- HELP HEADLIGHT PROBLEMS
- Computer Mapping
- Passing lamps 93 Heritage
- Speedometer Not Working
- Adjustment to a power commander map
- help with unknown electrical problem
- fxdwg charging problem
- Speedo
- 98 fatboy wire color to tail lights and rear turn lights
- Speedometer Electrical Problem
- Turn Signals
- Ordered a PowerCommander, anyonelse have one.
- Sudden ignition & engine shutdown
- Turn Signals
- Click, Click, Click!!!
- stereo help
- Electrical Problem
- Sea level more air /Altitude less air, why not flash ECU?
- Help, security system...Need a tech
- Wiring question
- (Stupid?!?) Noob Question...
- Electrical Gremlin driving me nuts!
- Flashing Lights after LED upgrade
- 1977 Harley XLH sportster 1000 wiring diagram?
- Power Commander
- Dobeck Performance TFI
- Radio Static
- Fuelpak by Vance & Hines
- Sportster Wiring Diagram
- Scanalizer Program
- How to do internal wiring on new handlebars?
- Pugs Wires Coil
- Electronic Fuel Injection and The Power Commander
- Gas Guage
- Engine Compression..How To Check It
- EFI Power Commander and the New Engine
- sportster alarm
- Know Your Security System
- Auxilary Lights
- TFI / DFO Pot Settings **
- diagnostic codes
- Fuel Injection controllers another view...*
- EFI Performance calibrations
- 2000 Fatboy Electrical Problem
- SERT, PCIII and TFI COMPARISONS
- Fuel Injection Terms Explained
- XM Satellite Radio Drains Battery
- Tach shuts down
- speedo
- Speedometer knob
- sportster starter problems
- turn signals quit working
- FYI article on DFO
- Wiring extensions???
- Power Commander
- How to test Delphi systems ECM codes (00-03)
- Starter Noise
- Wire connections question...
- head lights?
- Alarm check engine light on new fatboy
- Front Brake Switch
- Security Siren Malfunction
- Wiring Stuff
- HELP! HI-4 Single Fire Ignition
- CB stops transmitting
- EFI Tuning
- power commander acell pump download
- Brake Light
- Installed alarm module
- Fuse box 90 softail
- What's with the blinking lights?
- Electrical short
- Trouble with Kuryakyn Fuel Gauge
- Rear turn signals on Softail
- dead batteries
- FLHTCUI Fuel Gauge Problem
- Cost of Dyno-Tuning
- blinker out bulb good
- Code B1121 = what?
- Questions Regarding ECU & Muffler Baffles
- blowing accessory fuse
- sreamin eagle 7000rpm modual install on sportster ???
- Charging System Problem
- hooking up power commander
- I need the 2003 Classic EFI Diagnostic codes
- Accessory Connector and Switch - '05 Road King
- Help with Race Tuner and Caliber pipes
- Blowing an accessory fuse
- historic codes
- power commander III or TFI?
- Stage I download be to lean???
- Power Commander III USB
- Starter Problems??
- installing power commander
- HD Hand-Held CB mic????
- Testing ECM codes (04 - 06 Serial Data bikes only)
- Fuel Gauge
- Battery Tender
- power commander voids warranty
- Check Engine Light FLHRCI
- COIL
- Speedometer problem
- SILVER BULLETS LEDS
- Single fire--Dual fire
- Turn signal problems
- Road Glide Headlite Cover
- Bulk Wire
- Turn signal problems got worse...HELP
- No turn signals
- turn signal problems
- Engine issue. Engine Light on...
- Turn Signal stays on but not blinking
- Brake/Turn Signal Lights
- Simple to change lights---WRONG
- Hand Held CB Mic
- bad ignition switch
- WIRING PROBLEMS
- Brightest bulbs?
- HD High Performance Ignition Modules
- Installing air and oil guages?
- headlight help
- Ignition?
- RACETUNER
- Newbie Post RE: Intercoms
- Aftermarket headlight question
- Turn signals?
- After I had the remap
- Rev counter
- v.o.e.s.
- odometer
- LED Fuel Gauge and Voltmeter
- 99 DYNA LOWRIDER SPEEDO QUESTION
- Best Buy on PCIII w/usb
- High Beam Lamp
- Can't see the light(s)!!!!
- Ignition Switch
- Wiring diagram
- Turn Signal has mind of its Own
- Second Alarm Keyfob - Programming help
- 2 cylinder tach?
- Battery sizes
- FLHTCUI with radio/casette
- Tachometer 2004 Road King Install
- Low fuel light.
- Speedometer out!!
- More HP from High Voltage Coil?
- Left rear turn signal...
- Integrated Garage Door Opener
- speedometer question
- factory security?
- speedo
- EFI bike help
- Need wire color for T/Signal
- Tech lusion? module......
- Batt. Removal - 04 Sportster
- Tach install on a Dyna
- Turn signals
- passing lights and turn signals loose
- Stray Thought on Fuel Injection
- Power Commander...
- Fuel Injection Primer...
- Turn signal relocation
- crane ign
- Replacement Battery for HD Road King
- How Do Maps Work?
- Efi trouble code Help!!
- Blowing Ignition fuse
- Tachs
- Stage1 & Remap
- Need more rear running lights for SGlide
- HD Radio for RK
- Cruise Control
- starter shot, now what!!
- Rev limiter
- charging
- Sporty Feul Gauge?
- WHATS a DFO
- Carb or F.I.,which one do you prefer and why.
- Rear brake light
- starter solenoid
- Electric Start
- Computer downloads for Exhaust
- LED's on yur ride?
- TSM/TSSM programing
- Raod King cruise control
