- ECM to Carb on 2000 Road King Classic
- PV Tuner-idle enrichment
- V&H Fuel Pak3 - Buyer Beware
- B2161h - PN 41000349F error code on diagnostic
- Tps at 7% in idle
- Power vision questions reset trim levels and scale cap?
- Spark Plug Wires..??
- Has anyone experienced putting fitting on a nylon fuel line?
- ECM is putting out 10v instead of 5v Help
- evo wiring
- 2009 Sportster cutting out 1/4 P0131
- Possible 02 Sensor Failing
- V&H Tuners and ABS Brake Bleeding
- 97 EFI road king
- 2007 HARLEY XL 1200 C Rough Idle & Wont pull away
- Powervision PV4 issue
- Dyno tune using Dynojet PV3
- installing Cylinder over Piston
- No hits with target tune help
- Help me,,, sportster 1200 s ignition
- PowerVision and displacement change
- Single Fire Coil ohm acceptable tolerance and 2.4 vs 3.0 ohm coils
- Air cleaner bolt 923 torque
- Fuel gauge reading?
- No more auto cap and scale
- Performance ignition hp gain?
- Low Fuel Light On, for no good reason
- Winter storage
- 08 Road King running on rear cylinder only!
- Dead bike
- Tuner questions.
- "interesting" timing event
- Autotune
- End of tuners?
- PV4 Question
- Engine sensors major supplier/source
- Im not getting spark
- S E Ventilator Extreme Air Cleaner
- Is there any danger or issue with running a 1:1 Throttle Blade setting, 2018 M8 Softail 114?(Ref Screenshots)
- Powervision 3 vs HD warranty
- Powervision 3 wont connect to 2022 iron 883
- Screaming Eagle EFI tuner help
- 2007 HARLEY XL 1200 C Not Running right
- 97 dyna
- HD SE Smart Tune Pro with Pro Street Tuner vs Thundermax
- FP3 Throttle Progressivity change fail
- Rough shake
- 2021 Softail Standard Air Filter/Exhaust
- I know nothing
- Thundermax ECM without O2-Sensors
- Power Vision WB 02 Sensors
- 1995 FLHCTUI no spark
- Anyone Replaced 6228-08A Fuel Check Valve Assembly on Newer FLHT Models? How to do it?
- Throttle Progressivity SEPST
- swapping stock air cleaner for another stock air cleaner
- ECM: Is there any where to get a 2000 Classic Road King ECM repaired at?????
- Dyno Tuner in NJ
- Sportster not starting after sitting for a year
- 2014 dyna replaced fuel pump due to problematic behavior and now the bike won't start
- Throttle Body Shaft Worn
- Testing fuel pressure on 2000 EFI bikes
- 93 Sportster Crank Sensor Test?
- New Thunder-Max Install On My Softail Springer
- 2012 Road King Electrical Nightmare
- P2185 code won't clear
- clutch arm bushing
- Screaming eagle super tuner pro reuse?
- Power Vision Autotune
- primary chain
- evo adjustable pushrods
- 93 Sportster, No Spark
- Rough idle troubleshooting
- Ignition Terminals and What They Mean
- 2000 Harley Road King Classic high idle after warm up
- Bleeding fuel pump/tank line
- ECM problem, no go
- SE Super Tuner Questions
- tranny oil
- Stage 1 Question
- '89 Sportster Running Rough (Front Cylinder Timing Off)
- 1 pop when revving
- WTF Tutorial on Building Timing Maps for Modified Engines
- Magneto trouble - Fairbanks Morse
- 2 Bad PV4's in a row?
- Out with TTS in with Thunder-Max
- 08 Road King backfiring
- HOW TO TEST fuel pump?
- Target tune install help
- Brand New PV4 Dead
- !984 Super Glide oil in dry primary
- '09 CVO Ultra - Won't Start
- Power Commander V
- New TTS Unit - Bluetooth!
- calibration programs sharing
- ThunderMax shipping to California
- What is the length of time that you can run a smart tune for with the HD Pro Street T
- 2000 TC w/ MM w/ ThunderMax ECM Idle Issues
- Stage 1 tune by dealer without a tuner?
- Xr1200x 2012 - ecm
- FP3 or Vied
- Faulty/bad ECM?
- DynoJet PowerVision Tuner Setting: RPM Limit Threshold and intended RPM/Speed limiters.
- 2003 sportster 883 spark issue
- 2016 HD Softail Deluxe ECM reset after nut came off header flang
- Have FP3 but now need a new phone- Help!
- 2010 SG Random stumble/misfire? off idle into initial acceleration
- 107 with Heavy Breather Elite
- A2 license map Harley
- Efi tuner
- clutch problem
- Power Vision - Idle Speed adjust
- Tuner question’s
- 05 FLHT , rear cylinder issues, misfire
- High RPM P0122 (TPS v Low) Code only on decel
- Power Vision (PV2B) tune file needed
- 2000 Sportster 883 spark problems
- DynoJet Quick Shifter for Harley Touring
- Bike's too slow! Really
- Speedo counting mileage in neutral
- M8 High Idle. Air leak test?
