- harley tc 88
- Problems with it shutting down
- Cost to Dyno
- PC III in an 07 FXSTC
- Amps Needed for Heated Clothing
- Warranty
- Coil Blows ECM Fuse?
- Help needed! Looking for a Stage 1 download
- Recall on 07 Harley-Davidsons
- Load equalizer needed to swith to LED blinkers?
- Has anyone used PowerCommander (extra features)
- SERT Stage II Map for 07s 96"
- Question for SERT tuners
- SERT
- tuner
- No Knock Retard Data in SERT Data Mode
- PCIII-looking for a canned map
- VE changes for drag pipes
- Decel popping
- Garage door touch pad
- Do I remap for pipe change?
- Changing OEM to LED signals
- share custom SERT numbers ????
- To dyno tune or not to dyno tune
- Roadking Accessory Switch...
- Dyno tuning
- PIAA bulbs for spot lights, what size?
- HD Signal/brake/Running Light Module
- Anyone install SE Ignition System, help?
- Irregular Idle Speed
- LED Problems
- bike pop-ing and spitting
- Installing radio need help
- Speedo/turn signal woes
- eetings friends,
- Running Lights Blowing Fuse
- Will not run below 5k rpm
- To SERT or Not to SERT
- Larger throttle body
- Rewiring not working ,Need help !!!
- dieing at idle
- hd race tuner
- How is warranty affected by adding a SERT or PCIII?
- sportster won't start
- can any1 help on a Sert map
- Tach
- SERT on a Carbureted bike??
- turn signals
- tach wiring on 06 road king
- How to read SERT O2 values?
- Deal or no Deal on a sert,
- Has anyone tried the SERT maps from HD Maps.com??
- Plug Wires
- softail cruise control
- Which Way to GO!
- another sert/fuelpak question w/a few new variables (i did search..)
- Pc 3 quit working today
- Reduce idle ?
- Thanks to Shovelhead Bob, SERT Info
- Lean & decel pops big time dealer says everything is good??
- Will these work?
- How close is the Canned MAP??
- PClll Tuner in Central Illinois?
- Idle vs oil
- lights out...
- Stage 1 or Stage 2
- Downside to Running Too Rich
- need advise on oil cooler/cruise c...please
- 2007 PCIII USB Maps?
- Is the SERT easy to master DIY?
- Installing a mini tach, need to know where pin #3 is in connector 39B
- Stock vs Stage 1 Ignition Curve?
- Decel popping....again!
- F.I. tuners suck
- SERT real time tuning
- My 01 EG has no spark
- want to keep o2 on 07 night train
- No dyno on modified bikes in so. cal?
- custom map....
- everyones take on SERT
- spark plug wires 95/FLHR
- brake lite stuck on
- Replacing Speedometer Mileage Difference
- Exhaust/Stage 1/ECM
- PCIII, hesitation, missing, popping
- Idle Adjustment EFI
- Power Commander Product Warranty?
- Recomended A/F mixture
- Got SERT
- WIRING FOR APES
- Bad pcIII
- SERT Base map for sock bike
- What's this hanging?
- Bike won't start
- SERT Says Bad ECM, Then Programs Successfully
- SERT and Brazilian Fuel (20% alcohol)
- 07 EFI question
- PC III & decel popping
- Thundermax ECM
- Data Logging
- engine trouble codes
- Will Not Start
- Snap-On Torque Adapter
- pinging
- badlands load equalizer 3
- My PCIII Dumped now I need a few ???
- Ignition table on PCIIIusb
- 07 ping, timing, lean ?
- new plug wires
- Welding on the bike
- popping
- SERT vs. PCIII's accelorator pump
- George ROCKS!!!
- Rear spark plug fouling
- Oil light flickering
- Complaints??? Thank You HD!!!
- Code won't clear
- New StreetGlide.....Stage 2 or High Output Build?
- Alarm system
- GROUP DYNO TUNING!!!!! SAVE $$$$
- map question...
- Mysterious Modes 20/21 on FuelPak
- Problems with CB
- TFI installation question
- Tutorial on EFI Dyno Tune
- ALTMANN AMM-P3
- Will PC III "Fry" ECM?
