PDA
View Full Version : Ignition/Tuner/ECM/Fuel Injection
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 [54] 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90
  1. what am i missing???
  2. dealer wouldnt change injectors
  3. Check engine light/ Battery light
  4. Want to lower IDLE RPM on 08 FXSTC
  5. 95 fatboy w/ 110' Revtech 45 mikuni, running on 1 cylinder
  6. pipe question
  7. Strange Idle
  8. Electrical issue, need advice.
  9. 99 Road King Carbed no crank!
  10. 01 fatboy intermittent miss firer and rough running
  11. SERT to TTS upgrade question...
  12. Starter kicking in as soon as you turn ign on????
  13. Bike shuts off under hard accelleration!!!
  14. 2000 road king fuel pump noise
  15. How precise are the V&H Fuel Pak Settings ??
  16. Interesting TSM/TSSM Question - Custom use on other vehicles...
  17. Battery has no charge
  18. Procharger on my 09 Street Glide
  19. Accel SLM?
  20. The Little Red Key Stays On
  21. Race Tuner
  22. Where to get mine tuned...
  23. blinkers on my 86 softail custom
  24. 07 Road Glide
  25. slipon muffler help!
  26. Nightster Tune
  27. Lube for throttle grip?
  28. SERT map help
  29. TTS mastertune help file error
  30. Tuning Required for 2005 Fat Boy w/ Big Sucker and Big Radius?
  31. Does this make Sense?
  32. Life span of a fuel pump?
  33. After charging battery, odometer reads wrong
  34. O2 Eliminators with HD Download?
  35. 1999 flhrci need help!!!!!
  36. 2004 FXDL/I stator question
  37. 2006 Ultra Classic - I'm a new HD owner
  38. Please somebody help
  39. 09 Streetbob wiring harness
  40. o2 sensor upgrade
  41. TMax Smartlink troubles
  42. Bike wont start after a while
  43. AF Ratio adjust vs parade download
  44. 07 FLHTCU Stock Map - TTS
  45. Fuel Controller - before or after break-in?
  46. runnin lean w/ PCIII
  47. Super Tuner Buy Question
  48. Brand New ECM
  49. Won't Start
  50. Problem Today
  51. blowing 40 amp maxi fuse
  52. Can we trick the Bank Angle Sensor
  53. Speedometer and Tachometer just quit working
  54. Using 04 - 06 Speedo in an 2003
  55. Fuse on the battery tender connector?
  56. 04 fatboy fuel problem
  57. How to check/clear codes '02 Deuce
  58. Have to start twice
  59. A "Band-Aid"
  60. headlight dims with blinker on
  61. SEST Map Timing Adjustment
  62. Hogtunes on CVO Ultra with /tourpack amp?
  63. Battery volyage went 5.5vdc
  64. Rapid LED signal flshing- Help!
  65. ignition switch problems
  66. need help? efi to carb list
  67. Check engine and security light with tmax
  68. Stator bad? 1994 FLHTP
  69. 1993 Softail won't start, need help!
  70. Key not working
  71. The RK Died Today
  72. Jiffy Stand Interlock Switch
  73. 04 electra glide oil light on
  74. "94 Heritage Charging Problem
  75. Weird PC3 USB problem
  76. Interesting Engine Temp Sensor Behavior
  77. Won't start after removing switch housing
  78. 09' XL883C Sportster Tach install Help
  79. tmax
  80. 07 sportster code P0107
  81. ironhead coil keeps shorting
  82. 04 road king help!!!
  83. Dual Bulb Headlight?
  84. where to tune for roll on ping?
  85. Ignition, electrcial popping noise/crackle.
  86. looking for help!
  87. download or not???
  88. Will low (bad) Battery effect EFI?? 03 Roadking
  89. Engine Light
  90. Arcing spark when wet
  91. PCIII took a dump
  92. 06 Softail Electrical Diagnostic Manual
  93. 06 electric glide
  94. fuelpak problem
  95. TMAT Communication Problems....
  96. 09 stock dyna pinging
  97. Need spark problem help please!!!
  98. Won't Start
  99. Another Tuning Question
  100. Question about SE Pro 50MM Throttle Body
  101. Need a little troubleshooting help..
  102. Speedo/Odometer
  103. Auxiliary lights on Fatboy...
  104. Tune Question??
  105. Erratic Idle, anything else I can check?
  106. Need Help
  107. B1145(HFSM) Security Antenna Open
  108. I dont know sh**
  109. 1997 roadking missfire
  110. Not Starting
  111. 09 touring trouble codes..p1511 and p2101?
  112. Will an ied give a p131 and p151 DTC code?
  113. Starting issues when attempting restart...
  114. Trouble code 06 Fxst
  115. Best place to buy Power Commander III?
  116. Went to bike show and put bike on the dyno
  117. Automatic Signal Cancel and Speedo problem
  118. Screamin Eagle Race Tuner for a 88 Twin Cam Help Needed
  119. 95 Electra Glide Overcharging
  120. Stage 1 Flash Question
  121. Replacing left side heated grip
  122. stall at stop
  123. 99 Night Train - Brake light not working
  124. here a tuner, there a tuner, everywhere a tuner... ole McTuner....