- Wye cable for O2 sensors?
- Vance & Hines 65006B Fuel Pak Question
- Twist grip sensor variations
- How To Richen Mixture
- 2000 FLSTC No Spark after Short
- is it the battery or something else?
- Thunder max and warranty
- 08 RK fuel Filter?
- Understanding Thundermax/ Fuel Moto/ Zippers
- ECM Problem? Stumbling / injectors Code P0261/P0264
- Logging Tune Data at Startup?
- Fuel Pak 4
- Troubleshooting error code P0152
- 2015 Sportster Iron - Start Hesitating
- 20215 Sportster Iron - Start Hesitating
- Tuning Used Engine; Unknown Specs
- Throttle issue involving induction module pins?
- Early Twin Cam replacted with Later model without CMP
- Surging off idle
- Tune or something else?
- Fuel pump issue
- 2008 FXDC starting issues, not firing?
- No fuel pressure but can still hear pump
- 2000 FXDL died while riding, blowing ignition and accessory fuses now.
- High idle
- Question on Powervision "Base Maps"
- 09 Nightster Wont fire up
- 2007 Roadking starting issues
- 2014 Harley Fatboy Won't Start
- Crank no start
- evaporated gas
- Ignition with kick start 1979 XLH conversion
- Softail Sputtering and Backfiring
- Cobra fi2000 fuel gauge reads empty
- Fuel Pump or Similiar Issue?
- Harley Street Tuner and S&S 50 state 2-1
- Power Cuts out in 2nd Gear - TTS Mastertune
- Throttle Trouble
- New here, not a harley guy but helping a friend w/a no spark situation
- Need help tuner , used bike
- Spark, fuel, cranks, will not start
- The blipmaster 5,000
- Switching from dual fire to single fire?
- 2008 RoadKing
- Installation of my new ignition module.
- 02 flstfi
- Idling/Sputtering, Can use some Direction
- 95 FLHTC bike won't turn on, everything else works
- 2007 FXDB replacing fuel filter
- Fuelpak Flub
- 2005 sportster Xl1200c
- Stage 1 Upgrade
- Help in Austin - bike is down on vacation
- fuel injection question
- no spark, novice question
- Problems with efi to carb swap
- 07 Fatboy won’t idle when hot
- 2000 Screaming Eagle Street Glide. the ignition module
- 2014 FLHR Electrical Issue - Ignition?
- fuel leak
- No Power to Dash/Ignition HELP!!
- Screamin' Eagle Smart Tune PRO
- Help with my throttle sensor wires
- Help with 2 red, 2 black, 2 white throttle wires
- 07 Street Bob loses power/misfire after wash
- Coil question.
- Bar change=fuel pump not priming
- What can I change to help fight heat?
- 2020 RG Idle/Throttle
- PV3 vs PV4 and dyno tuning
- 2007 Night Train stalls when reducing to first or even second gear...
- In need of working ECU 32423-99
- Yet Another SE PRO Race Tuner Question
- 2009 Sportster 883 EFI, Sputtering
- High voltage O2 sensor
- Screamin' Eagle Smart Tune PRO Automatic Tuning
- V&H Fuel Pak 3 and "modes"
- Powervision or Direct link??
- Fuel Injected Fuel Tank
- Po131, 132, 151 &152
- HD Plugs and High Compression Builds
- Riding with a Mag Ignition
- Misfire and O2 Sensor Reading
- Twin Cam with S&S MR103
- engine stutter
- High IAT reading powervision
- Huge shout out to Fuel Moto and DynoJet
- TC88, '01, Cam sensor symptoms? Check engine, hard start, MM
- Powercommander + AutoTune -> Powervision + AutoTune
- Can't retrieve STK file for Power vision PV2B
- Perplexed
- Temp Sensor Causing Driveability/Stalling Issues ?
- Ramsey speed fraud
- Need tuner advice for cam install
- 2021/2022 California screaming eagle tune
- weird ignition issue on 2014 fxdb Dyna street bob
- Anyone else had a TTS interface break?
- fuel pump assembly
- Acr solenoid
- TTS speed limiter issues
- Need some advice!
- Lug setting dynojet powervision ?
- Kinda panicking, hoping someone can help
- Compression + Heat and the benefits of a good tune..
- ignition problem
- Ignition and Fuel Management
- Fuel tank interchangeability for 2018 48
- FXSTB (customized) Fuel Pump Problem
- ignition switch disassembly 2015 with canbus
- Starter Relay
- 1996 Electra Glide ignition issue
- '03 Road King fuel pump ISSUE
- Smart tune pro
- Sale of Powervision PV-2B hardware?
- FP3 Fuel Pack
- wiring to my coil
- Fp3 tuner reving problems
- How can I check the current map on the bike with PV?
- Inconsistent start up idle
- Compression Ratio
- Ed, I need your opinion
- PV and FP3. Keep both?
- Major idle issues
- Ignition on 2001 Ultra
- Power but no start
- CVO flash and Mapping? - Is it going to reset the mapping?
- Power Vision will not recover
- Changes from Autotune
