribly
- 04 road king vicious vibration
- Powervision dyno tune
- Thundermax - MAP Sanity Check
- Power Vision Gauges
- When to Go to Larger Throttle Body
- Running on one
- Dyna 2000 tc ignition?
- Thundermax - Throttle Position in Monitor Mode
- SE Pro Tuner
- Only stays running if start button is pushed out solenoid is engaged.
- Harley ECM Tuners
- Tacho wiring
- looking to see stage 1 AFR
- Dynojet power vision users
- Acceleration Pop
- Road King Stalling at stop lights
- Rich or Lean in the midrange?
- 2008 ultra / p2122 p2138 codes
- 103 touring misfire/hesitation
- 85fxr starter shaft
- simple vacuum / curve question
- Hissing Tank
- Sputter at 1/4 throttle
- Help with super tuner pro, 16 stage 5 road glide
- 1994 Ultra Classic No Spark/No PWR at Coil
- P0132 / P0152 / P0562 and the repair
- Staged 2+, but "Fuel Range" doesn't know
- PV tune for a 143?
- Help...adding new pipes and tuner to bike with Stage 1
- Throttle Position Sensor
- Ignition question for the tuning junkies
- Talk to me about Sportster EFI please
- Starting problems
- Power Commander 5 connections?
- FLHTCUI In Tank Fuel Lines
- SEPST & Decat
- P2135 TPS correlation error- Twist grip sensor? 2008 Ultra.
- Tune help info?
- Power Vision Target Tune
- rough idle, poor throttle responce
- weird noise when starting
- Magneti Marelli to carb
- Tuner/Dyno
- 2014 flhr breather options
- Understanding the ECM Calibration
- What size injectors?
- 94 Sportster starter problem
- Need Stage 1 upgrade help
- A little confusion about the Fuel Pak 3 - Auto Tune Feature
- Tuner purchase suggestions
- Best way to tune my 17 XL1200X
- Ordered a FP3
- Fulepak instructions please
- Dynojet PV - Go back to Stock??
- 2004 Road King EFI cold start trouble!
- HELP!!! 2004 Ultra Classic giving fit
- 2003 sportster xl883c anniversary edition carb issue
- Hot fuel pump issue
- V&H fuelpak FP3 flat spot off idle
- Rev limiter setting
- Carb for EFI Swap
- 2003 XL1200c gas tank leak
- Stage 4 Base Map Cal
- Had to replace a fuel injector...question
- Fxdls no throttle
- No spark, no joy
- Solenoid rebuild
- confused and need some help (starting Problems)
- New HPI throttle body, do I need to change fuel pressure regulator or will stock work
- Mistakes were made. Need starter help
- Modify Air/Fuel Ratio using Pro Street Tuner
- Dyna tuning help! Low throttle misfiring
- Tuning issues after cam swap
- 2019 FXBB DLC connector
- SE Super Tuner Pro
- SE street tuner question
- Unlock
- 2011 Softail Won't Start After Rain ride
- Fuel pump issue? Broken down in Grand Praire, Alberta
- Would using 87 octane reak havoc on my '01 EFI fat boy like it did on my '02 A4 Quattro 3.0L?
- 883 Sportster Bogs With Throttle
- FuelPak 3
- New Harley owner HELP with misfires!
- wont start
- Bad Gas! (The Bike Not me)
- Need help with 85 FXRS
- wi-fi OBD reader?
- Ignition Switch Replacement Problem
- I need help with STREET BOB 15
- Dropped bike and now it won't start
- New Battery Keeps Draining
- How to tell is FP3 has been "Married"
- Solid Red key light, No Start.
- Electronic Throttle Control (ETC) 2018-19 Fatboy
- Best practice to ship a bike with key fob tech
- Power Vision backups
- Power vision on non O2 bike??
- Tuning issues
- 2017 FXDWG DLC connector
- Have orange spark, but won’t stay running
- No response from scanalyzer
- 1997 Electra Glide with M/M F/I
- PV Auto Tune help please
- PC III maps
- 3000 RPM chugging
- 19 m8 107 power vision decel fuel cut off
- Starting Issues
- Power Vision Competent Tuners?
- Cam /crank angle sensors mm 99RK
- Replacing IAC 2006 Dyna VH fuel pack
- Hi,,,,,,ion sensor system
- 2004 Road Glide EFI Cranks but No Start
- Screaming eagle pro street tuner delete
- Help please. ECM going bad or tune issue? Chasing a ghost of a problem
- To tune or not to tune?