- Stage 1 flash...........what does it do?
- Fuel Injector replacement
- gas mileage
- Advice - TFI/intake
- Choosing a Starter
- Powercommander Help Please?
- SERT REPLACEMENT ???
- 07
- SE Race Fueler
- Bay Area Perfromance Cycles-Dyno
- Part number help
- SERT Question/Help
- repllied from Jamie pc 3 and mods
- PCIII tuner in Maryland ??
- fule gauge started the problem
- pc111 set up
- pc111 set up
- New SERT Owner needs help!!
- Engine runs rough
- Where riders are putting their PCIII on 07
- Mapping question
- 1K service coming up, which air filter best choice
- Hesitation problem with new cams
- Cobra fuel management
- Battery Tender
- 07 Harley FLSTSC & Dobeck TFI
- 01 Electra Glide Std Radio problem
- Idle jump to 1200 rpm after mods
- Lights below pegs
- SERT Dyno Tuning
- Dead Bike
- Fuel pack to Power commander?
- question about fuelmoto
- Odometer Display Gone
- Duel bulb halogen headlight
- TFI/DFO
- help me on my PCIII it pings and stutters
- understanding pcIII
- Tuning center in NE Ohio?
- Right Rear Turn Signal
- Alen ness big shot
- turn signal problems
- Idle Speed
- Yet another PCIII question
- What can I expect to pay for PCIII tuning
- Battery, Alternator, or Both??
- flstc starter motor problem?
- dfo/tfi
- SERT Base Map for '07
- "Click... Click... Click"
- PCIII Question
- 1982-1995 Handlerbar Control Switches Wiring Diagram Needed
- HD Race Tuner
- K&N 3909
- Speed/Odometer Probs....
- Dyno tuning in Dyersburg TN.
- cruise control roll off switch
- Fuel Pak
- slow idle return
- K&N airfilter
- '95 FXD turn signal wiring issue....
- Dyna 2000i Help!
- Help I need a pc map for supertrapp 2:1
- going from SEII slip-ons to v&h shortys...
- Stock Fuel Gauge Removal
- best place to buy 2007 PCIII online
- Installed PCIII map...
- OMG !!! I installed my Fuel Pak
- Tuners
- Am I Lean or Fat?
- Turn signal problem
- Looking for DYNO in Ft Lauderdale area PC III
- My friend's bike (2003 lowrider) would not start after a short 1 hour ride. We took it to the house
- SERT Data Backup
- Brake light stopped working
- Race Tuner
- two 2003 lowriders with no spark
- TECHLUSION TFI
- "Check Engine" light problem still not resolved!
- Adding xtra passing lights
- Battery Problem?
- License Plate Lighting
- Speedometer problem
- cruise disengages
- H-D Stage 1 & Pipe Swap
- Advice for Ignition choice
- Zippers Thundermax 07
- Help please
- PCIII Accelerator Pump
- Poping Back on Acceleration
- Looking for a PCIII Map for 2006 Touring with Wild Pigs
- Help with carb tuning please!
- Headsets problem
- DYNO TUNERS IN DALLAS
- Brake Light Flasher
- injector size and spects
- stud/bolt size for Softtail rear signals
- Considering the 07's LEAN condition
- loose connection on ignition switch, cause misfire?
- Auxiliary Brake Light/Turn Signal Kit
- 2001 FLHTC radio problem
- sert cd part #
- Finally Power Commander availble softail
- engine miss or vibration
- HD Platinum Spark Plugs
- Burned wire
- 93 Heritage.. sometimes wont fire
- Left Blinker
- Finally!
- Shovel ignition conversion
- momentarily engine stalling
- Wiring Problem
- n
- Base 2006 Dyna Map
- Failed Idle Control Sensor ???
- help with ignition switch
- Codes U 1255 and Pn 670333-04
- Lighted switches
- A.N. A/C
- Tourpac Lighting
- Headlight dimming/volt meter dropping
- erratic idle
- Tuners for 07 Softail?
