- Really annoyed with FP3
- Stage 1 tune with stock muffler?
- Oil pressure reading on Power Vision
- Fuelpak for 107
- vance hines tuners and throttle pack
- Another ignition issue, rear cylinder won't fire
- 2006 flhtcuse poblems
- Problems after installing new bars
- 2017 RGS Ignition switch reinstall
- Looking for old SERT software
- Engine running problems after Stage 1
- TTS and VE being low, help.
- My 4 Pin Plug Has Only 3 Pins.
- Better injectors?
- Ping Ping Ping
- do I NEED a fuelpak?
- 2010 street glide
- Efi to carb
- Tuner question??
- 41000008B vs 41000008C pro street tuner
- Spittering and hesitates on a qwick throttle snap...
- Security reset?
- Tuner advice
- Finally decided on a tuner.
- Tuner or dealer repair
- code error
- Crank Position Sensor Replacement
- 02 sensor
- Error code?
- 2005 ultra classic S&S .509 cams power vision map
- shovel with dyna ignitions just stops!!!!
- VOES setting of T-MAN build
- Can I still use my FP3 Fuelpak
- Dyno tuning in the Toronto area
- Won't Start
- Woods 777 cams and a fp3
- Adding a cam
- New PowerVision Harley CX Tuner from DynoJet / Fuel Moto
- TTS Masterune 2 single module - new
- Calibrate Your Speedometer, Using the Power Visions Tuner
- Replacement ECM and Screaming Eagle Tuner
- New Battery, Bike won't even turn over
- Speedo/Tach replacement
- A Honest Question.
- SE Super Tuner?
- Backfire into the intake, advise needed please
- tuning issues - pipe & cams combo?
- PCV questions
- High Idle After Coil/Ignition Relocation
- Low RPM deadspot
- Used SE pro street tuner
- An error code problem
- Sportster won't start when kick stand is down
- Arlen Ness Big Sucker
- SE 117" Street Kit Air Cleaner Option - 58mm intake
- New Build Hot Start Issues
- 2015 fxdb starting with ignition OFF
- MM to Carb Conversion - 2001 RK with factory Security- Please HELP
- Anyone know about this one ?
- fuel pump not turning on
- new fuel pump 2000 RoadKing
- FP3 vs dyno run
- FP3 autotune vs. preloaded map
- powervision or t-max auto tune
- Ignition problem
- "Finding" tuner
- 2003 RK occasional fast idle issue
- I Think I Have Decided on a Fuel Programmer
- Issues with fueling/fuel gauge
- Bigger o2 senser
- idle jumping when hot coming to a stop
- Fuel Injector Part Number Question
- Power Vision Help
- Tuner for CA Lowrider S
- $600 dyno tune?
- Part 2 of tuning issues
- Looking for SoCal Tuner
- 96ci with 103 tune?
- SERT pro Ve tables
- '00-"01 Magneti Marelli EFI Fuel Filter
- New build issues. Please help!
- Won't Crank
- What is this called, and is it supposed to leak?
- 2010 fatboy, wont start.
- 62MM HPI Throttle body M8
- TTS Mastertune or PCV with Auto Tune Kit?
- Ordered A PV Tuner
- When is an ignition module necessary?
- TTS Flight Recorder Tables Blank?
- XR1200 Starting Issues
- FP3 install
- Help with TTS
- Diagnostic Codes
- Want a shift light for my twin cam
- Engine will crank but won't start
- Crazy Idle Problem on '04 WG FI Help!
- Dyno and powervision
- "drive by wire throttle limit vs gear" Powervision
- Rev 11.002 SEPST
- S and S Cam plate and Oil Pump vs. Fueling
- Throttlebody help
- wiring diagram
- RoadKing Police V&H FP3 flash disabled cruise control
- Check engine light on and bike not starting
- Knock sensor sportster
- Chromebook and tuners
- stage 1 tuner
- Someone can share their injection map (septs) for a low rider s
- FP3 Autotune question
- Power Vision O2 Reading Stuck at 17.90
- Fuel injection
- 98'Road King Backfire fouled plug
- Start engine in gear?
- Need Help With Base Map for Fresh Engine Build SEPST
- Save tune on ECM with PV
- PC-5 W/Autotune, anything left on the table?
- fuel injection problem,
- Decel Tuning
- Auto tuner
- Drilling O2 bungs to 18MM
- These are good to go !
- Engine sputters 09 SG
- Cleaning Fuel Injectors
- Magneti marelli fuel problem on 2001 Road King
- Strange 2005 problem
- 09 FLHX bogging on 1st gear starts.
