PDA
View Full Version : Ignition/Tuner/ECM/Fuel Injection
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90
  1. Power Commander 807-511
  2. FP3 for 2008 Ultra Classic
  3. SEPST Cables not included?
  4. Cruise Control
  5. Thundermax and Power Vision
  6. SEPST Intuitive?
  7. M8 off idle power loss, then takes off...
  8. Do I NEED an FP3?
  9. 2004 Road King Turn Handlebars Kills Engine
  10. Clean up
  11. 2004 Road King Turn Handlebars Kills Engine
  12. Burnt 2015 freewheeler
  13. Troubleshooting 2003 Ultra Fuel System
  14. X14ied for stage 1?
  15. FP3 Tuner
  16. Dyno jet pre configured maps
  17. Tuning question?
  18. PV2 / ECM issue ?
  19. Convert a carb EVO to EFI?
  20. Stock rotor, twin tec rotor
  21. 2011 fuel pump system removel street glide
  22. California Emissions vapor canister BS
  23. Tuner info
  24. 1991 police special ignition switch
  25. Tuners: Do you check TPS values before tuning MM systems?
  26. Sceaming eagle Protuner Updater issues
  27. 4.5” Street Cannons
  28. Red hot Rear Pipe
  29. I need help!
  30. TTS VTune results, 2011 FLTHCUSE6
  31. Primary coil wire 2018 Road King?
  32. best tuner Softail 2001
  33. Cranking timing for modified engines
  34. Fuel gauge empty, tank has gas, won't start. 2004 FLSTC/I
  35. 107 wont start
  36. A Timing Question
  37. 19 M8 ECM controlled oil cooler fan.
  38. Adjust PC V Map for higher compression
  39. No spark from shovelhead
  40. PC V Map for higher compression
  41. PCIII trade in?
  42. Fp3
  43. Old 8 degree injectors, '06 Ultra
  44. Tuning Day
  45. Spark-knock/pinging under load; backfire/pop while shifting
  46. What is necessary???
  47. Carb to EFI ?
  48. 01 Flhr spitting and sputtering
  49. Error Codes
  50. FP3 and S&S big bore kit on Iron ?
  51. Fp3 afr
  52. False knock
  53. sreain Eagle Race Tuner vs Power Commander
  54. Power Comander 3usb tune needed
  55. Engine temperature sensor: full output voltage ranges
  56. Does the ECM "smooth" timing between table values?
  57. Extract timing map from 2000 MM ECM?
  58. Do engine mechanics impact AFR as measured by O2 sensors?
  59. Can the FP3 overwrite a SEPST Stage 1 Tune?
  60. Engine light came on after 10k miles 2016 883 iron
  61. Which Tuner
  62. Fuel pressure regulator question.
  63. High RPM on cold start and low rpm surge
  64. Clearing codes
  65. Fuel pack FP3 Sensor data
  66. Starter relay or ignition question
  67. FuelPak FP3 VE Tables - Advanced Autotune
  68. O2 codes
  69. Same tune but one cylinder leaner than the other
  70. Train with bad fuel or false sensor
  71. Need some PV guru help
  72. Spark Plugs
  73. 1998 Ultra classic Electra Glide 1340 not charging.
  74. PowerVision Install 101 - 103" Dyna
  75. 2012 Ultra classic poor gas mileage and speedometer troubles
  76. Fuel issues with my new to me Night Train.
  77. thunder max Gen 111 upgrade
  78. twin cam 96 ignition timing with power vision
  79. How to test fuel pressure on a 2000 MM EFI system?
  80. TTS datamaster logging high O2 voltages
  81. 2001 fatboy carbed shutting off
  82. Has anyone just pulled their Fuel Injection?
  83. Hello everyone
  84. Real good M8 tuner in Phoenix area
  85. Throttle Position Sensor output low
  86. RPM data logger graph: Is this as good as it gets?
  87. Power Vision firmware and tune DB update 2019 Harley's
  88. IAC issue
  89. Ignition arced
  90. PV on on another bike
  91. ECM Unplug 2017 FLHR
  92. 2007 FLHX fork lock assy pronlem
  93. FM 110 Kit 10.5 comp 777 LVL B heads --Pinging a bit 2300-2600
  94. fuel injector plug
  95. no slow go
  96. TTS, VTune, Clarity -- advice needed
  97. Recherche carto pour 1200 xlc 2008, merci
  98. HG .030 in a 2012 Heritage
  99. 50mm Throttle body?
  100. Idle Air Control - bike cuts out with closed throttle
  101. Super tuner pro
  102. Fast Idle
  103. Power Vision with Target Tune. Help Needed
  104. S&s 465
  105. Advice
  106. Help!! bike will continuously crank but not start 08 Harley street glide
  107. ECM's on back order?
  108. Dynojet Tuners !!!!!!!!!
  109. How to check if stage 1 tune installed?
  110. HELP, Sportster 48 Died
  111. that suck's, cant find paper filter anymore.
