- Dyna FXD not staying charged please help
- Pinging under load?
- Fuel Management
- Engine check lamp
- HD race tuner
- 1200 to 1800 rpm engine miss
- '06' Softail Deuce SERT Map Needed
- Rain and regulators
- SERT Dyno Tuner Needed - Near Raleigh, NC
- Starter??
- Arlen Ness Big Shot and Cobra FI200(R)
- 2006 Softail Electrical Diagram
- Speed Sensor short - Chrome flaking in tranny pic
- Rev. limit
- speedo sensor
- starting problem
- Thundermax EFI ??
- Spark plugs
- Help!!! - ECM Error code P0562
- bad coil cause engine sputter?
- utradio problems
- Save my bike from my 357 Magnum.....
- low idle
- SERT Part #
- Cig Lighter Specifications
- Hitachi generators
- Stator question
- first generation smartsiren vs smart sirenII
- every time
- Fatboy fuel guages are junk
- Hi, new guy here
- MPG & Acceleration Getting Progressively Worse?
- se coil
- SERT
- SERT: What temp should warmup enrichment stop?
- 2007 sert
- SERT & Laptop cost me Big Money for Failure
- PC3 and Gas Milage
- 06 Ultra Classic coughing
- Erratic tach and turn signals
- is this a fuel injection problem
- Help finding Tachometer
- Speedo problem?
- RACE TUNER, 06 Ultra
- Starter Removal and Installation
- Starter removal and installation
- '05 RK Runs different when hot
- PC3 Map for 06 Bob
- NEED HELP
- SERT Map Help - 2005 Road King
- Coil reistance
- DTC P1010 - Missing Password?
- SERT tune without dyno?
- Map Advice
- speedometer
- Power Commander Decel Adjustment
- Installation of Kuryakyn HALOGEN Silver Bullets
- DTC Help Please
- need gaps ect.
- Ignition Timing Marks
- '07 heat management gone?
- ignition problem dropping one cylinder
- Base Map File Number
- Trailer 5 pin to 4 pin convertor
- Turn signals and horn not working?!
- lightning strike
- Best Stage 1 and fuel control comb and why
- Daytona Twin Scan 88 Plus
- Low Speed Stutter, Im at the end of my rope
- Neutral indicator
- 05 RKC code U1016
- Is there advantage 42 mm throttle body
- brake lights
- LED Bulb question
- SERT cable question
- ThunderMax on 2006 Deuce or Fatboy
- Road Glide Inner Connect harness quetion
- Disappointing dyno results
- dyno results??
- 1994 Electraglide radio and turn signals problem
- rear lamp assembly
- FLHX Brake light strobe Wiring help
- code 53 2002 road king classic
- Charging cell phone??
- 2001Road King running on one cylinder? Need help.
- Keep killing starter relay
- Overheating and Electrical
- Blown fuse for lights
- SERT with previous download
- Decel Popping - Caused by Left over fuel, or freeflow exhaust??
- Brake Light Problem
- Cruise Control Question / Problem
- $275 Flat fee
- battery, speedo
- ironhead wiring question
- Going to have bike dyno-tuned Tues.
- Runs Great then shuts down
- Aftermarket Stators
- Gas pours out of air cleaner!
- Help warning light!!
- Canned map from the SERT CD?
- delete
- ESPFI
- Speedo & Tach problem?
- fuelpak values without baffles for VH BIG SHOTS
- marrying tsm
- Tuner reception very poor
- RevTech DFO installed
- PCIII & Popping Out the Air Cleaner?
- shovel won't start
- Ignition problem ?????
- No speedo, tac,turn signals,or directionals
- 05 RK sert programming....
- 86 sporty speedo & neutral light prob. w/ pics
- speedometer ?
- SERT
- Alternator or voltage regulator???
- Alternator or volage regulator???
- SERT Data Mode Question
- Dyno Results on a 06 With VH Pipes andFuelPak etc...
