PDA
View Full Version : Ignition/Tuner/ECM/Fuel Injection
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 [23] 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90
  1. rapidly fluctuating charging voltage
  2. Evo with little to no spark
  3. Thundermax map 362?? Where...
  4. Do I need bigger injectors or TB after piston and cam swap? Idles funny
  5. PCV/ AUTOTUNE Fuel Trims and Ignition Tables
  6. VE Table Values
  7. air filter/remap? Pipes already installed!!!
  8. PCV map suggestion
  9. Looking for a tuner in east/mid Tennessee
  10. Tuner needed?
  11. XiED Real World Test - Finally!
  12. spark plug. ..bla.bla..bla..
  13. Spark plugs / wires
  14. Initial Smart Tunes in Cold Weather?
  15. Whack the hdi plug in??
  16. Question about Tuners
  17. 111" motor, which TB?
  18. Back Late mod??
  19. Super tuner
  20. how to carb a m@m bike
  21. flash tuners
  22. Would not srart
  23. SE tuner and VE table question
  24. Accel stealth super coils
  25. fxstsse2, fuelpak wont let seat sit
  26. 2015 forty eight
  27. Terrible low end curve
  28. Dyno Guy
  29. Harley 883 Iron Starting problems
  30. Fuel Tank Build
  31. What MM Spares to Pack?
  32. ignition module
  33. 01 sportster 883 has sporadic rpm drops
  34. PCV question
  35. More air
  36. Magnetti FI to carb or stay FI options questions
  37. Plug wires
  38. Where to dyno tune in Midwest?
  39. SE Pro tuner - can you get it remapped?
  40. Se street performance tuner
  41. South Puget Sound tuners??
  42. No spark
  43. Any have a good base map for 2014 ultra limited
  44. New Cams Thundermax Tune Base Map Help
  45. Fuel Table Help
  46. Fuelpak FP3/Shortshots Install Results in P0031?
  47. MM EFI To Carb Conversion
  48. Cost to tune
  49. TW-222 and pro super tuner
  50. PV tuner, less RPM range when warm.
  51. No start when cold
  52. Single or dual fire ignition system for kickstart conversion
  53. Recommendations for a good tuner in Greater Cincinnati Area
  54. Base calibration help needed
  55. Starting engine causes signals to blink fast.
  56. 2015 SGS Trouble codes
  57. need se204 cam tune for power vision
  58. Trying to pick a Fuel Management System
  59. Injector help
  60. TTS VTune 3
  61. SE Super Tuner
  62. 124" TTS Mastertune map
  63. Power vistion with after market stereo
  64. Which tuner or download ? Confused....
  65. Best Dynojet Tuner near Daytona
  66. shorted out electrical 2006 softail fuel injected
  67. confused about tuning options
  68. SESPT Map
  69. Pegasus FI conversion
  70. Needs Tuned - SE SuperTuner
  71. fuel line quick connect o-ring?
  72. Tech Question - Bike Cutting Out
  73. Stage 1 or not
  74. 2007 night train starting/running issue security?
  75. PowerCommander 3USB Map recommendation
  76. Technoresearch Direct Link
  77. New Throttle Body Idle issues
  78. Air cleaner question
  79. Should I dyno?
  80. Power Vision Question
  81. 1998 flhrci cam position sensor
  82. 89 heritage ign relocation/wire elimination
  83. Stage 2 map needed for Power Vision
  84. PV AutoTune Module Placement on a Fat Boy Lo
  85. MM EFI and wiring harness
  86. Autotune module question.
  87. FP3 with CAMS????
  88. fuel pump loosing pressure
  89. 2007 street glide stalls when I pull the clutch in to decelerate
  90. AT-110 installation questions
  91. Power Vision tune - question
  92. can it be done
  93. multiple bikes
  94. Thundermax XMS (exhaust matched system)
  95. What does a fuel pak do for you?
  96. Superchips Vigilante explained
  97. What model number SE Pro Race Tuner do I need.
  98. Tuning spark timing
  99. Factory Default Calibration
  100. PCV Map Help
  101. Using a fuelpak with cam upgrade??
  102. Tts problem - pls help
  103. 1998 Road Glide, EVO,Injected, programmer/cam help
  104. Security system question
  105. Tuners in Sonoma County CA
  106. Vance and Hines fuelpak settings
  107. Vance and Hines fuelpak settings
  108. Replacing spark plug wires
  109. Battery post melted
  110. PCV - which base map do I use?
  111. Tuner but no disc or cords
  112. Part # for Bosch O2 Sensor
  113. diagnostic code question
  114. Ummm I need advice on Tuners
  115. 2002 XL Carbed
  116. SE Super Tuner Pro Question
  117. 2012 FDXWG - VH Fuelpak issue solved
  118. minimum fuel to start?
  119. 2010 road king switched to limp/parade mode in cool weather
  120. reinstalled ignition switch after fork oil change.... now won't start!!! misfire
  121. Dynojet Website Down??
  122. Soft tail slim lazy starter??
  123. hot stuff
  124. Superchip Vigilante tuner
  125. map sensor high
  126. 2003 Delphi FI Cold Start Issues
  127. Problems starting
  128. Power commander v...wow!!!!
  129. M&M to Delphi
  130. Active air intake blanking plug
  131. Which ignition for upgraded 88 to 98 motor (carb)
  132. Do I retune if I change mufflers ?
  133. do i need a tuner to get a dyno map
  134. Opinions on DK Customs
  135. Custom Tune Influence Tuner Decision??
  136. rushmore PV
  137. Weber carburetor
  138. SE Heavy Breather Filter Dimensions??
  139. what do i do ?
