- Adding spots to a Fatboy
- After market 02 sensors
- acr solenoid settings
- Starter switch (key barrel type) wiring??
- power commander maps for my bike
- A little help with SERT maps please
- Dim hi-beam indicator lite when lo-beam selected
- 08 HD UC Cruise Control Issues
- Twin Scan II Experts
- SERT question
- Lean from 27%-85% throttle? 14.6 lean?
- Deluxe 07- accessory tap?
- Are the SERT lean?
- Does this look right?
- Thundermax - install running O2 wires - softail
- pc111/mpg
- Rev Eliminator?
- Dyno Results Question
- FXDF Fat Bob Headlights
- Why Cop Glide Running Rich ??
- left rear turn signal problems
- What's Best?
- t/max files
- T max; my afr target is 13.8 but I am at 13.7 to 15.1 is this ok
- PCIII vs SERT
- Carb adjustment on or off jiffy stand?
- why PCIII ??
- SERT 32107-01G Help Please
- Rear turn signals
- San Antonio, TX tuner
- 07 Police Roadking flashing lights
- pc111 /02 lose wiring
- stage kits..
- Problems Starting Due to PcIII?
- PC III and winterizing
- help
- Great Service at Zipper's
- SERT & SE AIr filter - Advice please
- Dyno tuner in Baltimore area
- PCIII O2 Eliminators
- Headlight Turning On and Off
- PCIII Throttle Position Question
- Biketronics Inc. SmartEqualization
- SERT file list?
- Fuelpak pros/cons?
- Do plugs tell the tale?
- High rough idle and missing under throttle
- Question for tuners
- PCIII map for Woods 6-6 cam
- pc111.more dumb questions
- Heated Grips - Why do they have 2 power sources?
- Sert? PCIII? ECM Download?
- HELP!!! Tail light blowing fuses
- Can't find B+ connector on an '08 EGC
- HQ ProTuner
- Hole to small; Rush slip ons just starting to turn gold on the edges
- 1340 Starter
- seems like firing one plug only
- Any good tuners\Dynos in Charlotte, NC
- sert questions
- Starter Problems??????
- where to get new EFI connectors locally?
- Any T-Max experts on here?
- Sluggish to start
- Greenville,SC tuner
- South Texas Tuner
- ENGINE LIGHT WITH TMAX
- Engine Starter turns over slowly 96 1200 sportie
- DYNA LOW RYDER 2002 SECURITY LIGHT WILL NOT TURN OFF.
- Bypassed Clutch Interlock Switch...but
- S.E.R.T. WITH DYNO TUNE
- Tuner in Northern Il. or Southern Wi.
- AFR & TMax
- loss of power
- Code 134 07 FLSTC
- E C M codes
- change air filter sporster'07 this is correct?
- Will TMAX keep learned points on battery removal?
- noise suppressor for audio
- Screamin' Eagle Breathers
- What's the best way to lean out a PCIII map
- Engine Warning Light / Historic Fault Codes
- PCIII USB and 02 Elliminator
- Base SERT Map for GMR 107" Kit
- pc111 questions
- Why ?
- Humor the old man for a minute
- Zippers confirms Tmax for 08 available by "1st of the year or so"
- ebgine codes for 2000 road king
- Help with New Radio on FLHT!
- Odyssey battery
- SERT PLEASE HELP (problem solved WHEW)
- '08 SERT cals
- HELP PCIII hard start Melt battery post
- battery discharge rate
- is there a separated table for each cylinder on the tmax?
- Anybody wanna swap Dyna SERT maps?
- Gel batteries
- Sportster sputters after fuel light goes on.
- wiring
- Tmax trying to get better mpg
- ThunderMax before or after first service ?
- possible ignition problems (check engine light)
- Check engine light comes on at 40 mph and stays on
- Size of headlamp
- Knock Sensor set on or off with SERT?
- sert CLB tables
- How many times...
- SERT can't read vin
- no spark
- ANYONE RUNNING TMAX MAP FOR
- 80 MPH cruise control limit
- LED Turn Signal Installation Woes
- fog/running light switch and power
- SERT Cal #78 -- v462 vs v476
- Looking for good tuner in Western Washington
- used 93 electra glide classic...needs work
- Gremlins?!!!!
- Big Sucker not fit 08?
- hot wire under fairing on 2008 FLHX
- SERT H or G ?
- help with 06 Deuce (bad gas mileage)
- Radio 2000 ultra
- SERT & SE Air Filter - Results
- Help
- HELP!!!
