PDA
View Full Version : Ignition/Tuner/ECM/Fuel Injection
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 [46] 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90
  1. Getting a tune SESPT
  2. 2007 TC96 ignition swap (EFI to carb)
  3. Impatient curiosity question...
  4. EFI Tuners = Mind Boggling OVERLOAD!
  5. Map question
  6. Charging problem with 03 WG
  7. wiring a voes
  8. Power Commander and ECM Settings
  9. 2005 ultra overheating and no power
  10. 1974 Ironhead, severe misfire under load
  11. Stator and Regulator ID question
  12. 08 street glide starts and dies
  13. thundermax connectivity problem
  14. Question about SEPST software install
  15. Strange problem-help me fellas
  16. no tail lite
  17. Aftermarket stator
  18. throttle by wire harness question
  19. 99 FLHTCU-I IGN module or ECM??
  20. Low Mileage, stock staller....
  21. 91 fatboy doesn't power up
  22. Battery Drain
  23. Starter just spins....
  24. No dash, turn or brake lights
  25. What is the REAL story on mapping after minor intake & exhaust changes?
  26. 99 FLHTCUI-where is %$##@(*&^^&$! ign module
  27. SERT info & help please
  28. 08 Heritage Battery Problem?
  29. Got my bike back today!
  30. shutting down
  31. HD EFI Super Tuner SE??
  32. wiring in alarm siren ???????
  33. flasher relay location & or signal wire
  34. I have some questions about PC IIIs
  35. Need some advice with diagnosic codes
  36. Can the TSSM...
  37. SEST Vs. SEPT Question
  38. Tuning question for v rod
  39. HD heated grips
  40. MAPPING a Power Commander III
  41. Is My Stator Bad
  42. post usb III maps
  43. need help whats this wire for?
  44. timing on a 124 cu in
  45. Cobra Fi2000R Fuel Processor
  46. 1996 RK what is code 15 ?
  47. Charging system problem
  48. Power Commander III
  49. 2009 Crossbones issue long post from other thread. Hoping this sounds Familiar here?
  50. simple wiring plan for a evo with single fire coil
  51. I bought a NIB SERT...CHEAP, will 32109-08A work on a 2011 Deluxe?
  52. Need help Identifying this connector
  53. electrical/speedometer
  54. switch/ blinker problems
  55. Mytune question.
  56. Electra Glide fairing lighter
  57. smaller battery on the market ?
  58. Water problems
  59. Still cant find problem
  60. Security System, 2007 Street Glide
  61. master tune MT6 files
  62. Fuel Light
  63. Brake Relay Always Has Voltage - Correct Behavior?
  64. Security System Locked
  65. Loss of speedometer and headlight
  66. Dyna 2000 I No Spark ?
  67. Jaybrake Hand Control Wiring
  68. Tail-/break light problem. I think I just fried a board:(
  69. starting problem
  70. major electrical problem
  71. Anyone go back to SERT?
  72. brake function to fender tip: doable with my setup?
  73. Mikuni HSR Kit?
  74. code Reader's
  75. advanced timing
  76. Vance & Hines Fuelpak Tuning?
  77. need help
  78. ACR question
  79. New Pipes, ECM, Air Flow & Dyno'd
  80. Afr desired line at 14.6 shouldn’t be a 13.5 on my supper tuner.
  81. Electrical failure when riding over water
  82. Thundermax or race tuner ?
  83. Red Indicator/Warning Light - What is it?
  84. overheating
  85. Newbe SEST Question
  86. Have spark, no fuel delivery, new ECM
  87. Horn is the only thing that works.
  88. Park lights...
  89. Unsealed battery
  90. Blondie not so dumb
  91. Pushed the Yellow Steed for the LAST time!
  92. What went wrong with my Electrical?
  93. built an audio system for my RK and now it wont start. need help!
  94. How to tell if I have a sert or other
  95. Tuning abbreviations ?? Help
  96. 2003 Heritage EFI Coughing/Popping on Decel
  97. headlight bright, dim ,bright, dim
  98. I need a PCIII USB Map Suggestion
  99. road king speedometer issues
  100. Andrews Cams installed for $500
  101. Engine check lamp off
  102. 2003 high idle
  103. 2003 high idle
  104. Intermittent Starting Problem on my ’09 Softail Deluxe
  105. Blue Lightning Spark Plugs
  106. PCV question
  107. good tune makes motor smoother?
  108. Thoughts on an older DTT TCFI 2 single sensor kit?
  109. Best Tuner around Atlanta Ga area?
  110. Bad Stator - Underlying Problems?
  111. VR or Stator
  112. electrical issue
  113. Dead Electrical System
  114. CHT of XXX degrees = warmed up
  115. Dyna Fat Bob Relay Problems
  116. Smart Security key light on while riding
  117. help with dtc code 31
  118. TTS V-tune and 2007 VRSCX
  119. I have a few questions about fuelpak
  120. Shuts down
  121. Looking for an ECM
  122. Speedo Issues
  123. Running Lights
  124. HELP Why would i keep frying my ignition switch?
  125. 2003 Ultra CB wont receive.
