PDA
View Full Version : Ignition/Tuner/ECM/Fuel Injection
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 [38] 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90
  1. twin tec settings for 91 evo....
  2. Troublehead Electrical Question
  3. Help needed with PV Value File,PV LOG etc.....
  4. VTE2700P Injection over-ride
  5. Short?
  6. alarm problems
  7. Service Manager says Oil & Volt guages are for looks
  8. Headlight switch intermittent?
  9. screaming eagle ignition
  10. Idle Speed w/ new Rhinehart Slipons
  11. tail light and brake light out
  12. main harness got hot
  13. Idle air control
  14. need a honest mechanic in marysville wa
  15. Smoked a wire
  16. Help with custom R/T/B setup; 07 Fatboy
  17. Popping and spiting
  18. Can I zap my ECM back to OEM with the SEPST?
  19. Harley sx 125 problem
  20. Slip-ons to full exhaust...new map/tune mandatory?
  21. Power Commander V Map Request
  22. Technical help please. Strange problem.
  23. Cant Update TTS Mastertune
  24. P/n 70989-98b ???
  25. compu fire dual fire ignition to coil question
  26. TSSM and Assigned FOB question
  27. 71 static time
  28. dyno tune and programmer/tuner?
  29. speedometer
  30. Turn Signal Module??? Help!
  31. Stage 1 tuner help
  32. Could it be the spark plugs? Enginge sputtering
  33. jackshaft coupler
  34. Jackshaft coupler
  35. Testing Dyna S ignition system
  36. 02 night train fuse prob
  37. Pro-Tuner CPS question
  38. H-D softail custom 2003
  39. Big trouble in little China..
  40. no turnsignals only emergency flashers work
  41. Change the map on wrapped pipes?
  42. 2005 Super Dyna Glide won't start
  43. PCIII USB looking for good MAP to try
  44. Warms up and cuts out won't fire until cool..?
  45. Voltage Regulator
  46. Power Commander question.
  47. 02 fatboy electrical problem
  48. Battery tenders
  49. '95 Electra Glide Turn Signal Issues
  50. 2008 Ultra and pcv
  51. Flash ECM, SE PRO now invalid?
  52. Cruise control diagnostics
  53. Fuel guage not working, Fuel light constantly on
  54. ignition Module
  55. dead battery
  56. Turn signal question.
  57. Tach problem?
  58. PCV Maps
  59. Kickstart only evo big twin
  60. no spark!
  61. Starter Relay clicking and won't turn over
  62. ignition problem?
  63. big city thunder in short shots 07 dyna
  64. Hazard Lights flasing intermittently
  65. 97 electra turn signels
  66. Starter Issues
  67. Horn, headlight, left turn signal doesn't work
  68. brake/turn sign module question?
  69. Fuel gauge issue - 1995 flthcu
  70. Anyone using a PCV AND a TTS or SEPST
  71. Fuel Pump - Noisy
  72. Any experience with thunderMax open loop ecm
  73. Heat demon issues
  74. ways to enriched up fuel with super tuner
  75. 92 softail electrical question
  76. Speedo indicator cruise lights
  77. Help!!!!!
  78. Triglide battery charging problem when engine is hot
  79. Any takers ?
  80. Electrical problems
  81. 1980 shovel head won't start
  82. 2005 FXST Intermittent Start/Crank/"Click"
  83. Will not stay running
  84. 1980 fxs low rider won't start
  85. 1980 fxs low rider won't start
  86. Completely Dead
  87. HD Factory Security System, Reset after SE Speedo/Tach Installation?
  88. 97 electra front turn lights
  89. Power Commander III Lifespan
  90. pc3usb maps ? M802-007 or M802-006
  91. MAP sensor trouble codes
  92. `09 RG electrical fluke
  93. Power Vision Tuning Question
  94. Voltage Regulator going bad?
  95. Will not start
  96. Fuel Pump in FI tank???
  97. another tuner question for an 07 with exhaust change
  98. 96 road king fuel issue?
  99. 04 screaming eagle deuce electrical trouble
  100. TSSM doesn't reconize FOB ?
  101. electrical problem-need help
  102. Oily air cleaner
  103. Screaming Eagle Ignition Module, Sportster 91
  104. Need tssm help
  105. 93 softail custom wont start..?
  106. No Trims Showing PCV & AT-100
  107. accessory switch
  108. Dynojet Powercommander V question...
  109. bad or dirty injectors?? flooding out
  110. Bike fault or bad map?
  111. Don't neglect your battery
  112. Screamin Eagle spark plugs vs Harley Davidson spark plugs
  113. Dealer Replacing ECM's cause of TTS Mastertune
  114. Choosing Power Commander
  115. Dead fuel pump-need help!
  116. 04 FXDI drained battery, weird short
  117. Jumpstarted bike, now lights will not work (2002 Electra Glide)
  118. red oil light on. won't start
  119. Dyne tuned today.
  120. Se icm?
  121. SEPST map ACE disabled?
  122. Help with location of these ignition/engine control wires...
  123. Assumptions About TTS Mastertune
  124. Low Rider Instrument lights
  125. Engine cutting out when I open up the throttle?
  126. Dead Battery
  127. 2008 FXDF Fatbob won't crank
  128. Left Turn Signal Problem Sloved
  129. T-MAX Question
  130. 2 red 2 black 2 white help!