  112. SEPST Question post stage 1
  113. Need for bigger injectors?
  114. Dynojet Tech support
  115. Fuel tank problem
  116. Map Powervision
  117. FP3 rev limiter adjustment?
  118. Target tune
  119. Target Tune installation and cable routing on 2012 Dyna FXDB
  120. Thundermax won't link
  121. Dyno
  122. Engine just died
  123. no fire in one plug
  124. Spark plug split in half
  125. no fire
  126. PFI Pegasus help.
  127. Is a Power Commander V worth trying?
  128. Injector connection
  129. Tuning for early EFI
  130. Power Vision Question
  131. Thundermax help
  132. 06 Road King sputtering
  133. Why don’t Harley’s have direct fuel injection?
  134. 2015 Freewheeler
  135. Post Stage 1 question
  136. A newbie question
  137. Code 2107 EFI processor internal fault?
  138. 02 softail carbureted, engine dies intermittently
  139. 2006 dyna low rider no power when key turned to ignition and accessory position
  140. FP3 install, bike won't fire
  141. 03 lowrider carb
  142. Cold Compression Test Results
  143. Green solenoid wire grounded. 2006 FLHRCI (Road king classic)
  144. smart tuner 18mm O2 sensor clearances
  145. New power vision unsupported ecm fault
  146. Activate Fan Oil Cooler
  147. 2006 street bob will not start no spark
  148. Updated calibrations using Street tuner or race tuner
  149. Need help installing PV2 with Target Tune on 2012 Dyna FXDB
  150. Tune Even Needed?
  151. Identify this air cleaner?
  152. 2017 Ultra Limited ECM
  153. Intake, Exhaust and tuning...
  154. thunder max exaust specific tuner
  155. O2 Sensors Gone Haywire
  156. Which tuner?
  157. Ultra classic charging system
  158. Hesitation off idle at a warm engine/unbalanced AFR between the cylinders
  159. 2014 Road King Tuner, AC, Exhaust Changes
  160. Dyno on 2008 Deluxe after Camshaft replacement?
  161. Autotuning with reversion
  162. U1300 code engine light stays on for about 10 seconds after start up engine seems to be running okay
  163. Where to install O2 sensors?
  164. Arlen Ness big shot tuner over stage 1?
  165. Ignition for A Shovel....
  166. Andrews 48h Cams & Vance and Hines FP3
  167. 2010 ultra stage one o2 voltage over 1 volt?
  168. Street Tuner Pro DIY?
  169. External Fuel Injection
  170. Dyno Chart with 48 cams
  171. Air CLeaner
  172. 1997 RoadKing Fuelie to Carb Question
  173. U0 100 code
  174. Best Dyno Tuner in Milwaukee
  175. Voltage reading wrong
  176. Tuning softail with no O2 sensors with SEPST
  177. PCV/Autotune - tuning tips
  178. What is the output of a 2000 Twin Cam throttle position sensor?
  179. Tuning Help 2016 Roadster
  180. Intake question
  181. Could this be a thundermax issue
  182. Stalling
  183. 2014 Dyna Fat Bob Intermittent power loss
  184. 2013 Street Glide misfire HELP!!!!!
  185. Heritage Softail Classic, Twin Cam 88, 2001
  186. Bad coil problems
  187. Factory ignition map for 2000 TC 88 touring bikes
  188. Compression loss
  189. Bike Makes More Power When Backing Off Throttle
  190. Orange SERT not lighting
  191. Used 2012 Nightster backfiring and Momentary shutoff at idle
  192. Mm efi
  193. Validate tune, eliminate need for dyno tuning
  194. No adaptive emits or knock control on PV 2017 sporty
  195. Should I be using a tuner?
  196. T-M ECM running problems
  197. fp3
  198. 07 flstc Power commander V map
  199. Is there a place here to sell items?
  200. Cv jetting need speed!!
  201. Dynojet thumbs up
  202. bike randomly stops running
  203. 2002 FLHRI Ignition/Fuel issue
  204. No Spark on rear cylinder
  205. Power Vision Speedometer Calibration
  206. Front led turn signal not working
  207. 1991 FXSTC with RevTech sensor timing problem
  208. So who is going to be the first
  209. 2004 FXSTS with Dynajet Power Command 3 USB
  210. ecm can be modified?
  211. Starting issues
  212. Smart tune module problem
  213. O2 sensor swap
  214. Tuner Choice's Help
  215. PC3 not link to computer
  216. Stage 4 with 50 mm throttle body?
  217. FP3: improved fuel mileage during autotune?
  218. mm fuel injection 00 ultra classic.
  219. Codes and Pinging after PV + Exhaust install
  220. dyna over reeving
  221. MAP around 42 kPa on idling? and 100 kPa on 30% throttle.
  222. Looking for 96ci w/ 255 cams timing map.
  223. Fuel delivery, start up failure
  224. Vance and Hines FP3 Tuner
  225. Breath in Burn Breath out
  226. Just died!
  227. 1994 Heritage ignition wireing
  228. 2005 ultra w/95ci long block spits and sputters. HELP
  229. Sportster shut off, won’t restart.
  230. Code errors PO151 and PO572
  231. Relay problem
  232. Intermittent Stall
  233. Why there is VE map if MAP sensor is available
  234. 1978 fxs lowrider shovelhead
  235. 1/4 Tank Fuel, Right Turn, Power Loss
  236. 07 street bob falls on its face and shuts off
  237. My Harley Not Starting up
  238. tuning specifications / details — pro street tuner
  239. Throttle Position Trouble
  240. Fuel management
  241. Need Help 2017 FLTRXS ad power vision road glide. I have a she
  242. Please help!!
  243. 1975 ironhead sportster xlh1000 starting issue
  244. Check Engine Light and ECM Codes
  245. PCV rookie question
  246. Bike shutting off on me
  247. How soon to tune the bike?
  248. Advanced FP3 Settings
  249. FP3 on Closed Loop Systems
  250. Do I need to increase air flow?