- ECM swap/replacement
- swapping the ECM on 2018 Ultra Classic
- dts ecm no rSP
- New Gas Tank
- Bike shot off
- Change ecm and tssm tips
- Bad ECM 08 FXDL
- TUNERS - RCX celerator VS V&H FP3 ?????
- Fuel pressure test on pre-Delphi injection system
- VRSC 2003 Ignition problem
- 08 flhtcu o2 sensors
- Weird ignition problem
- Ignition coil
- Bike runs out of gas with plenty in the tank
- High Idle when pulling in clutch on highway
- Snap/Crackle/Pop
- P1355 Code Repair
- 0,5 ohm coil with Dyna 2000i ignition??
- Throttle -Slow return
- FP3 autotune added to base map
- sudden onset of stalling
- power vision tune/tuner flhtk 2013
- Codes 1097 and 1255 wont fire
- FXSTDSE Resurrection troubles
- CR575 cams
- V&H Code Reader #66035
- Low torque..tune issue?
- Tuner advice for someone (gasp) not interested in performance?
- Ignition locking pin 2005 super glide custom fxd
- Idle Speed Control Actuator ?
- 2017 FXDB rough idle when hot
- Ok, what did I do wrong...
- Reflashed the bike, made quite a difference.
- Installed 117 Stage III, can the leftover parts be used for 107->114?
- 2002 ULTRA won't start
- TPS Disconnected
- Can ya "fine tune" a FP3?
- speedo float
- breaker cam position
- EITMS Question
- V&H FP3 Issues
- FP 49 state
- Base tune for 2011 XL1200C on SEPST
- Plugs fouling like crazy
- Screaming eagle efi race tuner kit
- 2015 HD Street Bob starting issues
- shovel head timing
- is Tmax my solution ?
- Race Gas
- Pinging/Preignition
- PV1 Map S&S 509
- A friend needs some help
- problem upgrading from HD SE Pro Street Tuner to Power Vision
- ignition coil suggestions
- Idle RPM increase when adding timing
- FP3 Quick question about AFR
- VSS/IAC/Other Issues
- 2003 ultra anniv. Charging problems
- 1985 FXRS Ignition Module
- Had Harley softail dynoed and remap a question!
- Reset Married VCI On SEPST
- Ignition issues with 5 pole switch
- Induction
- ECM and TSSM Questions
- Possible bad injector, read on to see why I ask this
- Possible bad injector? Read why I question this
- Speed Sensor Location on 2014 FLHTK
- Fuel pack tune
- Installed new air cleaner
- PV on 2010 Ultra Limited
- TTS Cals that shut off Injectors at closed throttle
- Ignition Won’t Stay Locked
- Tuning Software that can import logs from Innovate Motorsports gear?
- ECM/FP3/ODO Help.
- FP3 failure/error
- Powervision speedo
- Mixture variance between decel, cruise, and accel in open-loop system?
- RB Racing LSR Exhaust Map Help - Decel Pop
- PC5 question
- Need some help, please
- Dynotek settings help
- Help needed
- Fuel Pack
- Stock ECM Plug & Play????
- Wanted a 07 streetglide ecm package with keyfobs
- Injector Pulse Width Question
- Anyone have a screenshot of a Stage 4 ignition map?
- Do I need to get an expensive tuner??
- Who tunes thundermax in the San Fran Bay Area or sacramento
- SEPST (super) Cranks to Fire
- 2019 FXDR 114- V&H Fuel Pak connector?
- Setting TPS voltage
- 110 a/f table help
- 96ci throttle body
- 1973 FLH Coil wirirng
- No power to fuel pump and no spark
- Flat spot and vibration at 2000 rpm.
- Ignition problems after parking downhill - FHLTCU 2008
- Question about installing new fuel injectors
- Only getting 4.8 volts at the coil
- Fuel Pump Primes But Will Not Run
- Please help no pulse from ECM
- Fuel pump turns on, have spark, won't start!
- Dyno ware RT setup
- Little Help
- 103 high output plug gap?
- electra glide 2007 got prime but startermotor not turning
- 2006 fxdwgi
- Bike dies while riding
- to someone that knows the Harley ecm
- Can a dealer “see” if I’ve used a DYNOJET PV?
- Is this normal?
- 1998 Fatboy Ignition Box
- ac element
- Map/Crankshaft position sensors
- Stumbling with throttle increase
- 2007 Street Glide no start
- 2008 FHLTCUI Throttle off high RPM
- road king no spark
- '07 FXDB won't start when engine hot
- Map for 96” 48H Jackpot 2:1