- location of the ecm
- not so positive
- What is he talking about
- Injector Upgrade 06 Touring
- soldering tips
- Passing lamps
- Disconnect turn signal lights
- Remove glass
- Turn signal comes on by itself, won't turn off
- Order of Installation ?!?!
- Removing Stock ECM for Thundermax installation
- SERT DYNO Tuner in South Florida Needed
- Need technical advice on modifying wiring on a TMax
- hand held electrical diagnostics
- Signal For Tach?
- Price Difference On Thundermax?
- pc111 vs hd warranty
- HEY GUYS...
- Canadian SERT price?
- V&H FuelPak or ........
- Fuel Gauge / Sender Unit - Diagnostic Test?
- Battery Recharge Problem
- help needed for headlight
- ecm and sert switch
- 2002 RG engine light.
- How do I stop the ping?
- 06 Cop Glide HP/TQ Numbers and MPG
- about VE, spark table, AFR....help.....
- Tmax ECM/auto tune $900.00 or just auto tune $400.00
- "08 Dyno Results?
- Tmax Assistance please
- Starter Engine Keeps Running Please Help
- Crane Hi-4 with VOES ???
- Fuel Level Sending Unit Schematic & Diagram Please...
- How to set "Chirp Mode" with hands-free security system?
- FLHT starting problem
- race tuner
- sert map confuse...help...
- What file to use?
- Terry TV II or Arlen Ness Big Shot?
- Terminal Velocity vs. Thundermax Closed loop
- Amp Pin Crimping Tool
- Dyno vs Fuel Management Devices...
- XM Radio / Blue-tooth Question
- Thundermax idle problem!.............help
- Tach Stopped Working
- Vance & Hines Deceleration Popping with SERT
- SERT Question & link to Manual and J files
- How do you determine if you have 8 Deg or 25 Deg Injectors
- Screaming Eagle Air Cleaner
- What does the auto tune in the tmax do?
- 2007 Softail "active exhaust" butterfly disableing
- No spark or very little spark
- Hard to Start
- have to raise VE on SERT REALLY high???
- 08 sert, 103 kit and fly by wire--need help
- Is Stage 1 Download Enough? SE/AC and Supertrapp 2into1 on '08
- 95 heritage turn signal issue
- deutsch and amp connectors??
- TMax install just done
- Pin Count
- sert help
- Twin Scan II Arrived Today
- Who has dumped their PC111 for a Thundermax?
- sert guess im stupid
- Make these lights go out!
- Arlen Ness Big Shot Adjustable Fuel Injection Tuner
- Are the Harley SERT maps cooler?
- Security Key Light and Turn Signal
- Ultima Wiring harness 18-533
- Please HELP 1972 Sporty Starter Problem
- Ocassional Sputter & Staul out on FLSTFI?
- opinions please
- Daytona-Sensor twin Scan II
- another newbie fuel controller question
- What to do with an 08 SG with abs
- Update Map (179AE...)
- Thundermax,Fatcat,&Big Sucker on 07 Streetglide
- Thunder-max tuning question
- t max bad mpg will the auto tune fix over time
- andrews coil
- Speedo cable connectors ..help please
- PC3 map 812-020 07 ultra w/rineharts ?
- Nitrous Oxide
- Cylinder Trim
- COBRA FI2000 FIRST IMPRESSIONS
- Apologizeing
- PCIII with SE air cleaner
- TMAX USERS
- Loading Maps
- So what was the out come for the PCIII slow start
- Fuelmoto
- PCIII or V&H Fuel Pak
- PC lll Commander
- O5 dyna shuts down at 3500 rpm
- SERT--DOES work with Vista!
- 98 FLHTC Hates cool weather
- Starter
- Anyone else have this problem with PCIII....
- speedometer problem, can someone plesae help
- DTC Help Please
- 02 Twin Cam shutting off after acceleration
- Gear Indicator
- Override clutch interlock
- Stock Air-Fuel Ratio?
- audio problems 96 ultra
- removing thundermax
- Cobra Tuner
- Fuel gauge sending unit
- Rush slip-on to Rienhart system
- SERT software V462
- will I have to remap?
- help with diagnostic codes please
- Wont Start please help
- re mapping question
- tmax install, 27 mpg, what the ****
- dead battery help!! do i need a new one, or what?
- T-Max Help!!!!!!!!!!!!!
- SERT prices
- download for 25 degree injectors
- Intermitent electical problem
- 2008 883 Sport Custom Induction