  126. Running Lean
  127. 08 electra glide pcv 6th gear sluggish
  128. 2007 Softail Deluxe ECM
  129. Who's The Best Tuner Close to Iowa
  130. Best tuner for forced induction
  131. fat boy 2002
  132. No radio..grounding issue?
  133. Tuners - controlling spark timing and duration
  134. I can't find the Short
  135. 07 Ultra falling on it's face. NEED HELP!
  136. Dead Bike.....now 3/4 dead bike ........
  137. Intake for '09 putting on '07 (Touring)
  138. 00 rk fast idle actuator not working
  139. Electrical Help Please.........
  140. LED's for turn signal's
  141. P1001 & P1004 current codes, bike wont start.
  142. 07 dyna headlight replacement
  143. Map Needed
  144. Exhaust Pipe Setting
  145. coil specs for points ign.
  146. 99 XL883 blowing headlight fuses instantly.
  147. 2008 ultra getting code u1300
  148. V&H Fuel Pak vs Power Commander vs H-D's kit
  149. Is knock turned off with SE Plugs?
  150. This Doesn't Look Good
  151. Fuel Injection Module
  152. 103" 2011 RG ultra sudden power losses
  153. Hitting bumps engine cuts out!!!!!!
  154. Won't start PIN issues
  155. HELP '98 FXD Electrically Dead
  156. Simple answer I'm sure Charging Question
  157. Laptop tuning Question
  158. DTC Code B122, Bike won't start !!!
  159. Charging System Issues
  160. Turn signals backwards on 2000 Sportster?
  161. tuning with Twin Scan + WEGO IIID
  162. question
  163. 07 Softail SERT canned map choice help ASAP please
  164. Troubleshooting codes
  165. TTS Mastertune Question
  166. fuel pump not coming on
  167. Fatboy Lo with pcv map question
  168. Starter/solenoid '03 Heritage
  169. Trouble with my sportster
  170. 97 Heritage Softail trouble starting
  171. alarm ?
  172. alarm 07 streat glide
  173. Quick ? about my ignition switch on Fat Boy
  174. 2002 VROD instrument cluster dead
  175. FuelMoto tuner-good for the money?
  176. 1990 Fl High Torque Starter
  177. Static from rear speakers when operating brakes
  178. New to forum! Help with 1972 Sportster not starting...
  179. Redding California needs TTS help
  180. Help with 1972 Sportster "issues"!
  181. bad ignition switch
  182. need help about coils and ign. modules
  183. Terry TV3
  184. TMAX Control Center
  185. Amp Multilock Help
  186. GPS Marine Speedometers
  187. I have an electrical bug, cant figure it out
  188. Brake lights question
  189. Horn doesn't work on '04 Road King
  190. Electrical Gremlin [clutch]– PCV w/Autotune Install (Not a PCV Issue in my opinion)
  191. Good tuner near Plattsburgh, NY 12901
  192. A question about the charging system
  193. Crank Case Sensor Intermittent Code
  194. 2008 FLSTC Loss of Idle
  195. What's the best option for fuel management
  196. 05 Softail headlight wiring problem
  197. 2003 Fatboy charging questions
  198. do i really need a new ecm
  199. new bike, bad plug wires
  200. Fault Codes P1003, P0261, P0263
  201. OK, so I need some help deciphering a PCV map
  202. Tail light works but brake light doesnt
  203. Complet Electrical Failure
  204. brake, tailight problem
  205. Sepst 2011
  206. give it gas and cuts off
  207. Need a tuner
  208. Maybe a problem....
  209. ironhead dosent start
  210. no lights except for brake lights????
  211. interchange tunes
  212. How weatherproof is the electrical system on a modern HD motorcycle?
  213. TTS - where to start?
  214. consistant misfire
  215. Problems with VCI update
  216. Please Help!!
  217. Looking for Diagnostic tools
  218. Bike just dies
  219. New air cleaner/exhaust...Need help.
  220. Se 254 Cams
  221. 1997 flhri speedo issue
  222. Type of ignition relay
  223. Speedometer not working...
  224. How do you check the IAC?
  225. Power Commander III Help
  226. Son of a!!!!! lol
  227. Cam Swap / Speedo Quit
  228. Bad Switch?
  229. Warm start problems
  230. 2006 Night Train EFI
  231. HELP HELP engine backfires when you give it gas
  232. SERT or PCIII MY HEAD HURTS!
  233. Will an amp kill a battery in 10 minutes???
  234. Which performance module?????
  235. pops thru air cleaner.... help
  236. Would a tuner make that much difference on a stock bike?
  237. What type of alarm system or security is the best?
  238. Installing a new air cleaner, time to remap the EFI
  239. 38 or 45 amp?
  240. Sporty Speedometer
  241. Sportster Cruise Control
  242. 06 Deluxe-Right Turn Signal won't flash
  243. new Battery...bike just won't start after ride.
  244. Grounding Problem?
  245. Advise on upgrading my ignition system
  246. Question re Dynotune and ECM Maps
  247. need some help
  248. 03 nightrain no spark
  249. Garbled Sound
  250. Gert ... Reach out bro its hawkeye