- Power Vision and Target Tune question
- Battery Tender
- Cloosed loop tuning strategy with Xied and PV together
- Cobra tuner
- Elec throttle issues
- MM EFI to Carb Tank Conversion
- FP3 Autotune on 2018 Fatbob 114
- Street Tuner
- I need help
- My14-17 calibration recall
- 2006 FLTRI 2k RPM when exiting freeway
- Tts mastertune
- Used Bike - Has it been tuned?
- P1019 Code & CEL/Water Temp Lights
- How to open throttle plate on drive by wire models?
- Warm up Idle with Powervision
- Help! New to HD, want to increase MPG.
- 2014 Ultra rough idle
- Making sense of ion sense technology
- Help with coil testing
- To time or not to time
- New to Power Vision and need help
- Vance and Hines FP3
- Check valve problems
- Having problems staying on while driving
- idles too low
- Need Ignition control module explained/ultimate wire harness issues
- 2001 Softail Injectors
- Power Commander Help!!
- Auto tune basic tuning
- 1999 FLHRCI MM EFI Tank to use on 2004 FLHRCI Delphi EFI
- coil cuttin out
- Will a high flow air filter do any good
- '97 FatBoy: New Battery, Won't Start
- Sputtering
- 2014 Sportster iron 883 SESTP super tuner pro race tuner ECM remap/tuning
- 2012 RK will not start
- 2015 CVO RGU hard to take off from Idle
- C&S Speed Shop
- FP3-iOS vs. Android
- Ignition switch
- Fuel Moto EFI tuner updated map install question
- Tune or not to tune?
- Ignition Switch Woes
- fatboy slim 2014 problems with ignition
- Timing problem any suggestions?
- SEPST & Smart Tune Pro Module
- Raw fuel out of the exhaust
- Exhaust and ECU troubles
- Road Glide stalls when throttle applied
- 09 Night Train
- You should read this; if you have a 2014 street guild stage 1 and Harley tune 617seb204
- Hi thank you for letting me join
- Install New Fuel Injectors
- M8 and check engine light
- Why would Harley change there tune (map) Is it worth the effort
- Fuel Line Tank to Intake P/N 62349-04F
- LOOKING for best PCV maps for 2017 Dyna w/cams
- 103 CI Upgrade
- Help!
- Tuner
- Why the hell
- Fuel pump running no fuel
- Not starting
- Carb to EFI Conversion
- 1st Gen EFI: good ore bad?
- Front cylinder turns into an air pump - NO CODES
- Trying to diagnose IAT code P0113
- Check valve 99flhtcui
- These new-fangled tuners
- After market tuner?
- 2007 Harley Wide Glide turn signal relocation
- Missfireing
- 2015 Heritage Security Light "on'
- ECU Dead?
- Power vision nitrous maps
- 1998 Road King Classic
- Harley will not allow me to download my old tune in my ecm. Harley says to use this new one instead.
- Coil and tuck
- SE Pro Street Tuner Autotune Questions
- Power vision active compression release
- V&H FP3 autotune question
- Rough Idle/Flat Coming Off Idle
- 99 flhtcui check valve
- Power vision data logs.
- Best bang for buck girl tunner
- 360 degree spark plugs
- Ignition modules
- Thunder-Max Map Problem with 2008 SE 110 motor
- 2007 street gilde
- bike shuts down
- FP3 Autotune - How many times?
- What tuner
- Spark plugs hi comp engine
- 1975 shovel electronic ignition
- Fuelmoto dynojet
- Screamin' Eagle Smart Tune PRO Automatic Tuning Module
- Error codes P0220, P0222, P1510, P2135
- kick stand is down engine not turning off
- Is there a way to view live data with tts?
- 2001 Fatboy Running bad
- Autotune thoughts
- Help
- No spark front cylinder
- Trouble codes
- Dbw injectors vs 07 96ci injectors
- Los of codes came up 2008 FLHRCI
- power vision and target tune issue
- Power loss
- Has a Miss at low rpm and cuts out and pops at wot.
- best tuner for a tc88??
- 2005 efi fatboy no O2 sensors wtf
- No fire
- Random hard cold starting 2002 Delphi EFI Road Glide
- No Pwr to the Fuel Pump
- 2015 softail shift light
- 99 ultra intermittent dead ign
- TTS Surgeon Needed
- 07 XL1200c runs rough at steady throttle
- 2001 roadking exhaust popping & throttle body chirp
- Code P0113
- 2000 Fatboy backfiring
- Accel super coil?