- removing switches from control housing
- Cobra 2000r
- FLHXI SERT Map
- Error Codes
- EFI - Fuel Pressure Test
- First Breakdown, Sudden Shutdown and no start action
- Stator Life
- SERT Cal w/o Baffles
- SERT Question
- I am running out of time....advice please!!
- Changin Idle on Delphi EFI???
- What do you suggest for electronic ignition for `77 FLH?
- WHich Calibration files should I use?
- 1987 Heritage ignition problem
- Want to swap new 05 DFO for 06 model
- SERT PC Cable help...
- This is totally and completely ridiculous!!!
- Phoenix, Tucson Dyno tuner needed
- Standard HD Down Load vs. SERT map Questions
- SERT advice needed
- SERT can they tell if it has been used or not?
- Need help
- EPA crakin down??
- PCIII USB Map for '06 SE Ultra
- Another one regarding low idle speed..
- CHeck engine light with PCIII USB
- PCIII Throttle Hesitation
- Is it possible?
- Passing lamp/headlamp not working
- 91 FLHTC Charging Issues
- Wiring Problem - Touring
- What EFi ecm to get?
- SERT install calibrations help needed?
- New Race Tuner Coming out, or Buy Now!
- ignition switch
- 96 FLHRI LIGHTING ISSUES!!!
- PCIII map w/ SEII, Air,stock ecm question
- which wire is the brake light signal ?
- serial port question
- FLHTCI Has it been flashed?
- 06 SE Fatboy SERT Map
- Finally....no more popping!
- Backfire through exhaust?
- VOES rattling in mount!!!
- Duece running like crap
- LED lighted turn signal mount..
- strange fuel pump noise at start-up?
- Electric/speedometer/turn signals
- Road King Problems
- Stage 1 with Stock Exhaust
- Help! Battery NOT holding charge..
- Terminal Velocity???????
- Battery Doesn't charge
- Logged a fault code
- won't run under 3K rpm
- Difficulty starting
- Left turn signal works, right doesn't
- injector differences
- Starter Relay
- Bottom Line... What ECM Option?
- stator failure
- Race Tuner
- electrical problem?
- Start Problem
- Fuel pak or not fuel pak
- Ping
- Stge 1 question
- Help me decide PC3 or TFI...........
- Ignition advice - stage 1???
- Do I have the right flash??
- Central IL dyno shop?
- Slow return to idle need advice
- 2006 Heritage Classic PCIII USB map questions
- Regulator
- will switching to 25's affect mpg
- FXDXI NIGHTMARE
- Changing SERT Decel Table for popping?
- Delayed Popping
- Bad Stator
- ECM Info
- Flashing turn signals when ignition is turned on
- Fuse keeps blowing
- PCIIIusb Cylinder Trim
- VH FuelPak with new 25 degree injectors...Update.
- Which injectors do I have?
- '02 rusty tank?
- Will A SERT help?
- DTC P0134
- V&H Fuel Pak Mystery
- Dynatek Ignition Question:
- Injector Wire connected to the ???
- SERT Questions
- Race tuner and OEM pipes air cleaner
- # of files included with sert
- I Wouldn't Have Believed It!
- Everyone's been stumped over this one...
- Motor Skipping - Help
- Quick battery question.
- SERT, best buy??
- Installing SERT
- 2005 Road King - Throwing Code P0122
- FXDXI Nightmare
- Need some help here!!!!!!
- Anyone have the sequence to reset the IAC?
- 1340ST TFI dobeck preformance dfo
- fuse blows every time replaced!!!
- Removing popping with SERT
- strange electrical issue
- SERT question
- Idiling problem
- sudden stalls..
- accessory circuit fails when ignition switch is on
- Hookers/now what?
- Adding acetone to fuel
- Shovelhead Bob....Little help here or anybody.
- crane hi-4tc
- Custom maps for SERT..
- EFI flooding issue
- lack of power
- Round AC Cover on TC?
- intermintent misfire
- rear wheel speedometer drive reloacation kit
- pcIII map for 25 degree injectors and rineharts tds?
- sporty random shut off problem
- SERT MAP NEEDED!
- Voiding the Harley Warranty?
- TVII questions
- Still popping after SERT and Dyno