  131. P O'd at Zippers Thundermax
  132. 2004 wide glide, headlight, tail light want come on
  133. Map help - 2005 King
  134. Neutral Lite Problems
  135. electrical problem 1982 flh police special
  136. This makes no sense to me
  137. Smart security won't start
  138. rapidly flashing left turn signal
  139. new Thundermax feature
  140. Pc5 Tuning
  141. Fog lamp wiring help.
  142. Trask in Phoenix Reputation?
  143. usb flash for pc 5 need help
  144. Need Dyno tuning for my Thundermax
  145. Timing
  146. 2004 FXDLI and HD platinum plugs?
  147. Help trouble Shooting an error code on an '07 Deluxe
  148. Bike wont start no red key or odometer
  149. 09 fat bob cranks but no fire
  150. Rev Tech Ignition Problem...PLEASE HELP.
  151. Sportster Coil Interchangeability - Coil Relocation
  152. Light bulb in speedo of 2000 FLSTC
  153. SERT software upgrade?
  154. Phoenix Tuner Recommendation?
  155. Voltage surge? Rear turn signal blown.
  156. Power Point Wiring
  157. please help tell me what you think
  158. Battery recharge
  159. load equalizer problem
  160. HD Heated grip wiring information
  161. Power vision map help
  162. Twin Cam Coil Voltage Output
  163. ignition problem
  164. 2007 softail fuel pump?
  165. RoadKing Owners "HELP"
  166. please help brand new 2012 nightster!
  167. head light wiring
  168. Neutral Light Out
  169. FLHR Cruise Control wiring
  170. Tts=sert=sepst???
  171. FLHTCUI Accel coil install
  172. 2012 dyna fuelpak
  173. 01 FHLT ignition issues. Headlight to blame?
  174. 2007 RKC quit running while riding...
  175. Thundermax
  176. ECM Help
  177. Codes?
  178. Where to find 3 clustered wire for sale? Turn signal application.
  179. BrakeLight Problem
  180. crazy short
  181. TW-777 and TTS
  182. speedo not working
  183. My 1992 FXLR.
  184. Sest
  185. No signals
  186. Solenoid issue...I think?
  187. 124" S&S runs on one cylinder in the rain.
  188. what could be the cause of the problem ?
  189. Received Stage 1 a/c - Have a question
  190. 98 Electra Glide Idle Issues
  191. Hd lan, can, bcu
  192. ThunderMax with Auto Tune Help Please
  193. 78fxs tachometer
  194. Blue gel at electrical connectors?
  195. heritage delphi fuel injection year start
  196. system problems after removing Fuel Gauge
  197. speedo install
  198. I want to know why my 2011 fat bob....
  199. Lights don't work, start button doesn't work.
  200. where is my Stock map
  201. Thinking about tuner for 2007 Road King Need Input
  202. Idle troubles
  203. '05 Road Glide radio LCD display back light ??
  204. 02 FLSTSI, Cruise control?
  205. Tuner recommendation needed
  206. 2011 Softail tuning dilemma.
  207. to solder or not to solder?
  208. Thundermax auto tune
  209. Technical help please...
  210. 07 883 Wont Start
  211. Signal problems
  212. Crimping for a novice - turn signals 2009 Street Glide
  213. 09 Sportster Spark/Ignition
  214. Turn signal indicator stays on
  215. Diagnose this Electrical Malfunction Please!
  216. Deltron Battery Tender
  217. 2007 Road King quit while running wont start
  218. 2007 Road King quit while running wont start
  219. Timing with a hammer? (gaps way off...)
  220. Help with no-start (Repost)
  221. 2/18/12 and tuning ride with the Thundermax
  222. Confused with Stock exhaust?
  223. Bike wont start...
  224. Tuner
  225. Evo EFI to Carb
  226. Battery Replacement
  227. Thundermax Question?!?!?
  228. PClll map needed
  229. dyno jet
  230. Road king stalling problem 2007 sharp techs needed
  231. 32 Amp Stator Rotor kit
  232. Istalling another Cobra Tuner; remove HD map?
  233. SE Pro tuner question
  234. wireing project question
  235. Ignition wont off
  236. Points wiring and tach...
  237. Which Fuel Injection?
  238. ecm reconditioning testing replacement 2007 road king
  239. V&H Tuner on top of SERT load in ECM...go back to stock mapping first?
  240. kuryakyn smoked laydown tail light question
  241. Nology Hot Wires
  242. Looking For Thunder Max dyno tuner in Michigan
  243. Thundermax guage display question
  244. Thundermax guage display question
  245. Nightster will not start
  246. Injector problem dyna want start
  247. Front cylinder not firing
  248. No gas to back cylinder
  249. '00 Road King 88", SE A/C, SE204, OEM Headers, Rush s/o w 2" baffles - PCIIIusb map?
  250. PCV 120R Map needed