  125. 1992 Softail wiring question
  126. 1975 FL wiring
  127. 92 electra glide left me stranded?
  128. Error Codes? Something to be Concerned with?
  129. Adjusting idle mixture MM
  130. '06 1450cc FI - cough/stall when warming up then OK
  131. Fayetteville NC, PCIII tuning
  132. my head light and passing lights
  133. Heat Demons Grip on a hd muscle
  134. Bike missfire shut down
  135. Volt Meter on Bike
  136. Bike Shut Down, Kind Of...Safe Mode?
  137. Can someone explain this?
  138. Power Commander Problems
  139. Help!Anyone ever had this problem before?
  140. Rk engine missing
  141. Fuel Map Failing to Load
  142. in need of 2010 bagger for TTS tuning
  143. intermittent stall
  144. New notebook and SERT?
  145. SERT And pics of plugs
  146. Disconnecting battery and alarm
  147. Will not start without security code
  148. 89 FLHTC Won't Start
  149. 2006 flhti backfires
  150. 04 Fat Boy - diagnosing 'bus er' - Help!
  151. TPS Setting on 01 Ultra Classic
  152. electrical problem
  153. 07 street glide stalls...
  154. Wrong Colors??
  155. tuner & map?
  156. 1991 fatboy runs fine then bogs/sputters after 20miles
  157. horn,turnsignals and brake lights not working
  158. Bad Regulator??
  159. anyone had trouble with system relay?
  160. thundermax w autotune
  161. 05 harley chopper starting problems
  162. How can I tell which tuner i have?
  163. 02 FLHTC - Weird odometer display and electrical burning smell
  164. CEL steady after start for 5-6 seconds
  165. Dyno again because of pinging?
  166. New firmware in the Race Tuner
  167. Bad decell popping
  168. Outstanding Service
  169. Do I have to get a...
  170. Fuel injector cleaner??
  171. EFI Help Needed/Poor Running
  172. it just quit
  173. Loss of throttle on 08 Street glide (1200 rpm max) Throttle grip clicks in forward mo
  174. Need Help- Sert
  175. Question about RideMax installation
  176. Recommended tuner for an '08 FLHR?
  177. To Hot?
  178. Dead Wide Glide
  179. Factory Alarm Problem
  180. Air cleaner shooting spurts of air
  181. Question About Popping and SE Pro Tuner
  182. thundermax and timing
  183. Headlight not working?
  184. for the tech folks.....fuel or electrical?
  185. Broken Stud on Starter
  186. New Scooter, maiden voyage - Dead battery
  187. Installed new Rear Turn Signal assembly and in Trouble -1988 FXSTS
  188. Need help please.
  189. Question on Super Tuner and Stage 1 Down Load
  190. rear right directional problem
  191. tmax midwest tuners
  192. Blinker nightmare...
  193. need power commander map
  194. Heritage stalled
  195. bike shut off in rain
  196. 07 FLSTC Ignition switch
  197. 2001 fat boy
  198. check engine light
  199. PC V by fuel moto help
  200. early EFI-1995 ISSUES??
  201. Thank you All
  202. 08 ultra ?
  203. SE airfilter vs K&N airfilter
  204. electronic throttle
  205. Rev Xtend on the PC V
  206. 02 duece p0374ckp code
  207. SERT Question
  208. Electrical issue
  209. TBW wiring?
  210. Tuning out heat and decel pop with TTS
  211. FLH headlamp electrical and radio display problem
  212. Tmax map 401
  213. Tmax problem
  214. PCV and timing tables
  215. 1986 harley sportster no start
  216. SERT - What to adjust for decel jerk
  217. low fuel lite
  218. brake light stays on
  219. Code U1097
  220. Ground Strap Location
  221. No Start
  222. Front Turn Signal Won't Turn Off??
  223. 82 XLH Ironhead Sporty won't charge
  224. Laptop placement for vtune
  225. Need Info on Stage 1
  226. Anyone have Wideband Data logger?
  227. No Power - Voltage
  228. PC111 Map help
  229. 02 Rdkng police engine miss
  230. I need info on 32654-98 adjustable "race" ignition module
  231. Timing changes...when...how much?
  232. Need MAP for Sportster 1200
  233. IAC Position - kinda odd
  234. 1995 FLHTC 1340 Timing problems
  235. 1988 Harley Electraglide won't start
  236. Innovate LM-2 tuning w/PC-5 on '08 RK
  237. From EFI to Carburetor Upgrade Instructions
  238. '09 883XLC Fuel Leak
  239. SERT part number question
  240. Wandering idle on MM
  241. dyna 03 / blinking lights/ gauges not working
  242. dyna 03 / blinking lights/ gauges not working
  243. Tuner Timing tables for TW-6-6 Cams
  244. Pingel dry shot
  245. selectable map ignition
  246. Help! Cable swap and now no power
  247. Looking for timing help 450 miles from home
  248. 2001 Road King Classic - How do I pull codes?
  249. 12.8v batttery, only 9.6 to starter WTF
  250. bike wouldn't start