  140. New exhaust, need a tuner and cleaner 13 SG
  141. 2014 Street Glide Special will not start!
  142. Why Autotune ?
  143. Tru Duals tuning
  144. no power to ignition
  145. Re-Install Fuel Tank on 2002 Road King
  146. Swapping TSM for TSSM
  147. Strange spark bug single fire igniton
  148. Fuel Pak 61001A
  149. HP and TQ at high(er) altitude
  150. Tuner for 2001 Ultra
  151. 06 street glide map for pcv
  152. Engine Flare On Start (TTS) TC103?
  153. Need help on air cleaner and tuner
  154. Another new problem
  155. Speed Vehicle sensor for 2014 iron
  156. 2008 Harley Davidson Nught Rod Doesn't Start
  157. Do I Use The Same Map ??
  158. Who makes this IGNITION BRACKET ?
  159. Backfire through intake during cranking
  160. Selecting SEPST Base Map for 2013 Touring
  161. 2005 FI RK Idle Screwed Up
  162. SEPST Basics???
  163. Fatboy2012 SE supertune
  164. 2000 sportster miss at higher RPM
  165. Module
  166. 06 FLHRI, FM 98", T-Max Map
  167. 2008 Ultra Classic Fly By Wire
  168. 2012 Road Glide Ultra MPG
  169. Fuel Mileage dropped too much!!
  170. Do I lose ion sensing with a Tmax?
  171. Coil issue? 99 Ultra classic
  172. Sportster fuel pump on a 96B
  173. 2014 ignition relocation and tank swap
  174. New Injectors, now what?
  175. Stage 4 103se starting issue
  176. Throttle bogging down
  177. Throttle by wire on 2014 Breakout?
  178. Fuel pack FP3 info
  179. Fuel pack FP3 info
  180. How is the 2015 cvo limited fuelled
  181. Tts map for 107 top end and s&s 585 cams
  182. Map for Tmax for my build?
  183. 2014 Ultra Limited gas tank question
  184. power vision
  185. PCV Map for 117"
  186. Need tuning advice.....
  187. Replace Dyna ignition module for same year Softail module?
  188. Changing VE Table question
  189. Magnetti-Marelli throttle / idle cable guide bore dimensions?
  190. 2002 FLHTCI bucking between idle and 70 mph. No check engine light
  191. Changing Coil on 01 Ultra
  192. 2012 ultra 103 i hear pinging but PV data log does not show it
  193. 06 stock touring exhaust
  194. 06 Street Fuel injector size?
  195. Spark plug wire reistance
  196. 1993 fxstc doesn't start
  197. Popping on decel and then dying at idle.
  198. system relay keeps blowing
  199. tuning
  200. 06 RK, T-Max Troubleshooting
  201. 2010 Street Glide CVO
  202. Fp3 rinehart extreme dual woos
  203. Fuel gauge/sender issues
  204. 107 build with rough idle in open loop
  205. 1997 Heritage
  206. Purge Tube? Cap or no Cap?
  207. Over heating engine Oil
  208. PV throttle position
  209. Dynojet auto tune questions
  210. Map and Tune question
  211. No power, but good battery
  212. Help! I have fireworks in my exhaust!
  213. 2000 dyna wideglide Engine light
  214. Air Cleaner Queston
  215. 2014 Wide Glide do i need a tuner
  216. My 98 Heritage classic just shuts off when riding
  217. Injector questions
  218. Need a better Spark Advance Map
  219. Tuning
  220. Will Turn Over, Will Not Start
  221. Power Vision Auto Tune
  222. 07 fxst
  223. Heat Problems with V&H FP3
  224. Any competent tuners in Texas?
  225. Tts calibration share-after a good map
  226. power commander 5 issues??
  227. Help an old Gearhead pick a tuner
  228. fuel moto 107 kit with super tuner pro help
  229. Zipper's "Zip Kit"
  230. "White goop" in fuel pump.
  231. help with screaming eagle tuner?
  232. Starter Sticking on 88 FXST Softail.... Can't figure out issue
  233. Power Vision Causing Very Hot Engine
  234. How can I remove a TTS tune?
  235. help me out
  236. Pro tuner reflash aorted
  237. need help with wiring
  238. 2006 flhx runs very poorly
  239. 262.11 HP. 241.65 Torque Daytona Twin Tec
  240. Need some advice…..FLHP to FLHX
  241. Metal flakes in fuel tank
  242. I'm looking for a map
  243. HELP!! 2014 HD Fat Bob (FXDF) Power Commander V Error Message
  244. Power commander 3 andrews 48h 2008 dyna
  245. oil dripping form air cleaner
  246. New bars cause bogging and backfire!?
  247. stumbles when hot at low rpms 2003 flhtcui
  248. stumbles when hot at low rpms 2003 flhtcui
  249. Sputtering, coughing and smoking nightster
  250. Lil bit of help with Thundermax PLEASE ...
